setActiveSources not updating in side panel
Engaged ,
Jan 21, 2017 Jan 21, 2017
catalog:setActiveSources() when called from a plugin changes the source but doesn't update the selection correctly in the list in the left hand panel. For example, I have a collection, say, "Clients" selected. I use setActiveSources() to change to, say, "Portraits". Although the source has changed and the change is reflected in the Image Display Area, the Filmsrip and the toolbar, "Clients" collection remains highlighted in the collections panel.
Any idea why and how to update highlighting to the correct source?
thanks.
SDK
629
Jan 22, 2017 Jan 22, 2017
This was an outstanding bug in the user interface for many years. It could happen when clicking in the source column of Library, and it could happen when a plugin invoked catalog:setActiveSources().   After a couple of attempts, Adobe seems to have fixed it for most people in 2015.8 / 6.8: Lightroom : Selected Published Folder or Collection is not deselected if a folder is selected | Phot...
Verify you have 2015.8 / 6.8 by doing Help > System Info (the LR updater often fools people into thinking they have the "latest").
Engaged ,
Lightroom version: CC 2015.8 [ 1099473 ] Is what I see. nothing about 6.8. I'm a subscriber so I'm using the Creative Cloud updater and this has nothing to update. OS X 10.12.2
So you have the "latest" version.   Looks like the bug wasn't completely fixed.  (It no longers happen for me, either when using LR directly or via my Any Source plugin.)   I suggest posting details to the bug report above (version number, steps to make the bug happen, Windows or Mac, etc.).
In this case, however, unless you can provide exact steps for reproducing the bug that Adobe can replicate, I think it is unlikely they will take any action (based on past experience).  It was only when I was able to provide them with a catalog and exact steps did they address the problem.
Engaged ,
Jan 23, 2017 Jan 23, 2017
the call is nested in pcalls, asynctasks and callwithcontexts, which might have something to do with it. I'll spend an hour or so on it, see if I can't narrow it down a bit further or figure a work around. I'll post if I do.
thanks for you time, John.
For what it might be worth, here is the function my Any Source plugin uses to set the active sources, view filters, and selection. It works around a number of issues, some of which may have been specific to older versions of LR.  You can ignore the lock() and unlock() -- they are there to provide mutual exclusion with another task that accesses global state (it's a myth that LR tasks are non-preemptive -- many SDK API calls can yield to other tasks).
private state
setState (state)
Sets the active sources, filter, and selection to be "state" (see the
description of "queue" above), returning "state".  We have to iterate
changing these, because they don't always "take" the first time around (a
general problem with many functions in the SDK).
function setState (state)
    lock ()
    local function setValues (label, set, compare)
        local newState
        local n, MaxIterations = 1, 100
        while n <= MaxIterations do
            set (state)
            newState = getState ()
            if compare (state, newState) then break end
            LrTasks.sleep (0)
            n = n + 1
            end
        if n > MaxIterations then
            Debug.lognpp ("setState failed", state, newState)
            end
        end
    setValues ("sources",
        function (s) catalog:setActiveSources (s.sources) end,
        function (s1, s2)
            return deepEqual (s1.sources, s2.sources) end)
    setValues ("filter",
        function (s) catalog:setViewFilter (s.filter) end,
        function (s1, s2) return deepEqual (s1.filter, s2.filter) end)
    if state.selectedPhoto ~= nil then
        setValues ("selectedPhotos",
            function (s)
                catalog:setSelectedPhotos (s.selectedPhoto, s.selectedPhotos)
                end,
            function (s1, s2)
                return s1.selectedPhoto == s2.selectedPhoto and
                    deepEqual (s1.selectedPhotos, s2.selectedPhotos)
                end)
        end
            --[[ Bug in LR 4 and 5 SDK -- can't clear the current
            selection.  catalog:setSelectedPhotos (nil, {}) results in
            "assertion failed!". ]]
    unlock ()
    return state
    end
Two other things to try:
1. When setting the current sources, first set it to All Photographs, do LrTasks.sleep (0) (a magic form of yield that sometimes fixed my issues by seemingly giving the rest of LR a chance to run), then set it to the desired state. The bug referenced above seemed to occur when switch the selection from a collection to a folder or vice versa.
2. Make sure that if you're invoking catalog:setActiveSources() as the result of a callback from an LrView control, you wrap the call in an async task.  Here's another code fragment from my plugin describing why:
void
selectionChanged (SearchableItems si, array of source sources)
Invoked whenever the user types into the edit field of the SearchableItems.
Changes the active sources to the ones currently matching the user input.
function selectionChanged (si, sources)
    if sources and #sources > 0 then
        LrTasks.startAsyncTask (showErrors (function ()
            LrTasks.pcall (function () catalog:setActiveSources (sources) end)
            end))
            --[[ Without an async task, we get the error message "Yielding is
            not allowed within a C or metamethod call" when setting a
            collection as the source, but not a folder.  The pcall()
            protects against "assertion failed" that can result from
            "sources" containing invalid poison folders from inconsistent
            catalogs created by buggy LR, probably in migration from
            Windows to Mac.]]
        end
    end
Engaged ,
Thanks again, John. I'll post back in a couple of days when I've had a chance to check these out. Much appreciated.
Engaged ,
Jan 25, 2017 Jan 25, 2017
It seems to be working now; good and bad in more or less equal parts because not a great deal has changed, meaning it hasn't really gone away.
That said, I think it may have to do with unfound images in collections I'm switching to and from. I have a whole older chunk of the catalogue that sits on another disk and I found that when I started testing using collections without any of the older images in it all started to behave. So I attached the drive and it all started working again. And it continued to work even after I removed the drive. Maybe it was some kind of caching issue, or not.
When it was failing it seemed to be exclusively related to the library and develop modules. If I switched to Map or Print the active source became shown correctly selected in the panel but reverted to incorrectly selected when I switched back to either dev or library.
That's all I have for now, I'm afraid. More if it happens.
