Adobe character animator internal error code assertion failed!
Jan 14, 2017 Jan 14, 2017
Hello there, I have tried to uninstall and reinstall adobe character animator and it still keeps coming up.
When I open the software it's fine but when I go to anything like "new illustrator puppet" or "new Photoshop puppet" it comes up with this error twice.
Adobe character animator internal error code (1033274218+19) assertion failed!
I'm using a quite new MSI laptop with windows 10, core i7 and 16GB of Ram. This problem does't come up on my tower computer and it's using windows 8.1 with 16GB of RAM.
I have tried disabling the camera on my laptop to see if it would still come up as my tower computer does not have a camera and it still comes up twice.
Any help would be appreciated.
5.5K
Adobe Employee , Jan 23, 2017 Jan 23, 2017
It would be an useful experiment if you're willing to try it.
DT
Adobe Employee ,
Jan 17, 2017 Jan 17, 2017
Are you able to do anything at all or does this always show up? File > Import with a PSD, opening the interactive tutorial from the welcome panel, or open an existing .puppet or .chproj file from the examples? In your Documents folder there should be an Adobe folder with CH stuff in it - if you delete it does that help?
Yeah, if it's opening up okay and then no puppets are loading, it feels like it might be a camera, microphone, or hardware conflict of some sort. Are any other programs running in the background that could possibly conflict? Can you post a screenshot or more detailed specs about your machine?
Jan 19, 2017 Jan 19, 2017
Thanks for the reply,
                                 I have been testing everything and the way it starts seems to be only when I open a new puppet in illustrator, after that; even when I than go out of illustrator and remove all projects/scenes that error keeps coming up even when hitting "File" or "Edit"?
If I restart the program and leave the default puppet up it seems to work fine, should I uninstall illustrator maybe?
P.S It works fine on Photoshop and with both my PC mic and my studio mic.
Adobe Employee ,
Okay so it's only happening with AI files? Strange. I'm assuming you're up to date with the latest 2017 version...
The Puppet Pack I put together has a couple of AI files like Red Monster and Wilk - are you getting the same error when selecting those? I'm trying to figure out if this is just something weird with the blue template character you have or something more.
I have 2017 and I just saw that it has an update, so I updated and shut down my computer and turned it back on. both before and after I did this when I opened that file you give me it came up with that same error from before.
I also tried removing the .AI files from that project you give me and it opened fine with out them.
Adobe Employee ,
Jan 20, 2017 Jan 20, 2017
Asking the team and it looks like this might be a bug - looking into it now. Thanks for reporting!
Adobe Employee ,
I was able to find what I think is the same assert (with full identifier 1033274218:975+19) which corresponds to an error detected when trying to format/save data into the Ch project when the locale of the app has been set to something surprising.
This might suggest a third party library being loaded when Character Animator loads the code it uses to access Adobe Illustrator files. It may also suggest a preference (maybe for number formatting or other locale specific options) causing the locale to be changed.
One thing that might help narrow it down would be to collect a list of the DLLs loaded into the Character Animator process before and after triggering the error. I haven't used it, but this tool seems like it should get the info: ListDLLs
This might be an easier way: https://support.microsoft.com/en-us/help/970920/using-process-explorer-to-list-dlls-running-under-th...  (the instructions should mostly be the same except we'd be looking for Character Animator.exe instead of Outlook.exe)
I have a bit more digging I can do, but hopefully that provides some clues as to what might be happening here.
Dan Tull
Jan 21, 2017 Jan 21, 2017
ProcessCPUPrivate BytesWorking SetPIDDescriptionCompany Name
System Idle Process90.460 K4 K0
System0.47128 K136 K4
Interrupts0.680 K0 Kn/aHardware Interrupts and DPCs
smss.exe376 K1,012 K528
Memory Compression172 K52,028 K3552
csrss.exe< 0.011,592 K4,180 K712
wininit.exe1,060 K4,964 K844
services.exe3,392 K7,468 K920
  svchost.exe< 0.019,696 K24,468 K104Host Process for Windows ServicesMicrosoft Corporation
   unsecapp.exe1,616 K6,588 K3940
   WmiPrvSE.exe3,900 K12,908 K4212
   RuntimeBroker.exe28,284 K59,988 K5900Runtime BrokerMicrosoft Corporation
   ShellExperienceHost.exeSuspended32,544 K72,872 K6244Windows Shell Experience HostMicrosoft Corporation
   SearchUI.exeSuspended81,748 K138,896 K6300Search and Cortana applicationMicrosoft Corporation
   SkypeHost.exeSuspended35,644 K58,120 K7056Microsoft Skype PreviewMicrosoft Corporation
   RemindersServer.exeSuspended10,444 K19,736 K7140Reminders WinRT OOP ServerMicrosoft Corporation
   SettingSyncHost.exe10,416 K10,364 K5604Host Process for Setting SynchronizationMicrosoft Corporation
   unsecapp.exe4,700 K9,788 K9528Sink to receive asynchronous callbacks for WMI client applicationMicrosoft Corporation
   nvspcaps64.exe< 0.0110,448 K29,772 K10076NVIDIA Capture ServerNVIDIA Corporation
    NVIDIA Share.exe21,676 K36,040 K9508NVIDIA ShareNVIDIA Corporation
     NVIDIA Share.exe41,348 K53,940 K6732NVIDIA ShareNVIDIA Corporation
   explorer.exe< 0.0123,548 K56,576 K10852Windows ExplorerMicrosoft Corporation
   dllhost.exe5,304 K12,240 K6932COM SurrogateMicrosoft Corporation
   ApplicationFrameHost.exe23,168 K37,104 K9296Application Frame HostMicrosoft Corporation
   Microsoft.Photos.exeSuspended177,716 K229,972 K12864
   Video.UI.exeSuspended14,412 K26,620 K364Video ApplicationMicrosoft Corporation
   SkypeApp.exeSuspended28,212 K57,412 K9012SkypeAppMicrosoft
   SystemSettings.exeSuspended13,200 K43,740 K14644SettingsMicrosoft Corporation
   Music.UI.exeSuspended16,160 K29,064 K7944Music ApplicationMicrosoft Corporation
   smartscreen.exe8,628 K15,036 K13372SmartScreenMicrosoft Corporation
   dllhost.exe4,852 K9,692 K6588COM SurrogateMicrosoft Corporation
  svchost.exe< 0.016,396 K11,780 K396Host Process for Windows ServicesMicrosoft Corporation
  svchost.exe7,124 K19,988 K620Host Process for Windows ServicesMicrosoft Corporation
   WUDFHost.exe< 0.011,296 K5,660 K1164
   dasHost.exe3,312 K11,596 K2296
   WUDFHost.exe1,976 K8,052 K12908
  svchost.exe14,668 K27,496 K840Host Process for Windows ServicesMicrosoft Corporation
  svchost.exe< 0.0122,584 K54,020 K1176Host Process for Windows ServicesMicrosoft Corporation
   sihost.exe9,272 K25,868 K6600Shell Infrastructure HostMicrosoft Corporation
   taskhostw.exe9,644 K19,736 K6508Host Process for Windows TasksMicrosoft Corporation
   SynTPEnh.exe0.338,508 K7,308 K6500Synaptics TouchPad 64-bit EnhancementsSynaptics Incorporated
   muachost.exe1,976 K1,120 K6820
  WRSA.exe0.0529,592 K9,416 K1248Webroot SecureAnywhereWebroot
   WRSA.exe0.057,836 K576 K6952Webroot SecureAnywhereWebroot
  svchost.exe18,408 K31,120 K1316Host Process for Windows ServicesMicrosoft Corporation
  svchost.exe12,452 K29,260 K1436Host Process for Windows ServicesMicrosoft Corporation
  svchost.exe0.017,228 K17,984 K1532Host Process for Windows ServicesMicrosoft Corporation
  svchost.exe4,120 K11,876 K1760Host Process for Windows ServicesMicrosoft Corporation
  igfxCUIService.exe1,800 K8,704 K1896igfxCUIService ModuleIntel Corporation
  svchost.exe2,440 K9,792 K1976Host Process for Windows ServicesMicrosoft Corporation
   audiodg.exe30,896 K33,020 K6956
  svchost.exe4,012 K13,216 K1340Host Process for Windows ServicesMicrosoft Corporation
  svchost.exe6,136 K17,708 K2092Host Process for Windows ServicesMicrosoft Corporation
   wlanext.exe5,060 K16,464 K2452
    conhost.exe1,152 K4,988 K2468
  AvastSvc.exe< 0.0188,008 K40,772 K2212avast! ServiceAVAST Software
  svchost.exe4,232 K13,000 K2232Host Process for Windows ServicesMicrosoft Corporation
  spoolsv.exe5,668 K14,516 K2600Spooler SubSystem AppMicrosoft Corporation
  svchost.exe0.0217,116 K35,188 K3024Host Process for Windows ServicesMicrosoft Corporation
  OfficeClickToRun.exe37,424 K56,268 K3040Microsoft Office Click-to-Run (SxS)Microsoft Corporation
  ibtsiva.exe796 K3,928 K3048Intel(R) Wireless Bluetooth(R) iBtSiva ServiceIntel Corporation
  EvtEng.exe4,876 K13,412 K2056Intel(R) PROSet/Wireless Event Log ServiceIntel(R) Corporation
  MsiTrueColorService.exe< 0.011,068 K5,492 K3144Msi True Color servicePortrait Displays, Inc.
