I would like to move the layers up and down in the timeline panel and set their starting point, maybe set some keyframes. I would like to do this without manually open after effects and set their order myself.
Can this be scripted using some programming language? And more generally, what are the things you can edit in After Effects project, without manually editing the project itself?
Thanks, Pat
Standard .aeps are not human-readable. You can save the project as XML (.aepx), and then some features are editable in a text editor.
Nothing. Open that project file up and get crackin'!
Thanks for stopping by Dave. Oh, thats unfortunate! I've been researching the subject further, and it seems that ExtendScript offers functionality of reordering layers, maybe even setting their staring point. Although I haven't found a way to do that without actually opening after effects and clicking running script manually.
There is no such thing as just running a script. Scripts are just reflections and instanciated internal functions and commands. Without running AE even the smartest script doesn't know what to do when executing a command. that and of course AE projects are just binary data blobs that can't be read without the actual parsing routines of the main program. So no, what you want is impossible. At some point AE has to be involved.
Mylenium
Well, I was WRONG about not being able to alter a project file without opening it. You can change the name of the project file, and you can't do so if it's open.
Here's a bit of the 'code' in an AEP file, do you see anything in there that looks like code you can edit?
cdat(?tdum tduM @Ytdmn(ADBE Envir Appear in ReflectLISTŒtdbstdsb tdsn tdb4|€ô ˇˇ ]®? 6‚Î C-???? cdat(?tdmn(ADBE Group Endtdmn(ADBE Camera Options GroupLISTJtdgptdsb tdsn tdmn(ADBE Group Endtdmn(ADBE Group EndLIST\Gidegdta LIST@listlhd34– Ó LIST Ewstfvdv fiop ftts foac fiac fipc fifl fvdv fiop ftts foac fiac fipc fifl LIST ‚CLayldta† X]® S]®D Custom View 3 Utf8 Custom View 3LIST ¥tdgptdsb tdsn tdmn(ADBE Transform GroupLIST ∞tdgptdsb tdsn tdmn(ADBE Anchor PointLISTÓtdbstdsb tdsn tdb4|€ô ˇˇˇˇ]®? 6‚Î C-???? cdatH@Ñ@vÄtdmn(ADBE PositionLISTÓtdbstdsb tdsn tdb4|€ô ˇˇˇˇ]®? 6‚Î C-???? cdatH@¢„é8·Û–¿ñ' q√Á°¿õ« q√Á°tdmn(ADBE Position_0LISTÓtdbstdsb tdsn tdb4|€ô ˇˇ]®? 6‚Î C-???? cdat(tdum tduM tdmn(ADBE Position_1LISTÓtdbstdsb tdsn tdb4|€ô ˇˇ]®? 6‚Î C-???? cdat(tdum tduM tdmn(ADBE Position_2LISTÓtdbstdsb tdsn tdb4|€ô ˇˇ]®? 6‚Î C-???? cdat(tdum tduM tdmn(ADBE ScaleLIST >tdbstdsb tdsn tdb4|€ô ˇˇ]®? 6‚Î C-???? cdatx???tdum tduM tdmn(ADBE Rotate ZLISTŒtdbstdsb tdsn tdb4|€ô ˇˇ]®? 6‚Î C-???? cdat(tdmn(ADBE OpacityLISTÓtdbstdsb tdsn tdb4|€ô ˇˇ]®? 6‚Î C-???? cdat(?tdum tduM @Ytdmn(ADBE Envir Appear in ReflectLISTŒtdbstdsb tdsn tdb4|€ô ˇˇ ]®? 