Hi guys,
Just finished creating name title animation in AE2017, saved, closed, opened up Premiere, imported wanted compositions and found out, that all animations are gone... opening AE again figuring out that all my keyframes are gone. Well... not all of them... all position keyframes I guess.
I tried to open autosave, that has been created like 30 minutes before I finished my work, but no keyframes at all!!!
I spent 8 hours doing it! Can anyone tell me, what is going on? Thank you!
Also all masks have gone...
You've landed in the non-tech supported Lounge.
I think you probably want the After Effects forum, yes?
Moved to After Effects.
I have never heard of that happening. The only possible thing I can think of is an unfortunate series of errant keystrokes or a poorly written (or inadvertently run) script.
Hi PeterLezo,
Sorry for this incredibly frustrating event. As Szalam has said, this sounds odd. Were you ever able to track down and solve this issue, or did you just redo the proejct? Do you still need assistance?
Kevin
Hi Kevin,
I haven't find solution, so I re-did all the project. Well... that part that disappeared...
Hi Peter Lezo,
Too bad you didn't get the mystery solved, but you got your project done. Hopefully, nothing similar has happened since then...
Kevin
