When editing PDF file (ex. add, delete, rotate & etc.), it will not allow me to save using the same file name but will allow me if I save it in another file name. This is time consuming since I have to create a new file & delete the the old file.
Hi Ericsr2698,
Could you please share the exact steps you do to save a PDF after making changes.
Is this an issue with a particular PDF? If yes, please check the document properties of the file. Check if changing is allowed or not.
What is the dot version of Adobe Acrobat installed on your system?
Are you on Mac or Windows? What is the OS version you are using on your system?
Meenakshi
Hi Ericsr2698,
Are you still experiencing issue with the save option?
If yes, please check if the preview pane on Windows explorer is closed or not.
It might be the reason for this.
Let us know if you need any help.
Meenakshi
See here for instructions about how to turn the Explorer preview pane off: http://khkonsulting.com/2014/01/who-is-hogging-my-file/
