Hi Photoshop has been running problem free even with updates etc no problem at all. Windows 10 just had a large update and now it won't start at all. Anyone with similar issues or know a fix? Thanks very much for reading. Allan
That file comes from a program called "Web Companion". Best to uninstall the whole thing from Programs and Features. You want it all out, not just the DLL.
Restart your computer afterwards.
IMHO it clearly has something to do with the Windows update. What that is I have no idea. Go to the folder that holds the Photoshop.exe file and right click on it and set it to Run as Admin. See if that helps.
Go to control panel/administrative tools/event viewer/windows logs/application and find the application error.
"copy details as text" and post them here.
Faulting application name: Photoshop.exe, version: 18.0.1.29, time stamp: 0x583e911d
Faulting module name: LavasoftTcpService64.dll, version: 2.3.4.7, time stamp: 0x555dc671
Exception code: 0xc0000095
Fault offset: 0x0000000000008902
Faulting process ID: 0x1414
Faulting application start time: 0x01d274c4ef5a3e95
Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe
Faulting module path: C:\WINDOWS\system32\LavasoftTcpService64.dll
Report ID: 8b98ec33-b397-49b2-9ce2-6303df4d8111
Faulting package full name:
Well it has something to do with the LavaSoft entry. I don't have that on my system but I am using Window 7 Pro
Find the file and rename it
Reboot your system
You should be fine
Sent from my iPhone
Hi jbm007, I have the same problem, which is the file to rename??
Thank You so much for your time and help it is really appreciated. Allan
You're welcome Glad to know you are back in business.
Maybe this might help you find a good AV.
The Best Antivirus Protection of 2017 | PCMag.com
Gene
Hi Guys I eventually solved the problem I have no idea why the Windows 10 update caused the intitial problem but with the Lavasoft clue I looked for what Lavasoft software I had and it was adaware and Web Companion. I tried reinstalling photoshop but no difference but once I removed The Lavasoft software Photoshop CC 2017 is now running. I just need new antivirus software now lol Thanks for your help