   MsiTrueColorHelper.exe736 K3,600 K9472
  TuneUpUtilitiesService64.exe0.0413,852 K29,344 K3156AVG PC TuneUp ServiceAVG Technologies
   TuneUpUtilitiesApp64.exe0.016,700 K18,468 K6656AVG PC TuneUpAVG Technologies
  WTSrv.exe1,060 K4,812 K3164
  nvcontainer.exe0.048,704 K22,684 K3192NVIDIA ContainerNVIDIA Corporation
   nvcontainer.exe0.0116,044 K29,392 K6676NVIDIA ContainerNVIDIA Corporation
  MSIService.exe1,672 K8,624 K3208MSI SCM ServiceMicro-Star International Co., Ltd.
  NVDisplay.Container.exe2,520 K9,924 K3216NVIDIA ContainerNVIDIA Corporation
   nvxdsync.exe0.019,380 K24,296 K4900
    nvtray.exe3,300 K12,392 K9016NVIDIA SettingsNVIDIA Corporation
  pnusbvirtualhubwssrv.exe< 0.011,868 K5,504 K3236Virtual USB Hub Main moduleDell Inc.
  NvTelemetryContainer.exe< 0.016,736 K13,436 K3248NVIDIA ContainerNVIDIA Corporation
  nvwirelesscontroller.exe2,352 K8,816 K3260NVIDIA Wireless Controller ServiceNVIDIA Corporation
  svchost.exe2,044 K8,384 K3296Host Process for Windows ServicesMicrosoft Corporation
  RegSrvc.exe1,876 K8,976 K3312Intel(R) PROSet/Wireless Registry ServiceIntel(R) Corporation
  ZeroConfigService.exe4,604 K16,496 K3344Intel® PROSet/Wireless Zero Configure ServiceIntel® Corporation
  svchost.exe< 0.018,876 K21,436 K3512Host Process for Windows ServicesMicrosoft Corporation
  svchost.exe12,376 K41,180 K6580Host Process for Windows ServicesMicrosoft Corporation
  PresentationFontCache.exe27,608 K22,564 K6540PresentationFontCache.exeMicrosoft Corporation
  SearchIndexer.exe< 0.0147,020 K52,984 K7028Microsoft Windows Search IndexerMicrosoft Corporation
  IAStorDataMgrSvc.exe30,004 K51,228 K11248IAStorDataSvcIntel Corporation
  wmpnetwk.exe6,380 K21,664 K10152Windows Media Player Network Sharing ServiceMicrosoft Corporation
  IntelCpHeciSvc.exe1,656 K7,188 K13712IntelCpHeciSvc ExecutableIntel Corporation
  isa.exe9,204 K12,820 K3448Intel(R) Security AssistIntel Corporation
lsass.exe6,724 K16,696 K928Local Security Authority ProcessMicrosoft Corporation
csrss.exe0.562,328 K6,740 K852
winlogon.exe1,996 K9,460 K740
dwm.exe0.7366,764 K98,436 K1028
fontdrvhost.exe812 K2,960 K10244
explorer.exe1.39108,976 K159,444 K7184Windows ExplorerMicrosoft Corporation
RtkNGUI64.exe7,296 K14,620 K6424Realtek HD Audio ManagerRealtek Semiconductor
MsiTrueColor.exe0.055,688 K14,636 K9364MSI True ColorPortrait Displays, Inc.
SCM.exe0.0459,000 K60,268 K9572SCMMSI
OneDrive.exe16,452 K41,708 K9840Microsoft OneDriveMicrosoft Corporation
flux.exe0.0117,344 K18,016 K9952f.luxFlux Software LLC
IDMan.exe18,880 K46,920 K10104Internet Download Manager (IDM)Tonec Inc.
  IDMIntegrator64.exe0.046,172 K13,656 K1292IDM Integration moduleInternet Download Manager, Tonec Inc.
  IEMonitor.exe0.021,628 K8,172 K9332Internet Download Manager agent for click monitoring in IE-based browsersTonec Inc.
SteelSeriesEngine3.exe< 0.0127,548 K40,600 K7240SteelSeries Engine 3 CoreSteelSeries ApS
MEGAsync.exe17,872 K36,692 K856MEGAsyncMega Limited
Rainmeter.exe2.9845,972 K64,372 K7776
  chrome.exe0.10103,476 K154,764 K11584Google ChromeGoogle Inc.
   chrome.exe0.033,268 K12,356 K11664Google ChromeGoogle Inc.
   chrome.exe0.046,452 K15,640 K11740Google ChromeGoogle Inc.
   chrome.exe0.0374,624 K88,636 K11952Google ChromeGoogle Inc.
   chrome.exe147,448 K148,964 K8848Google ChromeGoogle Inc.
   chrome.exe28,576 K36,684 K12388Google ChromeGoogle Inc.
   chrome.exe36,444 K41,656 K12396Google ChromeGoogle Inc.
   chrome.exe0.01423,932 K468,540 K14548Google ChromeGoogle Inc.
   chrome.exe0.05131,016 K147,608 K5620Google ChromeGoogle Inc.
   chrome.exe< 0.0164,536 K77,688 K10908Google ChromeGoogle Inc.
Character Animator.exe0.13242,276 K197,864 K13792Character Animator CC BetaAdobe Systems Incorporated
  dynamiclinkmanager.exe8,988 K17,740 K5964Adobe Dynamic Link Manager 1.0Adobe Systems Incorporated
procexp.exe4,176 K11,084 K1008Sysinternals Process ExplorerSysinternals - www.sysinternals.com
  procexp64.exe1.4938,012 K74,528 K3540Sysinternals Process ExplorerSysinternals - www.sysinternals.com
igfxEM.exe5,860 K14,104 K7772igfxEM ModuleIntel Corporation
igfxHK.exe5,360 K11,472 K7876igfxHK ModuleIntel Corporation
igfxTray.exe5,748 K12,772 K7988
SynTPHelper.exe908 K776 K8888
AvastUI.exe0.0216,424 K25,192 K2852avast! AntivirusAVAST Software
ProductUpdater.exe0.0131,148 K37,744 K8224ProductUpdater
NVIDIA Web Helper.exe0.0335,980 K53,216 K8516NVIDIA Web Helper ServiceNode.js
conhost.exe4,880 K7,992 K5356Console Window HostMicrosoft Corporation
PNUSBCLITRAY.exe1,336 K6,284 K9196Virtual USB Hub Client System TrayDell Inc.
pntray.exe< 0.011,204 K6,352 K9268Quest System TrayDell Inc.
