Windows 7 + Dreanweaver CC 環境で Compass のエラー
Jan 19, 2017 Jan 19, 2017
Windows 7 + Dreanweaver CC (2017.0.1 9346 ビルド) 環境で Compass を使用する際、.sass で @Import "compass"; を記述するとインポートできずにエラーになります。
@Import "compass/reset"; は OK です。
以下はエラーメッセージ。
Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/(my home)/Documents/Project/test-dw-compass/.sass-cache/75fcaf1b4852ceb732871195e41567cc2a7d8997/C%058/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-core-1.0.3/stylesheets/compass/utilities/general/_hacks.scssc20170120-5944-aqqlcs
Macos Sierra +  Dreanweaver CC 環境では、上記エラーは発生していないので、 Windows 7 環境での問題と考えています。
何か解決策をありますか?
704
Adobe Employee ,
Jan 20, 2017 Jan 20, 2017
Not the exact answer to your question, but I want to make sure that you are following the procedure mentioned in this document.
See, "Using the compass framework" in Using CSS preprocessors in Dreamweaver
Preran
Jan 22, 2017 Jan 22, 2017
I have read "Using CSS preprocessors in Dreamweaver". So, I have tried to make my new test site with the instructions in it. But, just found the same error.
See config.rb, screen.scss, screen.css:
Takeomi
-- config.rb
require 'compass/import-once/activate'
# Require any additional compass plugins here.
# Set this to the root of your project when deployed:
http_path = "/"
css_dir = "stylesheets"
sass_dir = "sass"
images_dir = "images"
javascripts_dir = "javascripts"
# You can select your preferred output style here (can be overridden via the command line):
# output_style = :expanded or :nested or :compact or :compressed
# To enable relative paths to assets via compass helper functions. Uncomment:
# relative_assets = true
# To disable debugging comments that display the original location of your selectors. Uncomment:
# line_comments = false
# If you prefer the indented syntax, you might want to regenerate this
# project again passing --syntax sass, or you can uncomment this:
# preferred_syntax = :sass
# and then run:
# sass-convert -R --from scss --to sass sass scss && rm -rf sass && mv scss sass
-- sass/screen.scss
@import "compass";
body {
  background-color: #fff;
-- stylesheets/creen.css
Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/merita/Documents/Project/test-dw-compass/.sass-cache/75fcaf1b4852ceb732871195e41567cc2a7d8997/C%058/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-core-1.0.3/stylesheets/compass/utilities/general/_hacks.scssc20170123-12964-b3ufpm
Backtrace:
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/2.2.0/tempfile.rb:136:in `initialize'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/2.2.0/tempfile.rb:136:in `open'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/2.2.0/tempfile.rb:136:in `block in initialize'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/2.2.0/tmpdir.rb:129:in `create'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/2.2.0/tempfile.rb:133:in `initialize'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/util.rb:1225:in `new'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/util.rb:1225:in `atomic_create_and_write_file'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/cache_stores/filesystem.rb:39:in `_store'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/cache_stores/base.rb:51:in `store'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/cache_stores/chain.rb:19:in `block in store'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/cache_stores/chain.rb:19:in `each'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/cache_stores/chain.rb:19:in `store'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/engine.rb:414:in `_to_tree'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/engine.rb:309:in `to_tree'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:324:in `block in visit_import'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/stack.rb:88:in `block in with_import'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/stack.rb:115:in `with_frame'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/stack.rb:88:in `with_import'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:323:in `visit_import'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/base.rb:36:in `visit'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:158:in `block in visit'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/stack.rb:79:in `block in with_base'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/stack.rb:79:in `with_base'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:158:in `visit'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:326:in `block (2 levels) in visit_import'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:326:in `map'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:326:in `block in visit_import'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/base.rb:52:in `block in visit_children'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/base.rb:52:in `map'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/base.rb:52:in `visit_children'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:167:in `block in visit_children'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:179:in `with_environment'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:166:in `visit_children'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/base.rb:36:in `block