InDesign crashes every time I try to open an InDesign file that I have packaged and archived. When I double-click the indd file, it opens for about 5 seconds, then Indesign abruptly closes. I receive a message saying, "InDesign CC Quit unexpectedly. Click Reopen to open the application again. Click Report to see more detailed information and send a report to Apple."
Upon clicking "Reopen" the same thing occurs.
If I click "Ignore" I then receive a prompt from InDesign saying "Adobe InDesign automatic recovery failed the last time it tried to open the document "Untitled." Do you want to receover "Untitled" again? Click Yes to begin recover. Click No to delete recovery data for this document. Click Cancel to postpone all document recovery until later.
Please note: the file name of my file is not "Untitled.indd".
Clicking "yes" causes the document to open temporarily again, then abruptly close again with the "InDesign CC quit unexpectedly" prompt appearing again.
I am running InDesign 12.0.0.81 Build, the 2017.0 release, on a Mac Pro running OS X 10.11.6 El Capitan.
I have tried uninstalling InDesign, restarting, deleting preferences, and even having the printer send me their archived files. I know it's not the file because it opens fine on a different Mac computer of mine.
Please help I need this for a big project that I'm working on.
Crash report:
Process: Adobe InDesign CC 2017 [843]
Path: /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Adobe InDesign CC 2017
Identifier: com.adobe.InDesign
Version: 12.0.0.81 (12000)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Adobe InDesign CC 2017 [843]
User ID: 32622
Date/Time: 2017-01-25 13:55:07.653 -0500
OS Version: Mac OS X 10.11.6 (15G1217)
Report Version: 11
Anonymous UUID: 3C1C2C9A-A301-8F5E-0395-97700A001050
Time Awake Since Boot: 2200 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: EXC_I386_GPFLT
Exception Note: EXC_CORPSE_NOTIFY
Global Trace Buffer (reverse chronological seconds):
18446744061.463650 CFNetwork 0x00007fff99644db3 TCP Conn 0x7fbcd1c97ad0 SSL Handshake DONE
18446744061.571030 CFNetwork 0x00007fff99644c8f TCP Conn 0x7fbcd1c97ad0 starting SSL negotiation
18446744061.571133 CFNetwork 0x00007fff99643659 TCP Conn 0x7fbcd1c97ad0 complete. fd: 52, err: 0
18446744061.571182 CFNetwork 0x00007fff996d1f33 TCP Conn 0x7fbcd1c97ad0 event 1. err: 0
18446744061.635143 CFNetwork 0x00007fff9964292b TCP Conn 0x7fbcd1c97ad0 started
18446744065.830894 CFNetwork 0x00007fff99644db3 TCP Conn 0x7fbcc3da86c0 SSL Handshake DONE
18446744065.931969 CFNetwork 0x00007fff99644c8f TCP Conn 0x7fbcc3da86c0 starting SSL negotiation
18446744065.932144 CFNetwork 0x00007fff99643659 TCP Conn 0x7fbcc3da86c0 complete. fd: 26, err: 0
18446744065.932171 CFNetwork 0x00007fff996d1f33 TCP Conn 0x7fbcc3da86c0 event 1. err: 0
18446744065.997574 CFNetwork 0x00007fff9964292b TCP Conn 0x7fbcc3da86c0 started
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_platform.dylib 0x00007fff90990551 _platform_memmove$VARIANT$Ivybridge + 49
1 com.adobe.InDesign.Hyperlinks Panel 0x00000001146150d9 0x1145a0000 + 479449
2 com.adobe.InDesign.Hyperlinks Panel 0x000000011461582a 0x1145a0000 + 481322
3 com.adobe.InDesign.Hyperlinks Panel 0x0000000114615434 0x1145a0000 + 480308
4 com.adobe.InDesign.Hyperlinks Panel 0x0000000114611fac 0x1145a0000 + 466860
5 com.adobe.InDesign.Hyperlinks Panel 0x00000001146123d1 0x1145a0000 + 467921
6 DV_WidgetBinLib.dylib 0x0000000106ff03df CTreeViewMgr::ChangeRoot(short) + 255
7 com.adobe.InDesign.Hyperlinks Panel 0x00000001145a1463 0x1145a0000 + 5219
8 com.adobe.InDesign.Hyperlinks Panel 0x00000001145a11a4 0x1145a0000 + 4516
9 com.adobe.InDesign.Hyperlinks Panel 0x00000001145a153f 0x1145a0000 + 5439
10 com.adobe.InDesign.Hyperlinks Panel 0x0000000114601b61 0x1145a0000 + 400225
11 com.adobe.InDesign.Hyperlinks Panel 0x00000001145c50e9 0x1145a0000 + 151785
12 DV_WidgetBinLib.dylib 0x0000000106f90d8f 0x106f86000 + 44431
13 com.adobe.dvaui.framework 0x0000000107cc6e22 dvaui::ui::UI_Node::UI_DrawSelf(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 354
14 com.adobe.dvaui.framework 0x0000000107cc70e4 dvaui::ui::UI_Node::UI_DrawAndCache(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 612
15 com.adobe.dvaui.framework 0x0000000107cc74cc dvaui::ui::UI_Node::UI_DispatchDrawToChild(dvaui::ui::UI_Node const*, dvaui::drawbot::Drawbot*) + 412
16 com.adobe.dvaui.framework 0x0000000107cc6db4 dvaui::ui::UI_Node::UI_DrawSelf(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 244
17 com.adobe.dvaui.framework 0x0000000107cc70e4 dvaui::ui::UI_Node::UI_DrawAndCache(dvaui::drawbot::Drawbot*, bool, dvaui::drawbot::ColorRGBA const*) const + 612
18 com.adobe.dvaui.framework 0x0000000107cc799f dvaui::ui::UI_Node::UI_DispatchDrawFromRoot(dvaui::drawbot::ColorRGBA const&, dvaui::drawbot::Drawbot*, bool) const + 479
19 com.adobe.InDesign.Application UI 0x00000001175070ab 0x117380000 + 1601707
20 com.adobe.dvaui.framework 0x0000000107d5c489 dvaui::ui::OS_NodeTimerData::~OS_NodeTimerData() + 53209
21 com.adobe.dvaui.framework 0x0000000107d4b0eb dvaui::ui::OS_View::UI_HandlePlatformDrawEvent(dvaui::drawbot::SurfaceInterface*) + 379
22 com.adobe.dvacore.framework 0x000000010761c3ac int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 28
23 com.adobe.InDesign.Application UI 0x00000001175029a2 0x117380000 + 1583522
24 com.adobe.dvacore.framework 0x000000010761c463 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::function0<void>, bool*) + 99
25 com.adobe.dvacore.framework 0x000000010761d0a0 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 160
26 com.adobe.dvaui.framework 0x0000000107d5611d dvaui::ui::OS_NodeTimerData::~OS_NodeTimerData() + 27757
27 com.apple.AppKit 0x00007fff83c7bcd2 -[NSView _drawRect:clip:] + 3626
28 com.apple.AppKit 0x00007fff83cd3cad -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 1873
29 com.apple.AppKit 0x00007fff83cd408a -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2862
30 com.apple.AppKit 0x00007fff83cd408a -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2862
31 com.apple.AppKit 0x00007fff83cd408a -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2862
32 com.apple.AppKit 0x00007fff83cd408a -[NSView _recursiveDisplayAllDirtyWithLockFocus:visRect:] + 2862
33 com.apple.AppKit 0x00007fff83c793fb -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 838
34 com.apple.AppKit 0x00007fff83c7a785 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 5840
35 com.apple.AppKit 0x00007fff83c7a785 -[NSView _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 5840
36 com.apple.AppKit 0x00007fff83cd3440 -[NSNextStepFrame _recursiveDisplayRectIfNeededIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:topView:] + 284
37 com.apple.AppKit 0x00007fff83c76feb -[NSView _displayRectIgnoringOpacity:isVisibleRect:rectIsVisibleRectForView:] + 2449
38 com.apple.AppKit 0x00007fff83c723f5 -[NSView displayIfNeeded] + 1950
39 com.apple.AppKit 0x00007fff83c71c3c -[NSWindow displayIfNeeded] + 232
40 com.apple.AppKit 0x00007fff842f641b ___NSWindowGetDisplayCycleObserver_block_invoke6365 + 476
41 com.apple.AppKit 0x00007fff83c715d6 __37+[NSDisplayCycle currentDisplayCycle]_block_invoke + 941
42 com.apple.QuartzCore 0x00007fff94b31f71 CA::Transaction::run_commit_handlers(CATransactionPhase) + 85
43 com.apple.QuartzCore 0x00007fff94b3142c CA::Context::commit_transaction(CA::Transaction*) + 160
44 com.apple.QuartzCore 0x00007fff94b310ec CA::Transaction::commit() + 508
45 com.adobe.dvaui.framework 0x0000000107d49295 dvaui::ui::OS_View::UI_UpdateNow(dvacore::utility::Flags<unsigned int>) + 181
46 DV_WidgetBinLib.dylib 0x0000000106f96687 DVHostedWidgetView::ForceRedraw(__HIShape*, short) + 887
47 com.adobe.InDesign.Document Framework 0x00000001183e6ca1 0x1183b3000 + 212129
48 com.adobe.InDesign.Document Framework 0x00000001183e920f 0x1183b3000 + 221711
49 PublicLib.dylib 0x00000001083ffe51 Command::DoImmediate(short) + 65
50 com.adobe.InDesign.Utilities 0x000000012022c60a 0x12022b000 + 5642
51 com.adobe.InDesign.AppFramework 0x0000000117117cdd 0x11710a000 + 56541
52 PublicLib.dylib 0x00000001083fef8e CmdUtils::ProcessCommand(ICommand*) + 62
53 com.adobe.InDesign.AppFramework 0x0000000117262f0a 0x11710a000 + 1412874
54 com.adobe.InDesign 0x0000000106f2c961 main + 513
55 libdyld.dylib 0x00007fff856655ad start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fff856415e2 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff96dbf578 _pthread_wqthread + 1283
2 libsystem_pthread.dylib 0x00007fff96dbd341 start_wqthread + 13
Thread 2:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff85641efa kevent_qos + 10
1 libdispatch.dylib 0x00007fff8f69b165 _dispatch_mgr_invoke + 216
2 libdispatch.dylib 0x00007fff8f69adcd _dispatch_mgr_thread + 52
Thread 3:
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:: com.apple.NSURLConnectionLoader
0 libsystem_kernel.dylib 0x00007fff8563af72 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff8563a3b3 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff86c4c124 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff86c4b5ec __CFRunLoopRun + 1356
4 com.apple.CoreFoundation 0x00007fff86c4ae38 CFRunLoopRunSpecific + 296
5 com.apple.CFNetwork 0x00007fff99609a6d +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
6 com.apple.Foundation 0x00007fff9781be64 __NSThread__start__ + 1351
7 libsystem_pthread.dylib 0x00007fff96dbf99d _pthread_body + 131
8 libsystem_pthread.dylib 0x00007fff96dbf91a _pthread_start + 168
9 libsystem_pthread.dylib 0x00007fff96dbd351 thread_start + 13
Thread 19:: VulcanMsgRecv
0 libsystem_kernel.dylib 0x00007fff85640fba __recvfrom + 10
1 VulcanMessage5.dylib 0x000000010bd05308 0x10bce7000 + 123656
2 VulcanMessage5.dylib 0x000000010bd046cc 0x10bce7000 + 120524
3 VulcanMessage5.dylib 0x000000010bd039c4 0x10bce7000 + 117188
4 VulcanMessage5.dylib 0x000000010bd03888 0x10bce7000 + 116872
5 VulcanMessage5.dylib 0x000000010bcfe4c7 0x10bce7000 + 95431
6 VulcanMessage5.dylib 0x000000010bcfef56 0x10bce7000 + 98134
7 VulcanMessage5.dylib 0x000000010bcfe8ef 0x10bce7000 + 96495
8 VulcanMessage5.dylib 0x000000010bd02974 0x10bce7000 + 113012
9 VulcanMessage5.dylib 0x000000010bd023cd 0x10bce7000 + 111565
10 VulcanMessage5.dylib 0x000000010bd020ba 0x10bce7000 + 110778
11 VulcanMessage5.dylib 0x000000010bd0200d 0x10bce7000 + 110605
12 VulcanMessage5.dylib 0x000000010bcf5848 0x10bce7000 + 59464
13 VulcanMessage5.dylib 0x000000010bcf4a86 0x10bce7000 + 55942
14 VulcanMessage5.dylib 0x000000010bd0320c 0x10bce7000 + 115212
15 VulcanMessage5.dylib 0x000000010bd05109 0x10bce7000 + 123145
16 libsystem_pthread.dylib 0x00007fff96dbf99d _pthread_body + 131
17 libsystem_pthread.dylib 0x00007fff96dbf91a _pthread_start + 168
18 libsystem_pthread.dylib 0x00007fff96dbd351 thread_start + 13
Thread 20:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff8564107a __select + 10
1 com.apple.CoreFoundation 0x00007fff86c8945a __CFSocketManager + 762
2 libsystem_pthread.dylib 0x00007fff96dbf99d _pthread_body + 131
3 libsystem_pthread.dylib 0x00007fff96dbf91a _pthread_start + 168
4 libsystem_pthread.dylib 0x00007fff96dbd351 thread_start + 13
Thread 21:
0 libsystem_kernel.dylib 0x00007fff85640db6 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff96dc0728 _pthread_cond_wait + 767
2 com.adobe.InDesign.AppFramework 0x000000011724e3c1 0x11710a000 + 1328065
3 com.adobe.InDesign.AppFramework 0x000000011724d928 0x11710a000 + 1325352
4 com.adobe.InDesign.AppFramework 0x000000011724aca5 0x11710a000 + 1313957
5 com.adobe.InDesign.AppFramework 0x00000001172506b9 0x11710a000 + 1337017
6 com.adobe.boost_threads.framework 0x00000001083a241a boost::thread::start_thread_noexcept() + 410
Thread 22:
3 com.adobe.InDesign.AppFramework 0x000000011724d85b 0x11710a000 + 1325147
Thread 23:
0 libsystem_kernel.dylib 0x00007fff8564110a __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff93d7dd0f nanosleep + 199
2 com.adobe.InDesign.Support for JavaScript 0x000000011f189498 0x11f131000 + 361624
3 com.adobe.InDesign.Support for JavaScript 0x000000011f17064c 0x11f131000 + 259660
4 com.adobe.InDesign.Support for JavaScript 0x000000011f1890e1 0x11f131000 + 360673
5 libsystem_pthread.dylib 0x00007fff96dbf99d _pthread_body + 131
6 libsystem_pthread.dylib 0x00007fff96dbf91a _pthread_start + 168
7 libsystem_pthread.dylib 0x00007fff96dbd351 thread_start + 13
Thread 24:
5 com.apple.Foundation 0x00007fff97923075 -[NSConnection run] + 149
Thread 25:: CEPMonitorThread
5 com.apple.Foundation 0x00007fff978b4d99 -[NSConcreteTask waitUntilExit] + 205
6 com.adobe.PlugPlugOwl 0x0000000109f7da2b 0x109ee4000 + 629291
7 com.apple.Foundation 0x00007fff9781be64 __NSThread__start__ + 1351
8 libsystem_pthread.dylib 0x00007fff96dbf99d _pthread_body + 131
9 libsystem_pthread.dylib 0x00007fff96dbf91a _pthread_start + 168
10 libsystem_pthread.dylib 0x00007fff96dbd351 thread_start + 13
Thread 26:
Thread 27:
Thread 28:
0 libsystem_kernel.dylib 0x00007fff8563afae semaphore_wait_trap + 10
1 libtbb.dylib 0x000000010a1b9d99 tbb::internal::concurrent_queue_base_v3::internal_pop(void*) + 537
2 com.adobe.InDesign.Layout UI 0x000000011a084e49 0x119f63000 + 1187401
3 com.adobe.boost_threads.framework 0x00000001083a241a boost::thread::start_thread_noexcept() + 410
4 libsystem_pthread.dylib 0x00007fff96dbf99d _pthread_body + 131
5 libsystem_pthread.dylib 0x00007fff96dbf91a _pthread_start + 168
6 libsystem_pthread.dylib 0x00007fff96dbd351 thread_start + 13
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0707060607070704 rcx: 0x0707060607070706 rdx: 0x0707060607070706
rdi: 0x0000000000000000 rsi: 0xf1f0f0efeeedecec rbp: 0x00007fff58cd00f0 rsp: 0x00007fff58cd00f0
r8: 0x0000000000000101 r9: 0x00000000000fffff r10: 0x00000000069ddf49 r11: 0x0e0f0f1011121314
r12: 0x01c1c18181c1c1c1 r13: 0x00007fbcc4e228e0 r14: 0x00007fbcc4e228e8 r15: 0x00007fff58cd0220
rip: 0x00007fff90990551 rfl: 0x0000000000010206 cr2: 0x0000000122c03000
Logical CPU: 0
Error Code: 0x00000000
Trap Number: 13
Binary Images:
0x106f2b000 - 0x106f34ff7 +com.adobe.InDesign (12.0.0.81 - 12000) <7D9D89A7-7C4A-32A9-B36E-626242C10277> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Adobe InDesign CC 2017
0x106f43000 - 0x106f46fff +com.adobe.InDesign.InDesignModelAndUI (9.0 - 0) <06FAAAD4-669A-34EF-9365-7FB3F8FC95DE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/InDesignModelAndUI.framework/Versions/A/InDesignModelAndUI
0x106f4e000 - 0x106f58ff7 +com.adobe.coretech.adobesplashkit (AdobeSplashKit Version 1.0 - 1.0) <B55F1CEC-518C-3999-A4A9-23C883871DAE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeSplashKit.framework/Versions/A/AdobeSplashKit
0x106f68000 - 0x106f76ffb +ASLSupportLib.dylib (0) <B1F022D3-52B3-33AA-BF3B-B7A294D7A97C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/ASLSupportLib.dylib
0x106f86000 - 0x10707bffb +DV_WidgetBinLib.dylib (0) <56298D44-D873-3EE8-ABCF-2B078EA2E642> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/DV_WidgetBinLib.dylib
0x1071b5000 - 0x1071f5ff3 +TextPanelLib.dylib (0) <EC73B739-F83F-3BEF-AFF6-D93AFFEB3904> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/TextPanelLib.dylib
0x107216000 - 0x10735bff3 +WidgetBinLib.dylib (0) <46576103-CF6B-30E3-BC66-2DB61DD7A692> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/WidgetBinLib.dylib
0x107419000 - 0x1075a1ff7 +com.adobe.owl (AdobeOwl version 5.2.9 - 5.2.9) <A08490CC-75C3-35F0-A207-AE39CF56C78F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x1075ed000 - 0x107902ffb +com.adobe.dvacore.framework (10.0.0 - 10.0.0.0) <8BE548C6-CE6A-374B-A071-BCFF4B9A7E5F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x1079e2000 - 0x107f72ff3 +com.adobe.dvaui.framework (10.0.0 - 10.0.0.0) <0E15B253-AC76-337D-867B-FBE77959B683> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x10839b000 - 0x10839bff7 +com.adobe.InDesign.InDesignModel (9.0 - 0) <3ABCBBC9-5789-363A-A6D5-BB29AFBBAA47> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/InDesignModel.framework/Versions/A/InDesignModel
0x1083a0000 - 0x1083aeff7 +com.adobe.boost_threads.framework (10.0.0 - 10.0.0.0) <B73D6065-556B-3AD6-900A-803D7BF1BDDB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
0x1083bf000 - 0x1083c0ffb +com.adobe.boost_system.framework (10.0.0 - 10.0.0.0) <27097AC9-14AD-3510-8BD6-6B69494489CA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
0x1083c9000 - 0x1083cdfff +com.adobe.boost_date_time.framework (10.0.0 - 10.0.0.0) <D0154E96-3135-3A27-AA36-FF8E600FE2C3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
0x1083d6000 - 0x1087f3ff3 +PublicLib.dylib (0) <1AA372E7-3936-3A10-BE2A-5A73A31AE8B2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/PublicLib.dylib
0x108947000 - 0x108952ffb +PMRuntime.dylib (0) <F704ADAD-42F1-3680-9F4A-7C0578EC3608> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/PMRuntime.dylib
0x108965000 - 0x108979fff +com.adobe.AFL (AdobeAFL 3.0.0 - 3.0) <63034C19-9D73-37B9-8D6C-230270E2F172> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeAFL.framework/Versions/A/AdobeAFL
0x108990000 - 0x108c84fff +com.adobe.CoolType (AdobeCoolType 5.15.00.37194 - 5.15.00.37194) <342B9526-C99A-3A1C-B3B3-9D50B8CF30F7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x108cd3000 - 0x108ceffff +com.adobe.BIB (AdobeBIB 1.2.03.36974 - 1.2.03.36974) <5B62D9F4-7012-3C7E-B821-31B38A101F3F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x108cfa000 - 0x108e46ffb +com.adobe.ACE (AdobeACE 2.20.02.36974 - 2.20.02.36974) <EC655948-66DE-39ED-9A50-424511FC81DC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x108e5f000 - 0x109601ff3 +com.adobe.AGM (AdobeAGM 4.30.60.1 - 4.30.60.1) <35BDB273-0D57-38FA-987A-A7D1CEA006FB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x1096c1000 - 0x1096f3fff +com.adobe.ARE (AdobeARE 1.5.02.36974 - 1.5.02.36974) <0272D45A-FB5C-3A86-ABAD-D1236768D51E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
0x1096fb000 - 0x1096fcfff +com.adobe.InDesign.Metadata Database Filter (12.0.0.81 - 0) <129ADE28-84B3-355D-949D-5C58B89DFCA2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Metadata Database Filter.InDesignPlugin/Metadata Database Filter
0x109702000 - 0x109725ffb +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <6FDFDB79-CE33-30EE-8056-D76B4D52B6EF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x109732000 - 0x109a98fff +com.adobe.MPS (AdobeMPS 5.8.1.36881 - 5.8.1.36881) <B9EFAA03-C560-3B5C-A92C-ED156F669D0B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x109b12000 - 0x109b43ff3 +com.adobe.dvaflashview.framework (10.0.0 - 10.0.0.0) <6A4CE2DA-0DE8-3097-BFA6-EB79B73669DB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
0x109b64000 - 0x109b68ff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <B9447EE8-6F91-9E85-C163-96600BF70764> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
0x109b75000 - 0x109c27fff +com.adobe.exo.framework (10.0.0 - 10.0.0.0) <A906B7BA-818F-3E27-9721-5907919F4034> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/exo.framework/Versions/A/exo
0x109ce8000 - 0x109df3ff7 +com.adobe.dvaworkspace.framework (10.0.0 - 10.0.0.0) <678A5E16-2CDC-330B-86DB-BCDEF76103F3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
0x109ee4000 - 0x10a15aff7 +com.adobe.PlugPlugOwl (7.0.0.59 - 7.0.0.59) <1A71FB55-00B7-3332-A7DF-27FC2A8D895D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
0x10a1b8000 - 0x10a1effe7 +libtbb.dylib (0) <57385823-CF98-3366-B55F-B454BCC39B7A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/libtbb.dylib
0x10a234000 - 0x10a257ff7 +libtbbmalloc.dylib (0) <2D49758A-80A5-33B2-AF4F-315DD0761657> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/libtbbmalloc.dylib
0x10a293000 - 0x10afd8fff +com.adobe.ICUData (4.0 - 3.61) <8726D6A3-3921-3AB2-94D5-062E9EA297DB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
0x10afed000 - 0x10b107ff7 +com.adobe.ICUInternationalization (4.0 - 3.61) <36984DC1-7D78-3AB5-9891-CA6ACD116AEE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/ICUInternationalization
0x10b15d000 - 0x10b24eff7 +com.adobe.ICUUnicode (4.0 - 3.61) <431F0368-6F63-3B0D-A215-D6866EEACA9A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
0x10b287000 - 0x10b3b1ff7 +com.winsoft.wrservices (WRServices 12.2.0 - 12.2.0) <02E9EA6A-5D56-3BF4-AFA3-3CB90539226D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
0x10b3fb000 - 0x10b4fefff +com.adobe.amtlib (10.0.0.47 - 10.0.0.47) <AD7B1E56-04A5-355A-AD70-DA2464879FC3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x10b515000 - 0x10b6b2fff +libtypekitC4Release.dylib (0) <7A1E8B5F-5505-3C2A-BB8E-37061B2FFED9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/libtypekitC4Release.dylib
0x10b6dd000 - 0x10b6e0fff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x10b6e9000 - 0x10b79cff7 +com.adobe.boost_regex.framework (10.0.0 - 10.0.0.0) <CA797BE1-B534-338C-9977-64B210FE8705> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
0x10b7f2000 - 0x10b8ecff7 +com.adobe.adobe_caps (adobe_caps 10.0.0.6 - 10.0.0.6) <F42B5047-A935-3B78-9F9A-F4841C6DEE88> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
0x10b900000 - 0x10b91afff +com.adobe.dvaunittesting.framework (10.0.0 - 10.0.0.0) <257F4E67-D99C-378C-8C10-1FCC00AED05A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
0x10b930000 - 0x10b930fff com.apple.applescript.component (2.5 - 377) <D205C65F-E27A-3D14-9F22-B8224F2C657C> /System/Library/Components/AppleScript.component/Contents/MacOS/AppleScript
0x10b935000 - 0x10b941ff3 +com.adobe.boost_filesystem.framework (10.0.0 - 10.0.0.0) <59376A9F-17E9-3BC4-AEE2-8957460769B0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
0x10b94f000 - 0x10b95afff +com.adobe.boost_signals.framework (10.0.0 - 10.0.0.0) <5D646DA9-E532-320C-9593-EC7E18FA3258> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
0x10b966000 - 0x10b966fe7 +cl_kernels (???) <892FD0CB-A297-47F6-8F3D-4D18448D3DA7> cl_kernels
0x10b96c000 - 0x10b970fff com.apple.agl (3.3.1 - AGL-3.3.1) <11FD7720-F5AC-3719-9CE7-FF8EBDF52B42> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x10b97a000 - 0x10baadfff +com.adobe.AIDE (1.5.0 - 1.5.0.36540) <D593F9F3-0032-338A-AE28-E6EF2CC91F70> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
0x10bad6000 - 0x10bb78ff7 +com.adobe.ICUConverter (4.0 - 3.61) <4D6A813A-56D5-3CE1-8743-2BA65500FD20> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
0x10bb99000 - 0x10bc55fff +com.adobe.dvanet.framework (10.0.0 - 10.0.0.0) <CC77D8A2-18C5-3506-8D9E-691DE9C2209A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
0x10bcaf000 - 0x10bcd3fff +VulcanControl.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <32AA6861-E0A7-37F8-8CE9-FCE97E3BFD07> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/VulcanControl.dylib
0x10bce7000 - 0x10bd22ff7 +VulcanMessage5.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <4B054DF8-614C-39A7-AC19-CBBA847B9014> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/VulcanMessage5.dylib
0x10bd3e000 - 0x10bdaaffb +DataBaseLib.dylib (0) <A6E884B0-76B7-35F3-A606-0C7FCFA1D5C5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/DataBaseLib.dylib
0x10bdc4000 - 0x10be3fff3 +ObjectModelLib.dylib (0) <0914C6C7-8E56-3C8F-8F70-FA6CC424F980> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/ObjectModelLib.dylib
0x10be63000 - 0x10be83ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.36783 - 3.8.0.36783) <3C3CE968-0069-3A67-AA90-EF82A1AC3745> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
0x111d17000 - 0x111d5aff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
0x112b66000 - 0x112b6fffb +com.adobe.InDesign.Data Services UI (12.0.0.81 - 0) <AAAB33BC-2F83-332F-9788-667A3A1A5166> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Data Services/Data Services UI.InDesignPlugin/Data Services UI
0x112b79000 - 0x112b7fff7 +com.adobe.InDesign.Data Services (12.0.0.81 - 0) <F3A64479-9CE4-3E55-9A95-6BAEE21C01D7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Data Services/Data Services.InDesignPlugin/Data Services
0x112b85000 - 0x112b90fff +com.adobe.InDesign.DTTransform (12.0.0.81 - 0) <329DB794-D0CB-3D23-99D2-1E28F3F8FF37> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Data Services/DTTransform.InDesignPlugin/DTTransform
0x112b99000 - 0x112bd0fff +com.adobe.InDesign.Dictionary Editor Dialog (12.0.0.81 - 0) <F3DBAA28-14D2-3DC3-B6E0-9FC2112845AC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Dictionaries/Dictionary Editor Dialog.InDesignPlugin/Dictionary Editor Dialog
0x112bf0000 - 0x112c15fff +com.adobe.InDesign.LILO (12.0.0.81 - 0) <8E0D9329-63F5-3746-B458-CA84C8BFB1DF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Dictionaries/LILO/LILO.InDesignPlugin/LILO
0x112c24000 - 0x112ceeff7 +com.adobe.linguistic.LinguisticManager (10.1.0 - 22175) <9A965912-1738-3875-B4E3-88FE4E19F2EA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
0x112d0b000 - 0x112d4affb +com.adobe.InDesign.Digital Publishing UI (12.0.0.81 - 0) <40041318-3260-368D-B664-1763CCC19FC8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Digital Publishing UI.InDesignPlugin/Digital Publishing UI
0x112d61000 - 0x112e74fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 137 - 79.159768) <0BEB92DC-04FA-37AD-8EC2-F07208EF1CFB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x112edb000 - 0x1130b1ff3 +com.adobe.InDesign.Digital Publishing (12.0.0.81 - 0) <4927EB4B-7D73-3D1B-B527-23428E7DD014> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Digital Publishing.InDesignPlugin/Digital Publishing
0x1130f7000 - 0x113357fff +com.adobe.InDesign.EBookExport (12.0.0.81 - 0) <CEAD0C3A-BECC-31CC-91E8-EAF9DD25AA7A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/EBookExport.InDesignPlugin/EBookExport
0x113393000 - 0x1133d8ff3 +com.adobe.InDesign.Media Import Filter (12.0.0.81 - 0) <C5679F28-01C8-3505-95F3-0DB2C800D223> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Media Import Filter.InDesignPlugin/Media Import Filter
0x1133ea000 - 0x1133f4ffb +com.adobe.InDesign.PNG Import Filter UI (12.0.0.81 - 0) <F1F9D2EC-9223-385E-BF09-4A62EC42A0A2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/PNG Import Filter UI.InDesignPlugin/PNG Import Filter UI
0x1133fe000 - 0x113423ff3 +com.adobe.InDesign.Sangam Preferences UI (12.0.0.81 - 0) <A682D260-3623-3D3B-B261-7A477118A2AE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Sangam Preferences UI.InDesignPlugin/Sangam Preferences UI
0x113436000 - 0x113497fff +com.adobe.AdobeSangam (AdobeSangam 5.65.0.36985 - 5.65.0.36985) <F1E4000E-DAB0-313F-A6BB-9EC2028B4CB9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeSangam.framework/Versions/A/AdobeSangam