IAStorIcon.exe21,816 K36,408 K11500IAStorIconIntel Corporation
HDDtoGOLaunch.exe3,756 K7,724 K13676
Process: Character Animator.exe Pid: 13792
NameDescriptionCompany NamePath
{AFBF9F1A-8EE8-4C77-AF34-C647E37CA0D9}.1.ver0x0000000000000044.dbC:\Users\Patrick\AppData\Local\Microsoft\Windows\Caches\{AFBF9F1A-8EE8-4C77-AF34-C647E37CA0D9}.1.ver0x0000000000000044.db
ACE.dllAdobe Color EngineAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\ACE.dll
adobe_caps.dllAdobe CAPS DLLAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\adobe_caps.dll
AdobeLinguistic.dllLinguistic LibraryAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AdobeLinguistic.dll
AdobePDFL.dllAdobe PDF LibraryAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AdobePDFL.dll
AdobePIP.dllAdobe Product Improvement ProgramAdobe Systems, IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AdobePIP.dll
AdobePSL.dllAdobePSLAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AdobePSL.dll
AdobeXMP.dllAdobe XMP Core 5.6-c067 ( 64 bit )Adobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AdobeXMP.dll
AdobeXMPFiles.dllAdobe XMP Files 5.6-f146 ( 64 bit )Adobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AdobeXMPFiles.dll
advapi32.dllAdvanced Windows 32 Base APIMicrosoft CorporationC:\Windows\System32\advapi32.dll
AgKernel.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AgKernel.dll
AGM.dllAdobe Graphics ManagerAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AGM.dll
aif_core.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\aif_core.dll
aif_ogl.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\aif_ogl.dll
AILib.dllAdobe Illustrator CCAdobe Systems Inc.C:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AILib.dll
AmioAiff.amioCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Plug-Ins\Amio\AmioAiff.amio
AmioMp3.amioCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Plug-Ins\Amio\AmioMp3.amio
AmioWav.amioCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Plug-Ins\Amio\AmioWav.amio
amtlib.dllAMT LicensingAdobe Systems, IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\amtlib.dll
ARE.dllAdobe Raster ExpressAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\ARE.dll
AuAudioComponents.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AuAudioComponents.dll
AuBackEnd.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AuBackEnd.dll
AuCore.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AuCore.dll
AudioSes.dllAudio SessionMicrosoft CorporationC:\Windows\System32\AudioSes.dll
avicap32.dllAVI Capture window classMicrosoft CorporationC:\Windows\System32\avicap32.dll
avicap32.dll.muiAVI Capture window classMicrosoft CorporationC:\Windows\System32\en-US\avicap32.dll.mui
avifil32.dllMicrosoft AVI File support libraryMicrosoft CorporationC:\Windows\System32\avifil32.dll
avrt.dllMultimedia Realtime RuntimeMicrosoft CorporationC:\Windows\System32\avrt.dll
AXE8SharedExpat.dllAXE Shared EXPAT (UTF-8 native)Adobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AXE8SharedExpat.dll
AXEDOMCore.dllAdobe XML Engine: DOM CoreAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AXEDOMCore.dll
bcrypt.dllWindows Cryptographic Primitives LibraryMicrosoft CorporationC:\Windows\System32\bcrypt.dll
bcryptprimitives.dllWindows Cryptographic Primitives LibraryMicrosoft CorporationC:\Windows\System32\bcryptprimitives.dll
BIB.dllBravo Interface BinderAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\BIB.dll
BIBUtils.dllBravo Interface Binder UtilitiesAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\BIBUtils.dll
boost_date_time.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\boost_date_time.dll
boost_filesystem.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\boost_filesystem.dll
boost_program_options.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\boost_program_options.dll
boost_regex.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\boost_regex.dll
boost_signals.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\boost_signals.dll
boost_system.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\boost_system.dll
boost_threads.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\boost_threads.dll
C_20127.NLSC:\Windows\System32\C_20127.NLS
C_932.NLSC:\Windows\System32\C_932.NLS
C_936.NLSC:\Windows\System32\C_936.NLS
C_949.NLSC:\Windows\System32\C_949.NLS
C_950.NLSC:\Windows\System32\C_950.NLS
cfgmgr32.dllConfiguration Manager DLLMicrosoft CorporationC:\Windows\System32\cfgmgr32.dll
Character Animator.exeCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Character Animator.exe
clbcatq.dllCOM+ Configuration CatalogMicrosoft CorporationC:\Windows\System32\clbcatq.dll
combase.dllMicrosoft COM for WindowsMicrosoft CorporationC:\Windows\System32\combase.dll
comctl32.dllUser Experience Controls LibraryMicrosoft CorporationC:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_5.82.14393.447_none_0d5aa7fbb6d35646\comctl32.dll
comctl32.dllUser Experience Controls LibraryMicrosoft CorporationC:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.14393.447_none_42191651c6827bb3\comctl32.dll
comdlg32.dllCommon Dialogs DLLMicrosoft CorporationC:\Windows\System32\comdlg32.dll
concrt140.dllMicrosoft® Concurrency Runtime LibraryMicrosoft CorporationC:\Windows\System32\concrt140.dll
CoolType.dllCoolType Typography EngineAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\CoolType.dll
counters.datC:\Users\Patrick\AppData\Local\Microsoft\Windows\INetCache\counters.dat
crypt32.dllCrypto API32Microsoft CorporationC:\Windows\System32\crypt32.dll
cryptbase.dllBase cryptographic API DLLMicrosoft CorporationC:\Windows\System32\cryptbase.dll
cryptnet.dllCrypto Network Related APIMicrosoft CorporationC:\Windows\System32\cryptnet.dll
cryptsp.dllCryptographic Service Provider APIMicrosoft CorporationC:\Windows\System32\cryptsp.dll
d2d1.dllMicrosoft D2D LibraryMicrosoft CorporationC:\Windows\System32\d2d1.dll
d3d11.dllDirect3D 11 RuntimeMicrosoft CorporationC:\Windows\System32\d3d11.dll
DataExchange.dllData exchangeMicrosoft CorporationC:\Windows\System32\DataExchange.dll
dbghelp.dllWindows Image HelperMicrosoftC:\Windows\System32\dbghelp.dll
dciman32.dllDCI ManagerMicrosoft CorporationC:\Windows\System32\dciman32.dll
dcomp.dllMicrosoft DirectComposition LibraryMicrosoft CorporationC:\Windows\System32\dcomp.dll
ddraw.dllMicrosoft DirectDrawMicrosoft CorporationC:\Windows\System32\ddraw.dll
devenum.dllDevice enumeration.Microsoft CorporationC:\Windows\System32\devenum.dll
devobj.dllDevice Information Set DLLMicrosoft CorporationC:\Windows\System32\devobj.dll
dnsapi.dllDNS Client API DLLMicrosoft CorporationC:\Windows\System32\dnsapi.dll
dpapi.dllData Protection APIMicrosoft CorporationC:\Windows\System32\dpapi.dll
dsound.dllDirectSoundMicrosoft CorporationC:\Windows\System32\dsound.dll
dsound.dll.muiDirectSoundMicrosoft CorporationC:\Windows\System32\en-US\dsound.dll.mui
dvaaccelerate.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaaccelerate.dll
dvaadameve.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaadameve.dll
dvaaudiodevice.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaaudiodevice.dll
dvaaudiodeviceui.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaaudiodeviceui.dll
dvaaudiodsp.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaaudiodsp.dll
dvaaudiofilterhost.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaaudiofilterhost.dll
dvaaudiofilters.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaaudiofilters.dll
dvacore.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvacore.dll
dvalua.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvalua.dll