in visit'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:186:in `visit_root'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:157:in `visit'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:8:in `visit'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/root_node.rb:36:in `css_tree'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/root_node.rb:20:in `render'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/engine.rb:278:in `render'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-import-once-1.0.5/lib/compass/import-once/engine.rb:17:in `block in render'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-import-once-1.0.5/lib/compass/import-once/engine.rb:29:in `with_import_scope'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-import-once-1.0.5/lib/compass/import-once/engine.rb:16:in `render'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/plugin/compiler.rb:492:in `update_stylesheet'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/plugin/compiler.rb:215:in `block in update_stylesheets'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/plugin/compiler.rb:209:in `each'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/plugin/compiler.rb:209:in `update_stylesheets'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/sass_compiler.rb:40:in `compile!'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/commands/update_project.rb:49:in `perform'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/commands/base.rb:18:in `execute'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/commands/project_base.rb:19:in `execute'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/exec/sub_command_ui.rb:43:in `perform!'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/exec/sub_command_ui.rb:15:in `run!'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/bin/compass:30:in `block in <top (required)>'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/bin/compass:44:in `call'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/bin/compass:44:in `<top (required)>'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/bin/compass:23:in `load'
C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/bin/compass:23:in `<main>'
body:before {
  white-space: pre;
  font-family: monospace;
  content: "Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/merita/Documents/Project/test-dw-compass/.sass-cache/75fcaf1b4852ceb732871195e41567cc2a7d8997/C%058/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-core-1.0.3/stylesheets/compass/utilities/general/_hacks.scssc20170123-12964-b3ufpm"; }
Please show us the contents of config.rb
Is config.rb located in the root directory of your site?
Is the location of config.rb specified in Site Setup?
Perhaps I should have asked the most important question first, namely do need Compass or can you do without. See here for more info Why I Don't Use Compass Anymore
If you do not need Compass, then the problem is solved.
Edit:
I do use Compass only to create my image sprites and have no problem with it. However, I will be moving away from that soon preferring to use SVG's equivalent. After that, I will have no use for Compass.
Wappler, the only real Dreamweaver alternative.
Here:
-- config.rb
http_path = "/"
sass_dir = "sass"
# and then run:
Yes.
Yes.
> Edit:
Yes, I need Compass for now.
I have read your "info Why I Don't Use Compass Anymore". I partially agree.
I'm using Compss on Windws 7 + Cygwin + cygwin ruby gem + Compass with many Compass mixin. It's not bad. But, my Web team members are not familiar with Cygwin, ruby, gem. So, I'm going to change our development environment from Cygwin + Compass to DW + Compass. I's more simpe for my Web team members.
Takeomi
Change
http_path = "/"
sass_dir = "sass"
to (note the http_path link which goes below the root directory)
http_path = "../"
sass_dir = "sass"
Jan 23, 2017 Jan 23, 2017
I have chaged config.rb. But, nothing has been changed.
Thannks,
Takeomi
--- config.rb
http_path = "../"
sass_dir = "sass"
# and then run:
--- sass/screen.scss
@import "compass";
body {
--- stylesheets/screen.compass - compiled sass/screen.scss
Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/merita/Documents/Project/test-dw-compass/.sass-cache/75fcaf1b4852ceb732871195e41567cc2a7d8997/C%058/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-core-1.0.3/stylesheets/compass/utilities/general/_hacks.scssc20170124-16324-lpmam3
Backtrace:
body:before {
  white-space: pre;
  content: "Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/merita/Documents/Project/test-dw-compass/.sass-cache/75fcaf1b4852ceb732871195e41567cc2a7d8997/C%058/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-core-1.0.3/stylesheets/compass/utilities/general/_hacks.scssc20170124-16324-lpmam3"; }
Jan 24, 2017 Jan 24, 2017
I'm sorry that it still will not work. Please have a look at how I have my setup.
1. Directory structure
2. Site Setup - General
3. Site Setup - Source & Output
4. Site Setup - Compass
That's all and it works like a charm.
If, after comparing the above with your setup, you still cannot get it to work, you may like to try to un-install Dreamweaver, Use the Creative Cloud Cleaner Tool to solve installation problems and re-install Dreamweaver. Hopefully that will fix it. Fingers crossed.
