I'm working on a document with superscript endnote numbers within the text. I copied over the text from a word document, in the word document the endnote numbers ascend to the end of the chapter and then reset at the beginning of the next, however when I copied them over InDesign renumbered them so they now ascend continuously through the book. Annoyingly I didn't realise and set the book and the author now wants them back as they were.
They're all set to a character style and I've been speculating on the quickest way of changing them (through GREP or other means). I thought the community might have some bright ideas?
Thanks in advance!
use the below script.. select every chapter and run the script.. it will reset to 1 to
app.findGrepPreferences = null; app.changeGrepPreferences = null;
app.findGrepPreferences.findWhat = "\\d+";
app.findGrepPreferences.appliedCharacterStyle = "Endnote reference"; //change the character style name here
app.findGrepPreferences.position = Position.SUPERSCRIPT;
list = app.selection[0].findGrep(true);
changes = 1;
n=list.length;
for (i=0; i<list.length; i++)
app.changeGrepPreferences.changeTo = String(changes);
list[--n].changeGrep();
changes++;
alert ("Number of changes: "+i);
HTH
K
Thanks! I'll give it a try later.
Whoah!
Using a script is way over the top. This route is much simpler as you can turn the option on or off as your client changes his/her mind.
Go to the page that starts each chapter. And choose Numbering and Section options from the Pages panel menu. Simply click to make that a new section.
With all the chapters starting a section, then choose Type > Document Footnote Options and set the "Restart Every Section" option.
Ah wow, I did think there was probably an easier way. The other solution worked but I'll change it to the more functional approach. Thanks!
Just a little note. I should have shown the screen shot to Restart Every "Section" not Page.
Haha yeah that's alright, I realised, I already have the sections, I just had no knowledge of the numbering and formatting section!
I realised that annoyingly neither method works, the superscript for the typeface I've used isn't built in to the typeface, it's just a set of glyphs so they can't just be changed numerically, I'll have to type them manually. Unless there's a way I can tell indesign to find a number and replace it with a specific glyph and at the same time get it to renumber the entire section for me.