dvamarshal.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvamarshal.dll
dvamediatypes.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvamediatypes.dll
dvametadata.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvametadata.dll
dvanet.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvanet.dll
dvaplayer.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaplayer.dll
dvaspeech.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaspeech.dll
dvatemporalxmp.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvatemporalxmp.dll
dvatransport.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvatransport.dll
dvaui.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaui.dll
dvaundo.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaundo.dll
dvaunittesting.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaunittesting.dll
dvaworkspace.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dvaworkspace.dll
dwmapi.dllMicrosoft Desktop Window Manager APIMicrosoft CorporationC:\Windows\System32\dwmapi.dll
DWrite.dllMicrosoft DirectX Typography ServicesMicrosoft CorporationC:\Windows\System32\DWrite.dll
dxgi.dllDirectX Graphics InfrastructureMicrosoft CorporationC:\Windows\System32\dxgi.dll
dynamiclink.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\dynamiclink.dll
exo.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\exo.dll
fastprox.dllWMI Custom MarshallerMicrosoft CorporationC:\Windows\System32\wbem\fastprox.dll
FWPUCLNT.DLLFWP/IPsec User-Mode APIMicrosoft CorporationC:\Windows\System32\FWPUCLNT.DLL
gdi32.dllGDI Client DLLMicrosoft CorporationC:\Windows\System32\gdi32.dll
gdi32full.dllGDI Client DLLMicrosoft CorporationC:\Windows\System32\gdi32full.dll
GdiPlus.dllMicrosoft GDI+Microsoft CorporationC:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.14393.321_none_72fe05dd211a5fae\GdiPlus.dll
git2.dlllibgit2 - the Git linkable libraryC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\git2.dll
glu32.dllOpenGL Utility Library DLLMicrosoft CorporationC:\Windows\System32\glu32.dll
icudt40.dllICU Data DLLIBM Corporation and othersC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\icudt40.dll
icui18n.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\icui18n.dll
icuin40.dllIBM ICU I18N DLLIBM Corporation and othersC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\icuin40.dll
icuuc.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\icuuc.dll
icuuc40.dllIBM ICU Common DLLIBM Corporation and othersC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\icuuc40.dll
iertutil.dllRun time utility for Internet ExplorerMicrosoft CorporationC:\Windows\System32\iertutil.dll
ig9icd64.dllOpenGL(R) Driver for Intel(R) Graphics AcceleratorIntel CorporationC:\Windows\System32\ig9icd64.dll
igc64.dllIntel Graphics Shader Compiler for Intel(R) Graphics AcceleratorIntel CorporationC:\Windows\System32\igc64.dll
imm32.dllMulti-User Windows IMM32 API Client DLLMicrosoft CorporationC:\Windows\System32\imm32.dll
InkObjCore.dllMicrosoft Tablet PC Ink Platform ComponentMicrosoft CorporationC:\Windows\System32\InkObjCore.dll
input.dllInputSetting DLLMicrosoft CorporationC:\Windows\System32\input.dll
IPHLPAPI.DLLIP Helper APIMicrosoft CorporationC:\Windows\System32\IPHLPAPI.DLL
iZotope_Omega_x64.dlliZotope OmegaiZotope, Inc.C:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\iZotope_Omega_x64.dll
iZotope_Radius_x64.dlliZotope RadiusiZotope, Inc.C:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\iZotope_Radius_x64.dll
JP2KLib.dllAdobe JPEG2000 Core LibraryAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\JP2KLib.dll
kernel.appcore.dllAppModel API HostMicrosoft CorporationC:\Windows\System32\kernel.appcore.dll
kernel32.dllWindows NT BASE API Client DLLMicrosoft CorporationC:\Windows\System32\kernel32.dll
KernelBase.dllWindows NT BASE API Client DLLMicrosoft CorporationC:\Windows\System32\KernelBase.dll
ksuser.dllUser CSA LibraryMicrosoft CorporationC:\Windows\System32\ksuser.dll
libmmd.dllMath Library for Intel(r) Compilers (thread-safe)Intel CorporationC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\libmmd.dll
libzip.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\libzip.dll
locale.nlsC:\Windows\System32\locale.nls
LogSession.dllLogSessionAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\LogSession.dll
mdnsNSP.dllBonjour Namespace ProviderApple Inc.C:\Program Files\Bonjour\mdnsNSP.dll
midimap.dllMicrosoft MIDI MapperMicrosoft CorporationC:\Windows\System32\midimap.dll
mkl_core.dllIntel® Math Kernel LibraryIntel CorporationC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\mkl_core.dll
mkl_sequential.dllIntel® Math Kernel LibraryIntel CorporationC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\mkl_sequential.dll
MMDevAPI.dllMMDevice APIMicrosoft CorporationC:\Windows\System32\MMDevAPI.dll
MMDevAPI.dll.muiMMDevice APIMicrosoft CorporationC:\Windows\System32\en-US\MMDevAPI.dll.mui
mpr.dllMultiple Provider Router DLLMicrosoft CorporationC:\Windows\System32\mpr.dll
MPS.dllModular Parsing SystemAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\MPS.dll
msacm32.dllMicrosoft ACM Audio FilterMicrosoft CorporationC:\Windows\System32\msacm32.dll
msacm32.drvMicrosoft Sound MapperMicrosoft CorporationC:\Windows\System32\msacm32.drv
msasn1.dllASN.1 Runtime APIsMicrosoft CorporationC:\Windows\System32\msasn1.dll
msctf.dllMSCTF Server DLLMicrosoft CorporationC:\Windows\System32\msctf.dll
msdmo.dllDMO RuntimeMicrosoft CorporationC:\Windows\System32\msdmo.dll
msi.dllWindows InstallerMicrosoft CorporationC:\Windows\System32\msi.dll
mskeyprotect.dllMicrosoft Key Protection ProviderMicrosoft CorporationC:\Windows\System32\mskeyprotect.dll
msvcp_win.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\msvcp_win.dll
msvcp100.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\msvcp100.dll
msvcp120.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\msvcp120.dll
msvcp140.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\msvcp140.dll
msvcr100.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\msvcr100.dll
msvcr120.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\msvcr120.dll
msvcr90.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\WinSxS\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.9247_none_08e394a1a83e212f\msvcr90.dll
msvcrt.dllWindows NT CRT DLLMicrosoft CorporationC:\Windows\System32\msvcrt.dll
msvfw32.dllMicrosoft Video for Windows DLLMicrosoft CorporationC:\Windows\System32\msvfw32.dll
msvfw32.dll.muiMicrosoft Video for Windows DLLMicrosoft CorporationC:\Windows\System32\en-US\msvfw32.dll.mui
mswsock.dllMicrosoft Windows Sockets 2.0 Service ProviderMicrosoft CorporationC:\Windows\System32\mswsock.dll
msxml3.dllMSXML 3.0Microsoft CorporationC:\Windows\System32\msxml3.dll
msxml3r.dllXML ResourcesMicrosoft CorporationC:\Windows\System32\msxml3r.dll
ncrypt.dllWindows NCrypt RouterMicrosoft CorporationC:\Windows\System32\ncrypt.dll
ncryptsslp.dllMicrosoft SChannel ProviderMicrosoft CorporationC:\Windows\System32\ncryptsslp.dll
netapi32.dllNet Win32 API DLLMicrosoft CorporationC:\Windows\System32\netapi32.dll
netutils.dllNet Win32 API Helpers DLLMicrosoft CorporationC:\Windows\System32\netutils.dll
normnfc.nlsC:\Windows\System32\normnfc.nls
nsi.dllNSI User-mode interface DLLMicrosoft CorporationC:\Windows\System32\nsi.dll
ntasn1.dllMicrosoft ASN.1 APIMicrosoft CorporationC:\Windows\System32\ntasn1.dll
ntdll.dllNT Layer DLLMicrosoft CorporationC:\Windows\System32\ntdll.dll
ntmarta.dllWindows NT MARTA providerMicrosoft CorporationC:\Windows\System32\ntmarta.dll
