I just downloaded the trial version for Photoshop and opened up Creative Cloud. I try and launch Photoshop and after like 5 seconds, Windows starts searching for a solution and makes me close the program. I did some research and nothing worked. I tried the Ctrl+Shift+Alt thing and it did nothing. I don't get the limited access error. Any help is appreciated.
Ok, try this:
1. Please, start Command Prompt as an administrator by right-clicking it and select Run as administrator.
2. Enter this command to reset the network adapter (end with the Enter key):
netsh winsock reset
3. Restart the computer.
4. Please, delete these two files:
C:\WINDOWS\system32\LavasoftTcpService64.dll
C:\WINDOWS\SysWOW64\LavasoftTcpService.dll (only for 64-bit Windows)
First check Windows Programs and Features list. Is there a program called "Web Companion"? If so, uninstall it.
I uninstalled Web Companion and it still automatically stops working and Windows starts searching for a solution and fails. I read about the lavasoft thing and I'm sure that helped something else but this still isn't working.
Here's a screenshot.
Have you tried restarting your PC now that you removed it?
Still nope. Not sure what it could be.
You would have to check the crash report for the "Faulting Module".
Here's how:
What you want to do is to get into the Windows Event Viewer. On a modern system you can hit Start then type event log into the search box, then when View event logs comes up, click it.
A Photoshop crash will be in the Windows Logs - Application section as an Application Error.
You'll want to copy the textual description, which should include the Faulting module, and paste it here. Usually the Faulting module tells us what part of your system is failing.
Faulting application name: Photoshop.exe, version: 18.0.1.29, time stamp: 0x583e911d
Faulting module name: LavasoftTcpService64.dll, version: 2.3.4.2, time stamp: 0x553aaf1b
Exception code: 0xc0000095
This doesn't seem right because I for sure deleted the Lavasoft Software. Here's a screenshot.
Ok, try this:
netsh winsock reset
It worked! Thanks so much for your help!
Sure. Uninstalling via the Control Panel should have removed the Lavasoft DLLs, but in your case it missed them.
Glad it's over with.
Gene