0x1134e9000 - 0x113633ffb +com.adobe.InDesign.SangamServicer-Mapper (12.0.0.81 - 0) <41174835-35B9-3ABF-B1B2-FBE1E949A743> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/SangamServicer-Mapper.InDesignPlugin/SangamServicer-Mapper
0x113661000 - 0x113675fff +com.adobe.InDesign.SaveBack (12.0.0.81 - 0) <7B66BEC5-7EB7-396A-A3B5-BE4F63CB0026> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/SaveBack.InDesignPlugin/SaveBack
0x113683000 - 0x113685ff7 +com.adobe.InDesign.SimpleTextImportFilter (12.0.0.81 - 0) <AE8F3E2E-3077-37A6-BF87-83B4A7D309ED> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/SimpleTextImportFilter.InDesignPlugin/SimpleTextImportFilter
0x11368b000 - 0x11370eff7 +com.adobe.InDesign.Tagged Text Attributes (12.0.0.81 - 0) <C1A0501D-4B40-3DF9-94C5-91BC2904515D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Tagged Text Attributes.InDesignPlugin/Tagged Text Attributes
0x11373d000 - 0x113748ffb +com.adobe.InDesign.Tagged Text Filters UI (12.0.0.81 - 0) <F8A328D0-3CB9-3461-886E-3DC4AE4F4CA5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Tagged Text Filters UI.InDesignPlugin/Tagged Text Filters UI
0x113754000 - 0x1137e3ffb +com.adobe.InDesign.Tagged Text Filters (12.0.0.81 - 0) <B50A1A3D-56B0-3316-BA20-D105C2E30381> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Tagged Text Filters.InDesignPlugin/Tagged Text Filters
0x1137f7000 - 0x113803ff3 +com.adobe.InDesign.Clipping Path Dialog (12.0.0.81 - 0) <031FE8FC-DB59-3CFF-AC8D-66C188FC6537> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Clipping Path Dialog.InDesignPlugin/Clipping Path Dialog
0x113815000 - 0x113854ff3 +com.adobe.InDesign.Color Management UI (12.0.0.81 - 0) <78DDC256-9135-389C-9B47-C537CE177339> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Color Management UI.InDesignPlugin/Color Management UI
0x113864000 - 0x1138e5ff3 +com.adobe.InDesign.Color Picker Panel (12.0.0.81 - 0) <088716BC-AFF1-3663-843C-E0B902E8496E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Color Picker Panel.InDesignPlugin/Color Picker Panel
0x113912000 - 0x113988ff7 +com.adobe.InDesign.DynamicDocumentsUI (12.0.0.81 - 0) <7EC20AB4-52AB-315A-8AE6-7A9B6DB8ABC0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/DynamicDocumentsUI.InDesignPlugin/DynamicDocumentsUI
0x1139af000 - 0x1139c8ffb +com.adobe.InDesign.EPS UI (12.0.0.81 - 0) <5FDB513E-635A-3749-B62D-7CFC8654BE95> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/EPS UI.InDesignPlugin/EPS UI
0x1139d9000 - 0x1139e4fff +com.adobe.InDesign.Generic Style Editor (12.0.0.81 - 0) <90D366EB-CB1C-3A4F-94C6-44596B423A1B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Generic Style Editor.InDesignPlugin/Generic Style Editor
0x1139f2000 - 0x113a26ff3 +com.adobe.InDesign.Gradient Panel (12.0.0.81 - 0) <FCC84854-FCDE-33AE-A4D3-17940C12D706> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Gradient Panel.InDesignPlugin/Gradient Panel
0x113a3f000 - 0x113ae8ffb +com.adobe.InDesign.Graphic Panels (12.0.0.81 - 0) <4BE79D70-76EF-357F-9453-CA26128E372D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Graphic Panels.InDesignPlugin/Graphic Panels
0x113b14000 - 0x113b1dff7 +com.adobe.InDesign.JPEG Export UI (12.0.0.81 - 0) <B77D3E9B-C264-3DD0-BD0B-9CD856392D9E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/JPEG Export UI.InDesignPlugin/JPEG Export UI
0x113b26000 - 0x113b3bffb +com.adobe.InDesign.JPEG Export (12.0.0.81 - 0) <57D8CC84-4AF6-3B1B-ABC5-98FAF80DEB93> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/JPEG Export.InDesignPlugin/JPEG Export
0x113b4c000 - 0x113b98ffb +com.adobe.InDesign.Output Preview (12.0.0.81 - 0) <665012E5-914E-3A45-9350-8891C2B6974E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Output Preview.InDesignPlugin/Output Preview
0x113bb4000 - 0x113bcbff7 +com.adobe.InDesign.OutputMiscUI (12.0.0.81 - 0) <A9208127-2E79-36B4-B5A4-2820E79EDD34> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/OutputMiscUI.InDesignPlugin/OutputMiscUI
0x113bde000 - 0x113c69fff +com.adobe.InDesign.PDF UI (12.0.0.81 - 0) <E06DDBA1-D488-31FD-91B6-99BC6F6ECDFC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/PDF UI.InDesignPlugin/PDF UI
0x113c8f000 - 0x113ca1fff +com.adobe.InDesign.Printer Styles (12.0.0.81 - 0) <3256EC82-58C3-3F81-918F-8F1724C66FFC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Printer Styles.InDesignPlugin/Printer Styles
0x113caf000 - 0x113d7cffb +com.adobe.InDesign.PrintUI (12.0.0.81 - 0) <61E78318-0765-388B-9778-42AE572EC987> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/PrintUI.InDesignPlugin/PrintUI
0x113da7000 - 0x113db8ff3 +com.adobe.InDesign.PS Import UI (12.0.0.81 - 0) <1AE97B4A-229C-3F77-9941-28CCB82421AF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/PS Import UI.InDesignPlugin/PS Import UI
0x113dc7000 - 0x113de8fff +com.adobe.InDesign.Swatch Library Panel (12.0.0.81 - 0) <52B76571-5586-3E52-ABA7-E5BF67FC087A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Swatch Library Panel.InDesignPlugin/Swatch Library Panel
0x113df7000 - 0x113edcff7 +com.adobe.InDesign.Swatches Panel (12.0.0.81 - 0) <EB891CAC-F4CE-3D42-B1E1-5F233BB5BB34> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Swatches Panel.InDesignPlugin/Swatches Panel
0x113f17000 - 0x113fabff3 +com.adobe.InDesign.Transparency UI (12.0.0.81 - 0) <05AA3716-8CD9-3EC3-B116-B2251722BA45> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Transparency UI.InDesignPlugin/Transparency UI
0x113fde000 - 0x114039ffb +com.adobe.InDesign.Assignment UI (12.0.0.81 - 0) <D9030AA9-16EC-3446-967F-994DDFB62A32> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/Assignment UI.InDesignPlugin/Assignment UI
0x11405c000 - 0x11407cff3 +com.adobe.InDesign.InCopy Bridge UI (12.0.0.81 - 0) <985CB572-CFAB-37D1-91F4-83E0AE2186EC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopy Bridge UI.InDesignPlugin/InCopy Bridge UI
0x11408a000 - 0x1140beff3 +com.adobe.InDesign.InCopy Bridge (12.0.0.81 - 0) <28FB35C8-BE11-3FC1-919A-B5AC1E975FC6> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopy Bridge.InDesignPlugin/InCopy Bridge
0x1140cd000 - 0x1140d3ff7 +com.adobe.InDesign.InCopyExport (12.0.0.81 - 0) <453DC2AF-B2EA-3FA6-B2F0-47478B7A9D7E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopyExport.InDesignPlugin/InCopyExport
0x1140dc000 - 0x1140e3ffb +com.adobe.InDesign.InCopyExportUI (12.0.0.81 - 0) <8A5A058D-F444-358C-AF99-1B990EBB93AD> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopyExportUI.InDesignPlugin/InCopyExportUI
0x1140ec000 - 0x1140f1ff3 +com.adobe.InDesign.InCopyImport (12.0.0.81 - 0) <240BABC7-70DC-3480-8C53-8A95E8A5AE72> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopyImport.InDesignPlugin/InCopyImport
0x1140f8000 - 0x1140ffff7 +com.adobe.InDesign.InCopyWorkflow UI (12.0.0.81 - 0) <69B522C8-D610-30BD-832F-58865C378E66> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopyWorkflow UI.InDesignPlugin/InCopyWorkflow UI
0x11410a000 - 0x11415aff3 +com.adobe.InDesign.Note (12.0.0.81 - 0) <0CD90339-CCBA-3FBD-B7E5-9057598C8B50> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/Note.InDesignPlugin/Note
0x11417a000 - 0x114184fff +com.adobe.InDesign.NotePref (12.0.0.81 - 0) <25CC3ADF-9929-3B3E-8CAD-2633D6C483F5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/NotePref.InDesignPlugin/NotePref
0x114192000 - 0x114198ffb +com.adobe.InDesign.Username UI (12.0.0.81 - 0) <91CB1D7D-032D-3CCE-96D0-7B6787A8ABBA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/Username UI.InDesignPlugin/Username UI
0x1141a1000 - 0x114233fff +com.adobe.InDesign.ButtonUI (12.0.0.81 - 0) <CA784015-7264-3E0E-B562-00F7FFA2D1D1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Interactive/ButtonUI.InDesignPlugin/ButtonUI
0x114262000 - 0x114289ffb +com.adobe.InDesign.MediaUI (12.0.0.81 - 0) <97BACAB1-F482-32FC-9291-4B6129186D02> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Interactive/MediaUI.InDesignPlugin/MediaUI
0x1142a2000 - 0x1142b1ff7 +com.adobe.InDesign.Alignment Panel (12.0.0.81 - 0) <AFF308EF-3A59-391B-9FA3-74CCCFF41421> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Alignment Panel.InDesignPlugin/Alignment Panel
0x1142ba000 - 0x114302ff3 +com.adobe.InDesign.Asset Library Panel (12.0.0.81 - 0) <E48DC50A-ABF0-30A9-B03B-D254B65483C4> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Asset Library Panel.InDesignPlugin/Asset Library Panel
0x114328000 - 0x114385ff7 +com.adobe.InDesign.Asset PubLibrary (12.0.0.81 - 0) <8B8FF99C-8373-30E2-85D8-C30E6DB63F8D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Asset PubLibrary.InDesignPlugin/Asset PubLibrary
0x1143a2000 - 0x1143e9ff7 +com.adobe.InDesign.Book Panel (12.0.0.81 - 0) <D454BD4B-7CA6-3F50-865F-CF9882E431CC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Book Panel.InDesignPlugin/Book Panel
0x11440e000 - 0x114427ffb +com.adobe.InDesign.Bookmark Panel (12.0.0.81 - 0) <260AF045-9FA7-3917-BA02-5C83393D0BBC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Bookmark Panel.InDesignPlugin/Bookmark Panel
0x11443d000 - 0x11446dffb +com.adobe.InDesign.ContentDropper Tool (12.0.0.81 - 0) <523536D6-2FF3-338C-B75E-8B8146F1FBCF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/ContentDropper Tool.InDesignPlugin/ContentDropper Tool
0x11448c000 - 0x1144c8ff7 +com.adobe.InDesign.Control Panel (12.0.0.81 - 0) <3A295F76-6448-3152-ADC5-AAAA2C820A50> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Control Panel.InDesignPlugin/Control Panel
0x1144e5000 - 0x1144effff +com.adobe.InDesign.Create Guides Dialog (12.0.0.81 - 0) <2F8F9DCC-6A19-3815-BDB8-48E829932D20> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Create Guides Dialog.InDesignPlugin/Create Guides Dialog
0x1144fa000 - 0x11457affb +com.adobe.InDesign.Eyedropper Tool (12.0.0.81 - 0) <A41370CA-6C66-36FD-BF95-D99F6D83E41F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Eyedropper Tool.InDesignPlugin/Eyedropper Tool
0x1145a0000 - 0x11463eff7 +com.adobe.InDesign.Hyperlinks Panel (12.0.0.81 - 0) <1E5232B0-B0C3-3DBE-85A0-0A1D450864F0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Hyperlinks Panel.InDesignPlugin/Hyperlinks Panel
0x11466a000 - 0x1146edfff +com.adobe.InDesign.Index Panel (12.0.0.81 - 0) <8850A0E9-B000-32E3-9F1C-7E66244BD3D5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Index Panel.InDesignPlugin/Index Panel
0x11470e000 - 0x114718fff +unihan (0) <54E13787-663F-3550-94EF-6CD94F63C375> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/unihan.framework/Versions/A/unihan
0x114725000 - 0x11477ffff +com.adobe.InDesign.Info Panel (12.0.0.81 - 0) <C654E51A-C1BB-3B91-B080-1C13F5769C32> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Info Panel.InDesignPlugin/Info Panel
0x114797000 - 0x114848ff7 +com.adobe.InDesign.Knowledge Base (12.0.0.81 - 0) <67013AB3-D322-3870-AC96-8DBFE1E6DFB4> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Knowledge Base.InDesignPlugin/Knowledge Base
0x114852000 - 0x11489afff +com.adobe.InDesign.Layers Panel (12.0.0.81 - 0) <5CD50EE0-12F9-3A3B-AFBC-E72B15E4B4A3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Layers Panel.InDesignPlugin/Layers Panel
0x1148bc000 - 0x1148c1ffb +com.adobe.InDesign.Layout Adjustment Panel (12.0.0.81 - 0) <81B4ADAE-08A0-3110-A059-E5FE44AA7260> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Layout Adjustment Panel.InDesignPlugin/Layout Adjustment Panel
0x1148ca000 - 0x1148e3ff3 +com.adobe.InDesign.Layout Adjustment (12.0.0.81 - 0) <8B07AB35-4130-3DEE-A69B-D23EC3B52EDA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Layout Adjustment.InDesignPlugin/Layout Adjustment
0x1148f1000 - 0x114938ff7 +com.adobe.InDesign.Links UI (12.0.0.81 - 0) <8E3849B6-A879-34F1-9C70-61E4DF95E5CC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Links UI.InDesignPlugin/Links UI
0x114959000 - 0x1149f0ffb +com.adobe.InDesign.ObjectStylesUI (12.0.0.81 - 0) <7882A96F-EC25-38F5-A2AA-7EDC55047276> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/ObjectStylesUI.InDesignPlugin/ObjectStylesUI
0x114a20000 - 0x114a4eff7 +com.adobe.InDesign.Page Setup Dialog (12.0.0.81 - 0) <ABA18DA1-6FAF-35CD-85A2-40EE9F588AEE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Page Setup Dialog.InDesignPlugin/Page Setup Dialog
0x114a65000 - 0x114b1dff3 +com.adobe.InDesign.Pages Panel (12.0.0.81 - 0) <CD4DB179-57B4-3AFB-9721-A766467FA2B4> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Pages Panel.InDesignPlugin/Pages Panel
0x114b4e000 - 0x114b60ff7 +com.adobe.InDesign.Sections UI (12.0.0.81 - 0) <0ACFD577-F66C-3FE6-945A-7A8D8A0A8B1E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Sections UI.InDesignPlugin/Sections UI
0x114b6b000 - 0x114b75ff3 +com.adobe.InDesign.StepRepeat (12.0.0.81 - 0) <0D53DD3B-9AE3-3A2C-BF1E-85C1439F6F9F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/StepRepeat.InDesignPlugin/StepRepeat
0x114b81000 - 0x114bbaff3 +com.adobe.InDesign.Text Wrap Panel (12.0.0.81 - 0) <B98A0063-961E-3B3D-AC08-4CAEFE03F971> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Text Wrap Panel.InDesignPlugin/Text Wrap Panel
0x114bd3000 - 0x114c10ff3 +com.adobe.InDesign.TOC UI Dialog (12.0.0.81 - 0) <96D0A57E-52B0-3E18-AABC-88846EFBC450> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/TOC UI Dialog.InDesignPlugin/TOC UI Dialog
0x114c29000 - 0x114c60ffb +com.adobe.InDesign.Transform Panel (12.0.0.81 - 0) <9F57DB5E-7682-35CF-B8AD-9FD68FDB42F7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Transform Panel.InDesignPlugin/Transform Panel
0x114c77000 - 0x114c96ffb +com.adobe.InDesign.OnBoarding (12.0.0 - 0) <55A5963B-431F-3BBD-8C57-CE4454B3F22C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/OnBoarding/OnBoarding.InDesignPlugin/OnBoarding
0x114ca7000 - 0x114cc0ffb +com.adobe.InDesign.Image Import UI (12.0.0.81 - 0) <A75498F0-246C-370B-B9BC-09E464E5A268> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Page Item/Image Import UI.InDesignPlugin/Image Import UI
0x114cd4000 - 0x114ce5ff7 +com.adobe.InDesign.Scotch Rules (12.0.0.81 - 0) <1AAB5DAD-E78B-36D3-943A-1FD9A3B3F6D9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Page Item/Scotch Rules.InDesignPlugin/Scotch Rules
0x114cef000 - 0x114d47ff3 +com.adobe.InDesign.BNUI (12.0.0.81 - 0) <482826D0-9C7E-33ED-A2A7-20B36B797C79> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/PMPack/BNUI.InDesignPlugin/BNUI
0x114d67000 - 0x114e04fff +com.adobe.InDesign.DataMerge (12.0.0.81 - 0) <69C991B5-F8B8-33E0-BB41-5FDFE8F8B91F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/PMPack/DataMerge.InDesignPlugin/DataMerge
0x114e23000 - 0x114e54ff3 +com.adobe.InDesign.DataMergeUI (12.0.0.81 - 0) <A0E00A91-1F26-348E-8B56-8F4E06DA9DC7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/PMPack/DataMergeUI.InDesignPlugin/DataMergeUI
0x114e6e000 - 0x114f5fffb +com.adobe.InDesign.Package and Preflight UI (12.0.0.81 - 0) <B48C25C0-2C79-3911-AE89-A83CC93CF709> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Prepress/Package and Preflight UI.InDesignPlugin/Package and Preflight UI
0x114fa0000 - 0x1151ccffb +com.adobe.InDesign.Package and Preflight (12.0.0.81 - 0) <19BF9EBB-242C-3FB4-BD0C-40DFCC3717EC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Prepress/Package and Preflight.InDesignPlugin/Package and Preflight
0x115211000 - 0x1152e7ff3 +com.adobe.InDesign.JBX (12.0.0.81 - 0) <6900A400-3AEC-32B7-94BB-098E775A3240> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Sandbox/JBX.InDesignPlugin/JBX
0x115314000 - 0x115332fff +com.adobe.InDesign.SavebackService (12.0.0 - 0) <5FA1922F-43AA-31D6-B34F-D864E0006A48> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/SavebackService/SavebackService.InDesignPlugin/SavebackService
0x115344000 - 0x11534bfff +com.adobe.InDesign.Script Label Panel (12.0.0.81 - 0) <5441E77C-2925-30E6-B9EE-26D122C99863> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Script/Script Label Panel.InDesignPlugin/Script Label Panel
0x115357000 - 0x115364ff3 +com.adobe.InDesign.Scripts Panel (12.0.0.81 - 0) <646C073B-66C5-3AEB-8B32-B77226975B9C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Script/Scripts Panel.InDesignPlugin/Scripts Panel
0x115374000 - 0x115450ff7 +com.adobe.InDesign.Tables UI (12.0.0.81 - 0) <916251FE-B080-30BD-9CF8-7DC76F9E866A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Tables/Tables UI.InDesignPlugin/Tables UI
0x115482000 - 0x115516ff3 +com.adobe.InDesign.TableStylesUI (12.0.0.81 - 0) <64AC052A-6A6A-3B01-B1A0-54434A080E08> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Tables/TableStylesUI.InDesignPlugin/TableStylesUI
0x115542000 - 0x1155e5ff3 +com.adobe.InDesign.Character Panel (12.0.0.81 - 0) <52B86336-E63C-3C8B-8C02-DD788A6B49D8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Character Panel.InDesignPlugin/Character Panel
0x115632000 - 0x11565ffff +com.adobe.InDesign.Conditional Text UI (12.0.0.81 - 0) <B232A286-B18E-3AF8-B23E-1A49C4F710DC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Conditional Text UI.InDesignPlugin/Conditional Text UI
0x11567a000 - 0x115693ff7 +com.adobe.InDesign.Create Outlines (12.0.0.81 - 0) <1E6A5942-69FD-36B9-B4BC-00247AC6C287> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Create Outlines.InDesignPlugin/Create Outlines
0x11569f000 - 0x1157aeff3 +com.adobe.InDesign.Find and Change Panel (12.0.0.81 - 0) <E4749361-65CD-36AC-AB63-57506BADFE38> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Find and Change Panel.InDesignPlugin/Find and Change Panel
0x1157eb000 - 0x115810ff3 +com.adobe.InDesign.Find Change Format Panel (12.0.0.81 - 0) <43A02721-7790-3837-B57D-8823C7FB6FD9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Find Change Format Panel.InDesignPlugin/Find Change Format Panel
0x115824000 - 0x11586aff3 +com.adobe.InDesign.Font Usage Dialog (12.0.0.81 - 0) <67DFFFFA-AC70-388F-9C7D-34EEEBFD22CD> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Font Usage Dialog.InDesignPlugin/Font Usage Dialog
0x115884000 - 0x11594dff3 +com.adobe.InDesign.Glyphs Panel (12.0.0.81 - 0) <6A589C08-D75D-3BAF-B8A2-85F1678B99BA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Glyphs Panel.InDesignPlugin/Glyphs Panel
0x115974000 - 0x11597dff3 +com.adobe.InDesign.Hyphenation Panel (12.0.0.81 - 0) <78BC5601-B711-3629-8E7D-47F543E9DE8F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Hyphenation Panel.InDesignPlugin/Hyphenation Panel
0x11598c000 - 0x11599effb +com.adobe.InDesign.Indents and Tabs (12.0.0.81 - 0) <AB0F86BB-3395-334B-8C15-FCD049DAE36F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Indents and Tabs.InDesignPlugin/Indents and Tabs
0x1159ae000 - 0x1159b7fff +com.adobe.InDesign.Justification Panel (12.0.0.81 - 0) <E25008E3-70F3-313D-9046-C286C3376747> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Justification Panel.InDesignPlugin/Justification Panel
0x1159c3000 - 0x1159caff7 +com.adobe.InDesign.Keeps Panel (12.0.0.81 - 0) <E238E435-DDD8-3964-9CEC-2781D58DDB39> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Keeps Panel.InDesignPlugin/Keeps Panel
0x1159d3000 - 0x1159f0fff +com.adobe.InDesign.Optical Kerning (12.0.0.81 - 0) <D39A4D55-B168-307F-B59E-2C2E33B22397> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Optical Kerning.InDesignPlugin/Optical Kerning
0x1159fc000 - 0x115a31ff3 +com.adobe.InDesign.Paragraph Panel (12.0.0.81 - 0) <BF29973E-2A3B-39FE-B9C2-A619FA922175> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Paragraph Panel.InDesignPlugin/Paragraph Panel
0x115a48000 - 0x115a59ffb +com.adobe.InDesign.Paragraph Rules Panel (12.0.0.81 - 0) <747B51F0-ED0B-3C52-AF34-9A030DED0500> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Paragraph Rules Panel.InDesignPlugin/Paragraph Rules Panel
0x115a64000 - 0x115a79ff7 +com.adobe.InDesign.Path Type UI (12.0.0.81 - 0) <51B47F10-C617-3B31-A967-F7EC0579D1BD> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Path Type UI.InDesignPlugin/Path Type UI
0x115a89000 - 0x115a90ff3 +PathTypeLib.dylib (0) <BBCE3A07-2FCD-381B-A79F-32AE7887A256> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/PathTypeLib.dylib
0x115a98000 - 0x115ac1ff3 +com.adobe.InDesign.RunIn Styles Panel (12.0.0.81 - 0) <B1C78260-AFD4-3927-969C-84E33F929B8D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/RunIn Styles Panel.InDesignPlugin/RunIn Styles Panel
0x115ad4000 - 0x115ae1ff3 +com.adobe.InDesign.SING (12.0.0.81 - 0) <85BA6A3D-EA1A-3344-A014-3E27088F36D5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/SING.InDesignPlugin/SING
0x115aea000 - 0x115af3fff +com.adobe.InDesign.Span Columns Panel (12.0.0.81 - 0) <5455B95B-C5F9-36C3-B16B-A499C7F942FF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Span Columns Panel.InDesignPlugin/Span Columns Panel
0x115afc000 - 0x115b43fff +com.adobe.InDesign.Spelling Panel (12.0.0.81 - 0) <72AE4F6F-7D24-3878-8EB3-47A88358FE55> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Spelling Panel.InDesignPlugin/Spelling Panel
0x115b5c000 - 0x115b6eff3 +com.adobe.InDesign.Story Panel (12.0.0.81 - 0) <6050F3FF-50B4-357E-97BA-89EACFC83576> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Story Panel.InDesignPlugin/Story Panel
0x115b7d000 - 0x115bedfff +com.adobe.InDesign.Style Panel (12.0.0.81 - 0) <1898A9F7-3D12-365E-828A-E4A11D525B5B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Style Panel.InDesignPlugin/Style Panel
0x115c17000 - 0x115c23fff +com.adobe.InDesign.Text Color Panel (12.0.0.81 - 0) <E0652271-7986-3672-87D1-6B880662EC20> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Color Panel.InDesignPlugin/Text Color Panel
0x115c2c000 - 0x115c5aff3 +com.adobe.InDesign.Text Frame Options (12.0.0.81 - 0) <9F92829C-FC99-3822-835D-F246D6B36ED9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Frame Options.InDesignPlugin/Text Frame Options
0x115c6d000 - 0x115cccff3 +com.adobe.InDesign.Text Panel (12.0.0.81 - 0) <33781C75-540B-31D7-B229-93854799337B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Panel.InDesignPlugin/Text Panel
0x115cf4000 - 0x115d13ff7 +com.adobe.InDesign.Text Preferences (12.0.0.81 - 0) <1775600D-8234-375B-AAD5-B45751A0A99D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Preferences.InDesignPlugin/Text Preferences
0x115d23000 - 0x115d44ff3 +com.adobe.InDesign.Text Ruler (12.0.0.81 - 0) <AD2F6F0D-0DE1-35DE-8AF6-4A7A93BAA691> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Ruler.InDesignPlugin/Text Ruler
0x115d57000 - 0x115d7dff3 +com.adobe.InDesign.Text Style Panel (12.0.0.81 - 0) <E255B71E-1A83-30C6-9DF4-0A98A7D73233> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Style Panel.InDesignPlugin/Text Style Panel
0x115d8e000 - 0x115db6fff +com.adobe.InDesign.Article Panel (12.0.0.81 - 0) <4CE15E7F-D2F5-3B16-925E-4E6297444B24> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Article Panel.InDesignPlugin/Article Panel
0x115dcf000 - 0x115e4dfff +com.adobe.InDesign.CSXS (12.0.0.81 - 0) <AAE722B1-9AA8-31CC-A325-2A68D0461514> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/CSXS.InDesignPlugin/CSXS
0x115e74000 - 0x115f96ffb +libExperimentationSDKRelease.dylib (0) <23E0C445-66FC-35ED-A54B-5A40893AC048> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/libExperimentationSDKRelease.dylib
0x115fa5000 - 0x115fd8ff7 +com.adobe.InDesign.Galley Preferences (12.0.0.81 - 0) <1FF9DB14-4D4C-3BE1-BD0E-C0AF7E7DC278> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Galley Preferences.InDesignPlugin/Galley Preferences
0x115ff3000 - 0x116013fff +com.adobe.InDesign.GapTool (12.0.0.81 - 0) <1771139D-0661-364D-A607-3D69AE28C250> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/GapTool.InDesignPlugin/GapTool
0x116023000 - 0x11602fffb +com.adobe.InDesign.General Preferences Panel (12.0.0.81 - 0) <C152E38C-07C8-3E9E-8590-356092E94DA2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/General Preferences Panel.InDesignPlugin/General Preferences Panel
0x11603a000 - 0x11603fffb +com.adobe.InDesign.Help (12.0.0.81 - 0) <3AB11208-2055-38CC-AFB4-22A1688C856B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Help.InDesignPlugin/Help
0x116046000 - 0x116064fff +com.adobe.ahclientframework (2.2.0.1 - 2.2.0.1) <78C9396E-DBAE-3C68-9B67-95B28F2BEC76> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x11606e000 - 0x11608bfff +com.adobe.InDesign.Performance UI (12.0.0.81 - 0) <30609330-89AD-36EA-9626-21AF508EF2B8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Performance UI.InDesignPlugin/Performance UI
0x1160a2000 - 0x1160c3fff +com.adobe.InDesign.SharedContentUI (12.0.0.81 - 0) <42971359-C170-3200-A048-84CC3378FF63> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/SharedContentUI.InDesignPlugin/SharedContentUI
0x1160d2000 - 0x1160f5fff +com.adobe.InDesign.Shortcut Editor Dialog (12.0.0.81 - 0) <C063BD03-83D2-375D-BAF1-0C90D77BAE43> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Shortcut Editor Dialog.InDesignPlugin/Shortcut Editor Dialog
0x116109000 - 0x116127ffb +com.adobe.InDesign.Tool Box (12.0.0.81 - 0) <05C6D703-B4C2-34CF-9BE9-0576966A1824> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Tool Box.InDesignPlugin/Tool Box
0x116153000 - 0x11615bff3 +com.adobe.InDesign.Tool Tips (12.0.0.81 - 0) <5F96D857-BC0A-3353-BD29-C37A2BBD0E09> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Tool Tips.InDesignPlugin/Tool Tips
0x116164000 - 0x11616dfff +com.adobe.InDesign.Track Changes Preferences (12.0.0.81 - 0) <309BBAEB-1562-3AFD-A21F-3BE1922DBAB4> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Track Changes Preferences.InDesignPlugin/Track Changes Preferences
0x116177000 - 0x11618cfff +com.adobe.InDesign.Track Changes UI (12.0.0.81 - 0) <32F6CC77-6AD6-33DC-A2D3-3A6AAB9C3FF7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Track Changes UI.InDesignPlugin/Track Changes UI
0x116197000 - 0x1161a0ff7 +com.adobe.InDesign.PerformanceMetrics (12.0.0.81 - 0) <1716F8A5-881E-3706-BE27-792A68197501> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Utility/PerformanceMetrics.InDesignPlugin/PerformanceMetrics
0x1161aa000 - 0x1161b6ff7 +com.adobe.InDesign.Metadata UI (12.0.0.81 - 0) <1EC05707-738C-3F89-A2DF-72135961933C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Workflow/Metadata UI.InDesignPlugin/Metadata UI
0x1161c1000 - 0x1164faff7 +com.adobe.dvaadameve.framework (10.0.0 - 10.0.0.0) <69E932FE-4BBA-33BF-B556-7A5BD2F296BB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
0x11683c000 - 0x1168fbffb +com.adobe.dvametadata.framework (10.0.0 - 10.0.0.0) <3860678C-074D-3979-9BF2-D245C34D0E9A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
0x116955000 - 0x116a4cffb +com.adobe.dvametadataUI.framework (10.0.0 - 10.0.0.0) <FDABABFC-15AE-301F-895B-0DEB60209DE8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
0x116adc000 - 0x116c2dfff +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.7 -f 21 - 79.159768) <F3543365-4EDE-38D9-892F-BBE8EB88C26B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