ole32.dllMicrosoft OLE for WindowsMicrosoft CorporationC:\Windows\System32\ole32.dll
oleaut32.dllOLEAUT32.DLLMicrosoft CorporationC:\Windows\System32\oleaut32.dll
OnDemandConnRouteHelper.dllOn Demand Connctiond Route HelperMicrosoft CorporationC:\Windows\System32\OnDemandConnRouteHelper.dll
opencv_calib3d2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_calib3d2413.dll
opencv_core2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_core2413.dll
opencv_features2d2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_features2d2413.dll
opencv_flann2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_flann2413.dll
opencv_highgui2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_highgui2413.dll
opencv_imgproc2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_imgproc2413.dll
opencv_objdetect2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_objdetect2413.dll
opencv_video2413.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\opencv_video2413.dll
opengl32.dllOpenGL Client DLLMicrosoft CorporationC:\Windows\System32\opengl32.dll
pdfport.dllPDFPort Interface BinderAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\pdfport.dll
powrprof.dllPower Profile Helper DLLMicrosoft CorporationC:\Windows\System32\powrprof.dll
profapi.dllUser Profile Basic APIMicrosoft CorporationC:\Windows\System32\profapi.dll
propsys.dllMicrosoft Property SystemMicrosoft CorporationC:\Windows\System32\propsys.dll
psapi.dllProcess Status HelperMicrosoft CorporationC:\Windows\System32\psapi.dll
PuppetWarp.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\PuppetWarp.dll
quartz.dllDirectShow Runtime.Microsoft CorporationC:\Windows\System32\quartz.dll
R00000000000d.clbC:\Windows\Registration\R00000000000d.clb
rasadhlp.dllRemote Access AutoDial HelperMicrosoft CorporationC:\Windows\System32\rasadhlp.dll
RigDynamics.dllCharacter Animator CC BetaAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\RigDynamics.dll
rpcrt4.dllRemote Procedure Call RuntimeMicrosoft CorporationC:\Windows\System32\rpcrt4.dll
rsaenh.dllMicrosoft Enhanced Cryptographic ProviderMicrosoft CorporationC:\Windows\System32\rsaenh.dll
schannel.dllTLS / SSL Security ProviderMicrosoft CorporationC:\Windows\System32\schannel.dll
sechost.dllHost for SCM/SDDL/LSA Lookup APIsMicrosoft CorporationC:\Windows\System32\sechost.dll
setupapi.dllWindows Setup APIMicrosoft CorporationC:\Windows\System32\setupapi.dll
SHCore.dllSHCOREMicrosoft CorporationC:\Windows\System32\SHCore.dll
shell32.dllWindows Shell Common DllMicrosoft CorporationC:\Windows\System32\shell32.dll
shlwapi.dllShell Light-weight Utility LibraryMicrosoft CorporationC:\Windows\System32\shlwapi.dll
SortDefault.nlsC:\Windows\Globalization\Sorting\SortDefault.nls
SPBasic.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\SPBasic.dll
sspicli.dllSecurity Support Provider InterfaceMicrosoft CorporationC:\Windows\System32\sspicli.dll
StaticCache.datC:\Windows\Fonts\StaticCache.dat
taskschd.dllTask Scheduler COM APIMicrosoft CorporationC:\Windows\System32\taskschd.dll
tbb.dllThreading Building Blocks libraryIntel CorporationC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\tbb.dll
tbbmalloc.dllScalable Allocator libraryIntel CorporationC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\tbbmalloc.dll
twinapi.appcore.dlltwinapi.appcoreMicrosoft CorporationC:\Windows\System32\twinapi.appcore.dll
ucrtbase.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\ucrtbase.dll
updaternotifications.dllAdobe Updater Notifications LibraryAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\updaternotifications.dll
urlmon.dllOLE32 Extensions for Win32Microsoft CorporationC:\Windows\System32\urlmon.dll
user32.dllMulti-User Windows USER API Client DLLMicrosoft CorporationC:\Windows\System32\user32.dll
userenv.dllUserenvMicrosoft CorporationC:\Windows\System32\userenv.dll
uxtheme.dllMicrosoft UxTheme LibraryMicrosoft CorporationC:\Windows\System32\uxtheme.dll
v8.dllC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\v8.dll
vcruntime140.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\System32\vcruntime140.dll
version.dllVersion Checking and File Installation LibrariesMicrosoft CorporationC:\Windows\System32\version.dll
WacomMT.dllWacom Mutli-Touch APIWacom Technology, Corp.C:\Windows\System32\WacomMT.dll
wbemcomn.dllWMIMicrosoft CorporationC:\Windows\System32\wbemcomn.dll
wbemprox.dllWMIMicrosoft CorporationC:\Windows\System32\wbem\wbemprox.dll
wbemsvc.dllWMIMicrosoft CorporationC:\Windows\System32\wbem\wbemsvc.dll
wdmaud.drvWinmm  audio system driverMicrosoft CorporationC:\Windows\System32\wdmaud.drv
wdmaud.drv.muiWinmm  audio system driverMicrosoft CorporationC:\Windows\System32\en-US\wdmaud.drv.mui
webio.dllWeb Transfer Protocols APIMicrosoft CorporationC:\Windows\System32\webio.dll
win32u.dllWin32uMicrosoft CorporationC:\Windows\System32\win32u.dll
windows.storage.dllMicrosoft WinRT Storage APIMicrosoft CorporationC:\Windows\System32\windows.storage.dll
Windows.UI.dllWindows Runtime UI Foundation DLLMicrosoft CorporationC:\Windows\System32\Windows.UI.dll
Windows.UI.Input.Inking.dllWinRT Windows Inking DLLMicrosoft CorporationC:\Windows\System32\Windows.UI.Input.Inking.dll
WindowsCodecs.dllMicrosoft Windows Codecs LibraryMicrosoft CorporationC:\Windows\System32\WindowsCodecs.dll
winhttp.dllWindows HTTP ServicesMicrosoft CorporationC:\Windows\System32\winhttp.dll
wininet.dllInternet Extensions for Win32Microsoft CorporationC:\Windows\System32\wininet.dll
winmm.dllMCI API DLLMicrosoft CorporationC:\Windows\System32\winmm.dll
winmmbase.dllBase Multimedia Extension API DLLMicrosoft CorporationC:\Windows\System32\winmmbase.dll
winnlsres.dllNLSBuild resource DLLMicrosoft CorporationC:\Windows\System32\winnlsres.dll
winnlsres.dll.muiNLSBuild resource DLLMicrosoft CorporationC:\Windows\System32\en-US\winnlsres.dll.mui
winnsi.dllNetwork Store Information RPC interfaceMicrosoft CorporationC:\Windows\System32\winnsi.dll
winspool.drvWindows Spooler DriverMicrosoft CorporationC:\Windows\System32\winspool.drv
wintrust.dllMicrosoft Trust Verification APIsMicrosoft CorporationC:\Windows\System32\wintrust.dll
WinTypes.dllWindows Base Types DLLMicrosoft CorporationC:\Windows\System32\WinTypes.dll
wkscli.dllWorkstation Service Client DLLMicrosoft CorporationC:\Windows\System32\wkscli.dll
WP-SymbolC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\typesupport\cmaps\WP-Symbol
wrservices.dllWRServices EngineWinSoft S.A.C:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\wrservices.dll
ws2_32.dllWindows Socket 2.0 32-Bit DLLMicrosoft CorporationC:\Windows\System32\ws2_32.dll
wship6.dllWinsock2 Helper DLL (TL/IPv6)Microsoft CorporationC:\Windows\System32\wship6.dll
wshqos.dllQoS Winsock2 Helper DLLMicrosoft CorporationC:\Windows\System32\wshqos.dll
WSHTCPIP.DLLWinsock2 Helper DLL (TL/IPv4)Microsoft CorporationC:\Windows\System32\WSHTCPIP.DLL
wsock32.dllWindows Socket 32-Bit DLLMicrosoft CorporationC:\Windows\System32\wsock32.dll
wtsapi32.dllWindows Remote Desktop Session Host Server SDK APIsMicrosoft CorporationC:\Windows\System32\wtsapi32.dll
xerces-c_3_0.dllShared Library for Xerces-C++ Version 3.0.0Apache Software FoundationC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\xerces-c_3_0.dll
xmllite.dllMicrosoft XmlLite LibraryMicrosoft CorporationC:\Windows\System32\xmllite.dll
That's what It give me for all .dlls for Character Animator.exe
Adobe Employee ,
Hmm. I don't see anything surprising in there. Is that before or after you hit the error? One thing I'm wondering is if when Illustrator initializes it might be loading other libraries (plugins) that might explain the difference in behavior you're seeing.
