Hi all. I am trying to add a relink "automatically" missing artwork multiple filetypes (eps, ai, psd, pdf just to name a few). I know the Original Folder and the New Folder. I'm Cleaning up our Art folder and trying to put the almost never used artwork in its own Folder. its a simple Folder One is Art the other is Old Art.
Thanks for any help
If only a part of the path names is different, you may try this one.
I Couldnt get this one to work. The file names will stay the same just move Folders. THe Batch one works like a charm but it makes me select the Folder Each time. Is there a version you have that remembers the Folder I am changing to? I wont always have the files opened at the same time.
For instance on some jobs my folders will change like this From /Volumes/ART/ART.ai to /Volumes/ART/OLD ART/ART.ai those 2 folders will not change. I thought the First script you sent would allow me to plug that in but it wasnt working (Probably Operator error)/. I'm fighing a head cold so i may just not be understanding what to do.
I don't understand what you mean by "Unlinked Files": missing, embeded. Anyway, the script tries to relink every link.
I wrote it back in 2010 so don't remember details but in the new path don't add "/Volumes/" at the beginning, the script adds it automatically.
— Kas
I meant to say missing link's. ANd after playing around with it. It seems to do what i want. Thanks you. I'll give it a go and see what happens. From what i could see it only updated the Missing links. and did not change the Art that did not need it.
If you want the script to process only missing links, add a condition (after line #69) which checks 'if the current link isn't missing -- skip it'. Like so:
for (var i = gLinks.length-1; i >= 0 ; i--) {
var currentLink = gLinks;
if (currentLink.status != LinkStatus.LINK_MISSING) continue;
— Kas
First off thanks for your reply. This is kinda what i'm wanting. I actually want to have it do it automatically. So no one has to remember paths.
The 2nd script will remember the 'old' and the 'new' part of the path that is dissimilar so you don't have to reenter them next time you run the script.
On the other hand, you can use this script to batch process all the documents in the selected folder and optionally its subfolders. It will run a 'relink all missing links to this folder' script (still to be written, but that's easy) against all the files logging the result: e.g. relinked/not found.
—Kas
I'm going to play with The First Script actually. I dont know what i was thinking. All it needs to do is remember the folder names and the rest should work. So no one will need to enter Paths and tiles. I went crazy for a second there. SOrry
Perfect thank you ..
