Importing new background
May 05, 2008 May 05, 2008
I want to use either a Powerpoint image or a jpg image as a "Frame" around an existing Captivate movie. I want to place the movie inside this frame. So, basically, I want to have this frame serve as a background image. Is anything like this possible?
Import export
762
Hi LabOwner,
This certainly is possible! Add the image that you want to the slide (insert > image) and then once you have it the size and position you want, right click on the image and select 'Merge into background".
Kind Regards,
Matt
Hi Joel
As Matt indicated, merging is one approach. Before using this approach, however, you should consider some things.
1. Ensure the image is large enough so that the Captivate fits cleanly inside. Then resize Captivate to accommodate the image and center the existing part of the project.
2. If using this approach, you would need to merge each and every slide.
Another approach would be to simply insert the image on slide 1 and configure it to display for the rest of the project. Of course, you would also want to make the inside part transparent so the main part of your Captivate could "shine through" and be visible.
Cheers... Rick
Guest
Aug 13, 2008 Aug 13, 2008
Hi Captiv8r,
What do you mean by making inside part of image transparent so Captivate can shine through? I think you may have answer I need on current background question...
Richard
Hi Richard
In Captivate, when you insert an image, you are able to choose a color that is rendered as transparent.
Try this.
I just uploaded a simple image to one of my web sites. The link is below:
Click here to see the image
Insert that image into a Captivate slide. Note that the image has a yellow oval in the center. When you insert the image, Captivate allows you to make the yellow transparent by clicking the "Transparent background" check box, then clicking the eyedropper and clicking the yellow to set it as being transparent. Click the OK button and you should see what I'm referring to.
Hopefully this helps... Rick
Guest
Thanks, Rick! Appreciate the quick response. This will help with some other issues I'm tackling in Captivate 3.
Help resources
