I have an InDesign file that a previous colleague had made for use in creating percent off coupon cards.
I'm wondering if there's a way to easily automate the copy, paste, save process of updating each random number/letter coupon code for each specific card that needs to be saved.
It appears as though they would go to a text file, copy the random string of number/letters, paste it into one line of text in the InDesign file, and then save out to a pdf for printing...which seems horribly inefficient when you have to repeat this process 500 times.
Any help would be more than greatly appreciated!!!
There are two possible quick ways:
and the last solution:
Have fun
Hi pixxxel! Happy New Year To You! (… and to the op!)
Could the op show us a screenshot?
Just trying to batch the code change. I have a word file with the 500 codes that I can manipulate in whatever way I need in order to get the batch to work.
What is masked? The same 2 items on each page or different items per page?
Hi Obi, best wishes for you too.
Ink Monstr​
Data Merge.
Use a tab delimited TEXT instead of your word file and prepare you INDD (see screenshots below)
*.txt
*.indd
Have fun
Awesome! Thanks. I don't think I'll be needing to change anything other than the code itself so what I will most likely do is create a master page with all of the basic text and then create a new page for just the code itself.
Is there a way to use the method you're describing to change the code in separate pages? Or would this change need to be done on one page? The reason I ask is because how I will go about saving them out will depend on if the change can only be done on one page or if I can have it create 500 different pages with unique codes in order to save one large pdf.
Hope that makes sense. Appreciate the help!
If only code to be changed, just create on the master page, on a layer "Code", a "main" text block
and just have a single current page [see your Prefs. to have an "pages" automatic creation!]
Just import your Word file clicking in the current text block and it's done!
Awesome. Any chance you could provide a slightly more detailed step by step for this? I get the gist but am unsure as to where some of those preferences are located and how to import the word file
You can create a merged document with all codes at different pages by pressing the bottom left Button in Data Merge palette.
Create one PDF with all pages and/or split the PDF (with Acrobat Prof) in several pages.
Have fun
pixxxel,
Let's do very simple here!
Simply:
Create a doc.
On Master pages, create text blocks on 2 layers.
Red: Static text (the same on each page, as you said!)
Blue: For "Code" texts
Masking "Red" layer and selecting the 2 text blocks:
Go to the Prefs panel / See: Redistribution intelligente:
Go to the current page (only one page):
On the left side, the "Code" text you will import (.doc, .docx, .txt or excel file):
About the "Code" para style you could use, you could play an auto-numbering:
Import your text:
Done!
In other cases, pixxxel's way could be really better!
I think it, too.
