If I try to apply an adjustment to a group of layers without affecting layers underneath, how do I do that?
It used to be that if I group the layers and isolate the adjustment layer above the group by alt-clicking it, that would affect only the group.
Now it seems that doesn't work and it still affects all layers below the group as well.
And I thought that an adjustment layer inside a group would only affect layers inside the group, but now that also affects layers outside and below the group.
I'm sure it didn't used to work like this.
How do I isolate a group without affecting layers underneath?
dv8kiwi
Glad it is working now. So are you posting from NZ? I'm in Rapaura near Blenheim.
I can still do that. Either by Alt clicking the junction between the Adjustment Layer and Group to clip them together, or by using the icon at the bottom of the properties panel. If it were not for you specifically mentioning 'Alt' clicking, I'd ask what OS you are using. Is it an old version of Windows perhaps?
I just tried it and it is working. The bottom layer of the group is not fully covering the layer below it, is it?
Test -
Yes that is exactly what I'm doing and it is not working. And it always used to work. I'm using the current build of Windows 10, fully up to date.
Thanks for all your help! I don't know what was going on but a complete restart seems to have fixed it
dv8kiwi
Sweet. Gidday mate. Chur
