Is there a way to disable the timeout on the Coldfusion administrator / monitor applications? We are attempting to troubleshoot performance issues on our production server and the monitor times out every 10 minutes or so.
We are running Coldfusion 11,0,10,300066
I emailed Adobe directly on this and here was the response:
Server monitoring is using the same session of ColdFusion admin and it has a fixed timeout value which is hard coded and we cannot change it.
There isn't a timeout as far as I know. I've been programming against the CF monitor and monitor API since CF7 and have never seen any timeout settings. This sounds more like a connection issue.
Hmmm... We moved from CF8 to CF11 in one jump. When we ran CF8, I would kick off the monitor each morning and it would run all day. With CF11, it logs me out. I just assumed there was a timeout, but I haven't found anything that documents it.
Hmmm... Okay, maybe it's the security feature for logins that auto-expires a user session. FYI: you initially said "Timeout" not logged out. big difference.