6‚Î C-???? cdat(?tdmn(ADBE Group Endtdmn(ADBE Camera Options GroupLISTJtdgptdsb tdsn tdmn(ADBE Group Endtdmn(ADBE Group EndLIST\Gidegdta LIST@listlhd34– Ó LIST Ewstfvdv fiop ftts foac fiac fipc fifl fvdv fiop ftts foac fiac fipc fifl LIST êSecLldta† X]® S]®á Markers Utf8 MarkersLIST htdgptdsb tdsn tdmn(ADBE Transform GroupLIST ÷tdgptdsb tdsn tdmn(ADBE Position_0LISTÓtdbstdsb tdsn tdb4|€ô ˇˇ]®? 6‚Î C-???? cdat(tdum tduM tdmn(ADBE Position_1LISTÓtdbstdsb tdsn tdb4|€ô ˇˇ]®? 6‚Î C-???? cdat(tdum tduM tdmn(ADBE OrientationLISTˆotstLISTætdbstdsb tdsn tdb4|€ô ]®? 6‚Î C-???? cdat LIST$otkyotda tdmn(ADBE Rotate XLISTŒtdbstdsb tdsn tdb4|€ô ˇˇ]®? 6‚Î C-???? cdat(tdmn(ADBE Rotate YLISTŒtdbstdsb tdsn tdb4|€ô ˇˇ]®? 6‚Î C-???? cdat(tdmn(ADBE Envir Appear in ReflectLISTŒtdbstdsb tdsn tdb4|€ô ˇˇ ]®? 6‚Î C-???? cdat(?tdmn(ADBE Group Endtdmn(ADBE Layer StylesLIST btdgptdsb tdsn tdmn(ADBE Blend Options GroupLISTÃtdgptdsb tdsn tdmn(ADBE Adv Blend GroupLISTJtdgptdsb tdsn tdmn(ADBE Group Endtdmn(ADBE Group Endtdmn(dropShadow/enabledLISTJtdgptdsb tdsn tdmn(ADBE Group Endtdmn(innerShadow/enabledLISTJtdgptdsb tdsn tdmn(ADBE Group Endtdmn(outerGlow/enabledLISTJtdgptdsb tdsn tdmn(ADBE Group Endtdmn(innerGlow/enabledLISTJtdgptdsb tdsn tdmn(ADBE Group Endtdmn(bevelEmboss/enabledLISTJtdgptdsb tdsn tdmn(ADBE Group Endtdmn(chromeFX/enabledLISTJtdgptdsb tdsn tdmn(ADBE Group Endtdmn(solidFill/enabledLISTJtdgptdsb tdsn tdmn(ADBE Group Endtdmn(gradientFill/enabledLISTJtdgptdsb tdsn tdmn(ADBE Group Endtdmn(patternFill/enabledLISTJtdgptdsb tdsn tdmn(ADBE Group Endtdmn(frameFX/enabledLISTJtdgptdsb tdsn tdmn(ADBE Group Endtdmn(ADBE Group Endtdmn(ADBE Extrsn Options GroupLIST Ptdgptdsb tdsn tdmn(ADBE Bevel DirectionLISTŒtdbstdsb tdsn tdb4|€ô ]®? 6‚Î C-???? cdat(?tdmn(ADBE Group Endtdmn(ADBE Material Options GroupLIST 4tdgptdsb tdsn tdmn(ADBE Appears in ReflectionsLISTŒtdbstdsb tdsn tdb4|€ô ˇˇ ]®? 6‚Î C-???? cdat(?tdmn(ADBE Reflection CoefficientLISTÓtdbstdsb tdsn tdb4|€ô ˇˇ]®? 6‚Î C-???? cdat(tdum tduM @Ytdmn(ADBE Glossiness CoefficientLISTÓtdbstdsb tdsn tdb4|€ô ˇˇ]®? 6‚Î C-???? cdat(@Ytdum tduM @Ytdmn(ADBE Fresnel CoefficientLISTÓtdbstdsb tdsn tdb4|€ô ˇˇ]®? 6‚Î C-???? cdat(tdum tduM @Ytdmn(ADBE Transparency CoefficientLISTÓtdbstdsb tdsn tdb4|€ô ˇˇ]®? 6‚Î C-???? cdat(tdum tduM @Ytdmn(ADBE Transp RolloffLISTÓtdbstdsb tdsn tdb4|€ô ˇˇ]®? 6‚Î C-???? cdat(tdum tduM @Ytdmn(A
Not really. I will try changing some values and then compare the project to its previous state. Maybe something useful pops out. Btw, which app did you use to open the project as text?
Basic text editor....
Change anything and you'll get a can't open errors in the AEP.
There is nothing in there that can be directly edited.
Thanks. It appears they use a checksum.