0x116c80000 - 0x116d53fff +com.adobe.dvaeve.framework (10.0.0 - 10.0.0.0) <4E2283DE-B142-3E16-A40B-8A1904BE8E40> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
0x116df2000 - 0x116e43ffb +com.adobe.dvatemporalxmp.framework (10.0.0 - 10.0.0.0) <6E5C33AA-DD95-33DE-B9D3-141ABA537C63> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
0x116e6d000 - 0x116ea8ff3 +com.adobe.dvamediatypes.framework (10.0.0 - 10.0.0.0) <9DA2A835-9D31-338C-856F-953126DB9A65> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
0x116ec5000 - 0x116ecfffb +com.adobe.InDesign.Workgroup UI (12.0.0.81 - 0) <1E81D947-5401-3ABB-99B1-DC1F3F894A25> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Workgroup/Workgroup UI.InDesignPlugin/Workgroup UI
0x116ed8000 - 0x116f1eff3 +com.adobe.InDesign.Snippet (12.0.0.81 - 0) <9445570A-6658-3AA5-8DEB-2B4A1CABD71E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/XMedia/Snippet.InDesignPlugin/Snippet
0x116f36000 - 0x11704bff3 +com.adobe.InDesign.XMedia UI (12.0.0.81 - 0) <79820244-504C-3B67-A8FD-EB017E09BEB2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/XMedia/XMedia UI.InDesignPlugin/XMedia UI
0x117095000 - 0x1170edffb +com.adobe.InDesign.Actions (12.0.0.81 - 0) <7685643D-9612-335C-B8F0-5C3067C28D1C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Actions.InDesignPlugin/Actions
0x11710a000 - 0x1172dfff7 +com.adobe.InDesign.AppFramework (12.0.0.81 - 0) <101F5C03-4DE2-3436-8256-4F6CFDB7BB40> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/AppFramework.InDesignPlugin/AppFramework
0x117380000 - 0x1175dcff3 +com.adobe.InDesign.Application UI (12.0.0.81 - 0) <C2EEFEBA-B789-330F-98DC-165435DC9C9E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Application UI.InDesignPlugin/Application UI
0x1176aa000 - 0x117844fff +com.adobe.headlights.LogSessionFramework (7.4.1.60.45263) <2116CCCF-BA38-366C-8BCE-91827BA52E6D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x117869000 - 0x117906fff +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.4) <8FF7B7E4-C344-3433-B9BB-93737EF4A825> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
0x11792e000 - 0x1179c3ff7 +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.4) <8200505F-05B7-34FF-A81C-4221C6177FAF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
0x1179ee000 - 0x117a23fff +AgoraLib.dylib (1.0.0.0) <73697218-E690-371D-9728-7883DA2051A7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AgoraLib.dylib
0x117a56000 - 0x117b63fff +com.adobe.dvascriptui.framework (7.0.6 - 7.0.6.0) <1877E9C7-F52D-3E1E-8B97-1CFB7AF55F17> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvascriptui.framework/Versions/A/dvascriptui
0x117c7f000 - 0x117ca0ff3 +com.adobe.InDesign.Article (12.0.0.81 - 0) <FBBA34E6-32BD-34B2-B075-CEC2A715595D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Article.InDesignPlugin/Article
0x117caf000 - 0x117d39ffb +com.adobe.InDesign.Assignments (12.0.0.81 - 0) <10450C5F-6D02-35F2-A20F-6A73098ACAFC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Assignments.InDesignPlugin/Assignments
0x117d59000 - 0x117d94fff +com.adobe.InDesign.AWS (12.0.0.81 - 0) <666CF5CF-E6DA-31BF-B28B-789120E97467> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/AWS.InDesignPlugin/AWS
0x117daf000 - 0x117dd7fff +com.adobe.InDesign.AWSUI (12.0.0.81 - 0) <283221E2-2C53-344E-ACEE-BF1910ACBF8A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/AWSUI.InDesignPlugin/AWSUI
0x117ded000 - 0x117e20fff +com.adobe.InDesign.Basic Tools (12.0.0.81 - 0) <026E1461-C93A-3DF2-B0B7-6A8D464209F3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Basic Tools.InDesignPlugin/Basic Tools
0x117e3d000 - 0x117e88ff7 +com.adobe.InDesign.Behavior (12.0.0.81 - 0) <6DAF0693-413B-3904-A6F1-F61A53AB867E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Behavior.InDesignPlugin/Behavior
0x117ea5000 - 0x117f2dfff +com.adobe.InDesign.BNCore (12.0.0.81 - 0) <6DDF3759-07FF-3AB3-93C7-3C1C59CF6371> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/BNCore.InDesignPlugin/BNCore
0x117f49000 - 0x117fa3ff3 +com.adobe.InDesign.Book (12.0.0.81 - 0) <F3EB3E68-595C-353A-BD3D-FA3F28C749FE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Book.InDesignPlugin/Book
0x117fba000 - 0x117fedffb +com.adobe.InDesign.CellStyles (12.0.0.81 - 0) <A0185B4A-B10E-3C7E-ABBD-D7C8F1888D99> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/CellStyles.InDesignPlugin/CellStyles
0x117fff000 - 0x11806fff3 +com.adobe.InDesign.CJK Text Attributes (12.0.0.81 - 0) <6DD053CD-EBEB-347A-B424-D4251287B516> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/CJK Text Attributes.InDesignPlugin/CJK Text Attributes
0x118091000 - 0x118107ffb +com.adobe.InDesign.CJKGrid (12.0.0.81 - 0) <72CABFFE-B9D4-31E9-9865-35077526811D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/CJKGrid.InDesignPlugin/CJKGrid
0x118123000 - 0x1181fdff7 +com.adobe.InDesign.Color Management (12.0.0.81 - 0) <BF24BFC9-54D5-3324-A4A4-BE917A35703C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Color Management.InDesignPlugin/Color Management
0x11822a000 - 0x11828bff3 +com.adobe.InDesign.CompFontMgr (12.0.0.81 - 0) <C27F5478-D4CB-3CEF-B5DF-5ED4C1344557> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/CompFontMgr.InDesignPlugin/CompFontMgr
0x1182a5000 - 0x1182f1ff7 +com.adobe.InDesign.Conditional Text (12.0.0.81 - 0) <A1D66194-ADD5-3F82-8D1B-C2C247F1F1B2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Conditional Text.InDesignPlugin/Conditional Text
0x118309000 - 0x118337fff +com.adobe.InDesign.ContentDropper (12.0.0.81 - 0) <742AB3F1-9BB4-33EC-9203-616CBBE35A51> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/ContentDropper.InDesignPlugin/ContentDropper
0x11834b000 - 0x11836eff3 +com.adobe.InDesign.Dialog Layout (12.0.0.81 - 0) <082B6C3B-5D00-3D81-A6C0-C22BE105BB4C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Dialog Layout.InDesignPlugin/Dialog Layout
0x118383000 - 0x1183a6ff3 +com.adobe.InDesign.Document Actions (12.0.0.81 - 0) <12C834A6-6B6E-304F-8C9F-0BD6416D07EB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Document Actions.InDesignPlugin/Document Actions
0x1183b3000 - 0x11857cff3 +com.adobe.InDesign.Document Framework (12.0.0.81 - 0) <EC3C1587-4DA7-3686-9FC7-34E066EFA2C6> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Document Framework.InDesignPlugin/Document Framework
0x1185bd000 - 0x1185c9ff7 +com.adobe.InDesign.Document UI (12.0.0.81 - 0) <5EE88969-8105-3260-B009-28BAAAA42D9C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Document UI.InDesignPlugin/Document UI
0x1185d4000 - 0x118629ff7 +com.adobe.InDesign.DV_Widgets (12.0.0.81 - 0) <F72BF8EF-9F38-31FD-B303-FD0BD1D36D17> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/DV_Widgets.InDesignPlugin/DV_Widgets
0x118699000 - 0x118993ff7 +com.adobe.InDesign.Dynamic Documents (12.0.0.81 - 0) <DC91CE45-51A5-34E7-B9DC-60F7398F76EC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Dynamic Documents.InDesignPlugin/Dynamic Documents
0x1189e0000 - 0x118ad7fff +com.adobe.AGMFL (AdobeAGMFL 2.1.0.32362 - 2.1.0.32362) <C93FF155-AA80-34F1-A785-42BC0D8D3909> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ADBE_AGMFL.framework/Versions/A/ADBE_AGMFL
0x118af4000 - 0x118cd1ff7 +com.adobe.AFlamingo (AFlamingo 2.4.402.31977 - 2.4.402.31977) <B90D5CA4-DA52-39A1-95DD-8011764655A1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
0x118cf5000 - 0x118e00ff7 +com.adobe.InDesign.EPS Page Item (12.0.0.81 - 0) <7CAB8473-B1E9-381D-A1B8-26F3AC4EE8D8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/EPS Page Item.InDesignPlugin/EPS Page Item
0x118e3f000 - 0x118f49fff +com.adobe.InDesign.Font Manager (12.0.0.81 - 0) <B7DE4EE6-06B2-3DD2-ABD3-B6A509B341E9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Font Manager.InDesignPlugin/Font Manager
0x118f6f000 - 0x11902eff7 +com.adobe.InDesign.FormField (12.0.0.81 - 0) <0BC6CF28-3906-34FC-98BC-71880670D6CB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/FormField.InDesignPlugin/FormField
0x119052000 - 0x1190a9ffb +com.adobe.InDesign.Galley (12.0.0.81 - 0) <88DD237D-8DA0-3E53-B7A3-DF7E1F89E1ED> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Galley.InDesignPlugin/Galley
0x1190bf000 - 0x1191f9fff +com.adobe.InDesign.GalleyUI (12.0.0.81 - 0) <3B67EE29-961F-3116-97C7-CB8E2BA9BCBC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/GalleyUI.InDesignPlugin/GalleyUI
0x11922a000 - 0x119460ff3 +com.adobe.InDesign.Generic Page Item (12.0.0.81 - 0) <F1D42D33-B76B-385E-A887-3B3A49D9C89B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Generic Page Item.InDesignPlugin/Generic Page Item
0x1194ac000 - 0x1194b6fff +com.adobe.InDesign.GenericSettings (12.0.0.81 - 0) <D498FC39-9151-3B81-873C-E98839ED6ECA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/GenericSettings.InDesignPlugin/GenericSettings
0x1194bf000 - 0x1194c3ff7 +com.adobe.InDesign.Global Preferences Panel (12.0.0.81 - 0) <9E8C6084-DA2F-3249-A420-EB2F6BD38B4C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Global Preferences Panel.InDesignPlugin/Global Preferences Panel
0x1194ca000 - 0x119527fff +com.adobe.InDesign.Gradient Fill (12.0.0.81 - 0) <10CA39FE-BDB4-3A76-BFFB-FF61F0ADDDB2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Gradient Fill.InDesignPlugin/Gradient Fill
0x119542000 - 0x11961bff3 +com.adobe.InDesign.Graphics (12.0.0.81 - 0) <EDDEF96D-3BE6-3101-BD53-589192880A9B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Graphics.InDesignPlugin/Graphics
0x11963f000 - 0x119649ff3 +com.adobe.InDesign.Group (12.0.0.81 - 0) <0F029429-BF95-39A5-AA15-0091AF98C9E8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Group.InDesignPlugin/Group
0x119655000 - 0x119671ff3 +com.adobe.InDesign.Guides (12.0.0.81 - 0) <1D8B98E3-E0E4-3F48-A1BF-56D945BA4048> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Guides.InDesignPlugin/Guides
0x119682000 - 0x119753ffb +com.adobe.InDesign.HTMLPGT (12.0.0.81 - 0) <95EC760C-8AB4-396C-B05D-42922C57C816> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/HTMLPGT.InDesignPlugin/HTMLPGT
0x1197ac000 - 0x119890ff3 +com.adobe.InDesign.Hyperlinks (12.0.0.81 - 0) <69B1A7B5-B5F9-3AFE-8E7E-31FDB0C7AE7E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Hyperlinks.InDesignPlugin/Hyperlinks
0x1198bb000 - 0x11990aff3 +com.adobe.InDesign.Image Filters (12.0.0.81 - 0) <96B65FD6-2B2C-3FC9-AF45-FFFFDC3A24B0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Image Filters.InDesignPlugin/Image Filters
0x119916000 - 0x119a12fff +com.adobe.InDesign.Image (12.0.0.81 - 0) <B6BB788F-2326-3561-B4F5-D9B3E322225E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Image.InDesignPlugin/Image
0x119a3e000 - 0x119a55ff7 +com.adobe.InDesign.IME (12.0.0.81 - 0) <31F9511D-BFB0-3159-994A-B1EB694C7787> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/IME.InDesignPlugin/IME
0x119a67000 - 0x119b25ff3 +com.adobe.InDesign.Import Export UI (12.0.0.81 - 0) <46836589-899F-31D1-9DA8-E858D0224540> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Import Export UI.InDesignPlugin/Import Export UI
0x119b5a000 - 0x119c42ff7 +com.adobe.InDesign.InCopyShared (12.0.0.81 - 0) <BA4F24E6-82D6-3A68-99BE-7101DFF10839> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/InCopyShared.InDesignPlugin/InCopyShared
0x119c6e000 - 0x119c8aff3 +com.adobe.InDesign.InCopySharedUI (12.0.0.81 - 0) <5199569E-C5FE-3430-94D7-BFEC9B33032B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/InCopySharedUI.InDesignPlugin/InCopySharedUI
0x119c9c000 - 0x119d1fffb +com.adobe.InDesign.InCopyWorkflow (12.0.0.81 - 0) <4BB4B4C0-6C29-3246-9E5A-E5E97B94B7E2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/InCopyWorkflow.InDesignPlugin/InCopyWorkflow
0x119d45000 - 0x119e2aff3 +com.adobe.InDesign.Indexing (12.0.0.81 - 0) <6ABBFBEA-2284-319B-AB27-F9F7C63784A0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Indexing.InDesignPlugin/Indexing
0x119e4b000 - 0x119f01ffb +com.adobe.InDesign.INXCore (12.0.0.81 - 0) <2E006BD3-2579-31A1-A19D-621E1C18464F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/INXCore.InDesignPlugin/INXCore
0x119f2a000 - 0x119f50ffb +com.adobe.InDesign.Layer (12.0.0.81 - 0) <D42D9074-AFAA-386B-A126-E9498E36C864> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Layer.InDesignPlugin/Layer
0x119f63000 - 0x11a1b5ff7 +com.adobe.InDesign.Layout UI (12.0.0.81 - 0) <EA035A95-B098-3503-8438-2987602EB8D3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Layout UI.InDesignPlugin/Layout UI
0x11a239000 - 0x11a25fff7 +com.adobe.InDesign.Layout (12.0.0.81 - 0) <A17B43CD-24E4-309B-B256-3659AE03C60E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Layout.InDesignPlugin/Layout
0x11a26f000 - 0x11a2b3ff7 +com.adobe.InDesign.Linguistics (12.0.0.81 - 0) <294B8364-0C29-3D8C-B81F-C976E2BF596A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Linguistics.InDesignPlugin/Linguistics
0x11a2cc000 - 0x11a426ff3 +com.adobe.InDesign.Links (12.0.0.81 - 0) <0B8E6573-1959-307C-8B5E-E9CB3C79D9D3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Links.InDesignPlugin/Links
0x11a467000 - 0x11a4f5ff7 +com.adobe.InDesign.Master Page (12.0.0.81 - 0) <31799670-C224-3E5A-9340-C9F050FA3C97> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Master Page.InDesignPlugin/Master Page
0x11a50e000 - 0x11a558fff +com.adobe.InDesign.Media (12.0.0.81 - 0) <FB410EBE-BA9B-3C25-A2E9-30CDE0CADA29> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Media.InDesignPlugin/Media
0x11a56d000 - 0x11a5deffb +com.adobe.InDesign.Metadata (12.0.0.81 - 0) <76536F65-1692-3BB0-8009-A6AF6512A2A0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Metadata.InDesignPlugin/Metadata
0x11a5fa000 - 0x11a60effb +com.adobe.InDesign.Movie (12.0.0.81 - 0) <4F1B30F2-1358-3359-AEC3-DD6C94C0592C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Movie.InDesignPlugin/Movie
0x11a61c000 - 0x11a65aff3 +com.adobe.InDesign.Open Place (12.0.0.81 - 0) <8DFC5411-650B-30D3-9C82-0902C8460981> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Open Place.InDesignPlugin/Open Place
0x11a670000 - 0x11a71fff7 +com.adobe.InDesign.Paragraph Composer (12.0.0.81 - 0) <9B630291-ADF4-3A58-90F6-B0A1CBEFB3BA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Paragraph Composer.InDesignPlugin/Paragraph Composer
0x11a72f000 - 0x11a766fff +com.adobe.InDesign.Path Type (12.0.0.81 - 0) <5FF9C9DE-D9DB-3894-BF5A-8A4CB6850782> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Path Type.InDesignPlugin/Path Type
0x11a77f000 - 0x11a9bffff +com.adobe.InDesign.PDF (12.0.0.81 - 0) <30A6D0A1-D537-3B74-8170-67518615A972> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/PDF.InDesignPlugin/PDF
0x11aa06000 - 0x11aac6ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.36529) <759A9903-5910-3051-ABB6-CE6EBF18FF7E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x11aaea000 - 0x11abdcffb +com.adobe.PDFPort (AdobePDFPort 2.1.0.36974 - 2.1.0.36974) <EBC47077-B30C-3D9D-B624-73D1CDB07ED6> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
0x11abef000 - 0x11ac12ff3 +com.adobe.PDFSettings (AdobePDFSettings 1.07.0 - 1.7) <EE5AD335-1E84-381D-B433-32C95C5DEF4A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
0x11ac1d000 - 0x11ac58ff7 +com.adobe.InDesign.Photoshop Import Filter (12.0.0.81 - 0) <118529C5-FB6F-39F7-8123-07A352985D15> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Photoshop Import Filter.InDesignPlugin/Photoshop Import Filter
0x11ac6b000 - 0x11e2e1f8f +com.adobe.psl (AdobePSL 15.1.0.36906 - 15.1.0.36906) <104EE3CA-51E9-3F6B-A079-3E87BE36552D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
0x11e7d5000 - 0x11e7d7ff7 com.apple.textencoding.unicode (3.0 - 3.0) <B8CEE380-5919-3519-8088-119C65562EE9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x11e9fd000 - 0x11ea37ff3 +com.adobe.InDesign.PNG Import Filter (12.0.0.81 - 0) <42EBA308-5BC3-3E8A-ACAC-830496A5D0A9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/PNG Import Filter.InDesignPlugin/PNG Import Filter
0x11ea47000 - 0x11ebafff3 +com.adobe.InDesign.Print (12.0.0.81 - 0) <9C4B95B0-87FA-39B7-89BE-7DB4101ADF7F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Print.InDesignPlugin/Print
0x11ebdd000 - 0x11ec04ff7 +com.adobe.InDesign.Rulers (12.0.0.81 - 0) <D01BC512-274E-3FE1-8173-6065EAC0142E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Rulers.InDesignPlugin/Rulers
0x11ec19000 - 0x11ecb8ff7 +com.adobe.InDesign.Scripting (12.0.0.81 - 0) <DE3CC19F-B7C7-3EEE-B8CB-F1BBCAB3F298> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Scripting.InDesignPlugin/Scripting
0x11ecd8000 - 0x11ecf8fff +com.adobe.InDesign.Sections (12.0.0.81 - 0) <58D9D77C-B150-343B-B3BB-31A99873A461> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Sections.InDesignPlugin/Sections
0x11ed08000 - 0x11ed7cff7 +com.adobe.InDesign.SharedContent (12.0.0.81 - 0) <58ADA84E-7697-3958-924D-8DF7700612DF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/SharedContent.InDesignPlugin/SharedContent
0x11ed9d000 - 0x11eda8ffb +com.adobe.InDesign.Sound (12.0.0.81 - 0) <CE10C26A-F59F-312E-BEF3-05D0D9F40FA9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Sound.InDesignPlugin/Sound
0x11edb4000 - 0x11edc3ff3 +com.adobe.InDesign.Spelling Service (12.0.0.81 - 0) <126134BE-7999-381B-9D69-C3A61218F125> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Spelling Service.InDesignPlugin/Spelling Service
0x11edd1000 - 0x11ee15ffb +com.adobe.InDesign.Spline UI (12.0.0.81 - 0) <550C322B-B264-3596-BCCA-1993EFBB0076> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Spline UI.InDesignPlugin/Spline UI
0x11ee32000 - 0x11ee73fff +com.adobe.InDesign.Spline (12.0.0.81 - 0) <04630691-6029-32BA-B508-47ECE76BF2D1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Spline.InDesignPlugin/Spline
0x11ee8b000 - 0x11eeecff3 +com.adobe.InDesign.Spread UI (12.0.0.81 - 0) <9EE5CB84-2902-3FEA-8CEF-6097048EFF2F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Spread UI.InDesignPlugin/Spread UI
0x11ef0e000 - 0x11f029ff7 +com.adobe.InDesign.Spread (12.0.0.81 - 0) <3A084E49-7BE9-32A8-8F13-746C4E96903B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Spread.InDesignPlugin/Spread
0x11f05a000 - 0x11f0acff7 +com.adobe.InDesign.Stroke and Fill (12.0.0.81 - 0) <ED6E5B60-FE5C-3B0B-8788-6A396D4DE3F8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Stroke and Fill.InDesignPlugin/Stroke and Fill
0x11f0c3000 - 0x11f11afff +com.adobe.InDesign.Support for AppleScript (12.0.0.81 - 0) <DA7AB65F-4203-30C6-9353-D34D522EA04E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Support for AppleScript.InDesignPlugin/Support for AppleScript
0x11f131000 - 0x11f1beff3 +com.adobe.InDesign.Support for JavaScript (12.0.0.81 - 0) <BFD2572F-E62E-37F7-A559-36D88581BB4A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Support for JavaScript.InDesignPlugin/Support for JavaScript
0x11f1ea000 - 0x11f25affb +com.adobe.InDesign.SVGExport (12.0.0.81 - 0) <F796556D-AB44-33AB-A48F-9E0DA49B7864> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/SVGExport.InDesignPlugin/SVGExport
0x11f274000 - 0x11f332fff +com.adobe.SVGExport (AdobeSVGExport 6.0 - 6.0) <2FAB4B9A-EDB9-0FF9-55B2-52DEC380D2BF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeSVGExport.framework/Versions/A/AdobeSVGExport
0x11f355000 - 0x11f568fff +com.adobe.InDesign.Table Model (12.0.0.81 - 0) <E13EFBA3-5D81-3562-8C07-E9CE06BD5D72> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Table Model.InDesignPlugin/Table Model
0x11f5ab000 - 0x11f5fbff3 +com.adobe.InDesign.TableStyles (12.0.0.81 - 0) <977B6A65-0C07-307B-A20A-A0FFA2BC4F16> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/TableStyles.InDesignPlugin/TableStyles
0x11f60d000 - 0x11f650ffb +com.adobe.InDesign.Text Attributes (12.0.0.81 - 0) <CB83D8A8-3990-32F3-8978-97B1E7A43B4B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Attributes.InDesignPlugin/Text Attributes
0x11f66a000 - 0x11f67dfff +com.adobe.InDesign.Text Editor Model (12.0.0.81 - 0) <3BC234FF-11C5-39AB-AF73-8A76877E839F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Editor Model.InDesignPlugin/Text Editor Model
0x11f688000 - 0x11f76cfff +com.adobe.InDesign.Text Editor (12.0.0.81 - 0) <8F0E0DB4-0701-3AEE-B5FD-529D652C335F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Editor.InDesignPlugin/Text Editor
0x11f7a4000 - 0x11f920ff3 +com.adobe.InDesign.Text Walker (12.0.0.81 - 0) <28EC1749-88D4-34D6-824B-728D2DFA435F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Walker.InDesignPlugin/Text Walker
0x11f971000 - 0x11f991ff3 +com.adobe.InDesign.Text Wrap Path (12.0.0.81 - 0) <B36BAA42-AE34-3732-8502-22BEEB208F88> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Wrap Path.InDesignPlugin/Text Wrap Path
0x11f99a000 - 0x11f9feff3 +com.adobe.InDesign.Text Wrap (12.0.0.81 - 0) <5BCB14B7-B4E5-313D-B287-747D89D84B29> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Wrap.InDesignPlugin/Text Wrap
0x11fa17000 - 0x11ffcdfff +com.adobe.InDesign.Text (12.0.0.81 - 0) <166E1D01-FB9D-331C-8A29-5D5FB37770EC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text.InDesignPlugin/Text
0x120070000 - 0x1200cafff +com.adobe.InDesign.TOC (12.0.0.81 - 0) <5943DCFC-3FDA-3D02-BFF2-57A6DEB14506> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/TOC.InDesignPlugin/TOC
0x1200dd000 - 0x120201fff +com.adobe.InDesign.Transparency (12.0.0.81 - 0) <D8201F77-76DC-3830-BF6E-3107FF232C98> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Transparency.InDesignPlugin/Transparency
0x12022b000 - 0x12024bffb +com.adobe.InDesign.Utilities (12.0.0.81 - 0) <95BBD18D-E95E-3413-8FDE-BDCB67D323B5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Utilities.InDesignPlugin/Utilities
0x120265000 - 0x120351ff7 +com.adobe.InDesign.Widgets (12.0.0.81 - 0) <7D6492A1-D0D8-3835-A213-C4722EB72969> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Widgets.InDesignPlugin/Widgets
0x1203cb000 - 0x1203d3ff7 +com.adobe.InDesign.Workgroup Client UI (12.0.0.81 - 0) <95C6F351-6EBA-3D48-8C1C-4B985ADA4D5B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Workgroup Client UI.InDesignPlugin/Workgroup Client UI
0x1203d9000 - 0x1203f5fff +com.adobe.InDesign.Workgroup Client (12.0.0.81 - 0) <08C19498-76C7-3CE6-AC0B-34DF38142967> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Workgroup Client.InDesignPlugin/Workgroup Client
0x120403000 - 0x120436fff +com.adobe.InDesign.Workgroup (12.0.0.81 - 0) <22C9733E-28D9-3C7B-A660-4D3D9ED4D3C1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Workgroup.InDesignPlugin/Workgroup
0x120445000 - 0x120469ff3 +com.adobe.InDesign.WorldReady (12.0.0.81 - 0) <20026D60-96B0-36FC-B459-3E4BF1C0A600> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/WorldReady.InDesignPlugin/WorldReady
0x120479000 - 0x120670fff +com.adobe.InDesign.XML (12.0.0.81 - 0) <062983B6-26DF-397F-9FF5-C57D2D5B2F83> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/XML.InDesignPlugin/XML
0x1206ba000 - 0x120785ff7 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.36783 - 3.8.0.36783) <EE56856F-5988-38F6-B748-F9E07288D7E9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
0x120799000 - 0x1207efff7 +com.adobe.InDesign.XMLParser (12.0.0.81 - 0) <7B8946CF-5EA5-3E99-95D9-1272B9B55E6E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/XMLParser.InDesignPlugin/XMLParser
0x120804000 - 0x1208b3ff7 +com.adobe.AXEXSLT (AdobeAXSLE 3.8.0.36783 - 3.8.0.36783) <96EEFBFD-FA69-3B1D-B74A-46F207AA1EFA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeAXSLE.framework/Versions/A/AdobeAXSLE
0x1213f6000 - 0x12141cff7 +com.adobe.ape (3.4.0.29366 - 3.4.0.29366) <40A59819-7A57-0E9F-658D-1803B2A461AE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/adbeapecore.framework/adbeapecore
0x12142f000 - 0x12157afff +IMSLib.dylib (10.0.0.11 - 10.0.0.11) <21D0C981-4447-364F-AAAA-F64A310F55B4> /Library/Application Support/Adobe/*/IMSLib.dylib
0x12159b000 - 0x121615ff7 com.apple.xquery (1.3.1 - 30) <C1020441-B131-3995-86D9-9D0B725D3FAD> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
0x121913000 - 0x121929ff7 +com.adobe.AdobeSFL (AdobeSFL 1.1.0.36043 - 1.1.0.36043) <049C1233-3D7E-38C6-9A14-4DF92626AB51> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
0x122b15000 - 0x122bbafff ColorSyncDeprecated.dylib (470.3) <A30CB963-667F-39D0-8537-66FCC820F5A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x123ee8000 - 0x123f9cff7 com.apple.AMDRadeonX4000GLDriver (1.42.15 - 1.4.2) <578CDCA4-1CE6-3E56-8D65-6319C49901FE> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/AMDRadeonX4000GLDriver
0x12411c000 - 0x12421eff7 com.apple.AMDMTLBronzeDriver (1.42.15 - 1.4.2) <88937E6A-81B0-3079-9BD7-12EED4FC9ABA> /System/Library/Extensions/AMDMTLBronzeDriver.bundle/Contents/MacOS/AMDMTLBronzeDriver
0x12433f000 - 0x12481afff ATIRadeonX4000SCLib.dylib (1.42.15) <66B1764C-35D8-343B-8350-8B9EEBC7DFBB> /System/Library/Extensions/AMDRadeonX4000GLDriver.bundle/Contents/MacOS/ATIRadeonX4000SCLib.dylib
0x1248a5000 - 0x12492dfff com.apple.applescript (2.5 - 377) <B280DAC6-E614-3AC0-81B5-C2F1E994514B> /System/Library/PrivateFrameworks/AppleScript.framework/Versions/A/AppleScript
0x7fff62438000 - 0x7fff6246fa47 dyld (360.22) <884763FC-CC0F-31CC-ACC4-75A805CE401D> /usr/lib/dyld
0x7fff83031000 - 0x7fff83039fff libGFXShared.dylib (12.1) <FFB3BBDE-0AE4-3570-B9F4-1BC093F8777A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff8303a000 - 0x7fff83184ff7 com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff83185000 - 0x7fff8318dfff com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff8318e000 - 0x7fff8318eff7 libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
0x7fff832be000 - 0x7fff8330afff com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff83342000 - 0x7fff8334dfff libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff83420000 - 0x7fff83420fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <848125D3-AF14-3526-8745-FFCDB200CD76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff83424000 - 0x7fff83482fff com.apple.SystemConfiguration (1.14 - 1.14) <8886E043-B668-3A49-BCA5-F89FB0ECB6EC> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff834bf000 - 0x7fff834c7fff com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff834de000 - 0x7fff8351fff7 libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff83520000 - 0x7fff83520fff com.apple.CoreServices (728.13 - 728.13) <E3DFECD2-ECEA-3242-972D-95B9646B57B8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff83521000 - 0x7fff83610ff7 libxml2.2.dylib (29.11) <DBAD6C6D-DF50-32E0-A621-F556DFD12A71> /usr/lib/libxml2.2.dylib
0x7fff83622000 - 0x7fff83630fff libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
0x7fff83631000 - 0x7fff83634ffb libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
