Find And Change Case Sensetive?
Jan 23, 2017 Jan 23, 2017
Example: Find: Ahmet Change: Mehmet Find: AHMET Change: MEHMET Find: AHmEt Change: MEhMt But the script should detect it. 🙂
Scripting
2.5K
Guide ,
Case sensitive available only in Text search, unfortunately GREP search not allowing this
    app.findChangeTextOptions.caseSensitive = true;
Advisor ,
Jan 24, 2017 Jan 24, 2017
To ignore case when using find grep you can specify the (?i) flag. Unfortunately, the change will not respect the original case. Eg:
find: (?i)ahmet
will match Ahmet, ahmet, AhMeT etc.
but
find: (?i)ahmet
change: mehmet
will change everything to lowercase.
thanks but I did not exactly say what I meant.
But not working
Advisor ,
That is what i said. There is no way to get what you want.
You can find all instances of ahmet, regardless of it's case, but you can only replace them with "mehmet" lower case (or however you typed it in the "Change to" field.
Consider this example:
the before text in indesign is:
AhMet ahmet aHMet
you are searching for "ahmet" case insensitive. "Ahmet" has 5 characters, and it will be found in the source text 3 times.
you try to replace "ahmet" with "Mahmud", which has 6 characters. Which of the letters form each match should be capitalised?