If that's not it, I'm going to have to think a bit on how to get more clues to track down how the locale is getting reset.
DT
that was before, this is after and I'm fairly sure that I don't use any plugins for adobe
System Idle Process93.210 K4 K0
System0.22128 K136 K4
Interrupts0.220 K0 Kn/aHardware Interrupts and DPCs
smss.exe376 K1,016 K528
Memory Compression196 K62,676 K3552
csrss.exe< 0.011,704 K4,220 K712
services.exe3,708 K7,616 K920
  svchost.exe< 0.019,720 K24,540 K104Host Process for Windows ServicesMicrosoft Corporation
   unsecapp.exe1,628 K6,612 K3940
   WmiPrvSE.exe3,928 K13,052 K4212
   RuntimeBroker.exe33,832 K91,952 K5900Runtime BrokerMicrosoft Corporation
   ShellExperienceHost.exeSuspended33,020 K73,904 K6244Windows Shell Experience HostMicrosoft Corporation
   SkypeHost.exe0.0237,196 K65,368 K7056Microsoft Skype PreviewMicrosoft Corporation
   RemindersServer.exeSuspended10,116 K19,796 K7140Reminders WinRT OOP ServerMicrosoft Corporation
   SettingSyncHost.exe19,800 K4,732 K5604Host Process for Setting SynchronizationMicrosoft Corporation
   unsecapp.exe4,940 K10,180 K9528Sink to receive asynchronous callbacks for WMI client applicationMicrosoft Corporation
   nvspcaps64.exe0.0110,956 K30,376 K10076NVIDIA Capture ServerNVIDIA Corporation
    NVIDIA Share.exe< 0.0121,748 K36,456 K9508NVIDIA ShareNVIDIA Corporation
     NVIDIA Share.exe42,244 K54,764 K6732NVIDIA ShareNVIDIA Corporation
   dllhost.exe6,868 K13,108 K6932COM SurrogateMicrosoft Corporation
   ApplicationFrameHost.exe24,780 K38,708 K9296Application Frame HostMicrosoft Corporation
   SkypeApp.exe0.3037,400 K95,152 K9012SkypeAppMicrosoft
   SystemSettings.exeSuspended13,200 K43,736 K14644SettingsMicrosoft Corporation
   InputPersonalization.exe8,908 K26,068 K15236Input Personalization ServerMicrosoft Corporation
   Microsoft.Photos.exeSuspended118,136 K177,180 K1044
   SearchUI.exeSuspended43,328 K96,680 K11652Search and Cortana applicationMicrosoft Corporation
   Video.UI.exeSuspended14,404 K27,032 K3356Video ApplicationMicrosoft Corporation
   smartscreen.exe8,496 K14,860 K10436SmartScreenMicrosoft Corporation
   WmiPrvSE.exe< 0.013,720 K10,684 K10332
  svchost.exe< 0.016,696 K12,016 K396Host Process for Windows ServicesMicrosoft Corporation
  svchost.exe7,292 K20,168 K620Host Process for Windows ServicesMicrosoft Corporation
   dasHost.exe3,316 K11,596 K2296
  svchost.exe< 0.0114,420 K27,304 K840Host Process for Windows ServicesMicrosoft Corporation
  svchost.exe0.0123,208 K55,672 K1176Host Process for Windows ServicesMicrosoft Corporation
   sihost.exe12,080 K33,640 K6600Shell Infrastructure HostMicrosoft Corporation
   taskhostw.exe11,480 K22,776 K6508Host Process for Windows TasksMicrosoft Corporation
   SynTPEnh.exe< 0.019,296 K6,968 K6500Synaptics TouchPad 64-bit EnhancementsSynaptics Incorporated
   muachost.exe1,976 K1,124 K6820
   taskhostw.exe4,848 K14,196 K11272
  WRSA.exe0.1134,328 K8,328 K1248Webroot SecureAnywhereWebroot
   WRSA.exe0.0310,196 K500 K6952Webroot SecureAnywhereWebroot
  svchost.exe23,032 K36,412 K1316Host Process for Windows ServicesMicrosoft Corporation
  svchost.exe12,860 K30,212 K1436Host Process for Windows ServicesMicrosoft Corporation
  svchost.exe< 0.017,360 K18,120 K1532Host Process for Windows ServicesMicrosoft Corporation
  svchost.exe< 0.014,184 K11,964 K1760Host Process for Windows ServicesMicrosoft Corporation
  svchost.exe2,684 K10,120 K1976Host Process for Windows ServicesMicrosoft Corporation
   audiodg.exe7,160 K12,204 K13040
  svchost.exe3,964 K13,240 K1340Host Process for Windows ServicesMicrosoft Corporation
  svchost.exe6,376 K17,856 K2092Host Process for Windows ServicesMicrosoft Corporation
   wlanext.exe5,132 K16,532 K2452
    conhost.exe1,152 K4,984 K2468
  AvastSvc.exe< 0.0186,180 K40,740 K2212avast! ServiceAVAST Software
  svchost.exe< 0.014,244 K13,256 K2232Host Process for Windows ServicesMicrosoft Corporation
  spoolsv.exe< 0.015,948 K14,744 K2600Spooler SubSystem AppMicrosoft Corporation
  svchost.exe< 0.0117,412 K35,992 K3024Host Process for Windows ServicesMicrosoft Corporation
  EvtEng.exe5,072 K13,612 K2056Intel(R) PROSet/Wireless Event Log ServiceIntel(R) Corporation
  TuneUpUtilitiesService64.exe0.0314,012 K29,884 K3156AVG PC TuneUp ServiceAVG Technologies
   TuneUpUtilitiesApp64.exe0.016,960 K20,692 K6656AVG PC TuneUpAVG Technologies
  WTSrv.exe1,084 K4,860 K3164
   nvcontainer.exe0.0116,020 K29,304 K6676NVIDIA ContainerNVIDIA Corporation
  MSIService.exe1,676 K8,664 K3208MSI SCM ServiceMicro-Star International Co., Ltd.
  NVDisplay.Container.exe2,520 K9,932 K3216NVIDIA ContainerNVIDIA Corporation
   nvxdsync.exe< 0.019,768 K24,568 K4900
  pnusbvirtualhubwssrv.exe< 0.011,928 K5,540 K3236Virtual USB Hub Main moduleDell Inc.