0x7fff8365b000 - 0x7fff8365cff3 com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff8369d000 - 0x7fff836c6ff7 libxpc.dylib (765.50.8) <54D1328E-054E-3DAA-89E2-375722F9D18F> /usr/lib/system/libxpc.dylib
0x7fff838b3000 - 0x7fff838b4fff libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
0x7fff838ba000 - 0x7fff83ac5fff libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
0x7fff83ac8000 - 0x7fff83ad0ffb libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib
0x7fff83ad1000 - 0x7fff846faff7 com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff846ff000 - 0x7fff847dfff7 unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
0x7fff847e0000 - 0x7fff847efffb com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff847f1000 - 0x7fff84c1ffff com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff84c20000 - 0x7fff84c20fff libmetal_timestamp.dylib (600.0.44.2) <DEEA1127-7A5D-3EF2-A4B2-AE125CBA5DB5> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fff85300000 - 0x7fff85377ff7 com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
0x7fff85378000 - 0x7fff8548afef libvDSP.dylib (563.5) <5702650E-DF08-3D58-B16F-9EF0A28702B3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff85494000 - 0x7fff8549ffff libkxld.dylib (3248.60.11.2.1) <9DFD804D-B16C-379C-8986-2D8781DFAEAE> /usr/lib/system/libkxld.dylib
0x7fff854e3000 - 0x7fff854e9ff7 com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff854ea000 - 0x7fff8553bfff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff8553c000 - 0x7fff85556fff com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff85557000 - 0x7fff85574ff7 com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <7B26B7D9-AEB3-3DEC-B4AD-B49BC0FD1082> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff85575000 - 0x7fff8559efff com.apple.ProtectedCloudStorage (1.0 - 1) <7436B2B3-943A-3500-B099-80F133B3E002> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff8559f000 - 0x7fff855cdff7 com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff855ce000 - 0x7fff85629ff7 libTIFF.dylib (1460) <37D499DA-A4A6-3CC8-8F60-F374F992C304> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff8562a000 - 0x7fff85648ff7 libsystem_kernel.dylib (3248.60.11.2.1) <19B06617-EDC1-3925-8A09-BC775F3D6A08> /usr/lib/system/libsystem_kernel.dylib
0x7fff85649000 - 0x7fff8565fff7 libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff85660000 - 0x7fff85661fff liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
0x7fff85662000 - 0x7fff85665ffb libdyld.dylib (360.22) <F103B2FB-D383-38CB-992A-E16BDCB00A03> /usr/lib/system/libdyld.dylib
0x7fff85686000 - 0x7fff856faff7 com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff867e5000 - 0x7fff867eaff7 libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
0x7fff867eb000 - 0x7fff867fffff com.apple.CoreDuetDaemonProtocol (1.0 - 1) <1D60D60C-914A-3BAB-8607-79F68F4C712E> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff86800000 - 0x7fff86837ff7 com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff868e5000 - 0x7fff86972dd7 com.apple.AppleJPEG (1.0 - 1) <BF7EDBDB-A52D-37F7-BDE4-EAD49310D7A9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff86973000 - 0x7fff869c3ff7 com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff86bc2000 - 0x7fff87038ff7 com.apple.CoreFoundation (6.9 - 1259) <51D1F34F-9FEC-3EF2-8382-2D13D75F845A> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff87044000 - 0x7fff871eaff7 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff871ee000 - 0x7fff871f7fff com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x7fff872e3000 - 0x7fff876e5fff libLAPACK.dylib (1162.2) <42238ED4-6B7A-39D0-BFF2-304A0C287213> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff876e6000 - 0x7fff876e9ff7 libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff87748000 - 0x7fff877aeff7 libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib
0x7fff877af000 - 0x7fff87a49ff3 com.apple.security (7.0 - 57337.60.2) <E2E553E7-28C4-3296-B3B6-BB1B3CA73943> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff87a4a000 - 0x7fff87a61ff7 libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
0x7fff87a67000 - 0x7fff87c30ff7 com.apple.ImageIO.framework (3.3.0 - 1460) <A436D5E1-64E3-33A1-9403-DC63E7809285> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff87c61000 - 0x7fff87d08fff com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff87d0b000 - 0x7fff87d16fff libGPUSupportMercury.dylib (12.1) <28957CBD-2E85-3D1E-9750-757F2A893FCA> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fff87d17000 - 0x7fff87d18fff libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff87f66000 - 0x7fff87fd5fff com.apple.datadetectorscore (7.0 - 460) <E8616F01-90AC-3863-B18C-426E6DD1ACDE> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff87fd6000 - 0x7fff87fd8fff libCVMSPluginSupport.dylib (12.1) <C503A29A-D3AE-3935-8E0D-69C575684B60> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff87fdf000 - 0x7fff87fe0ffb libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
0x7fff880cd000 - 0x7fff8824bfff com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff88268000 - 0x7fff88281fff com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff882b4000 - 0x7fff882bffff com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff882c0000 - 0x7fff882c3fff libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff882d1000 - 0x7fff882fcffb libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
0x7fff88573000 - 0x7fff885c4ff7 libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib
0x7fff885eb000 - 0x7fff885f0fff com.apple.DiskArbitration (2.7 - 2.7) <F55902AA-5316-3255-A701-FDED5B553065> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff89773000 - 0x7fff8986fff7 libFontParser.dylib (158.6) <267A9AE4-4138-3112-8D73-BDFDC96568FF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff89901000 - 0x7fff899e7ff7 libcrypto.0.9.8.dylib (59.60.1) <D68067AD-D1E0-3196-9796-51BE9B969C8E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff899f9000 - 0x7fff89c9fff7 com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff89ca0000 - 0x7fff89ca1fff libffi.dylib (18.1) <5BA9612C-747E-33CE-9DB1-3C01ECF3041D> /usr/lib/libffi.dylib
0x7fff89ca2000 - 0x7fff89cf5ff7 libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
0x7fff8a0ba000 - 0x7fff8a0e9ff7 com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff8a0ea000 - 0x7fff8a0f2fff com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff8a0f3000 - 0x7fff8a127ff7 com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff8a128000 - 0x7fff8a136fff com.apple.opengl (12.1.0 - 12.1.0) <62997B59-BCD2-3A71-BD16-DE75DBAFA7C2> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff8a367000 - 0x7fff8a37afff com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff8a37b000 - 0x7fff8a381fff com.apple.IOAccelerator (205.11 - 205.11) <C51BF724-F8E8-3B9F-806E-A00C65056445> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff8a382000 - 0x7fff8a81dffb com.apple.GeoServices (1.0 - 1151.49.1) <2D887517-B73D-30FF-91DC-AF6AD91F96B9> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff8a85a000 - 0x7fff8a865ff7 libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
0x7fff8a894000 - 0x7fff8a89efff com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8afda000 - 0x7fff8afe3ff7 com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff8b051000 - 0x7fff8b0a3fff com.apple.CloudDocs (1.0 - 383.13) <5FD9138D-09D9-3B97-BBAD-5692E1687F30> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff8b0c3000 - 0x7fff8b17dfff com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff8b17e000 - 0x7fff8b1b1ff7 com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff8b1cc000 - 0x7fff8b358ff7 libGLProgrammability.dylib (12.1) <CAE9E2B5-7E37-337C-8C84-4F449C237494> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff8b37a000 - 0x7fff8b37cfff libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
0x7fff8b37d000 - 0x7fff8b37ffff libCGXType.A.dylib (960.7) <F52CB9D5-B366-3A93-B1E6-81B583675B19> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff8b3bb000 - 0x7fff8b40aff7 com.apple.opencl (2.7.0 - 2.7.0) <07FB8F36-A00C-3BFD-BC38-9E4EC484907E> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff8b40b000 - 0x7fff8b426ff7 libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
0x7fff8b427000 - 0x7fff8b446ff7 com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff8b455000 - 0x7fff8b4b3fff com.apple.CoreServices.OSServices (728.13 - 728.13) <27C12B92-7845-38DD-B82D-DC5B678352D6> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff8b4b4000 - 0x7fff8b4b9ff7 libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
0x7fff8b4ba000 - 0x7fff8b573ff7 com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff8b589000 - 0x7fff8b58afff libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
0x7fff8b58d000 - 0x7fff8b5dbff7 libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
0x7fff8b709000 - 0x7fff8b725ff3 libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
0x7fff8bae3000 - 0x7fff8bafcfff com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff8bccd000 - 0x7fff8bd42fff com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff8bd94000 - 0x7fff8bda0fff com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff8bda1000 - 0x7fff8bdadff7 com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff8bdae000 - 0x7fff8be22ff3 com.apple.securityfoundation (6.0 - 55126) <DAA4FDD0-7F84-30AA-BE6F-96BB9F871F07> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff8be23000 - 0x7fff8d089ff3 com.apple.CoreGraphics (1.600.0 - 960.7) <61850A83-03A8-33D0-8A9B-3DC57177DFB3> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff8d0a2000 - 0x7fff8d0a4ff7 libRadiance.dylib (1460) <FE5180D2-115B-3B7C-8F90-CF352BCC38F3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff8d302000 - 0x7fff8d3e8fef unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x7fff8d41a000 - 0x7fff8d627fff libicucore.A.dylib (551.51.4) <3899B146-3840-3D4A-8C4A-FE391D5D25C7> /usr/lib/libicucore.A.dylib
0x7fff8d6a3000 - 0x7fff8d795ff7 libJP2.dylib (1460) <7FD6231B-EDB9-377F-87F0-ED1C6EDC6F21> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff8d7dc000 - 0x7fff8d7deff7 com.apple.xpc.ServiceManagement (1.0 - 1) <D96D7A6D-EDEB-35EE-B5D9-E33A3BF011B5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff8d7e5000 - 0x7fff8d87afff com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff8d87f000 - 0x7fff8d938ff7 libvMisc.dylib (563.5) <BF612F7D-FA3B-3F9F-8BE7-8D1BCB21ECC5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff8d9e2000 - 0x7fff8da2eff7 com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff8da2f000 - 0x7fff8da3fff3 com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff8da77000 - 0x7fff8dae2ff7 com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff8dae3000 - 0x7fff8dd04ff7 com.apple.CoreImage (11.4.0 - 366.4.20) <7721BA55-A10E-3425-8392-C5D7C510EAAB> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff8dd35000 - 0x7fff8dd5fff7 libc++abi.dylib (307.2) <922EFB36-0E9E-315B-8270-E81AC43472C0> /usr/lib/libc++abi.dylib
0x7fff8e06d000 - 0x7fff8e22dffb libBLAS.dylib (1162.2) <B4C21826-5EB3-3C6D-B75D-CA4886E2B6A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff8eac9000 - 0x7fff8eacdfff libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
0x7fff8ee0e000 - 0x7fff8ee12fff libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
0x7fff8ee13000 - 0x7fff8ee38ff7 libPng.dylib (1460) <2A9174D0-445A-3AD9-8141-D602E9A1D735> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8ee51000 - 0x7fff8effcffb GLEngine (12.1) <F7DBE3F9-3187-33D6-A3F4-BDF99CE9D425> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff8f01c000 - 0x7fff8f02dff7 libsystem_trace.dylib (201.10.3) <E9311C03-9E61-3B13-AF3F-A64956FFF269> /usr/lib/system/libsystem_trace.dylib
0x7fff8f02e000 - 0x7fff8f02eff7 liblaunch.dylib (765.50.8) <834ED605-5114-3641-AA4D-ECF31B801C50> /usr/lib/system/liblaunch.dylib
0x7fff8f02f000 - 0x7fff8f14cfff libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
0x7fff8f17b000 - 0x7fff8f2a8ff3 com.apple.CoreText (352.0 - 494.12) <ADBE8355-D4F5-3316-A6C4-D641D615CEC4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff8f341000 - 0x7fff8f365fff com.apple.MultitouchSupport.framework (304.12 - 304.12) <25FA270C-361D-3732-ABF5-A291240AD6A4> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff8f50a000 - 0x7fff8f5aefff com.apple.Bluetooth (4.4.6 - 4.4.6f1) <4072EA3E-F2DD-32C1-9B19-9339C7087051> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff8f693000 - 0x7fff8f6c0fff libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
0x7fff8f6c1000 - 0x7fff8f716fff com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff9019f000 - 0x7fff901c8ff7 libxslt.1.dylib (14.4) <72CD1CA4-1FBD-3672-ADCE-A89AB741689A> /usr/lib/libxslt.1.dylib
0x7fff901c9000 - 0x7fff9045ffff libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
0x7fff9052a000 - 0x7fff90895657 libobjc.A.dylib (680) <D55D5807-1FBE-32A5-9105-44D7AFE68C27> /usr/lib/libobjc.A.dylib
0x7fff90936000 - 0x7fff90974ff7 libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff90975000 - 0x7fff9097eff3 libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
0x7fff9098f000 - 0x7fff90997fef libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
0x7fff90ac8000 - 0x7fff90acafff com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff90acb000 - 0x7fff90ad3fff libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
0x7fff9115e000 - 0x7fff9116cff7 libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
0x7fff91266000 - 0x7fff91280ff3 liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
0x7fff91281000 - 0x7fff912f8feb libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib
0x7fff912f9000 - 0x7fff912f9fff com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff9142e000 - 0x7fff91430ffb libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
0x7fff9144a000 - 0x7fff91466ff7 libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
0x7fff91b3b000 - 0x7fff91b4dfff libsasl2.2.dylib (209) <11C7D200-0CA5-30F4-A19A-178CA81D48FE> /usr/lib/libsasl2.2.dylib
0x7fff91b4e000 - 0x7fff91bd6fff com.apple.CoreSymbolication (3.1 - 58048.1) <1A6BF14E-55F3-324E-81DB-BB22B9C288AE> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff91bd7000 - 0x7fff91bf0fe7 libcompression.dylib (28) <F83F421D-115D-3457-A9AA-1BEB5070A30B> /usr/lib/libcompression.dylib
0x7fff92146000 - 0x7fff92238ff7 libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
0x7fff92240000 - 0x7fff92248fff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff92249000 - 0x7fff92249fff libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
0x7fff92262000 - 0x7fff92338ffb com.apple.DiskImagesFramework (10.11.4 - 417.4) <B9525D22-6F0D-39C5-BA9B-9DF195FE1968> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff923c1000 - 0x7fff9240ffff libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
0x7fff92d45000 - 0x7fff92d6efff libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib
0x7fff92dff000 - 0x7fff92e9ffff com.apple.Metadata (10.7.0 - 972.34) <5F407CB0-3244-3A15-8000-82DDB0420244> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff92ed9000 - 0x7fff92ee1fef libcldcpuengine.dylib (2.7.3) <6A6B8893-5A77-3014-9780-D3681DC0A08B> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff92f69000 - 0x7fff92f80ff7 libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
0x7fff92f81000 - 0x7fff92f83ff7 libquarantine.dylib (80) <0F4169F0-0C84-3A25-B3AE-E47B3586D908> /usr/lib/system/libquarantine.dylib
0x7fff92f84000 - 0x7fff92f86ff7 libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
0x7fff92f87000 - 0x7fff92fa3ff7 libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
0x7fff931e1000 - 0x7fff931f6ff3 libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff93214000 - 0x7fff93219fff com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff934c9000 - 0x7fff934f0fff com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff934fd000 - 0x7fff93535ff7 com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff93538000 - 0x7fff93538fff libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
0x7fff93539000 - 0x7fff93541fff libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
0x7fff93919000 - 0x7fff939a2ff7 com.apple.PerformanceAnalysis (1.0 - 1) <07DC8D32-56AF-3AD3-83D8-9DC413BA8C2F> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff93a10000 - 0x7fff93b1eff3 com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff93b1f000 - 0x7fff93b41fff com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff93b42000 - 0x7fff93b6cff7 GLRendererFloat (12.1) <15894300-8350-343F-942D-6D168BFFDB13> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff93cfe000 - 0x7fff93d8bfef libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib
0x7fff93faa000 - 0x7fff93fbafff com.apple.AppleScriptObjC (1.4 - 32) <0C137AF5-9086-3205-9895-F3B8DF3B47FF> /System/Library/Frameworks/AppleScriptObjC.framework/Versions/A/AppleScriptObjC
0x7fff93fbb000 - 0x7fff94000ff7 com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff94001000 - 0x7fff94003fff com.apple.CoreDuetDebugLogging (1.0 - 1) <7C932160-AC9C-3173-900F-98138E829CB3> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff94004000 - 0x7fff944c2fcf com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff945ab000 - 0x7fff945b0ff7 com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
0x7fff945b5000 - 0x7fff945b9fff com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff9460b000 - 0x7fff946a1fff com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff94b21000 - 0x7fff94cefff3 com.apple.QuartzCore (1.11 - 410.14) <3CEA7616-63A9-3B69-B6A8-476BF6D3F58B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff94f48000 - 0x7fff94f48fff com.apple.Accelerate (1.10 - Accelerate 1.10) <5831771A-C1C3-3625-9FE9-2CCB6B2E7EE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff94f49000 - 0x7fff9522effb com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff95388000 - 0x7fff953b1ffb libRIP.A.dylib (960.7) <6C9E6C2C-62FD-32E6-AEB8-564A3510B17A> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff953b2000 - 0x7fff953b3ffb libSystem.B.dylib (1226.10.1) <012548CD-614D-3AF0-B3B1-676F427D2CD6> /usr/lib/libSystem.B.dylib
0x7fff953b4000 - 0x7fff953c5ff7 libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
0x7fff9545c000 - 0x7fff95467ff7 libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
0x7fff954b4000 - 0x7fff954b5fff com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff954b6000 - 0x7fff954fcff7 libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
0x7fff9552f000 - 0x7fff95553ff7 libJPEG.dylib (1460) <82AF76D7-B3E6-39AA-947E-C34A280FD1CF> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff95554000 - 0x7fff955c2ff7 com.apple.ApplicationServices.ATS (377 - 394.4) <9779E916-0788-3CAC-B1EC-F68BCB12A2B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff955ce000 - 0x7fff955ceff7 libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
0x7fff95601000 - 0x7fff95604fff com.apple.IOSurface (108.2.3 - 108.2.3) <52E51D16-42E9-3DDB-A16C-48225EF262C4> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff95605000 - 0x7fff9560efff com.apple.IOAccelMemoryInfo (1.0 - 1) <5938394C-EAF4-37C7-A335-62D9A5DEC196> /System/Library/PrivateFrameworks/IOAccelMemoryInfo.framework/Versions/A/IOAccelMemoryInfo
0x7fff9560f000 - 0x7fff95614fff com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff95615000 - 0x7fff956a4ff7 libCoreStorage.dylib (517.50.1) <E6283FE9-B5AC-3110-8D4C-8E2BF185983E> /usr/lib/libCoreStorage.dylib
0x7fff956a5000 - 0x7fff956a7fff com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff956c4000 - 0x7fff956c4fff com.apple.audio.units.AudioUnit (1.13 - 1.13) <378B5292-F216-32AB-B628-8C33A72D7052> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff956e1000 - 0x7fff95712fff com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff96053000 - 0x7fff9606ffff com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff96070000 - 0x7fff9607cfff com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff960a6000 - 0x7fff960b6fff libSparseBLAS.dylib (1162.2) <6F591A0F-80D0-384D-8304-B035C4ED1BBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff960b7000 - 0x7fff9616fff7 com.apple.CoreDuet (1.0 - 1) <FC1EAEE1-73A4-3B13-A634-1D2A94D0C0B7> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff96170000 - 0x7fff961b2ff7 com.apple.Metal (56.6 - 56.6) <30518711-8D00-3759-AA19-800D3C88E693> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff96233000 - 0x7fff9626dfff com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff96d6f000 - 0x7fff96dbbffb com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff96dbc000 - 0x7fff96dc5ff7 libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
0x7fff96dcb000 - 0x7fff970c0fff com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff970c1000 - 0x7fff97353ffb com.apple.RawCamera.bundle (6.21 - 879) <4F0A10FB-7C96-31E8-9A70-E30F615B2565> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff97354000 - 0x7fff973c3fff com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff973c4000 - 0x7fff97409ff3 libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff97561000 - 0x7fff975c8fff com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff975c9000 - 0x7fff975dafff libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
0x7fff975ed000 - 0x7fff975efff7 com.apple.securityhi (9.0 - 55006) <1E7BE52B-97EA-371A-AECA-1EE2AD246D8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff9761e000 - 0x7fff976cefff com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff977a4000 - 0x7fff977abff7 libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
0x7fff977ac000 - 0x7fff977afff7 com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff977e6000 - 0x7fff97b3afff com.apple.Foundation (6.9 - 1259) <71A9D3A0-0B1F-3E3A-86F3-1486365A6EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff97f83000 - 0x7fff97f9afff libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
0x7fff97f9b000 - 0x7fff97fcdff7 libTrueTypeScaler.dylib (158.6) <469A7620-3B6F-3E06-80A7-8D89E5DD9C81> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff97fd9000 - 0x7fff97fdeff3 libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
0x7fff97fdf000 - 0x7fff9800effb libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
0x7fff98173000 - 0x7fff9829afff com.apple.LaunchServices (728.13 - 728.13) <DF9A69C3-06AD-3062-A40A-50ED12CA18CA> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff987e5000 - 0x7fff987e9fff libGIF.dylib (1460) <DEF81CFC-35F0-3BE3-9D53-F269B72AA619> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff98884000 - 0x7fff988beff7 com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff98a8f000 - 0x7fff98a8ffff com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff98a96000 - 0x7fff98ab8ff7 com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff98e34000 - 0x7fff98e3ffff libcsfde.dylib (517.50.1) <52F0DB6A-13B8-355E-ADFD-72834D3CA183> /usr/lib/libcsfde.dylib
0x7fff99602000 - 0x7fff99889fff com.apple.CFNetwork (760.6.3 - 760.6.3) <8CB9CB2E-D0FB-31D4-A1AE-2A5FE028AD6B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff998e2000 - 0x7fff998f2fff libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
0x7fff99919000 - 0x7fff9991cfff libsystem_sandbox.dylib (460.60.2) <2A68B39C-B786-3A05-87A2-56E688469FB8> /usr/lib/system/libsystem_sandbox.dylib
0x7fff9997f000 - 0x7fff9997ffff com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 3
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 1274
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=519.9M resident=0K(0%) swapped_out_or_unallocated=519.9M(100%)
Writable regions: Total=527.6M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=527.6M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate.framework 128K 2
Activity Tracing 2048K 2
CG backing stores 13.1M 7
CG image 24K 6
CG shared images 464K 15
CoreAnimation 124K 21
CoreUI image data 1000K 9
CoreUI image file 192K 4
Dispatch continuations 32.0M 2
Image IO 1744K 29
Kernel Alloc Once 8K 3
MALLOC 414.0M 113
MALLOC guard page 32K 7
MALLOC_LARGE (reserved) 7180K 2 reserved VM address space (unallocated)
Memory Tag 242 12K 2
Memory Tag 249 156K 3
OpenCL 8K 2
Process Corpse Info 2048K 2
STACK GUARD 56.2M 43
Stack 28.4M 48
VM_ALLOCATE 3284K 11
__DATA 41.6M 780
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__LINKEDIT 127.4M 325
__TEXT 392.5M 550
__UNICODE 552K 2
mapped file 68.2M 34
shared memory 16.4M 11
TOTAL 1.2G 2010
TOTAL, minus reserved VM space 1.2G 2010
Model: MacPro6,1, BootROM MP61.0116.B21, 8 processors, 8-Core Intel Xeon E5, 3 GHz, 32 GB, SMC 2.20f18
Graphics: AMD FirePro D700, AMD FirePro D700, PCIe, 6144 MB
Memory Module: DIMM1, 8 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343147553741465238432D52442020
Memory Module: DIMM2, 8 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343147553741465238432D52442020
Memory Module: DIMM3, 8 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343147553741465238432D52442020
Memory Module: DIMM4, 8 GB, DDR3 ECC, 1866 MHz, 0x80AD, 0x484D54343147553741465238432D52442020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x135), Broadcom BCM43xx 1.0 (7.21.95.175.1a6)
Bluetooth: Version 4.4.6f1 17910, 3 services, 27 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en2
PCI Card: AMD FirePro D700, Display Controller, Slot-1
PCI Card: AMD FirePro D700, Display Controller, Slot-2
PCI Card: Apple 57761-B0, Ethernet Controller, Thunderbolt@77,0,0
PCI Card: pci11c1,5901, IEEE 1394 Open HCI, Thunderbolt@76,0,0
PCI Card: pci12d8,400e, USB Open Host Controller, Thunderbolt@82,0,0
PCI Card: pci12d8,400e, USB Open Host Controller, Thunderbolt@82,0,1
PCI Card: pci12d8,400f, USB Enhanced Host Controller, Thunderbolt@82,0,2
Serial ATA Device: APPLE SSD SM1024F, 1 TB
USB Device: USB 2.0 Bus
USB Device: Hub
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: Hub
USB Device: LaCie Rugged FW/USB
USB Device: FaceTime HD Camera (Display)
USB Device: Apple Thunderbolt Display
USB Device: Display Audio
USB Device: USB 3.0 Bus
USB Device: FreeAgent GoFlex
USB Device: UJ-846S F20002/10/06FE3J
Thunderbolt Bus: Mac Pro, Apple Inc., 19.2
Thunderbolt Device: Thunderbolt Display, Apple Inc., 3, 26.2
There are two specific fixes for InDesign CC 2017 crashes. Try these:
1. Please try the steps mentioned at this troubleshooting page https://helpx.adobe.com/indesign/kb/crash-hyperlinks-panel-quick-apply.html
2. Navigate to Preference->Advance Type -> Type Contextual Controls and disable the first preference “show for Character Alternates, Fractions, Ordinals and Ligatures” or both the preferences.
