Now my photoshop is not allowing me to drag and drop photos. Then entire thing is glitching is there a way to do a cxomplete reset. I have already treid ctrl + alt + shift
Did you get the prompt to delete you preferences and reply yes when you used Ctrl+Alt+Shift. Did tou also reset all tools. If your menu Help>System Info shows you have third paty plug-ins you cam try removing them or reinstalling them. You could also renaming your user Id Photoshop Preferences folder. "C:\Users\Your User ID\AppData\Roaming\Adobe\Adobe Photoshop CC 2017" to "C:\Users\Your User ID\AppData\Roaming\Adobe\Adobe Photoshop CC 2017 Old" the start Photoshop so it will build all you u
...Copy link to clipboard
Did you get the prompt to delete you preferences and reply yes when you used Ctrl+Alt+Shift. Did tou also reset all tools. If your menu Help>System Info shows you have third paty plug-ins you cam try removing them or reinstalling them. You could also renaming your user Id Photoshop Preferences folder. "C:\Users\Your User ID\AppData\Roaming\Adobe\Adobe Photoshop CC 2017" to "C:\Users\Your User ID\AppData\Roaming\Adobe\Adobe Photoshop CC 2017 Old" the start Photoshop so it will build all you userid Photoshop stuff over.
Did you see this when you tried resetting your preferences?