  NvTelemetryContainer.exe< 0.016,720 K13,456 K3248NVIDIA ContainerNVIDIA Corporation
  nvwirelesscontroller.exe2,352 K8,836 K3260NVIDIA Wireless Controller ServiceNVIDIA Corporation
  svchost.exe2,308 K8,988 K3296Host Process for Windows ServicesMicrosoft Corporation
  ZeroConfigService.exe4,644 K16,532 K3344Intel® PROSet/Wireless Zero Configure ServiceIntel® Corporation
  svchost.exe7,900 K20,520 K3512Host Process for Windows ServicesMicrosoft Corporation
  svchost.exe13,012 K41,776 K6580Host Process for Windows ServicesMicrosoft Corporation
  SearchIndexer.exe0.0146,424 K53,768 K7028Microsoft Windows Search IndexerMicrosoft Corporation
   SearchProtocolHost.exe2,500 K11,636 K3100
   SearchFilterHost.exe1,256 K6,240 K3604
  IAStorDataMgrSvc.exe30,044 K51,312 K11248IAStorDataSvcIntel Corporation
  wmpnetwk.exe6,556 K2,388 K10152Windows Media Player Network Sharing ServiceMicrosoft Corporation
  IntelCpHeciSvc.exe1,812 K7,376 K13712IntelCpHeciSvc ExecutableIntel Corporation
  isa.exe9,280 K12,868 K3448Intel(R) Security AssistIntel Corporation
lsass.exe< 0.016,980 K16,964 K928Local Security Authority ProcessMicrosoft Corporation
csrss.exe0.282,584 K8,452 K852
winlogon.exe2,020 K9,636 K740
dwm.exe0.77106,964 K132,492 K1028
explorer.exe0.07133,564 K202,072 K7184Windows ExplorerMicrosoft Corporation
RtkNGUI64.exe8,196 K16,076 K6424Realtek HD Audio ManagerRealtek Semiconductor
MsiTrueColor.exe0.066,356 K15,916 K9364MSI True ColorPortrait Displays, Inc.
SCM.exe95,984 K101,180 K9572SCMMSI
OneDrive.exe< 0.0120,136 K45,464 K9840Microsoft OneDriveMicrosoft Corporation
flux.exe0.0117,448 K19,452 K9952f.luxFlux Software LLC
IDMan.exe18,584 K46,804 K10104Internet Download Manager (IDM)Tonec Inc.
  IDMIntegrator64.exe< 0.016,836 K14,620 K1292IDM Integration moduleInternet Download Manager, Tonec Inc.
  IEMonitor.exe1,628 K8,192 K9332Internet Download Manager agent for click monitoring in IE-based browsersTonec Inc.
SteelSeriesEngine3.exe< 0.0128,256 K41,376 K7240SteelSeries Engine 3 CoreSteelSeries ApS
MEGAsync.exe25,020 K44,000 K856MEGAsyncMega Limited
Rainmeter.exe2.7254,980 K79,680 K7776
  chrome.exe0.08191,576 K256,720 K11584Google ChromeGoogle Inc.
   chrome.exe0.013,488 K14,872 K11664Google ChromeGoogle Inc.
   chrome.exe0.026,776 K18,216 K11740Google ChromeGoogle Inc.
   chrome.exe0.0188,660 K104,364 K11952Google ChromeGoogle Inc.
   chrome.exe< 0.01170,872 K174,916 K8848Google ChromeGoogle Inc.
   chrome.exe28,832 K37,036 K12388Google ChromeGoogle Inc.
   chrome.exe< 0.0164,956 K71,280 K12396Google ChromeGoogle Inc.
   chrome.exe< 0.01114,432 K234,096 K12596Google ChromeGoogle Inc.
   chrome.exe< 0.01161,516 K238,712 K13908Google ChromeGoogle Inc.
rundll32.exe1,480 K9,772 K2472Windows host process (Rundll32)Microsoft Corporation
Photoshop.exe0.203,531,608 K1,663,196 K8732Adobe Photoshop CC 2017Adobe Systems, Incorporated
  AdobeIPCBroker.exe2,564 K9,748 K864Adobe IPC BrokerAdobe Systems Incorporated
  Adobe Spaces Helper.exe< 0.0137,392 K58,200 K4120
  Adobe Spaces Helper.exe49,720 K67,520 K5944
  Adobe Spaces Helper.exe43,488 K56,760 K2684
  node.exe44,568 K48,892 K9908Node.js: Server-side JavaScriptNode.js
   conhost.exe8,116 K12,892 K12224Console Window HostMicrosoft Corporation
  CEPHtmlEngine.exe< 0.0122,040 K49,716 K1784Adobe CEP HTML EngineAdobe Systems Incorporated
   CEPHtmlEngine.exe< 0.0128,088 K48,196 K1020Adobe CEP HTML EngineAdobe Systems Incorporated
   CEPHtmlEngine.exe< 0.0153,800 K59,340 K11332Adobe CEP HTML EngineAdobe Systems Incorporated
  CEPHtmlEngine.exe< 0.0111,896 K31,216 K2248Adobe CEP HTML EngineAdobe Systems Incorporated
   CEPHtmlEngine.exe< 0.0123,708 K28,524 K5640Adobe CEP HTML EngineAdobe Systems Incorporated
   CEPHtmlEngine.exe27,120 K35,852 K3976Adobe CEP HTML EngineAdobe Systems Incorporated
  CCLibrary.exe436 K2,636 K8968CCLibrariesAdobe Systems Incorporated
   node.exe< 0.0143,728 K60,912 K3152Node.js: Server-side JavaScriptNode.js
    conhost.exe4,880 K9,492 K10264Console Window HostMicrosoft Corporation
  CEPHtmlEngine.exe< 0.0111,700 K31,032 K9388Adobe CEP HTML EngineAdobe Systems Incorporated
   CEPHtmlEngine.exe< 0.0123,368 K28,324 K14292Adobe CEP HTML EngineAdobe Systems Incorporated
   CEPHtmlEngine.exe32,744 K41,180 K13660Adobe CEP HTML EngineAdobe Systems Incorporated
Character Animator.exe0.40304,400 K274,816 K1220Character Animator CC BetaAdobe Systems Incorporated
  dynamiclinkmanager.exe9,032 K17,788 K8852Adobe Dynamic Link Manager 1.0Adobe Systems Incorporated
procexp.exe4,216 K10,952 K3276Sysinternals Process ExplorerSysinternals - www.sysinternals.com
  procexp64.exe1.0333,508 K69,392 K8276Sysinternals Process ExplorerSysinternals - www.sysinternals.com
igfxEM.exe6,292 K14,712 K7772igfxEM ModuleIntel Corporation
igfxHK.exe5,552 K11,820 K7876igfxHK ModuleIntel Corporation
igfxTray.exe5,704 K13,044 K7988
SynTPHelper.exe908 K748 K8888
AvastUI.exe0.0216,528 K27,744 K2852avast! AntivirusAVAST Software
ProductUpdater.exe0.0131,412 K37,952 K8224ProductUpdater
NVIDIA Web Helper.exe0.0331,760 K47,544 K8516NVIDIA Web Helper ServiceNode.js
conhost.exe4,880 K7,988 K5356Console Window HostMicrosoft Corporation
Process: Character Animator.exe Pid: 1220
{6AF0698E-D558-4F6E-9B3C-3716689AF493}.2.ver0x000000000000001b.dbC:\ProgramData\Microsoft\Windows\Caches\{6AF0698E-D558-4F6E-9B3C-3716689AF493}.2.ver0x000000000000001b.db
{DDF571F2-BE98-426D-8288-1A9A39C3FDA2}.2.ver0x0000000000000001.dbC:\ProgramData\Microsoft\Windows\Caches\{DDF571F2-BE98-426D-8288-1A9A39C3FDA2}.2.ver0x0000000000000001.db
3DLib.aip3D EffectsAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\3DLib.aip
69b8a4a.BUDC:\Windows\System32\spool\V4Dirs\210C7759-3DEA-49B1-BDB4-71735B1C6889\69b8a4a.BUD
AavmRpch.dllavast! AAVM Remote Procedure Call LibraryAVAST SoftwareC:\Program Files (x86)\avast\x64\AavmRpch.dll
AIPort.dllAIPort Interface BinderAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\AIPort.dll
AIRes.dllAdobe Illustrator CCAdobe Systems Inc.C:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\System\AIRes.dll
amsi.dllAnti-Malware Scan InterfaceMicrosoft CorporationC:\Windows\System32\amsi.dll
ArtConverters.aipArt ConvertersAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\ArtConverters.aip
AssetMgmt.aipAssetMgmt PluginAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\AssetMgmt.aip
aswAMSI.dllAvast AMSI COM objectAVAST SoftwareC:\Program Files (x86)\avast\x64\aswAMSI.dll