Excellent, thank you, Steve! That was incredible helpful
Hi I am having the same issue and tried the "Advanced Type" tip but the file I am trying to open still crashes InDesign. What else can I try? I have already rebuilt the preferences folder, saved the file in .idml and .inx but nothing seems to be working. I am almost positive that it is a font issue but I cannot resolve this one for some reason. Can you help? Here is my latest crash report:
Process: Adobe InDesign CC 2017 [5314]
Path: /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Adobe InDesign CC 2017
Identifier: com.adobe.InDesign
Version: 12.1.0.56 (12100)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: Adobe InDesign CC 2017 [5314]
User ID: 501
Date/Time: 2017-07-07 13:38:27.767 -0400
OS Version: Mac OS X 10.11.6 (15G1510)
Report Version: 11
Anonymous UUID: 710B3085-AD43-DCD3-4E6D-1F1087633B7D
Sleep/Wake UUID: 20F24DF2-CEC4-446A-A2DE-DD4AE44CD9B2
Time Awake Since Boot: 18000 seconds
Time Since Wake: 1300 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
abort() called
*** error for object 0x7fedaf775ff8: incorrect checksum for freed object - object was probably modified after being freed.
Global Trace Buffer (reverse chronological seconds):
6.208192 libextension.dylib 0x00007fff91029533 tearing down extension request for pid 5346
6.208277 libextension.dylib 0x00007fff91029533 tearing down extension request for pid 5347
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff9a12ff06 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fff962144ec pthread_kill + 90
2 libsystem_c.dylib 0x00007fff936776df abort + 129
3 libsystem_malloc.dylib 0x00007fff9ee2c396 szone_error + 626
4 libsystem_malloc.dylib 0x00007fff9ee1f817 tiny_malloc_from_free_list + 347
5 libsystem_malloc.dylib 0x00007fff9ee1e705 szone_malloc_should_clear + 292
6 libsystem_malloc.dylib 0x00007fff9ee1e5a1 malloc_zone_malloc + 71
7 libsystem_malloc.dylib 0x00007fff9ee1d0cc malloc + 42
8 PMRuntime.dylib 0x0000000111a79a64 0x111a77000 + 10852
9 PMRuntime.dylib 0x0000000111a79b6e 0x111a77000 + 11118
10 PMRuntime.dylib 0x0000000111a78608 MemoryPool::Allocate(unsigned long long, void*) + 72
11 PublicLib.dylib 0x00000001115a4427 0x111501000 + 668711
12 com.adobe.CoolType 0x0000000111b28c8b CTCleanup + 1557
13 com.adobe.CoolType 0x0000000111accf27 0x111ab8000 + 85799
14 com.adobe.CoolType 0x0000000111abfeb0 0x111ab8000 + 32432
15 com.adobe.CoolType 0x0000000111c85e45 CTCleanup + 1431503
16 com.adobe.CoolType 0x0000000111c816d8 CTCleanup + 1413218
17 com.adobe.CoolType 0x0000000111c820c8 CTCleanup + 1415762
18 com.adobe.CoolType 0x0000000111c6ce7c CTCleanup + 1329158
19 com.adobe.CoolType 0x0000000111c85fc5 CTCleanup + 1431887
20 com.adobe.CoolType 0x0000000111c85cdc CTCleanup + 1431142
21 com.adobe.CoolType 0x0000000111ac70bf 0x111ab8000 + 61631
22 com.adobe.CoolType 0x0000000111bb8523 CTCleanup + 589485
23 com.adobe.CoolType 0x0000000111b8e8de CTCleanup + 418408
24 com.adobe.CoolType 0x0000000111b17edf 0x111ab8000 + 392927
25 com.adobe.InDesign.Optical Kerning 0x000000011ed0f0f6 0x11ed0a000 + 20726
26 com.adobe.InDesign.Optical Kerning 0x000000011ed0efc0 0x11ed0a000 + 20416
27 com.adobe.InDesign.Optical Kerning 0x000000011ed16b1c 0x11ed0a000 + 51996
28 com.adobe.InDesign.Optical Kerning 0x000000011ed17c05 0x11ed0a000 + 56325
29 com.adobe.InDesign.Optical Kerning 0x000000011ed0dd1a 0x11ed0a000 + 15642
30 com.adobe.InDesign.Optical Kerning 0x000000011ed0cef7 0x11ed0a000 + 12023
31 com.adobe.InDesign.Optical Kerning 0x000000011ed0b898 0x11ed0a000 + 6296
32 com.adobe.InDesign.Optical Kerning 0x000000011ed0b713 0x11ed0a000 + 5907
33 com.adobe.InDesign.Optical Kerning 0x000000011ed0c3f4 0x11ed0a000 + 9204
34 com.adobe.InDesign.Paragraph Composer 0x0000000123a9856d 0x123a09000 + 587117
35 com.adobe.InDesign.Paragraph Composer 0x0000000123a27595 0x123a09000 + 124309
36 com.adobe.InDesign.Paragraph Composer 0x0000000123a22149 0x123a09000 + 102729
37 com.adobe.InDesign.Paragraph Composer 0x0000000123a1e623 0x123a09000 + 87587
38 com.adobe.InDesign.Paragraph Composer 0x0000000123a5694e 0x123a09000 + 317774
39 com.adobe.InDesign.Paragraph Composer 0x0000000123a57536 0x123a09000 + 320822
40 com.adobe.InDesign.Paragraph Composer 0x0000000123a6265f 0x123a09000 + 366175
41 com.adobe.InDesign.Paragraph Composer 0x0000000123a64ded 0x123a09000 + 376301
42 com.adobe.InDesign.Paragraph Composer 0x0000000123a0e48e 0x123a09000 + 21646
43 com.adobe.InDesign.Paragraph Composer 0x0000000123a11369 0x123a09000 + 33641
44 com.adobe.InDesign.Paragraph Composer 0x0000000123a0a6df 0x123a09000 + 5855
45 com.adobe.InDesign.Text 0x000000012919b140 0x128db4000 + 4092224
46 com.adobe.InDesign.Text 0x0000000128f70bd8 0x128db4000 + 1821656
47 com.adobe.InDesign.Text 0x0000000128f3a4c5 0x128db4000 + 1598661
48 com.adobe.InDesign.Text 0x0000000128f3a40e 0x128db4000 + 1598478
49 com.adobe.InDesign.Package and Preflight 0x000000011e3ed500 0x11e2d0000 + 1168640
50 com.adobe.InDesign.Package and Preflight 0x000000011e3ecd25 0x11e2d0000 + 1166629
51 com.adobe.InDesign.Package and Preflight 0x000000011e3ad3cd 0x11e2d0000 + 906189
52 com.adobe.InDesign.Package and Preflight 0x000000011e3b38a0 0x11e2d0000 + 932000
53 com.adobe.InDesign.Package and Preflight 0x000000011e3af9cb 0x11e2d0000 + 915915
54 com.adobe.InDesign.Package and Preflight 0x000000011e3bb212 0x11e2d0000 + 963090
55 com.adobe.InDesign.Package and Preflight 0x000000011e3bbf43 0x11e2d0000 + 966467
56 com.adobe.InDesign.AppFramework 0x00000001204f3ab1 0x120486000 + 449201
57 com.adobe.InDesign.AppFramework 0x00000001204f33e1 0x120486000 + 447457
58 com.adobe.InDesign.Application UI 0x000000012088a9f8 0x1206fc000 + 1632760
59 com.apple.AppKit 0x00007fff8d6acdf2 -[NSApplication run] + 796
60 com.adobe.exo.framework 0x0000000112ca8a38 exo::app::OS_AppBase::RunEventLoop() + 56
61 com.adobe.InDesign.AppFramework 0x00000001205e0423 0x120486000 + 1418275
62 com.adobe.InDesign.AppFramework 0x00000001205df07a 0x120486000 + 1413242
63 com.adobe.InDesign 0x000000010fec5961 main + 513
64 libdyld.dylib 0x00007fff949305ad start + 1
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff9a130efa kevent_qos + 10
1 libdispatch.dylib 0x00007fff8d572165 _dispatch_mgr_invoke + 216
2 libdispatch.dylib 0x00007fff8d571dcd _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x00007fff9a1305e2 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff96211578 _pthread_wqthread + 1283
2 libsystem_pthread.dylib 0x00007fff9620f341 start_wqthread + 13
Thread 3:: com.apple.NSURLConnectionLoader
0 libsystem_kernel.dylib 0x00007fff9a129f72 mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff9a1293b3 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff8d13b114 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff8d13a5dc __CFRunLoopRun + 1356
4 com.apple.CoreFoundation 0x00007fff8d139e28 CFRunLoopRunSpecific + 296
5 com.apple.CFNetwork 0x00007fff9b7f7a6d +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
6 com.apple.Foundation 0x00007fff9ad70f24 __NSThread__start__ + 1351
7 libsystem_pthread.dylib 0x00007fff9621199d _pthread_body + 131
8 libsystem_pthread.dylib 0x00007fff9621191a _pthread_start + 168
9 libsystem_pthread.dylib 0x00007fff9620f351 thread_start + 13
Thread 4:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff9a13007a __select + 10
1 com.apple.CoreFoundation 0x00007fff8d17845a __CFSocketManager + 762
2 libsystem_pthread.dylib 0x00007fff9621199d _pthread_body + 131
3 libsystem_pthread.dylib 0x00007fff9621191a _pthread_start + 168
4 libsystem_pthread.dylib 0x00007fff9620f351 thread_start + 13
Thread 5:: VulcanMsgRecv
0 libsystem_kernel.dylib 0x00007fff9a12ffba __recvfrom + 10
1 VulcanMessage5.dylib 0x0000000114ea39a8 0x114e85000 + 125352
2 VulcanMessage5.dylib 0x0000000114ea2d6c 0x114e85000 + 122220
3 VulcanMessage5.dylib 0x0000000114ea2064 0x114e85000 + 118884
4 VulcanMessage5.dylib 0x0000000114ea1f28 0x114e85000 + 118568
5 VulcanMessage5.dylib 0x0000000114e9cb67 0x114e85000 + 97127
6 VulcanMessage5.dylib 0x0000000114e9d5f6 0x114e85000 + 99830
7 VulcanMessage5.dylib 0x0000000114e9cf8f 0x114e85000 + 98191
8 VulcanMessage5.dylib 0x0000000114ea1014 0x114e85000 + 114708
9 VulcanMessage5.dylib 0x0000000114ea0a6d 0x114e85000 + 113261
10 VulcanMessage5.dylib 0x0000000114ea075a 0x114e85000 + 112474
11 VulcanMessage5.dylib 0x0000000114ea06ad 0x114e85000 + 112301
12 VulcanMessage5.dylib 0x0000000114e92b5a 0x114e85000 + 56154
13 VulcanMessage5.dylib 0x0000000114e91f01 0x114e85000 + 52993
14 VulcanMessage5.dylib 0x0000000114ea18ac 0x114e85000 + 116908
15 VulcanMessage5.dylib 0x0000000114ea37a9 0x114e85000 + 124841
16 libsystem_pthread.dylib 0x00007fff9621199d _pthread_body + 131
17 libsystem_pthread.dylib 0x00007fff9621191a _pthread_start + 168
18 libsystem_pthread.dylib 0x00007fff9620f351 thread_start + 13
Thread 6:
0 libsystem_kernel.dylib 0x00007fff9a12fdb6 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff96212728 _pthread_cond_wait + 767
2 com.adobe.InDesign.AppFramework 0x00000001205ca331 0x120486000 + 1327921
3 com.adobe.InDesign.AppFramework 0x00000001205c9898 0x120486000 + 1325208
4 com.adobe.InDesign.AppFramework 0x00000001205c6c15 0x120486000 + 1313813
5 com.adobe.InDesign.AppFramework 0x00000001205cc629 0x120486000 + 1336873
6 com.adobe.boost_threads.framework 0x00000001114c641a boost::thread::start_thread_noexcept() + 410
Thread 7:
Thread 8:
0 libsystem_kernel.dylib 0x00007fff9a13010a __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff93698d0f nanosleep + 199
2 com.adobe.InDesign.Support for JavaScript 0x0000000128525498 0x1284cd000 + 361624
3 com.adobe.InDesign.Support for JavaScript 0x000000012850c64c 0x1284cd000 + 259660
4 com.adobe.InDesign.Support for JavaScript 0x00000001285250e1 0x1284cd000 + 360673
5 libsystem_pthread.dylib 0x00007fff9621199d _pthread_body + 131
6 libsystem_pthread.dylib 0x00007fff9621191a _pthread_start + 168
7 libsystem_pthread.dylib 0x00007fff9620f351 thread_start + 13
Thread 9:
5 com.apple.Foundation 0x00007fff9ae77fd5 -[NSConnection run] + 149
Thread 10:: CEPMonitorThread
5 com.apple.Foundation 0x00007fff9ae09e5d -[NSConcreteTask waitUntilExit] + 205
6 com.adobe.PlugPlugOwl 0x000000011310ea8b 0x11306b000 + 670347
7 com.apple.Foundation 0x00007fff9ad70f24 __NSThread__start__ + 1351
8 libsystem_pthread.dylib 0x00007fff9621199d _pthread_body + 131
9 libsystem_pthread.dylib 0x00007fff9621191a _pthread_start + 168
10 libsystem_pthread.dylib 0x00007fff9620f351 thread_start + 13
Thread 11:
Thread 12:
Thread 13:
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
0 libsystem_kernel.dylib 0x00007fff9a129fae semaphore_wait_trap + 10
1 libtbb.dylib 0x0000000113354d99 tbb::internal::concurrent_queue_base_v3::internal_pop(void*) + 537
2 com.adobe.InDesign.Layout UI 0x000000012341bca9 0x1232fa000 + 1186985
3 com.adobe.boost_threads.framework 0x00000001114c641a boost::thread::start_thread_noexcept() + 410
4 libsystem_pthread.dylib 0x00007fff9621199d _pthread_body + 131
5 libsystem_pthread.dylib 0x00007fff9621191a _pthread_start + 168
6 libsystem_pthread.dylib 0x00007fff9620f351 thread_start + 13
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:: CEPMonitorThread
Thread 38:
Thread 39:: CEPMonitorThread
Thread 40:
3 com.adobe.InDesign.AppFramework 0x00000001205c995f 0x120486000 + 1325407
Thread 41:
2 com.adobe.headlights.LogSessionFramework 0x0000000120b89ccc 0x120a31000 + 1412300
3 com.adobe.headlights.LogSessionFramework 0x0000000120b885ef 0x120a31000 + 1406447
4 com.adobe.headlights.LogSessionFramework 0x0000000120b36059 0x120a31000 + 1069145
5 com.adobe.headlights.LogSessionFramework 0x0000000120b04cfb 0x120a31000 + 867579
6 com.adobe.headlights.LogSessionFramework 0x0000000120b87969 0x120a31000 + 1403241
Thread 42:
Thread 43:: MPSupport Worker
2 MultiProcessor Support 0x0000000135f816fb 0x135f3a000 + 292603
3 MultiProcessor Support 0x0000000135f8161b 0x135f3a000 + 292379
4 MultiProcessor Support 0x0000000135fa3bed 0x135f3a000 + 433133
Thread 44:: MPSupport Worker
Thread 45:: MPSupport Worker
Thread 46:: MPSupport Worker
Thread 47:: MPSupport Worker
Thread 48:: MPSupport Worker
Thread 49:: MPSupport Worker
Thread 50:: MPSupport Worker
Thread 51:: MPSupport Worker
Thread 52:: MPSupport Worker
Thread 53:: MPSupport Worker
Thread 54:: MPSupport Worker
Thread 55:: MPSupport Worker
Thread 56:: MPSupport Worker
Thread 57:: MPSupport Worker
Thread 58:
Thread 59:
Thread 60:
Thread 61:
Thread 62:
Thread 63:
Thread 64:
Thread 65:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x00007fff4fd38318 rdx: 0x0000000000000000
rdi: 0x000000000000160b rsi: 0x0000000000000006 rbp: 0x00007fff4fd38340 rsp: 0x00007fff4fd38318
r8: 0x00000000fffffff0 r9: 0x0000000000000010 r10: 0x0000000008000000 r11: 0x0000000000000206
r12: 0x0000000000000001 r13: 0x000000012a4ca000 r14: 0x00007fff7ce2a000 r15: 0x000000010fee0000
rip: 0x00007fff9a12ff06 rfl: 0x0000000000000206 cr2: 0x00007fff7c979008
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x10fec4000 - 0x10fecdff7 +com.adobe.InDesign (12.1.0.56 - 12100) <7D9D89A7-7C4A-32A9-B36E-626242C10277> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Adobe InDesign CC 2017
0x10fed7000 - 0x10fedafff +com.adobe.InDesign.InDesignModelAndUI (9.0 - 0) <06FAAAD4-669A-34EF-9365-7FB3F8FC95DE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/InDesignModelAndUI.framework/Versions/A/InDesignModelAndUI
0x10fee5000 - 0x10feefff7 +com.adobe.coretech.adobesplashkit (AdobeSplashKit Version 1.0 - 1.0) <B55F1CEC-518C-3999-A4A9-23C883871DAE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeSplashKit.framework/Versions/A/AdobeSplashKit
0x10fefe000 - 0x10ff0cffb +ASLSupportLib.dylib (0) <B1F022D3-52B3-33AA-BF3B-B7A294D7A97C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/ASLSupportLib.dylib
0x10ff1e000 - 0x110019fff +DV_WidgetBinLib.dylib (0) <7E63DC53-B6ED-3218-AD8D-5EC90B848B50> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/DV_WidgetBinLib.dylib
0x110163000 - 0x1101a3ff7 +TextPanelLib.dylib (0) <AB51E420-C2AE-3FA3-9E95-E296EAABB90F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/TextPanelLib.dylib
0x1101c2000 - 0x110309ffb +WidgetBinLib.dylib (0) <39A5DFC2-575E-3C93-83E9-57BA0341A01A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/WidgetBinLib.dylib
0x1103cf000 - 0x110557fff +com.adobe.owl (AdobeOwl version 5.2.9 - 5.2.9) <1B071A30-BA84-3E3F-8A54-F152F1911194> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
0x1105a6000 - 0x1108bcff3 +com.adobe.dvacore.framework (11.0.0 - 11.0.0.0) <0AF05961-5832-304C-BE7D-5E2577836FD9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x11099d000 - 0x110fe1fff +com.adobe.dvaui.framework (11.0.0 - 11.0.0.0) <67CB4B7B-83D2-3A0C-903E-C0D532146FDC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x1114b8000 - 0x1114b8ff7 +com.adobe.InDesign.InDesignModel (9.0 - 0) <3ABCBBC9-5789-363A-A6D5-BB29AFBBAA47> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/InDesignModel.framework/Versions/A/InDesignModel
0x1114c4000 - 0x1114d2ff7 +com.adobe.boost_threads.framework (11.0.0 - 11.0.0.0) <B73D6065-556B-3AD6-900A-803D7BF1BDDB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
0x1114e4000 - 0x1114e5ffb +com.adobe.boost_system.framework (11.0.0 - 11.0.0.0) <27097AC9-14AD-3510-8BD6-6B69494489CA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
0x1114ed000 - 0x1114f1fff +com.adobe.boost_date_time.framework (11.0.0 - 11.0.0.0) <D0154E96-3135-3A27-AA36-FF8E600FE2C3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
0x1114fa000 - 0x1114fbfff +com.adobe.InDesign.Metadata Database Filter (12.1.0.56 - 0) <129ADE28-84B3-355D-949D-5C58B89DFCA2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Metadata Database Filter.InDesignPlugin/Metadata Database Filter
0x111501000 - 0x111920fff +PublicLib.dylib (0) <4E2DA26D-51AC-3638-881F-DC7ABEE3A4DE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/PublicLib.dylib
0x111a77000 - 0x111a82ffb +PMRuntime.dylib (0) <F704ADAD-42F1-3680-9F4A-7C0578EC3608> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/PMRuntime.dylib
0x111a8f000 - 0x111aa3fff +com.adobe.AFL (AdobeAFL 3.0.0 - 3.0) <63034C19-9D73-37B9-8D6C-230270E2F172> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeAFL.framework/Versions/A/AdobeAFL
0x111ab8000 - 0x111dacfff +com.adobe.CoolType (AdobeCoolType 5.15.00.37194 - 5.15.00.37194) <342B9526-C99A-3A1C-B3B3-9D50B8CF30F7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
0x111dfe000 - 0x111e1afff +com.adobe.BIB (AdobeBIB 1.2.03.37194 - 1.2.03.37194) <5B62D9F4-7012-3C7E-B821-31B38A101F3F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
0x111e27000 - 0x111f73ffb +com.adobe.ACE (AdobeACE 2.20.02.37194 - 2.20.02.37194) <EC655948-66DE-39ED-9A50-424511FC81DC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
0x111f8b000 - 0x11272dff3 +com.adobe.AGM (AdobeAGM 4.30.60.1 - 4.30.60.1) <B901C7AC-C443-3047-AEA2-09D75632AE63> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
0x1127ef000 - 0x112821fff +com.adobe.ARE (AdobeARE 1.5.02.37194 - 1.5.02.37194) <E8DA9835-2FDB-3FDD-9212-88BB7A098F62> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
0x11282e000 - 0x112851ffb +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <6FDFDB79-CE33-30EE-8056-D76B4D52B6EF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
0x11285a000 - 0x112bc0ff7 +com.adobe.MPS (AdobeMPS 5.8.1.37738 - 5.8.1.37738) <160FBCB6-8141-3B4E-80E3-E8F753BA2EE8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
0x112c3a000 - 0x112c73ff7 +com.adobe.dvaflashview.framework (11.0.0 - 11.0.0.0) <6970A25A-4D7E-3646-9996-B63ECD0E0311> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
0x112c94000 - 0x112c98ff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <B9447EE8-6F91-9E85-C163-96600BF70764> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
0x112ca0000 - 0x112d55ffb +com.adobe.exo.framework (11.0.0 - 11.0.0.0) <A27D895E-D15F-3F46-94CA-5A01B0436B31> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/exo.framework/Versions/A/exo
0x112e19000 - 0x112f51ff3 +com.adobe.dvaworkspace.framework (11.0.0 - 11.0.0.0) <8A56675D-1916-30C5-91FE-443FA9DBEB82> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
0x11306b000 - 0x1132f0fc3 +com.adobe.PlugPlugOwl (7.0.0.95 - 7.0.0.95) <6CD618E0-69A1-3A37-AC15-6FB4AEEE0499> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
0x113353000 - 0x11338afe7 +libtbb.dylib (0) <57385823-CF98-3366-B55F-B454BCC39B7A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/libtbb.dylib
0x1133ca000 - 0x1133cafff com.apple.applescript.component (2.5 - 377) <D205C65F-E27A-3D14-9F22-B8224F2C657C> /System/Library/Components/AppleScript.component/Contents/MacOS/AppleScript
0x1133d1000 - 0x1133f4ff7 +libtbbmalloc.dylib (0) <2D49758A-80A5-33B2-AF4F-315DD0761657> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/libtbbmalloc.dylib
0x11342c000 - 0x114171fff +com.adobe.ICUData (4.0 - 3.61) <8726D6A3-3921-3AB2-94D5-062E9EA297DB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
0x114189000 - 0x1142a3ff7 +com.adobe.ICUInternationalization (4.0 - 3.61) <36984DC1-7D78-3AB5-9891-CA6ACD116AEE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/ICUInternationalization
0x1142f8000 - 0x1143e9ff7 +com.adobe.ICUUnicode (4.0 - 3.61) <431F0368-6F63-3B0D-A215-D6866EEACA9A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
0x114424000 - 0x114552ff7 +com.winsoft.wrservices (WRServices 12.2.0 - 12.2.0) <201C682B-309D-31E2-AEE2-B27E62945339> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
0x11459c000 - 0x1146a2fff +com.adobe.amtlib (10.0.0.119 - 10.0.0.119) <53139645-73AD-3787-AEE6-579FABE39250> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
0x1146b8000 - 0x114855fff +libtypekitC4Release.dylib (0) <7FEA19BD-1A22-3C50-99D3-345F5C3C2F5D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/libtypekitC4Release.dylib
0x11487a000 - 0x11487dfff +com.adobe.AdobeCrashReporter (7.3 - 7.4.0) <AC1EBE59-1242-3933-A0C8-EC1D73CD2C26> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
0x11488b000 - 0x11493eff7 +com.adobe.boost_regex.framework (11.0.0 - 11.0.0.0) <CA797BE1-B534-338C-9977-64B210FE8705> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
0x11499a000 - 0x114a94ff7 +com.adobe.adobe_caps (adobe_caps 10.0.0.6 - 10.0.0.6) <F42B5047-A935-3B78-9F9A-F4841C6DEE88> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
0x114aa6000 - 0x114ab2ff3 +com.adobe.boost_filesystem.framework (11.0.0 - 11.0.0.0) <59376A9F-17E9-3BC4-AEE2-8957460769B0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
0x114abe000 - 0x114ad8fff +com.adobe.dvaunittesting.framework (11.0.0 - 11.0.0.0) <257F4E67-D99C-378C-8C10-1FCC00AED05A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
0x114af2000 - 0x114afdfff +com.adobe.boost_signals.framework (11.0.0 - 11.0.0.0) <5D646DA9-E532-320C-9593-EC7E18FA3258> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
0x114b0f000 - 0x114b13fff com.apple.agl (3.3.1 - AGL-3.3.1) <2FC3E30C-5370-3369-B8D1-1C7050A4A85A> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x114b1b000 - 0x114c4efff +com.adobe.AIDE (1.5.0 - 1.5.0.37764) <7ABC7C2C-E464-3C50-B13E-64090A6705CE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
0x114c75000 - 0x114d17ff7 +com.adobe.ICUConverter (4.0 - 3.61) <4D6A813A-56D5-3CE1-8743-2BA65500FD20> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
0x114d3d000 - 0x114df9fff +com.adobe.dvanet.framework (11.0.0 - 11.0.0.0) <A5ADA67B-5A93-3D51-9197-E92623B15BB3> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
0x114e57000 - 0x114e72ffb +VulcanControl.dylib (5.4.0.12 - 5.4.0.12 Copyright 2017, Adobe Systems Incorporated. All rights reserved.) <7E56E512-AED2-3AE2-B44B-22483C33451D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/VulcanControl.dylib
0x114e85000 - 0x114eb1ffb +VulcanMessage5.dylib (5.4.0.12 - 5.4.0.12 Copyright 2017, Adobe Systems Incorporated. All rights reserved.) <06C8FCC4-E4E4-3842-8413-7E0BB20AFB24> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/VulcanMessage5.dylib
0x114ece000 - 0x114f3affb +DataBaseLib.dylib (0) <A6E884B0-76B7-35F3-A606-0C7FCFA1D5C5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/DataBaseLib.dylib
0x114f54000 - 0x114fcfff3 +ObjectModelLib.dylib (0) <B350A8FA-3205-3C20-A451-7D208BBB733E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/ObjectModelLib.dylib
0x114ff6000 - 0x115017ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.37286 - 3.8.0.37286) <8DABAD0C-B1D1-3E52-BB34-961E1B18271D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpat
0x11b31f000 - 0x11b362ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotifications
0x11be86000 - 0x11be8fffb +com.adobe.InDesign.Data Services UI (12.1.0.56 - 0) <AAAB33BC-2F83-332F-9788-667A3A1A5166> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Data Services/Data Services UI.InDesignPlugin/Data Services UI
0x11be99000 - 0x11be9fff7 +com.adobe.InDesign.Data Services (12.1.0.56 - 0) <F3A64479-9CE4-3E55-9A95-6BAEE21C01D7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Data Services/Data Services.InDesignPlugin/Data Services
0x11bea5000 - 0x11beb0fff +com.adobe.InDesign.DTTransform (12.1.0.56 - 0) <329DB794-D0CB-3D23-99D2-1E28F3F8FF37> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Data Services/DTTransform.InDesignPlugin/DTTransform
0x11beb9000 - 0x11bef0fff +com.adobe.InDesign.Dictionary Editor Dialog (12.1.0.56 - 0) <04E629AF-27DD-306E-A37D-B4120C217ED7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Dictionaries/Dictionary Editor Dialog.InDesignPlugin/Dictionary Editor Dialog
0x11bf10000 - 0x11bf35fff +com.adobe.InDesign.LILO (12.1.0.56 - 0) <683AA132-1E8F-3ECA-92D1-C0C1D8A7490A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Dictionaries/LILO/LILO.InDesignPlugin/LILO
0x11bf44000 - 0x11c00eff7 +com.adobe.linguistic.LinguisticManager (10.1.0 - 22175) <9A965912-1738-3875-B4E3-88FE4E19F2EA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
0x11c02b000 - 0x11c06affb +com.adobe.InDesign.Digital Publishing UI (12.1.0.56 - 0) <A2B8741F-C76D-31DB-92AF-EAB3CE0B6945> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Digital Publishing UI.InDesignPlugin/Digital Publishing UI
0x11c081000 - 0x11c194ff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 138 - 79.159824) <275C69CE-1552-3B46-ADE9-7C642051B948> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
0x11c1fc000 - 0x11c3d2ff3 +com.adobe.InDesign.Digital Publishing (12.1.0.56 - 0) <5E60F5AA-86BD-34E6-9A35-44906FC1C3B7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Digital Publishing.InDesignPlugin/Digital Publishing
0x11c418000 - 0x11c678fff +com.adobe.InDesign.EBookExport (12.1.0.56 - 0) <3A1EEE43-6869-3978-8651-F50A55DF3B2A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/EBookExport.InDesignPlugin/EBookExport
0x11c6b4000 - 0x11c6f9ff3 +com.adobe.InDesign.Media Import Filter (12.1.0.56 - 0) <C5679F28-01C8-3505-95F3-0DB2C800D223> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Media Import Filter.InDesignPlugin/Media Import Filter
0x11c70b000 - 0x11c715ffb +com.adobe.InDesign.PNG Import Filter UI (12.1.0.56 - 0) <F1F9D2EC-9223-385E-BF09-4A62EC42A0A2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/PNG Import Filter UI.InDesignPlugin/PNG Import Filter UI
0x11c71f000 - 0x11c744ff3 +com.adobe.InDesign.Sangam Preferences UI (12.1.0.56 - 0) <B3AA5114-1D2D-3D7B-BCCB-348AB185C61E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Sangam Preferences UI.InDesignPlugin/Sangam Preferences UI
0x11c757000 - 0x11c7b8fff +com.adobe.AdobeSangam (AdobeSangam 5.65.0.36985 - 5.65.0.36985) <F1E4000E-DAB0-313F-A6BB-9EC2028B4CB9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeSangam.framework/Versions/A/AdobeSangam
0x11c80a000 - 0x11c954ffb +com.adobe.InDesign.SangamServicer-Mapper (12.1.0.56 - 0) <41174835-35B9-3ABF-B1B2-FBE1E949A743> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/SangamServicer-Mapper.InDesignPlugin/SangamServicer-Mapper
0x11c982000 - 0x11c996fff +com.adobe.InDesign.SaveBack (12.1.0.56 - 0) <7B66BEC5-7EB7-396A-A3B5-BE4F63CB0026> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/SaveBack.InDesignPlugin/SaveBack
0x11c9a4000 - 0x11c9a6ff7 +com.adobe.InDesign.SimpleTextImportFilter (12.1.0.56 - 0) <AE8F3E2E-3077-37A6-BF87-83B4A7D309ED> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/SimpleTextImportFilter.InDesignPlugin/SimpleTextImportFilter
0x11c9ac000 - 0x11ca2fff7 +com.adobe.InDesign.Tagged Text Attributes (12.1.0.56 - 0) <C1A0501D-4B40-3DF9-94C5-91BC2904515D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Tagged Text Attributes.InDesignPlugin/Tagged Text Attributes
0x11ca5e000 - 0x11ca69ffb +com.adobe.InDesign.Tagged Text Filters UI (12.1.0.56 - 0) <F8A328D0-3CB9-3461-886E-3DC4AE4F4CA5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Tagged Text Filters UI.InDesignPlugin/Tagged Text Filters UI
0x11ca75000 - 0x11cb04ffb +com.adobe.InDesign.Tagged Text Filters (12.1.0.56 - 0) <7D874B6A-5242-3C03-A008-F38625FC1050> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Filters/Tagged Text Filters.InDesignPlugin/Tagged Text Filters
0x11cb18000 - 0x11cb24ff3 +com.adobe.InDesign.Clipping Path Dialog (12.1.0.56 - 0) <031FE8FC-DB59-3CFF-AC8D-66C188FC6537> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Clipping Path Dialog.InDesignPlugin/Clipping Path Dialog
0x11cb36000 - 0x11cb75ff3 +com.adobe.InDesign.Color Management UI (12.1.0.56 - 0) <78DDC256-9135-389C-9B47-C537CE177339> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Color Management UI.InDesignPlugin/Color Management UI
0x11cb85000 - 0x11cc06fff +com.adobe.InDesign.Color Picker Panel (12.1.0.56 - 0) <34065A68-50A2-3653-9758-E6A4E0DD87E4> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Color Picker Panel.InDesignPlugin/Color Picker Panel
0x11cc33000 - 0x11cca9ff7 +com.adobe.InDesign.DynamicDocumentsUI (12.1.0.56 - 0) <84D23B33-A582-3806-A9B6-28C45A280274> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/DynamicDocumentsUI.InDesignPlugin/DynamicDocumentsUI
0x11ccd0000 - 0x11cce9ff7 +com.adobe.InDesign.EPS UI (12.1.0.56 - 0) <E279EDF4-44DC-31A2-B143-7411D4E83FAC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/EPS UI.InDesignPlugin/EPS UI
0x11ccfa000 - 0x11cd05fff +com.adobe.InDesign.Generic Style Editor (12.1.0.56 - 0) <90D366EB-CB1C-3A4F-94C6-44596B423A1B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Generic Style Editor.InDesignPlugin/Generic Style Editor
0x11cd13000 - 0x11cd47ff3 +com.adobe.InDesign.Gradient Panel (12.1.0.56 - 0) <274F3564-D31C-3430-B0DF-0B5F2BBACB3A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Gradient Panel.InDesignPlugin/Gradient Panel
0x11cd60000 - 0x11ce08ff3 +com.adobe.InDesign.Graphic Panels (12.1.0.56 - 0) <C7495813-8A8D-3D33-8C41-BA4BAC5412EA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Graphic Panels.InDesignPlugin/Graphic Panels
0x11ce34000 - 0x11ce3dff7 +com.adobe.InDesign.JPEG Export UI (12.1.0.56 - 0) <B77D3E9B-C264-3DD0-BD0B-9CD856392D9E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/JPEG Export UI.InDesignPlugin/JPEG Export UI
0x11ce46000 - 0x11ce5bffb +com.adobe.InDesign.JPEG Export (12.1.0.56 - 0) <57D8CC84-4AF6-3B1B-ABC5-98FAF80DEB93> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/JPEG Export.InDesignPlugin/JPEG Export
0x11ce6c000 - 0x11ceb8ffb +com.adobe.InDesign.Output Preview (12.1.0.56 - 0) <16AF3C81-641D-3489-883B-E9D5298C63A0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Output Preview.InDesignPlugin/Output Preview
0x11ced4000 - 0x11ceebff7 +com.adobe.InDesign.OutputMiscUI (12.1.0.56 - 0) <A9208127-2E79-36B4-B5A4-2820E79EDD34> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/OutputMiscUI.InDesignPlugin/OutputMiscUI
0x11cefe000 - 0x11cf89ff7 +com.adobe.InDesign.PDF UI (12.1.0.56 - 0) <A4838F65-9714-33DC-BB30-E66090FB0E1A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/PDF UI.InDesignPlugin/PDF UI
0x11cfaf000 - 0x11cfc1fff +com.adobe.InDesign.Printer Styles (12.1.0.56 - 0) <3256EC82-58C3-3F81-918F-8F1724C66FFC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Printer Styles.InDesignPlugin/Printer Styles
0x11cfcf000 - 0x11d09cfff +com.adobe.InDesign.PrintUI (12.1.0.56 - 0) <D3603E58-8B48-34C8-8CE7-B7B98A6A383E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/PrintUI.InDesignPlugin/PrintUI
0x11d0c8000 - 0x11d0d9ff3 +com.adobe.InDesign.PS Import UI (12.1.0.56 - 0) <0AB8FD7E-6187-319E-9CFC-51FC335A5C36> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/PS Import UI.InDesignPlugin/PS Import UI
0x11d0e8000 - 0x11d109ffb +com.adobe.InDesign.Swatch Library Panel (12.1.0.56 - 0) <07DB1B67-FACC-39F0-BC49-D68AEBB24D9A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Swatch Library Panel.InDesignPlugin/Swatch Library Panel
0x11d119000 - 0x11d205ff3 +com.adobe.InDesign.Swatches Panel (12.1.0.56 - 0) <CB90435C-7D9B-3669-9B40-D899421B4E2C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Swatches Panel.InDesignPlugin/Swatches Panel
0x11d241000 - 0x11d2d5ffb +com.adobe.InDesign.Transparency UI (12.1.0.56 - 0) <A6604DB4-D837-3D9D-BD44-E82F8704653E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Graphics/Transparency UI.InDesignPlugin/Transparency UI
0x11d30a000 - 0x11d365ffb +com.adobe.InDesign.Assignment UI (12.1.0.56 - 0) <93AF26B0-7213-3077-B42D-67C32CFDBCA9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/Assignment UI.InDesignPlugin/Assignment UI
0x11d388000 - 0x11d3a8fff +com.adobe.InDesign.InCopy Bridge UI (12.1.0.56 - 0) <108CBE90-475D-3252-8EAA-E33D49DEA505> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopy Bridge UI.InDesignPlugin/InCopy Bridge UI
0x11d3b6000 - 0x11d3eaff3 +com.adobe.InDesign.InCopy Bridge (12.1.0.56 - 0) <28FB35C8-BE11-3FC1-919A-B5AC1E975FC6> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopy Bridge.InDesignPlugin/InCopy Bridge
0x11d3f9000 - 0x11d3ffff7 +com.adobe.InDesign.InCopyExport (12.1.0.56 - 0) <453DC2AF-B2EA-3FA6-B2F0-47478B7A9D7E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopyExport.InDesignPlugin/InCopyExport
0x11d408000 - 0x11d40fffb +com.adobe.InDesign.InCopyExportUI (12.1.0.56 - 0) <8A5A058D-F444-358C-AF99-1B990EBB93AD> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopyExportUI.InDesignPlugin/InCopyExportUI
0x11d418000 - 0x11d41dff3 +com.adobe.InDesign.InCopyImport (12.1.0.56 - 0) <240BABC7-70DC-3480-8C53-8A95E8A5AE72> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopyImport.InDesignPlugin/InCopyImport
0x11d424000 - 0x11d42bff7 +com.adobe.InDesign.InCopyWorkflow UI (12.1.0.56 - 0) <A41F557B-3351-3F13-ADFD-912442155E26> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopyWorkflow UI.InDesignPlugin/InCopyWorkflow UI
0x11d436000 - 0x11d486ff3 +com.adobe.InDesign.Note (12.1.0.56 - 0) <8396B059-AC2E-3A0E-B6E1-D4DD0A9893F8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/Note.InDesignPlugin/Note
0x11d4a6000 - 0x11d4b0fff +com.adobe.InDesign.NotePref (12.1.0.56 - 0) <25CC3ADF-9929-3B3E-8CAD-2633D6C483F5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/NotePref.InDesignPlugin/NotePref
0x11d4be000 - 0x11d4c4ffb +com.adobe.InDesign.Username UI (12.1.0.56 - 0) <91CB1D7D-032D-3CCE-96D0-7B6787A8ABBA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/Username UI.InDesignPlugin/Username UI
0x11d4cd000 - 0x11d55effb +com.adobe.InDesign.ButtonUI (12.1.0.56 - 0) <1304E682-B40F-36A1-BFBE-7DA820FFACBF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Interactive/ButtonUI.InDesignPlugin/ButtonUI
0x11d58d000 - 0x11d5b4ffb +com.adobe.InDesign.MediaUI (12.1.0.56 - 0) <97BACAB1-F482-32FC-9291-4B6129186D02> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Interactive/MediaUI.InDesignPlugin/MediaUI
0x11d5cd000 - 0x11d5dcff7 +com.adobe.InDesign.Alignment Panel (12.1.0.56 - 0) <AFF308EF-3A59-391B-9FA3-74CCCFF41421> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Alignment Panel.InDesignPlugin/Alignment Panel
0x11d5e5000 - 0x11d62dfff +com.adobe.InDesign.Asset Library Panel (12.1.0.56 - 0) <5918FEDB-7F42-3925-9716-BE003B000E04> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Asset Library Panel.InDesignPlugin/Asset Library Panel
0x11d654000 - 0x11d6b1ff7 +com.adobe.InDesign.Asset PubLibrary (12.1.0.56 - 0) <8B8FF99C-8373-30E2-85D8-C30E6DB63F8D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Asset PubLibrary.InDesignPlugin/Asset PubLibrary
0x11d6ce000 - 0x11d715ff7 +com.adobe.InDesign.Book Panel (12.1.0.56 - 0) <0B7132A1-86DE-3CC0-90F9-6A45847CD424> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Book Panel.InDesignPlugin/Book Panel
0x11d73a000 - 0x11d753ffb +com.adobe.InDesign.Bookmark Panel (12.1.0.56 - 0) <30D3E4A5-D704-3A28-961F-6BFC7764B89C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Bookmark Panel.InDesignPlugin/Bookmark Panel
0x11d769000 - 0x11d799ffb +com.adobe.InDesign.ContentDropper Tool (12.1.0.56 - 0) <3DA7B610-8C70-31B5-8795-F8636A2517A8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/ContentDropper Tool.InDesignPlugin/ContentDropper Tool
0x11d7b9000 - 0x11d7f5ff7 +com.adobe.InDesign.Control Panel (12.1.0.56 - 0) <6BF02E80-94FD-3E21-8EC6-12371133151A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Control Panel.InDesignPlugin/Control Panel
0x11d812000 - 0x11d81cfff +com.adobe.InDesign.Create Guides Dialog (12.1.0.56 - 0) <2F8F9DCC-6A19-3815-BDB8-48E829932D20> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Create Guides Dialog.InDesignPlugin/Create Guides Dialog
0x11d827000 - 0x11d8a7ffb +com.adobe.InDesign.Eyedropper Tool (12.1.0.56 - 0) <04E9C067-F254-35F3-AD47-A8A82CCF38D9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Eyedropper Tool.InDesignPlugin/Eyedropper Tool
0x11d8ce000 - 0x11d96afff +com.adobe.InDesign.Hyperlinks Panel (12.1.0.56 - 0) <7B1B8406-50F5-3F79-BBBE-E2CEBAC7C9A7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Hyperlinks Panel.InDesignPlugin/Hyperlinks Panel
0x11d996000 - 0x11da19fff +com.adobe.InDesign.Index Panel (12.1.0.56 - 0) <D02B8CEB-BA22-3398-ACB3-9FBAE11A60FA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Index Panel.InDesignPlugin/Index Panel
0x11da3a000 - 0x11da44fff +unihan (0) <54E13787-663F-3550-94EF-6CD94F63C375> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/unihan.framework/Versions/A/unihan
0x11da51000 - 0x11daabfff +com.adobe.InDesign.Info Panel (12.1.0.56 - 0) <97AF1718-C776-35C4-B531-1F7F5A8E0EA1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Info Panel.InDesignPlugin/Info Panel
0x11dac3000 - 0x11db74ff7 +com.adobe.InDesign.Knowledge Base (12.1.0.56 - 0) <67013AB3-D322-3870-AC96-8DBFE1E6DFB4> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Knowledge Base.InDesignPlugin/Knowledge Base
0x11db7e000 - 0x11dbc7fff +com.adobe.InDesign.Layers Panel (12.1.0.56 - 0) <9D6D68FC-3563-3FFF-9FA0-0E5BEF94C077> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Layers Panel.InDesignPlugin/Layers Panel
0x11dbea000 - 0x11dbefffb +com.adobe.InDesign.Layout Adjustment Panel (12.1.0.56 - 0) <81B4ADAE-08A0-3110-A059-E5FE44AA7260> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Layout Adjustment Panel.InDesignPlugin/Layout Adjustment Panel
0x11dbf8000 - 0x11dc11ff3 +com.adobe.InDesign.Layout Adjustment (12.1.0.56 - 0) <8B07AB35-4130-3DEE-A69B-D23EC3B52EDA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Layout Adjustment.InDesignPlugin/Layout Adjustment
0x11dc1f000 - 0x11dc66ff7 +com.adobe.InDesign.Links UI (12.1.0.56 - 0) <AB274E41-D8CC-3EDA-BD5C-F76D20226D55> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Links UI.InDesignPlugin/Links UI
0x11dc88000 - 0x11dd1fffb +com.adobe.InDesign.ObjectStylesUI (12.1.0.56 - 0) <07A98A85-C8B7-3BFB-A9D9-E4D4845E9B2D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/ObjectStylesUI.InDesignPlugin/ObjectStylesUI
0x11dd4f000 - 0x11dd7dffb +com.adobe.InDesign.Page Setup Dialog (12.1.0.56 - 0) <7E8767A9-9DE9-3F7F-BC97-38D978846990> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Page Setup Dialog.InDesignPlugin/Page Setup Dialog
0x11dd94000 - 0x11de4dfff +com.adobe.InDesign.Pages Panel (12.1.0.56 - 0) <417420DF-9CE4-3E85-95CE-12C009EA0FB8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Pages Panel.InDesignPlugin/Pages Panel
0x11de7e000 - 0x11de90ff7 +com.adobe.InDesign.Sections UI (12.1.0.56 - 0) <0ACFD577-F66C-3FE6-945A-7A8D8A0A8B1E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Sections UI.InDesignPlugin/Sections UI
0x11de9b000 - 0x11dea5ff3 +com.adobe.InDesign.StepRepeat (12.1.0.56 - 0) <0D53DD3B-9AE3-3A2C-BF1E-85C1439F6F9F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/StepRepeat.InDesignPlugin/StepRepeat
0x11deb1000 - 0x11deeaff3 +com.adobe.InDesign.Text Wrap Panel (12.1.0.56 - 0) <B98A0063-961E-3B3D-AC08-4CAEFE03F971> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Text Wrap Panel.InDesignPlugin/Text Wrap Panel
0x11df03000 - 0x11df40ff3 +com.adobe.InDesign.TOC UI Dialog (12.1.0.56 - 0) <96D0A57E-52B0-3E18-AABC-88846EFBC450> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/TOC UI Dialog.InDesignPlugin/TOC UI Dialog
0x11df59000 - 0x11df90ff3 +com.adobe.InDesign.Transform Panel (12.1.0.56 - 0) <6788AF07-E822-3954-99C8-5D4910ACD108> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Layout/Transform Panel.InDesignPlugin/Transform Panel
0x11dfa7000 - 0x11dfc6ffb +com.adobe.InDesign.OnBoarding (12.0.0 - 0) <DB2C8337-1536-3AFF-9D0A-ADC2BAC28E80> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/OnBoarding/OnBoarding.InDesignPlugin/OnBoarding
0x11dfd7000 - 0x11dff0ff7 +com.adobe.InDesign.Image Import UI (12.1.0.56 - 0) <A1CB21E1-DB55-38D4-8A46-AC233B35BA95> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Page Item/Image Import UI.InDesignPlugin/Image Import UI
0x11e004000 - 0x11e015ff7 +com.adobe.InDesign.Scotch Rules (12.1.0.56 - 0) <1AAB5DAD-E78B-36D3-943A-1FD9A3B3F6D9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Page Item/Scotch Rules.InDesignPlugin/Scotch Rules
0x11e01f000 - 0x11e077ffb +com.adobe.InDesign.BNUI (12.1.0.56 - 0) <704DEC82-0DBA-30AC-8587-ECB3F49CBD8D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/PMPack/BNUI.InDesignPlugin/BNUI
0x11e097000 - 0x11e134fff +com.adobe.InDesign.DataMerge (12.1.0.56 - 0) <69C991B5-F8B8-33E0-BB41-5FDFE8F8B91F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/PMPack/DataMerge.InDesignPlugin/DataMerge
0x11e153000 - 0x11e184ff3 +com.adobe.InDesign.DataMergeUI (12.1.0.56 - 0) <A0E00A91-1F26-348E-8B56-8F4E06DA9DC7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/PMPack/DataMergeUI.InDesignPlugin/DataMergeUI
0x11e19e000 - 0x11e28fff3 +com.adobe.InDesign.Package and Preflight UI (12.1.0.56 - 0) <C1C626A8-7364-3402-89F1-521D0711CB57> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Prepress/Package and Preflight UI.InDesignPlugin/Package and Preflight UI
0x11e2d0000 - 0x11e4fcffb +com.adobe.InDesign.Package and Preflight (12.1.0.56 - 0) <19BF9EBB-242C-3FB4-BD0C-40DFCC3717EC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Prepress/Package and Preflight.InDesignPlugin/Package and Preflight
0x11e541000 - 0x11e617ff3 +com.adobe.InDesign.JBX (12.1.0.56 - 0) <6900A400-3AEC-32B7-94BB-098E775A3240> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Sandbox/JBX.InDesignPlugin/JBX
0x11e644000 - 0x11e662fff +com.adobe.InDesign.SavebackService (12.0.0 - 0) <5FA1922F-43AA-31D6-B34F-D864E0006A48> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/SavebackService/SavebackService.InDesignPlugin/SavebackService
0x11e674000 - 0x11e67bfff +com.adobe.InDesign.Script Label Panel (12.1.0.56 - 0) <066B67A8-9A47-3F3F-9853-B08951DE49C0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Script/Script Label Panel.InDesignPlugin/Script Label Panel
0x11e687000 - 0x11e694ff3 +com.adobe.InDesign.Scripts Panel (12.1.0.56 - 0) <37D2B8AC-380E-3BA2-A2CC-E0A19F015D28> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Script/Scripts Panel.InDesignPlugin/Scripts Panel
0x11e6a4000 - 0x11e780ff7 +com.adobe.InDesign.Tables UI (12.1.0.56 - 0) <79A21478-7EDB-3497-8990-2A84E827B4AB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Tables/Tables UI.InDesignPlugin/Tables UI
0x11e7b2000 - 0x11e846ff7 +com.adobe.InDesign.TableStylesUI (12.1.0.56 - 0) <77158B35-13A3-3CEC-84FF-6B08DFBAEFE5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Tables/TableStylesUI.InDesignPlugin/TableStylesUI
0x11e874000 - 0x11e918ff3 +com.adobe.InDesign.Character Panel (12.1.0.56 - 0) <E797BEC3-D2AF-3773-A6B1-57193818F23B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Character Panel.InDesignPlugin/Character Panel
0x11e967000 - 0x11e994ff7 +com.adobe.InDesign.Conditional Text UI (12.1.0.56 - 0) <3A7C8073-09EF-361B-848F-D01BF35F3211> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Conditional Text UI.InDesignPlugin/Conditional Text UI
0x11e9b0000 - 0x11e9c9ff7 +com.adobe.InDesign.Create Outlines (12.1.0.56 - 0) <1E6A5942-69FD-36B9-B4BC-00247AC6C287> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Create Outlines.InDesignPlugin/Create Outlines
0x11e9d5000 - 0x11eae4ffb +com.adobe.InDesign.Find and Change Panel (12.1.0.56 - 0) <1C5A451F-5873-3133-9A88-8D377224F8D8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Find and Change Panel.InDesignPlugin/Find and Change Panel
0x11eb21000 - 0x11eb46ffb +com.adobe.InDesign.Find Change Format Panel (12.1.0.56 - 0) <A471E618-FC56-33BE-A287-78BD6EB7E6F5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Find Change Format Panel.InDesignPlugin/Find Change Format Panel
0x11eb5a000 - 0x11eba0fff +com.adobe.InDesign.Font Usage Dialog (12.1.0.56 - 0) <CFB14080-EBFE-31E1-BC9C-CE1C5DE0FC9B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Font Usage Dialog.InDesignPlugin/Font Usage Dialog
0x11ebb8000 - 0x11ec82ffb +com.adobe.InDesign.Glyphs Panel (12.1.0.56 - 0) <007F022F-7734-3730-85EA-58751E549710> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Glyphs Panel.InDesignPlugin/Glyphs Panel
0x11ecab000 - 0x11ecb4ffb +com.adobe.InDesign.Hyphenation Panel (12.1.0.56 - 0) <8CE04773-08B4-32CF-AE1D-AF50C0D28E3F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Hyphenation Panel.InDesignPlugin/Hyphenation Panel
0x11ecc3000 - 0x11ecd5ffb +com.adobe.InDesign.Indents and Tabs (12.1.0.56 - 0) <6B102CD7-E885-34DE-BE0E-B280190D8B5C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Indents and Tabs.InDesignPlugin/Indents and Tabs
0x11ece5000 - 0x11eceefff +com.adobe.InDesign.Justification Panel (12.1.0.56 - 0) <E25008E3-70F3-313D-9046-C286C3376747> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Justification Panel.InDesignPlugin/Justification Panel
0x11ecfa000 - 0x11ed01ff7 +com.adobe.InDesign.Keeps Panel (12.1.0.56 - 0) <E238E435-DDD8-3964-9CEC-2781D58DDB39> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Keeps Panel.InDesignPlugin/Keeps Panel
0x11ed0a000 - 0x11ed27fff +com.adobe.InDesign.Optical Kerning (12.1.0.56 - 0) <AF82539E-4520-3645-82BC-5127F3824231> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Optical Kerning.InDesignPlugin/Optical Kerning
0x11ed33000 - 0x11ed68ff3 +com.adobe.InDesign.Paragraph Panel (12.1.0.56 - 0) <BF29973E-2A3B-39FE-B9C2-A619FA922175> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Paragraph Panel.InDesignPlugin/Paragraph Panel
0x11ed7f000 - 0x11ed90ffb +com.adobe.InDesign.Paragraph Rules Panel (12.1.0.56 - 0) <747B51F0-ED0B-3C52-AF34-9A030DED0500> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Paragraph Rules Panel.InDesignPlugin/Paragraph Rules Panel
0x11ed9b000 - 0x11edb0ff7 +com.adobe.InDesign.Path Type UI (12.1.0.56 - 0) <51B47F10-C617-3B31-A967-F7EC0579D1BD> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Path Type UI.InDesignPlugin/Path Type UI
0x11edc0000 - 0x11edc7ff3 +PathTypeLib.dylib (0) <BBCE3A07-2FCD-381B-A79F-32AE7887A256> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/PathTypeLib.dylib
0x11edcf000 - 0x11edf8ff3 +com.adobe.InDesign.RunIn Styles Panel (12.1.0.56 - 0) <90DF5634-1DEC-347F-B224-D141ABEECFF9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/RunIn Styles Panel.InDesignPlugin/RunIn Styles Panel
0x11ee0b000 - 0x11ee18ff3 +com.adobe.InDesign.SING (12.1.0.56 - 0) <85BA6A3D-EA1A-3344-A014-3E27088F36D5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/SING.InDesignPlugin/SING
0x11ee21000 - 0x11ee2afff +com.adobe.InDesign.Span Columns Panel (12.1.0.56 - 0) <5455B95B-C5F9-36C3-B16B-A499C7F942FF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Span Columns Panel.InDesignPlugin/Span Columns Panel
0x11ee33000 - 0x11ee79ff7 +com.adobe.InDesign.Spelling Panel (12.1.0.56 - 0) <5D044F10-FFC0-353B-9636-39686C46D638> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Spelling Panel.InDesignPlugin/Spelling Panel
0x11ee92000 - 0x11eea4ff3 +com.adobe.InDesign.Story Panel (12.1.0.56 - 0) <6050F3FF-50B4-357E-97BA-89EACFC83576> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Story Panel.InDesignPlugin/Story Panel
0x11eeb3000 - 0x11ef23fff +com.adobe.InDesign.Style Panel (12.1.0.56 - 0) <D2C48C84-CB92-3170-AC93-857DD49821CA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Style Panel.InDesignPlugin/Style Panel
0x11ef4d000 - 0x11ef59fff +com.adobe.InDesign.Text Color Panel (12.1.0.56 - 0) <E0652271-7986-3672-87D1-6B880662EC20> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Color Panel.InDesignPlugin/Text Color Panel
0x11ef62000 - 0x11ef90ff3 +com.adobe.InDesign.Text Frame Options (12.1.0.56 - 0) <9F92829C-FC99-3822-835D-F246D6B36ED9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Frame Options.InDesignPlugin/Text Frame Options
0x11efa3000 - 0x11f002ff3 +com.adobe.InDesign.Text Panel (12.1.0.56 - 0) <456F0B37-B9B1-3773-80BE-00DBB2F17881> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Panel.InDesignPlugin/Text Panel
0x11f02b000 - 0x11f04aff7 +com.adobe.InDesign.Text Preferences (12.1.0.56 - 0) <1775600D-8234-375B-AAD5-B45751A0A99D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Preferences.InDesignPlugin/Text Preferences
0x11f05a000 - 0x11f07bff3 +com.adobe.InDesign.Text Ruler (12.1.0.56 - 0) <9468E332-D499-3EE4-9C0F-1E159E9AA89C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Ruler.InDesignPlugin/Text Ruler
0x11f08e000 - 0x11f0b4ff3 +com.adobe.InDesign.Text Style Panel (12.1.0.56 - 0) <E255B71E-1A83-30C6-9DF4-0A98A7D73233> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Text/Text Style Panel.InDesignPlugin/Text Style Panel
0x11f0c5000 - 0x11f0edfff +com.adobe.InDesign.Article Panel (12.1.0.56 - 0) <AF6B8F1D-E1AF-38FE-8907-58A6D3D9CACC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Article Panel.InDesignPlugin/Article Panel
0x11f107000 - 0x11f1a0fff +com.adobe.InDesign.CSXS (12.1.0.56 - 0) <B0FBA243-9730-3E71-811D-036875D5C582> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/CSXS.InDesignPlugin/CSXS
0x11f1c8000 - 0x11f2eaffb +libExperimentationSDKRelease.dylib (0) <23E0C445-66FC-35ED-A54B-5A40893AC048> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/libExperimentationSDKRelease.dylib
0x11f2f9000 - 0x11f32cff3 +com.adobe.InDesign.Galley Preferences (12.1.0.56 - 0) <EA8320D5-C837-39F8-A50B-0551AB195759> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Galley Preferences.InDesignPlugin/Galley Preferences
0x11f348000 - 0x11f368fff +com.adobe.InDesign.GapTool (12.1.0.56 - 0) <1771139D-0661-364D-A607-3D69AE28C250> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/GapTool.InDesignPlugin/GapTool
0x11f378000 - 0x11f385ff3 +com.adobe.InDesign.General Preferences Panel (12.1.0.56 - 0) <3BB1C48D-1F35-345F-90A6-244A2205DB47> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/General Preferences Panel.InDesignPlugin/General Preferences Panel
0x11f390000 - 0x11f395ff7 +com.adobe.InDesign.Help (12.1.0.56 - 0) <F7F104D0-6063-3509-8BA1-768496062C5F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Help.InDesignPlugin/Help
0x11f39c000 - 0x11f3bafff +com.adobe.ahclientframework (2.2.0.1 - 2.2.0.1) <78C9396E-DBAE-3C68-9B67-95B28F2BEC76> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
0x11f3c4000 - 0x11f3e0ff7 +com.adobe.InDesign.Performance UI (12.1.0.56 - 0) <915617D2-9CAE-3742-B0F2-87619FAE1ED1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Performance UI.InDesignPlugin/Performance UI
0x11f3f7000 - 0x11f418fff +com.adobe.InDesign.SharedContentUI (12.1.0.56 - 0) <91E8134D-F774-38A7-8C3F-C4D6BE5983FB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/SharedContentUI.InDesignPlugin/SharedContentUI
0x11f427000 - 0x11f44afff +com.adobe.InDesign.Shortcut Editor Dialog (12.1.0.56 - 0) <C063BD03-83D2-375D-BAF1-0C90D77BAE43> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Shortcut Editor Dialog.InDesignPlugin/Shortcut Editor Dialog
0x11f45e000 - 0x11f47cff7 +com.adobe.InDesign.Tool Box (12.1.0.56 - 0) <55DF3379-AEFF-376D-8793-89FD08226210> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Tool Box.InDesignPlugin/Tool Box
0x11f4ab000 - 0x11f4b3ff3 +com.adobe.InDesign.Tool Tips (12.1.0.56 - 0) <5F96D857-BC0A-3353-BD29-C37A2BBD0E09> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Tool Tips.InDesignPlugin/Tool Tips
0x11f4bc000 - 0x11f4c5fff +com.adobe.InDesign.Track Changes Preferences (12.1.0.56 - 0) <309BBAEB-1562-3AFD-A21F-3BE1922DBAB4> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Track Changes Preferences.InDesignPlugin/Track Changes Preferences
0x11f4cf000 - 0x11f4e4fff +com.adobe.InDesign.Track Changes UI (12.1.0.56 - 0) <32F6CC77-6AD6-33DC-A2D3-3A6AAB9C3FF7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/UI/Track Changes UI.InDesignPlugin/Track Changes UI