aswCmnBS.dllCommon functionsAVAST SoftwareC:\Program Files (x86)\avast\x64\aswCmnBS.dll
aswCmnIS.dllAntivirus independent functionsAVAST SoftwareC:\Program Files (x86)\avast\x64\aswCmnIS.dll
aswCmnOS.dllAntivirus HW dependent libraryAVAST SoftwareC:\Program Files (x86)\avast\x64\aswCmnOS.dll
aswProperty.dllavast! Property Storage libraryAVAST SoftwareC:\Program Files (x86)\avast\x64\aswProperty.dll
BeautifulStrokes.aipBeautifulStrokes SuiteAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\BeautifulStrokes.aip
BRSPencilTool.aipBRS Pencil ToolAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\BRSPencilTool.aip
BrushManager.aipBrush ManagerAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\BrushManager.aip
cversions.2.dbC:\ProgramData\Microsoft\Windows\Caches\cversions.2.db
dbgcore.dllWindows Core Debugging HelpersMicrosoftC:\Windows\System32\dbgcore.dll
Deform.aipEnvelope and WarpAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\Deform.aip
DiffusionRasterSuite.aipDiffusion RasterAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\DiffusionRasterSuite.aip
edputil.dllEDP utilMicrosoft CorporationC:\Windows\System32\edputil.dll
ExpandS.aipExpand SuiteAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\ExpandS.aip
FilterPort.dllFilterPort Interface BinderAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\FilterPort.dll
FOConversionSuite.aipFO Conversion SuiteAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\FOConversionSuite.aip
FrameworkS.aipFWServerAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\FrameworkS.aip
FuzzyEffect.aipFuzzy EffectAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\FuzzyEffect.aip
jscript.dllMicrosoft ® JScriptMicrosoft CorporationC:\Windows\System32\jscript.dll
log.dllAvast Logging LibraryAVAST SoftwareC:\Program Files (x86)\avast\x64\log.dll
MPSCommon.aipMPSCommonAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Formats\MPSCommon.aip
mscms.dllMicrosoft Color Matching System DLLMicrosoft CorporationC:\Windows\System32\mscms.dll
MSOXMLMF.DLLMicrosoft Office XML MIME FilterMicrosoft CorporationC:\Program Files\Common Files\microsoft shared\OFFICE15\MSOXMLMF.DLL
msvcp140.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\WinSxS\amd64_avast.vc140.crt_fcc99ee6193ebbca_14.0.24210.0_none_56aba0211ca246c2\msvcp140.dll
msxml6.dllMSXML 6.0Microsoft CorporationC:\Windows\System32\msxml6.dll
msxml6r.dllXML ResourcesMicrosoft CorporationC:\Windows\System32\msxml6r.dll
MXDWDRV.DLLMicrosoft XPS Document WriterMicrosoft CorporationC:\Windows\System32\DriverStore\FileRepository\ntprint.inf_amd64_7b3eed059f4c3e41\Amd64\MXDWDRV.DLL
OpcServices.dllNative Code OPC Services LibraryMicrosoft CorporationC:\Windows\System32\OpcServices.dll
Pathfinder.aipPathfinderAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\Pathfinder.aip
PathfinderS.aipPathfinder SuiteAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\PathfinderS.aip
PathSuite.aipPath Construction SuiteAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\PathSuite.aip
PDFFormat.aipPDF FormatAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\PDFFormat.aip
PDFSuite.aipPDF SuiteAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\PDFSuite.aip
PhotoshopAdapter.aipPhotoshop Plug-in AdapterAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\PhotoshopAdapter.aip
PrintConfig.dllPrintConfig User InterfaceMicrosoft CorporationC:\Windows\System32\DriverStore\FileRepository\prnms003.inf_amd64_be4393c143e46548\Amd64\PrintConfig.dll
prntvpt.dllPrint Ticket Services ModuleMicrosoft CorporationC:\Windows\System32\prntvpt.dll
prntvpt.dll.muiPrint Ticket Services ModuleMicrosoft CorporationC:\Windows\System32\en-US\prntvpt.dll.mui
PSImport.aipPhotoshop File Import FilterAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Formats\PSImport.aip
Rasterize.aipRasterizeAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Required\Plug-ins\Rasterize.aip
stdole2.tlbSTDOLE2.TLBMicrosoft CorporationC:\Windows\System32\stdole2.tlb
SVGExport.dllSVGExport 6.0Adobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\SVGExport.dll
svgFileFormat.aipSVG File FormatAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\svgFileFormat.aip
SVGFilterEffect.aipSVG Filter EffectAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\SVGFilterEffect.aip
SVGRE.dllSVGRE 6.0Adobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\SVGRE.dll
sxs.dllFusion 2.5Microsoft CorporationC:\Windows\System32\sxs.dll
Transform.aipTransform EachAdobe Systems IncorporatedC:\Program Files\Adobe\Adobe Character Animator CC (Beta)\Support Files\Illustrator\Additional\Plug-ins\Illustrator Filters\Transform.aip
vcruntime140.dllMicrosoft® C Runtime LibraryMicrosoft CorporationC:\Windows\WinSxS\amd64_avast.vc140.crt_fcc99ee6193ebbca_14.0.24210.0_none_56aba0211ca246c2\vcruntime140.dll
xpsservices.dllXps Object Model in memory creation and deserializationMicrosoft CorporationC:\Windows\System32\xpsservices.dll
Adobe Employee ,
Ok, I had a chance to peruse these and compare with my own DLL lists. There are a few differences, but the most noteworthy  difference in what your machine loaded in the after list versus mine was a bunch of DLLs for Avast Anti-virus, including a DLL that appears to be from Avast but has the name vcruntime140.dll (the main C runtime DLL from Microsoft), which seems weird (though anti-virus programs often are, partially by necessity, rather invasive).
I'll need to look around a bit, but at the moment that's my prime suspect.
DT
Adobe Employee ,
I installed the free version of Avast in my VM and I'm still not seeing those extra DLLs being injected into Character Animator as your DLL lists show. I'm not sure if those are due to an option I don't have enabled or some other difference.
DT
That's odd? should i try and uninstall Avast just to see if it works? I'm only using the the free one aswell
Adobe Employee ,
DT
Your not going to believe this dude but it worked! I restarted my computer after I uninstalled it I it works fine now with illustrator.
Adobe Employee ,
Wow. I mean Avast was my number one suspect, but I'm still slightly surprised that smoking gun really turned out to be the murder weapon (so to speak). I did still add some bullet-proofing on our side to make us more resilient to this situation, but I'm really glad that it fixed your situation.
DT