0x11f4ef000 - 0x11f4f8ff7 +com.adobe.InDesign.PerformanceMetrics (12.1.0.56 - 0) <1716F8A5-881E-3706-BE27-792A68197501> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Utility/PerformanceMetrics.InDesignPlugin/PerformanceMetrics
0x11f502000 - 0x11f50eff7 +com.adobe.InDesign.Metadata UI (12.1.0.56 - 0) <5F859F52-E56B-3C84-86BE-757953F6296F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Workflow/Metadata UI.InDesignPlugin/Metadata UI
0x11f519000 - 0x11f859ffb +com.adobe.dvaadameve.framework (11.0.0 - 11.0.0.0) <241CBAEF-758E-397A-AF51-B0A9B59265D2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
0x11fbaa000 - 0x11fc69fff +com.adobe.dvametadata.framework (11.0.0 - 11.0.0.0) <013AC23E-E039-37B8-A7CD-39C1CC565C6A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
0x11fcc3000 - 0x11fdbcfff +com.adobe.dvametadataUI.framework (11.0.0 - 11.0.0.0) <F35A344E-84B5-31B6-A6C0-EA814FF6C537> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
0x11fe52000 - 0x11ffa3fff +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.7 -f 22 - 79.159824) <F8744863-1462-35FE-9C10-37DA6D0041CD> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
0x11fff6000 - 0x1200c9ffb +com.adobe.dvaeve.framework (11.0.0 - 11.0.0.0) <7FD71F90-DCA1-311C-BE20-DB4B83AE9918> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
0x12016a000 - 0x1201bbffb +com.adobe.dvatemporalxmp.framework (11.0.0 - 11.0.0.0) <F5B01088-CC6C-3EBB-BCE0-077D465C8524> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
0x1201e5000 - 0x120220ff3 +com.adobe.dvamediatypes.framework (11.0.0 - 11.0.0.0) <17FD976D-EC1F-3168-800F-A9EECFE0C34D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
0x12023d000 - 0x120247ffb +com.adobe.InDesign.Workgroup UI (12.1.0.56 - 0) <1E81D947-5401-3ABB-99B1-DC1F3F894A25> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/Workgroup/Workgroup UI.InDesignPlugin/Workgroup UI
0x120250000 - 0x120296ff3 +com.adobe.InDesign.Snippet (12.1.0.56 - 0) <9445570A-6658-3AA5-8DEB-2B4A1CABD71E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/XMedia/Snippet.InDesignPlugin/Snippet
0x1202ae000 - 0x1203c5ff3 +com.adobe.InDesign.XMedia UI (12.1.0.56 - 0) <C8049EC2-4701-3815-B037-D420592B2B91> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Plug-Ins/XMedia/XMedia UI.InDesignPlugin/XMedia UI
0x120411000 - 0x120469fff +com.adobe.InDesign.Actions (12.1.0.56 - 0) <3782C9F2-E69A-3D53-888B-3F913D91339E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Actions.InDesignPlugin/Actions
0x120486000 - 0x12065bff3 +com.adobe.InDesign.AppFramework (12.1.0.56 - 0) <A07F087F-E529-3D72-B69E-1C0B73BBF72D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/AppFramework.InDesignPlugin/AppFramework
0x1206fc000 - 0x12095effb +com.adobe.InDesign.Application UI (12.1.0.56 - 0) <2FA45793-20D5-30FC-AA9D-52C341C522F4> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Application UI.InDesignPlugin/Application UI
0x120a31000 - 0x120bcbfff +com.adobe.headlights.LogSessionFramework (7.4.1.63.45453) <2116CCCF-BA38-366C-8BCE-91827BA52E6D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
0x120bf0000 - 0x120c8dfff +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.4) <8FF7B7E4-C344-3433-B9BB-93737EF4A825> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
0x120cb5000 - 0x120d4aff7 +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.4) <8200505F-05B7-34FF-A81C-4221C6177FAF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
0x120d75000 - 0x120daafff +AgoraLib.dylib (1.0.0.0) <73697218-E690-371D-9728-7883DA2051A7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AgoraLib.dylib
0x120ddd000 - 0x120eecff7 +com.adobe.dvascriptui.framework (7.0.6 - 7.0.6.0) <9F8656A7-1973-321F-B38E-35C4DB6DA805> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/dvascriptui.framework/Versions/A/dvascriptui
0x12100b000 - 0x12102cff3 +com.adobe.InDesign.Article (12.1.0.56 - 0) <FBBA34E6-32BD-34B2-B075-CEC2A715595D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Article.InDesignPlugin/Article
0x12103b000 - 0x1210c5ffb +com.adobe.InDesign.Assignments (12.1.0.56 - 0) <81546D36-F733-30D3-AAC6-A36D7E1DAD40> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Assignments.InDesignPlugin/Assignments
0x1210e5000 - 0x121120fff +com.adobe.InDesign.AWS (12.1.0.56 - 0) <666CF5CF-E6DA-31BF-B28B-789120E97467> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/AWS.InDesignPlugin/AWS
0x12113b000 - 0x121163fff +com.adobe.InDesign.AWSUI (12.1.0.56 - 0) <283221E2-2C53-344E-ACEE-BF1910ACBF8A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/AWSUI.InDesignPlugin/AWSUI
0x121179000 - 0x1211acfff +com.adobe.InDesign.Basic Tools (12.1.0.56 - 0) <D93ED133-AD98-38AD-BD17-BFF45A1103D0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Basic Tools.InDesignPlugin/Basic Tools
0x1211c9000 - 0x121214ff7 +com.adobe.InDesign.Behavior (12.1.0.56 - 0) <6DAF0693-413B-3904-A6F1-F61A53AB867E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Behavior.InDesignPlugin/Behavior
0x121231000 - 0x1212b9fff +com.adobe.InDesign.BNCore (12.1.0.56 - 0) <6DDF3759-07FF-3AB3-93C7-3C1C59CF6371> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/BNCore.InDesignPlugin/BNCore
0x1212d5000 - 0x12132fff3 +com.adobe.InDesign.Book (12.1.0.56 - 0) <70118811-5625-3BF1-93BE-21032B6890A7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Book.InDesignPlugin/Book
0x121346000 - 0x121379ffb +com.adobe.InDesign.CellStyles (12.1.0.56 - 0) <A0185B4A-B10E-3C7E-ABBD-D7C8F1888D99> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/CellStyles.InDesignPlugin/CellStyles
0x12138b000 - 0x1213fbff3 +com.adobe.InDesign.CJK Text Attributes (12.1.0.56 - 0) <6DD053CD-EBEB-347A-B424-D4251287B516> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/CJK Text Attributes.InDesignPlugin/CJK Text Attributes
0x12141d000 - 0x121493ffb +com.adobe.InDesign.CJKGrid (12.1.0.56 - 0) <72CABFFE-B9D4-31E9-9865-35077526811D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/CJKGrid.InDesignPlugin/CJKGrid
0x1214af000 - 0x121589ff7 +com.adobe.InDesign.Color Management (12.1.0.56 - 0) <BF24BFC9-54D5-3324-A4A4-BE917A35703C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Color Management.InDesignPlugin/Color Management
0x1215b6000 - 0x121617ff3 +com.adobe.InDesign.CompFontMgr (12.1.0.56 - 0) <C27F5478-D4CB-3CEF-B5DF-5ED4C1344557> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/CompFontMgr.InDesignPlugin/CompFontMgr
0x121631000 - 0x12167dff7 +com.adobe.InDesign.Conditional Text (12.1.0.56 - 0) <A1D66194-ADD5-3F82-8D1B-C2C247F1F1B2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Conditional Text.InDesignPlugin/Conditional Text
0x121695000 - 0x1216c3fff +com.adobe.InDesign.ContentDropper (12.1.0.56 - 0) <742AB3F1-9BB4-33EC-9203-616CBBE35A51> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/ContentDropper.InDesignPlugin/ContentDropper
0x1216d7000 - 0x1216fafff +com.adobe.InDesign.Dialog Layout (12.1.0.56 - 0) <0AE8AB44-1AE7-39EF-A826-299CBA13F935> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Dialog Layout.InDesignPlugin/Dialog Layout
0x12170f000 - 0x121732ffb +com.adobe.InDesign.Document Actions (12.1.0.56 - 0) <B5DC4934-27C3-3D19-8461-16305A192611> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Document Actions.InDesignPlugin/Document Actions
0x12173f000 - 0x121908fff +com.adobe.InDesign.Document Framework (12.1.0.56 - 0) <D9CFF63A-4E2C-326B-8287-60A92A49D134> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Document Framework.InDesignPlugin/Document Framework
0x121949000 - 0x121955fff +com.adobe.InDesign.Document UI (12.1.0.56 - 0) <846BE7D7-6ADE-399A-8E2B-037BA754EB7F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Document UI.InDesignPlugin/Document UI
0x121960000 - 0x1219b7fff +com.adobe.InDesign.DV_Widgets (12.1.0.56 - 0) <23D39C10-7DD5-306E-82E4-97201929B7C1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/DV_Widgets.InDesignPlugin/DV_Widgets
0x121a2c000 - 0x121d26ff7 +com.adobe.InDesign.Dynamic Documents (12.1.0.56 - 0) <DC91CE45-51A5-34E7-B9DC-60F7398F76EC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Dynamic Documents.InDesignPlugin/Dynamic Documents
0x121d73000 - 0x121e6afff +com.adobe.AGMFL (AdobeAGMFL 2.1.0.32362 - 2.1.0.32362) <C93FF155-AA80-34F1-A785-42BC0D8D3909> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/ADBE_AGMFL.framework/Versions/A/ADBE_AGMFL
0x121e87000 - 0x122064ff7 +com.adobe.AFlamingo (AFlamingo 2.4.402.31977 - 2.4.402.31977) <B90D5CA4-DA52-39A1-95DD-8011764655A1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
0x122088000 - 0x122193ff7 +com.adobe.InDesign.EPS Page Item (12.1.0.56 - 0) <7CAB8473-B1E9-381D-A1B8-26F3AC4EE8D8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/EPS Page Item.InDesignPlugin/EPS Page Item
0x1221d2000 - 0x1222dcfff +com.adobe.InDesign.Font Manager (12.1.0.56 - 0) <B7DE4EE6-06B2-3DD2-ABD3-B6A509B341E9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Font Manager.InDesignPlugin/Font Manager
0x122302000 - 0x1223c1ff3 +com.adobe.InDesign.FormField (12.1.0.56 - 0) <FB3BA291-2A53-39A8-B31D-DB59D8BA96CD> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/FormField.InDesignPlugin/FormField
0x1223e5000 - 0x12243cffb +com.adobe.InDesign.Galley (12.1.0.56 - 0) <88DD237D-8DA0-3E53-B7A3-DF7E1F89E1ED> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Galley.InDesignPlugin/Galley
0x122452000 - 0x12258dfff +com.adobe.InDesign.GalleyUI (12.1.0.56 - 0) <D52D134D-F0BC-316E-8081-4BC6F54F4CF8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/GalleyUI.InDesignPlugin/GalleyUI
0x1225c0000 - 0x1227f6ff3 +com.adobe.InDesign.Generic Page Item (12.1.0.56 - 0) <F1D42D33-B76B-385E-A887-3B3A49D9C89B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Generic Page Item.InDesignPlugin/Generic Page Item
0x122842000 - 0x12284cfff +com.adobe.InDesign.GenericSettings (12.1.0.56 - 0) <D498FC39-9151-3B81-873C-E98839ED6ECA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/GenericSettings.InDesignPlugin/GenericSettings
0x122855000 - 0x122859ff7 +com.adobe.InDesign.Global Preferences Panel (12.1.0.56 - 0) <9E8C6084-DA2F-3249-A420-EB2F6BD38B4C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Global Preferences Panel.InDesignPlugin/Global Preferences Panel
0x122860000 - 0x1228bdfff +com.adobe.InDesign.Gradient Fill (12.1.0.56 - 0) <10CA39FE-BDB4-3A76-BFFB-FF61F0ADDDB2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Gradient Fill.InDesignPlugin/Gradient Fill
0x1228d8000 - 0x1229b1ff3 +com.adobe.InDesign.Graphics (12.1.0.56 - 0) <EDDEF96D-3BE6-3101-BD53-589192880A9B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Graphics.InDesignPlugin/Graphics
0x1229d5000 - 0x1229dfff3 +com.adobe.InDesign.Group (12.1.0.56 - 0) <0F029429-BF95-39A5-AA15-0091AF98C9E8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Group.InDesignPlugin/Group
0x1229eb000 - 0x122a07ff3 +com.adobe.InDesign.Guides (12.1.0.56 - 0) <1D8B98E3-E0E4-3F48-A1BF-56D945BA4048> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Guides.InDesignPlugin/Guides
0x122a18000 - 0x122ae9ffb +com.adobe.InDesign.HTMLPGT (12.1.0.56 - 0) <95EC760C-8AB4-396C-B05D-42922C57C816> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/HTMLPGT.InDesignPlugin/HTMLPGT
0x122b42000 - 0x122c26ff3 +com.adobe.InDesign.Hyperlinks (12.1.0.56 - 0) <69B1A7B5-B5F9-3AFE-8E7E-31FDB0C7AE7E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Hyperlinks.InDesignPlugin/Hyperlinks
0x122c51000 - 0x122ca0ff3 +com.adobe.InDesign.Image Filters (12.1.0.56 - 0) <96B65FD6-2B2C-3FC9-AF45-FFFFDC3A24B0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Image Filters.InDesignPlugin/Image Filters
0x122cac000 - 0x122da9ff3 +com.adobe.InDesign.Image (12.1.0.56 - 0) <EC20770F-E19A-338A-805C-DA25432516D9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Image.InDesignPlugin/Image
0x122dd5000 - 0x122decff7 +com.adobe.InDesign.IME (12.1.0.56 - 0) <31F9511D-BFB0-3159-994A-B1EB694C7787> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/IME.InDesignPlugin/IME
0x122dfe000 - 0x122ebcfff +com.adobe.InDesign.Import Export UI (12.1.0.56 - 0) <0E146841-A362-3559-B1A3-C352603D3D70> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Import Export UI.InDesignPlugin/Import Export UI
0x122ef1000 - 0x122fd9ffb +com.adobe.InDesign.InCopyShared (12.1.0.56 - 0) <31E4C53B-57B6-336A-9190-EE418B31F520> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/InCopyShared.InDesignPlugin/InCopyShared
0x123005000 - 0x123021ff3 +com.adobe.InDesign.InCopySharedUI (12.1.0.56 - 0) <21E3A3A2-CEFE-3B3C-8E44-8D41BD0A91B2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/InCopySharedUI.InDesignPlugin/InCopySharedUI
0x123033000 - 0x1230b6ffb +com.adobe.InDesign.InCopyWorkflow (12.1.0.56 - 0) <4BB4B4C0-6C29-3246-9E5A-E5E97B94B7E2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/InCopyWorkflow.InDesignPlugin/InCopyWorkflow
0x1230dc000 - 0x1231c1ff3 +com.adobe.InDesign.Indexing (12.1.0.56 - 0) <6ABBFBEA-2284-319B-AB27-F9F7C63784A0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Indexing.InDesignPlugin/Indexing
0x1231e2000 - 0x123298ffb +com.adobe.InDesign.INXCore (12.1.0.56 - 0) <C76023CD-F73C-377D-A9E7-2D4961281C0D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/INXCore.InDesignPlugin/INXCore
0x1232c1000 - 0x1232e7ffb +com.adobe.InDesign.Layer (12.1.0.56 - 0) <D42D9074-AFAA-386B-A126-E9498E36C864> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Layer.InDesignPlugin/Layer
0x1232fa000 - 0x12354dffb +com.adobe.InDesign.Layout UI (12.1.0.56 - 0) <C1E47C96-A782-3883-A66E-985185DE7471> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Layout UI.InDesignPlugin/Layout UI
0x1235d2000 - 0x1235f8ff7 +com.adobe.InDesign.Layout (12.1.0.56 - 0) <A17B43CD-24E4-309B-B256-3659AE03C60E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Layout.InDesignPlugin/Layout
0x123608000 - 0x12364cff7 +com.adobe.InDesign.Linguistics (12.1.0.56 - 0) <294B8364-0C29-3D8C-B81F-C976E2BF596A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Linguistics.InDesignPlugin/Linguistics
0x123665000 - 0x1237bfff3 +com.adobe.InDesign.Links (12.1.0.56 - 0) <D6004A79-B324-3A14-8775-880C60D9A42F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Links.InDesignPlugin/Links
0x123800000 - 0x12388eff7 +com.adobe.InDesign.Master Page (12.1.0.56 - 0) <DD3B178E-1B5B-3580-AB3E-34E4FED5161A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Master Page.InDesignPlugin/Master Page
0x1238a7000 - 0x1238f1fff +com.adobe.InDesign.Media (12.1.0.56 - 0) <FB410EBE-BA9B-3C25-A2E9-30CDE0CADA29> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Media.InDesignPlugin/Media
0x123906000 - 0x123977ffb +com.adobe.InDesign.Metadata (12.1.0.56 - 0) <76536F65-1692-3BB0-8009-A6AF6512A2A0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Metadata.InDesignPlugin/Metadata
0x123993000 - 0x1239a7ffb +com.adobe.InDesign.Movie (12.1.0.56 - 0) <4F1B30F2-1358-3359-AEC3-DD6C94C0592C> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Movie.InDesignPlugin/Movie
0x1239b5000 - 0x1239f3ff3 +com.adobe.InDesign.Open Place (12.1.0.56 - 0) <8DFC5411-650B-30D3-9C82-0902C8460981> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Open Place.InDesignPlugin/Open Place
0x123a09000 - 0x123ab8ff7 +com.adobe.InDesign.Paragraph Composer (12.1.0.56 - 0) <9B630291-ADF4-3A58-90F6-B0A1CBEFB3BA> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Paragraph Composer.InDesignPlugin/Paragraph Composer
0x123ac8000 - 0x123afffff +com.adobe.InDesign.Path Type (12.1.0.56 - 0) <5FF9C9DE-D9DB-3894-BF5A-8A4CB6850782> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Path Type.InDesignPlugin/Path Type
0x123b18000 - 0x123d58fff +com.adobe.InDesign.PDF (12.1.0.56 - 0) <D78766DD-4E60-3057-B488-5A27536D4EF2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/PDF.InDesignPlugin/PDF
0x123d9f000 - 0x123e5fff7 +com.adobe.JP2K (1.2.2 - 1.2.2.36529) <759A9903-5910-3051-ABB6-CE6EBF18FF7E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
0x123e83000 - 0x123f75ffb +com.adobe.PDFPort (AdobePDFPort 2.1.0.37194 - 2.1.0.37194) <EBC47077-B30C-3D9D-B624-73D1CDB07ED6> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
0x123f88000 - 0x123fabff3 +com.adobe.PDFSettings (AdobePDFSettings 1.07.0 - 1.7) <EE5AD335-1E84-381D-B433-32C95C5DEF4A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
0x123fb6000 - 0x123ff1ff7 +com.adobe.InDesign.Photoshop Import Filter (12.1.0.56 - 0) <118529C5-FB6F-39F7-8123-07A352985D15> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Photoshop Import Filter.InDesignPlugin/Photoshop Import Filter
0x124004000 - 0x12767af8f +com.adobe.psl (AdobePSL 15.1.0.36906 - 15.1.0.36906) <104EE3CA-51E9-3F6B-A079-3E87BE36552D> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
0x127b6e000 - 0x127b70ff7 com.apple.textencoding.unicode (3.0 - 3.0) <B8CEE380-5919-3519-8088-119C65562EE9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x127d96000 - 0x127dd0ff3 +com.adobe.InDesign.PNG Import Filter (12.1.0.56 - 0) <42EBA308-5BC3-3E8A-ACAC-830496A5D0A9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/PNG Import Filter.InDesignPlugin/PNG Import Filter
0x127de0000 - 0x127f48ff3 +com.adobe.InDesign.Print (12.1.0.56 - 0) <AC01C9C7-E13B-3DD8-B430-A98AB6D13257> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Print.InDesignPlugin/Print
0x127f76000 - 0x127f9dff7 +com.adobe.InDesign.Rulers (12.1.0.56 - 0) <D01BC512-274E-3FE1-8173-6065EAC0142E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Rulers.InDesignPlugin/Rulers
0x127fb2000 - 0x128051ff7 +com.adobe.InDesign.Scripting (12.1.0.56 - 0) <DE3CC19F-B7C7-3EEE-B8CB-F1BBCAB3F298> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Scripting.InDesignPlugin/Scripting
0x128071000 - 0x128091fff +com.adobe.InDesign.Sections (12.1.0.56 - 0) <58D9D77C-B150-343B-B3BB-31A99873A461> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Sections.InDesignPlugin/Sections
0x1280a1000 - 0x128115ff7 +com.adobe.InDesign.SharedContent (12.1.0.56 - 0) <58ADA84E-7697-3958-924D-8DF7700612DF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/SharedContent.InDesignPlugin/SharedContent
0x128136000 - 0x128141ffb +com.adobe.InDesign.Sound (12.1.0.56 - 0) <CE10C26A-F59F-312E-BEF3-05D0D9F40FA9> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Sound.InDesignPlugin/Sound
0x12814d000 - 0x12815cff3 +com.adobe.InDesign.Spelling Service (12.1.0.56 - 0) <126134BE-7999-381B-9D69-C3A61218F125> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Spelling Service.InDesignPlugin/Spelling Service
0x12816a000 - 0x1281aeffb +com.adobe.InDesign.Spline UI (12.1.0.56 - 0) <550C322B-B264-3596-BCCA-1993EFBB0076> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Spline UI.InDesignPlugin/Spline UI
0x1281cb000 - 0x12820cfff +com.adobe.InDesign.Spline (12.1.0.56 - 0) <04630691-6029-32BA-B508-47ECE76BF2D1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Spline.InDesignPlugin/Spline
0x128224000 - 0x128285ff3 +com.adobe.InDesign.Spread UI (12.1.0.56 - 0) <E63B8D54-4EAB-3697-A10C-29128BBFDDEC> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Spread UI.InDesignPlugin/Spread UI
0x1282a7000 - 0x1283c4ff3 +com.adobe.InDesign.Spread (12.1.0.56 - 0) <967FC6FF-44E8-3098-8881-E09A064F230E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Spread.InDesignPlugin/Spread
0x1283f6000 - 0x128448ff7 +com.adobe.InDesign.Stroke and Fill (12.1.0.56 - 0) <ED6E5B60-FE5C-3B0B-8788-6A396D4DE3F8> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Stroke and Fill.InDesignPlugin/Stroke and Fill
0x12845f000 - 0x1284b6fff +com.adobe.InDesign.Support for AppleScript (12.1.0.56 - 0) <DA7AB65F-4203-30C6-9353-D34D522EA04E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Support for AppleScript.InDesignPlugin/Support for AppleScript
0x1284cd000 - 0x12855aff3 +com.adobe.InDesign.Support for JavaScript (12.1.0.56 - 0) <BFD2572F-E62E-37F7-A559-36D88581BB4A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Support for JavaScript.InDesignPlugin/Support for JavaScript
0x128586000 - 0x1285f6ffb +com.adobe.InDesign.SVGExport (12.1.0.56 - 0) <AA4E306A-B03F-3700-90CE-F69AF385BE74> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/SVGExport.InDesignPlugin/SVGExport
0x128610000 - 0x1286cefff +com.adobe.SVGExport (AdobeSVGExport 6.0 - 6.0) <2FAB4B9A-EDB9-0FF9-55B2-52DEC380D2BF> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeSVGExport.framework/Versions/A/AdobeSVGExport
0x1286f1000 - 0x128905ffb +com.adobe.InDesign.Table Model (12.1.0.56 - 0) <04145CBD-B2ED-393E-BC13-61E11FCD9BAE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Table Model.InDesignPlugin/Table Model
0x128948000 - 0x128998ff3 +com.adobe.InDesign.TableStyles (12.1.0.56 - 0) <977B6A65-0C07-307B-A20A-A0FFA2BC4F16> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/TableStyles.InDesignPlugin/TableStyles
0x1289aa000 - 0x1289edffb +com.adobe.InDesign.Text Attributes (12.1.0.56 - 0) <CB83D8A8-3990-32F3-8978-97B1E7A43B4B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Attributes.InDesignPlugin/Text Attributes
0x128a07000 - 0x128a1afff +com.adobe.InDesign.Text Editor Model (12.1.0.56 - 0) <3BC234FF-11C5-39AB-AF73-8A76877E839F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Editor Model.InDesignPlugin/Text Editor Model
0x128a25000 - 0x128b09fff +com.adobe.InDesign.Text Editor (12.1.0.56 - 0) <2B48B35F-62B6-3A2A-A9B8-B6C71CF238C2> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Editor.InDesignPlugin/Text Editor
0x128b41000 - 0x128cbdff3 +com.adobe.InDesign.Text Walker (12.1.0.56 - 0) <28EC1749-88D4-34D6-824B-728D2DFA435F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Walker.InDesignPlugin/Text Walker
0x128d0e000 - 0x128d2eff3 +com.adobe.InDesign.Text Wrap Path (12.1.0.56 - 0) <B36BAA42-AE34-3732-8502-22BEEB208F88> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Wrap Path.InDesignPlugin/Text Wrap Path
0x128d37000 - 0x128d9bff3 +com.adobe.InDesign.Text Wrap (12.1.0.56 - 0) <5BCB14B7-B4E5-313D-B287-747D89D84B29> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text Wrap.InDesignPlugin/Text Wrap
0x128db4000 - 0x12936afff +com.adobe.InDesign.Text (12.1.0.56 - 0) <0291087F-6DB3-3F74-A120-3CA0BC54450F> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Text.InDesignPlugin/Text
0x12940d000 - 0x129467fff +com.adobe.InDesign.TOC (12.1.0.56 - 0) <5943DCFC-3FDA-3D02-BFF2-57A6DEB14506> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/TOC.InDesignPlugin/TOC
0x12947a000 - 0x12959efff +com.adobe.InDesign.Transparency (12.1.0.56 - 0) <D8201F77-76DC-3830-BF6E-3107FF232C98> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Transparency.InDesignPlugin/Transparency
0x1295c8000 - 0x1295e8ffb +com.adobe.InDesign.Utilities (12.1.0.56 - 0) <95BBD18D-E95E-3413-8FDE-BDCB67D323B5> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Utilities.InDesignPlugin/Utilities
0x129602000 - 0x1296efff3 +com.adobe.InDesign.Widgets (12.1.0.56 - 0) <82B79DC8-B3E2-3EF0-A134-3772A79778C0> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Widgets.InDesignPlugin/Widgets
0x12976b000 - 0x129773ff7 +com.adobe.InDesign.Workgroup Client UI (12.1.0.56 - 0) <95C6F351-6EBA-3D48-8C1C-4B985ADA4D5B> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Workgroup Client UI.InDesignPlugin/Workgroup Client UI
0x129779000 - 0x129795fff +com.adobe.InDesign.Workgroup Client (12.1.0.56 - 0) <08C19498-76C7-3CE6-AC0B-34DF38142967> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Workgroup Client.InDesignPlugin/Workgroup Client
0x1297a3000 - 0x1297d6fff +com.adobe.InDesign.Workgroup (12.1.0.56 - 0) <22C9733E-28D9-3C7B-A660-4D3D9ED4D3C1> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/Workgroup.InDesignPlugin/Workgroup
0x1297e5000 - 0x129809ff3 +com.adobe.InDesign.WorldReady (12.1.0.56 - 0) <20026D60-96B0-36FC-B459-3E4BF1C0A600> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/WorldReady.InDesignPlugin/WorldReady
0x129819000 - 0x129a10fff +com.adobe.InDesign.XML (12.1.0.56 - 0) <062983B6-26DF-397F-9FF5-C57D2D5B2F83> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/XML.InDesignPlugin/XML
0x129a5a000 - 0x129b25ff7 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.37286 - 3.8.0.37286) <890E93CE-9D67-3929-9632-24B510B8FDF7> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
0x129b39000 - 0x129b8fff7 +com.adobe.InDesign.XMLParser (12.1.0.56 - 0) <7B8946CF-5EA5-3E99-95D9-1272B9B55E6E> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/Required/XMLParser.InDesignPlugin/XMLParser
0x129ba4000 - 0x129c53ff7 +com.adobe.AXEXSLT (AdobeAXSLE 3.8.0.37286 - 3.8.0.37286) <71A179F9-D93F-3B00-AAE9-973452A06B00> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeAXSLE.framework/Versions/A/AdobeAXSLE
0x12a4c7000 - 0x12a4c7ff7 +cl_kernels (???) <3695944E-685B-4914-ADDF-54D5135557EC> cl_kernels
0x12aca4000 - 0x12aca5fff libCyrillicConverter.dylib (68) <79F5CFEF-92E4-30FE-A650-41F07B6D31B9> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
0x12acaa000 - 0x12acaafff +DTraceSupport.dylib (1) <E54DF20B-C169-68CF-A3F5-0470DEFF1C8A> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/MacOS/DTraceSupport.dylib
0x12b490000 - 0x12b4acff7 libJapaneseConverter.dylib (68) <D80D1583-1F6F-32A5-A683-F504A0DF973A> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
0x12b7d4000 - 0x12b7faff7 +com.adobe.ape (3.4.0.29366 - 3.4.0.29366) <40A59819-7A57-0E9F-658D-1803B2A461AE> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/adbeapecore.framework/adbeapecore
0x12b80d000 - 0x12b958fef +IMSLib.dylib (10.0.0.19 - 10.0.0.19) <32EDDC00-4237-3F41-8B49-8B8010FAA72B> /Library/Application Support/Adobe/*/IMSLib.dylib
0x12b979000 - 0x12b9f3ff7 com.apple.xquery (1.3.1 - 30) <C1020441-B131-3995-86D9-9D0B725D3FAD> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
0x12c985000 - 0x12c9a0fff com.apple.security.csparser (3.0 - 57337.60.3) <1E3D798B-2878-3486-84EE-14D609B88A36> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x12d16c000 - 0x12d8a2ff7 +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.37239) <3BDD9CA5-5DA7-3C27-992E-7713A632F5A4> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobePDFL.framework/AdobePDFL
0x12f1a2000 - 0x12f247fff ColorSyncDeprecated.dylib (470.3) <A30CB963-667F-39D0-8537-66FCC820F5A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x12f572000 - 0x12f581ff7 libSimplifiedChineseConverter.dylib (68) <DCFEA0D3-593E-3E5C-B311-53B8ACF8A318> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
0x12fe1c000 - 0x12fe4aff7 +com.adobe.Reader for DOCX (Reader for DOCX 5.65.0.36985 - 5.65.0.36985) <7222A7BA-EF2C-348B-8C1E-B7C65A08D959> /Applications/Adobe InDesign CC 2017/*/Reader for DOCX
0x12fe56000 - 0x12fedbff3 +com.adobe.AdobeSangamML (AdobeSangamML 5.65.0.36985 - 5.65.0.36985) <4E9C7BF3-881D-31C4-A7CB-7BE464760BEB> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeSangamML.framework/Versions/A/AdobeSangamML
0x12feff000 - 0x12ff52fff +com.adobe.Reader for Excel (Reader for Excel 5.65.0.36985 - 5.65.0.36985) <3657EB98-55BA-3964-8207-29C46CD5A386> /Applications/Adobe InDesign CC 2017/*/Reader for Excel
0x12ff64000 - 0x12ff7aff7 +com.adobe.AdobeSFL (AdobeSFL 1.1.0.36043 - 1.1.0.36043) <049C1233-3D7E-38C6-9A14-4DF92626AB51> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobeSFL.framework/Versions/A/AdobeSFL
0x12ff85000 - 0x130060ffb +com.adobe.Reader for Quark (Reader for Quark 5.65.0.36985 - 5.65.0.36985) <ED28641A-34D9-3301-904A-40B6CEA2A453> /Applications/Adobe InDesign CC 2017/*/Reader for Quark
0x130079000 - 0x1300c8ff3 +com.adobe.Reader for RTF (Reader for RTF 5.65.0.36985 - 5.65.0.36985) <1D11FE22-46FB-3E86-821E-B0046F99CCF8> /Applications/Adobe InDesign CC 2017/*/Reader for RTF
0x1300e1000 - 0x130142ff7 +com.adobe.Reader for Word (Reader for Word 5.65.0.36985 - 5.65.0.36985) <EBA8224F-4909-3F12-8C6D-C894507D0861> /Applications/Adobe InDesign CC 2017/*/Reader for Word
0x130157000 - 0x1301c5fff +com.adobe.Reader for XLSX (Reader for XLSX 5.65.0.36985 - 5.65.0.36985) <059C92E5-6884-3E6E-833A-816136E79B81> /Applications/Adobe InDesign CC 2017/*/Reader for XLSX
0x1301df000 - 0x1301e5ff7 +com.adobe.ZTextReader (ZTextReader 5.65.0.36985 - 5.65.0.36985) <ED055B47-0C1B-3FCB-B834-1AE7FA1E8C32> /Applications/Adobe InDesign CC 2017/*/ZTextReader
0x130ad4000 - 0x130b5cfff com.apple.applescript (2.5 - 377) <B280DAC6-E614-3AC0-81B5-C2F1E994514B> /System/Library/PrivateFrameworks/AppleScript.framework/Versions/A/AppleScript
0x130c22000 - 0x130c44ff7 libKoreanConverter.dylib (68) <F29010B7-FABC-3CDA-95F5-85DC12B6C91B> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
0x130dd6000 - 0x130dfffff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
0x1315f0000 - 0x131602fff libTraditionalChineseConverter.dylib (68) <62CEE84C-366B-3E43-821B-EE072DBF33D7> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
0x131818000 - 0x131821fff +FastCore (17.0.1 - 17.0.1) <E385B772-C887-3D72-B226-7E6BBB2DBC26> /Applications/Adobe InDesign CC 2017/*/FastCore.plugin/Contents/MacOS/FastCore
0x13190f000 - 0x132194fff com.apple.GeForceTeslaGLDriver (10.0.52 - 10.0.0) <B005E97D-A3B1-3B79-8A39-2252AD2D94C3> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/GeForceTeslaGLDriver
0x1334cd000 - 0x133c63fff libclh.dylib (4.0.3 - 4.0.3) <3A5F83CE-45DE-332D-8103-78CB590469DD> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/libclh.dylib
0x134e1d000 - 0x134e4fff7 +com.adobe.pip (7.4.1.63.45453) <D4D5717C-769F-3DC1-862F-17F5ED9D9482> /Applications/Adobe InDesign CC 2017/Adobe InDesign CC 2017.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
0x135d8b000 - 0x135e06fcf +MMXCore (17.0.1 - 17.0.1) <A30CB664-C3B8-3FE5-AC64-DFDCBFABA67F> /Applications/Adobe InDesign CC 2017/*/MMXCore.plugin/Contents/MacOS/MMXCore
0x135f3a000 - 0x135fb1ffb +MultiProcessor Support (17.0.1 - 17.0.1) <6B9B588B-80C7-3B82-AD28-A3B7D49CF0B0> /Applications/Adobe InDesign CC 2017/*/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
0x7fff5fdea000 - 0x7fff5fe21a47 dyld (360.22) <884763FC-CC0F-31CC-ACC4-75A805CE401D> /usr/lib/dyld
0x7fff8ae21000 - 0x7fff8ae23ff7 libRadiance.dylib (1461) <7E03085F-09C6-3329-9149-5568787C397F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff8ae24000 - 0x7fff8ae2fff7 libGPUSupport.dylib (12.1) <4B0F343C-B56E-3085-A4D9-11775BA7355A> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
0x7fff8ae30000 - 0x7fff8ae6aff7 com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff8b788000 - 0x7fff8b78afff libCVMSPluginSupport.dylib (12.1) <20BA72AF-C7C5-3551-8F59-E1AED5FC69F0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff8b78b000 - 0x7fff8b78bfff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <848125D3-AF14-3526-8745-FFCDB200CD76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff8b7df000 - 0x7fff8b88ffff com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff8b890000 - 0x7fff8b893fff libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff8b894000 - 0x7fff8b8c3ff7 com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff8b8c4000 - 0x7fff8ba42fff com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff8ba43000 - 0x7fff8ba74fff com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff8ca17000 - 0x7fff8ca22fff libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff8ca23000 - 0x7fff8cc30fff libicucore.A.dylib (551.51.4) <3899B146-3840-3D4A-8C4A-FE391D5D25C7> /usr/lib/libicucore.A.dylib
0x7fff8ccfe000 - 0x7fff8cd1bff7 com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <707C6ED6-B8C0-38D4-B45A-7F2F689BD157> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff8cef9000 - 0x7fff8cf1dfff com.apple.MultitouchSupport.framework (304.12 - 304.12) <598A8689-E97E-3C8D-AACD-8A0EB1956CA6> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff8cf30000 - 0x7fff8cf32fff com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff8cf33000 - 0x7fff8cf33fff libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
0x7fff8cf34000 - 0x7fff8cfd4fff com.apple.ViewBridge (159 - 159) <D8131B7E-DFC9-3FDD-9D56-49821C1D1521> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fff8cff5000 - 0x7fff8d063ff7 com.apple.ApplicationServices.ATS (377 - 394.4) <CB64C2B7-828A-3C4C-8F3C-72B78630CD94> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff8d064000 - 0x7fff8d0b0fff com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff8d0b1000 - 0x7fff8d527fff com.apple.CoreFoundation (6.9 - 1259.11) <B8056BE3-151B-3003-91C9-6720CF04937B> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff8d56a000 - 0x7fff8d597fff libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
0x7fff8d598000 - 0x7fff8d598ff7 libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
0x7fff8d5d5000 - 0x7fff8d608ff7 com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff8d63f000 - 0x7fff8d642ff7 com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff8d668000 - 0x7fff8d66dfff com.apple.DiskArbitration (2.7 - 2.7) <9BB60809-3EA3-3881-8F2F-27EDBF9C8DE3> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff8d670000 - 0x7fff8e299ff7 com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff8e2c4000 - 0x7fff8e2d0fff com.apple.HelpData (2.1.4 - 90) <10608EEC-B613-309C-96E6-5A40AB951FA4> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x7fff8e760000 - 0x7fff8e761ffb libSystem.B.dylib (1226.10.1) <8B780EC7-53B7-3844-B3D8-5E81F5CA598C> /usr/lib/libSystem.B.dylib
0x7fff8e762000 - 0x7fff8e96dfff libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
0x7fff8e96e000 - 0x7fff8e999ffb libarchive.2.dylib (33.20.2.1.1) <BC764A1E-573A-3D95-A3CC-1758935ADC56> /usr/lib/libarchive.2.dylib
0x7fff8ea6c000 - 0x7fff8ee44fef com.apple.CoreAUC (214.0.0 - 214.0.0) <F80C19CA-6CD0-3052-9C22-0288A257CCC8> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff8ef7e000 - 0x7fff8ef7efff com.apple.CoreServices (728.13 - 728.13) <CFE3EE73-A3F5-3824-9210-0790C07120F3> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff8efcd000 - 0x7fff8f4effff com.apple.QuartzComposer (5.1 - 334) <80235264-CA1B-3E3F-96F7-5F6F52FDC5B6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff8f4f0000 - 0x7fff8f4f2fff com.apple.xpc.ServiceManagement (1.0 - 1) <1A4DF1C0-1519-325D-B26B-8EA737863270> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff8f4f3000 - 0x7fff8f50aff7 libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
0x7fff8f5b6000 - 0x7fff8f62aff3 com.apple.securityfoundation (6.0 - 55126) <3FF6D6E0-0C5D-385A-A97E-441D3947EFAB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff8f62b000 - 0x7fff8f639fff libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
0x7fff8f6b5000 - 0x7fff8fb50ffb com.apple.GeoServices (1.0 - 1151.49.1) <2D887517-B73D-30FF-91DC-AF6AD91F96B9> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff8fb8e000 - 0x7fff8fdfbfff com.apple.imageKit (2.6 - 932) <FAE317B8-DF15-3096-AFAC-464913BF2F3B> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff8fdfc000 - 0x7fff8fe02fff com.apple.XPCService (2.0 - 1) <5E2122D6-FFA2-3552-BF16-9FD3F36B40DB> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fff8fe03000 - 0x7fff8fe04fff libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff8fe21000 - 0x7fff8fe29fff libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
0x7fff8fe2a000 - 0x7fff8fe58ff7 libsandbox.1.dylib (460.60.3) <34A99F79-A8DD-37EE-9227-94381C53B5C2> /usr/lib/libsandbox.1.dylib
0x7fff8fe59000 - 0x7fff8fe5affb libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
0x7fff8fe5b000 - 0x7fff8fed2ff7 com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
0x7fff8ff32000 - 0x7fff8ff92fff com.apple.QuickLookFramework (5.0 - 696.7) <ECD33169-5EB1-3783-AF9E-1AB9240F8358> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff90028000 - 0x7fff90057ffb libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
0x7fff90058000 - 0x7fff90066ff7 libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
0x7fff90650000 - 0x7fff90cefffb com.apple.JavaScriptCore (11601 - 11601.7.8) <38585ADC-1AD4-3BD2-8972-B90344CE57C0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff90cf0000 - 0x7fff90d19fff libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib
0x7fff90d1a000 - 0x7fff90ee8ff3 com.apple.QuartzCore (1.11 - 410.14) <06A2BE20-38CB-3A89-9629-A782829DF977> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff90f0b000 - 0x7fff90f1bfff com.apple.AppleScriptObjC (1.4 - 32) <0C137AF5-9086-3205-9895-F3B8DF3B47FF> /System/Library/Frameworks/AppleScriptObjC.framework/Versions/A/AppleScriptObjC
0x7fff90f1c000 - 0x7fff90f36fff com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff90f37000 - 0x7fff91022ff7 com.apple.QuickLookUIFramework (5.0 - 696.7) <5A4AAFEC-D38C-3DA0-9361-CBF1D4C6B376> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff91023000 - 0x7fff9103fff7 libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
0x7fff91044000 - 0x7fff91057fff com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff91058000 - 0x7fff922befff com.apple.CoreGraphics (1.600.0 - 960.7) <82D77440-30B2-3DCF-9414-88EC57CAD6CD> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff922ed000 - 0x7fff92316ff7 libxslt.1.dylib (14.5) <8E03110E-1529-3BE8-B5F4-052A47A1674C> /usr/lib/libxslt.1.dylib
0x7fff923d5000 - 0x7fff923ebff7 libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff923ec000 - 0x7fff923f8fff com.apple.CacheDelete (1.0 - 1) <678B521D-5B50-3137-A972-33F2DF1D7A5A> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
0x7fff923f9000 - 0x7fff92401fff com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff924a3000 - 0x7fff9266cff7 com.apple.ImageIO.framework (3.3.0 - 1460) <5941D3B1-E38E-3593-8026-4FE56313259D> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff928c4000 - 0x7fff928d9ff3 libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff928da000 - 0x7fff928e5fff com.apple.AppSandbox (4.0 - 261.40.2) <52766210-B6EB-3B73-AB1B-42E0A9AD2EE8> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fff928eb000 - 0x7fff92949fff com.apple.SystemConfiguration (1.14 - 1.14) <ACAEDA14-FAA0-3F14-B476-DE492A52D383> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff9294a000 - 0x7fff9295aff3 com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff9295b000 - 0x7fff9295dffb libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
0x7fff9295e000 - 0x7fff9295ffff liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
0x7fff92960000 - 0x7fff92962ff7 libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
0x7fff9296d000 - 0x7fff929aeff7 libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff929d1000 - 0x7fff92a5edd7 com.apple.AppleJPEG (1.0 - 1) <BF7EDBDB-A52D-37F7-BDE4-EAD49310D7A9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff92a5f000 - 0x7fff92a6aff7 libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
0x7fff92a6b000 - 0x7fff92b12fff com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff92b15000 - 0x7fff92cc1ff7 com.apple.avfoundation (2.0 - 1046.9.12) <41BDD03F-5545-3B9F-8DD7-7106485BAE8B> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff92e75000 - 0x7fff931f3ff3 com.apple.VideoToolbox (1.0 - 1731.15.207) <6C7C261F-CB65-3AF1-92E7-16ACAD371EF4> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff931f4000 - 0x7fff93240ff7 com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff93349000 - 0x7fff9334cfff libsystem_sandbox.dylib (460.60.3) <2DDCB4AF-3037-34E5-A451-6846AFB9B85C> /usr/lib/system/libsystem_sandbox.dylib
0x7fff9334d000 - 0x7fff9334dfff libmetal_timestamp.dylib (600.0.44.2) <DEEA1127-7A5D-3EF2-A4B2-AE125CBA5DB5> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fff9334e000 - 0x7fff93352fff com.apple.LoginUICore (3.2 - 3.2) <5524E4BC-4700-39F4-AF06-E53322712EE0> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fff9335c000 - 0x7fff93361ff3 libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
0x7fff93362000 - 0x7fff9336dff7 libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
0x7fff93379000 - 0x7fff9338aff7 libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
0x7fff9338b000 - 0x7fff933b9ff7 com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff933ba000 - 0x7fff9342ffff com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff93430000 - 0x7fff93438fff libMatch.1.dylib (27) <3AC0BFB8-7E69-3DBE-A175-7F3946FC4554> /usr/lib/libMatch.1.dylib
0x7fff93619000 - 0x7fff936a6fef libsystem_c.dylib (1082.60.1) <28733D22-553E-3CBC-8D2C-EDCEB46E46AF> /usr/lib/system/libsystem_c.dylib
0x7fff936a7000 - 0x7fff936bcfff com.apple.ToneKit (1.0 - 1) <6D5AD263-308F-3F70-8D86-7027569D2694> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
0x7fff9374a000 - 0x7fff937beff7 com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff937e2000 - 0x7fff93812ff3 com.apple.CoreAVCHD (5.8.0 - 5800.4.2) <4AAFB1C4-3708-30F9-ACFA-90564347204C> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x7fff93813000 - 0x7fff93905ff7 libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
0x7fff93906000 - 0x7fff9390bfff com.apple.MediaAccessibility (1.0 - 79) <C5E61B45-1967-3602-A48C-31E132B998B2> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x7fff9390c000 - 0x7fff9391dff7 libsystem_trace.dylib (201.10.3) <E9311C03-9E61-3B13-AF3F-A64956FFF269> /usr/lib/system/libsystem_trace.dylib
0x7fff9391e000 - 0x7fff93928fff com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff93977000 - 0x7fff939dafff libAVFAudio.dylib (161.2) <1A98DBF3-490B-37FB-928A-AB1E36E6E5DD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x7fff939db000 - 0x7fff939faff7 com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff93a08000 - 0x7fff93b2ffff com.apple.LaunchServices (728.13 - 728.13) <91147A89-9D0D-3272-AD05-48E2835BD8D5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff93b30000 - 0x7fff93b75ff3 libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff93b76000 - 0x7fff93b7bff7 libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
0x7fff947c5000 - 0x7fff947eefff com.apple.ProtectedCloudStorage (1.0 - 1) <7436B2B3-943A-3500-B099-80F133B3E002> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff947fc000 - 0x7fff94892fff com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff94893000 - 0x7fff948b2ff7 com.apple.contacts.vCard (1.0 - 2137.1) <41529BD9-1BCC-3A62-92BA-2A7110867355> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
0x7fff9492d000 - 0x7fff94930ffb libdyld.dylib (360.22) <F103B2FB-D383-38CB-992A-E16BDCB00A03> /usr/lib/system/libdyld.dylib
0x7fff94931000 - 0x7fff94969ff7 com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff9496a000 - 0x7fff94d6cfff libLAPACK.dylib (1162.2) <42238ED4-6B7A-39D0-BFF2-304A0C287213> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff94d6d000 - 0x7fff94d98ff7 com.apple.AddressBook.ContactsFoundation (8.0 - 2137.1) <BAE70E9D-BCC8-3650-B554-6D646388EDEF> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x7fff95eb4000 - 0x7fff95ebcfff com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff95ebd000 - 0x7fff95ed3fff com.apple.CoreMediaAuthoring (2.2 - 953) <A8F1B6EE-8ABE-3DC2-9829-A268D016648E> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff9620e000 - 0x7fff96217ff7 libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
0x7fff96218000 - 0x7fff9621cfff com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff9621d000 - 0x7fff9626efff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff9626f000 - 0x7fff9630ffff com.apple.Metadata (10.7.0 - 972.34) <303B7C79-FB39-3A30-983B-78334FF39BB1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff96310000 - 0x7fff963e6ffb com.apple.DiskImagesFramework (10.11.4 - 417.4) <FB30D069-648F-3FB2-AA55-FC603606C49E> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff96406000 - 0x7fff96406ff7 libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
0x7fff96407000 - 0x7fff96431ff7 libc++abi.dylib (307.2) <922EFB36-0E9E-315B-8270-E81AC43472C0> /usr/lib/libc++abi.dylib
0x7fff9643a000 - 0x7fff96442fff libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
0x7fff96443000 - 0x7fff96474ff7 libtidy.A.dylib (15.17) <6859415D-7A43-384E-ABDD-AA6B2AA9FDCD> /usr/lib/libtidy.A.dylib
0x7fff964d6000 - 0x7fff964defef libcldcpuengine.dylib (2.7.3) <745C41A3-CEC0-3BF5-91DC-FCB140A3DACE> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff96518000 - 0x7fff9655aff7 com.apple.Metal (56.6 - 56.6) <30518711-8D00-3759-AA19-800D3C88E693> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff966c5000 - 0x7fff966c6fff libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
0x7fff96741000 - 0x7fff96748ff7 libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
0x7fff96749000 - 0x7fff96798ff7 com.apple.opencl (2.7.0 - 2.7.0) <DAEC71D4-E0E7-3E24-BB44-C977A798C575> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff96799000 - 0x7fff9679bff7 libquarantine.dylib (80) <B3B7B630-9012-3DA3-9458-5C009625E606> /usr/lib/system/libquarantine.dylib
0x7fff9679c000 - 0x7fff967abffb com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff967ac000 - 0x7fff967adff3 com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff968f8000 - 0x7fff96943ff7 com.apple.CoreMediaIO (703.0 - 4791) <4568C211-8A55-3E6D-9A28-7AD23A49583A> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff9698f000 - 0x7fff96abcff3 com.apple.CoreText (352.0 - 494.13) <143887ED-1AB1-3C62-AC65-4F13E26B6D7C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff96abd000 - 0x7fff96b77fff com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff96b78000 - 0x7fff96b80ffb libsystem_dnssd.dylib (625.60.4) <80189998-32B0-316C-B5C5-53857486713D> /usr/lib/system/libsystem_dnssd.dylib
0x7fff96b81000 - 0x7fff96b86fff com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff96b87000 - 0x7fff96bf6fff com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff96bf7000 - 0x7fff96c3dff7 libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
0x7fff96c3e000 - 0x7fff96c4cfff com.apple.ToneLibrary (1.0 - 1) <AF05AF34-9BC4-3BA6-81C1-7420F22C9D7D> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
0x7fff96d5b000 - 0x7fff96d76ff7 libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
0x7fff96f18000 - 0x7fff96f1bfff com.apple.Mangrove (1.0 - 1) <2D86B3AD-64C3-3BB4-BC66-1CFD0C90E844> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
0x7fff96f1c000 - 0x7fff96f6efff com.apple.CloudDocs (1.0 - 383.13) <5FD9138D-09D9-3B97-BBAD-5692E1687F30> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff96ff0000 - 0x7fff97035ff7 com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff97036000 - 0x7fff971e1ffb GLEngine (12.1) <278B3208-B0D0-3FAE-AC23-A4FA06837311> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff97492000 - 0x7fff974a0fff com.apple.opengl (12.1.0 - 12.1.0) <12EBDE6A-2F44-3429-8337-2BB36870BFD8> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff974ab000 - 0x7fff974f9ff7 libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
0x7fff97511000 - 0x7fff97540fff com.apple.securityinterface (10.0 - 55065.40.1) <1BB39B19-DD74-347E-A344-0E6781773577> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff97541000 - 0x7fff97543fff com.apple.SecCodeWrapper (4.0 - 261.40.2) <1F832591-59A8-3B3F-943F-D6D827463782> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fff975cf000 - 0x7fff975d8ff3 libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
0x7fff97618000 - 0x7fff9762fff7 libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
0x7fff97630000 - 0x7fff9787cff7 com.apple.AddressBook.framework (9.0 - 1679.10) <24F823D3-C3FC-3AF9-B8B3-C166539DBD11> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fff97880000 - 0x7fff97972ff7 libJP2.dylib (1461) <C40F7658-2459-3737-913C-FF1463C9F51D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff97977000 - 0x7fff9797ffff com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff97980000 - 0x7fff97a08fff com.apple.CoreSymbolication (3.1 - 58048.1) <C1A1A8DB-8A51-3A21-865A-3CEF22A0E67A> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff97a0b000 - 0x7fff97ac3ff7 com.apple.CoreDuet (1.0 - 1) <FC1EAEE1-73A4-3B13-A634-1D2A94D0C0B7> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff97aed000 - 0x7fff97b1fff7 libTrueTypeScaler.dylib (158.7) <020536E5-C032-30B5-864C-920D5F7DB6DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fff97b20000 - 0x7fff97c06ff7 libcrypto.0.9.8.dylib (59.60.1) <D68067AD-D1E0-3196-9796-51BE9B969C8E> /usr/lib/libcrypto.0.9.8.dylib
0x7fff97c74000 - 0x7fff97c86fff libsasl2.2.dylib (209) <11C7D200-0CA5-30F4-A19A-178CA81D48FE> /usr/lib/libsasl2.2.dylib
0x7fff97c88000 - 0x7fff97d68ff7 unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
0x7fff97d69000 - 0x7fff97df8ff7 libCoreStorage.dylib (517.50.1) <E6283FE9-B5AC-3110-8D4C-8E2BF185983E> /usr/lib/libCoreStorage.dylib
0x7fff97df9000 - 0x7fff97dfafff com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff97dfb000 - 0x7fff97dfbfff com.apple.audio.units.AudioUnit (1.13 - 1.13) <378B5292-F216-32AB-B628-8C33A72D7052> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff97e31000 - 0x7fff97e6eff3 com.apple.bom (14.0 - 193.7) <9B8AE30B-24A3-37AB-B04E-4CE67AED4775> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff97e74000 - 0x7fff97e74fff com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff97e7a000 - 0x7fff97e88fff com.apple.IntlPreferences (2.0 - 192) <0108A3F2-6A11-30B1-965D-A167CC8131EC> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
0x7fff97e89000 - 0x7fff97e9efff com.apple.AppContainer (4.0 - 261.40.2) <F220E702-1C00-3BD2-9943-C7E75C3B4418> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fff97ec8000 - 0x7fff9816eff7 com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff981df000 - 0x7fff981e3fff libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
0x7fff981ed000 - 0x7fff98214fff com.apple.shortcut (2.16 - 93) <2BA6DF3E-04C7-39C8-B311-3413E9FC9022> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x7fff98215000 - 0x7fff98588fff com.apple.FinderKit (1.4.4 - 1.4.4) <76E52C7F-CA82-337E-BF8E-9961F11C4B8D> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
0x7fff985ea000 - 0x7fff985ecfff com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff985ed000 - 0x7fff985effff com.apple.CoreDuetDebugLogging (1.0 - 1) <7C932160-AC9C-3173-900F-98138E829CB3> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff985f0000 - 0x7fff9864efff com.apple.CoreServices.OSServices (728.13 - 728.13) <477EA3F9-D13E-3D83-ABAD-4DC7DB134CF0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff986b8000 - 0x7fff986b9fff libffi.dylib (18.1) <5BA9612C-747E-33CE-9DB1-3C01ECF3041D> /usr/lib/libffi.dylib
0x7fff986ba000 - 0x7fff986bafff liblaunch.dylib (765.50.8.1.1) <6E0BA641-F99D-398C-B5F1-A921EFFB3786> /usr/lib/system/liblaunch.dylib
0x7fff986bb000 - 0x7fff986beff7 libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff98705000 - 0x7fff9870bff7 com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff9870c000 - 0x7fff98726ff3 liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
0x7fff98778000 - 0x7fff987c9ff7 libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib
0x7fff987ca000 - 0x7fff98808ff7 libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff989a8000 - 0x7fff989adfff com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff989ae000 - 0x7fff989d3ff7 libPng.dylib (1461) <B492B557-A17E-3FAA-A78E-6E7B5AD54F3C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff98a77000 - 0x7fff98ae2ff7 com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff98ae3000 - 0x7fff98b0ffff com.apple.framework.SystemAdministration (1.0 - 1.0) <1318B6A5-FFC3-3615-914D-95CBFE5BA727> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fff98b12000 - 0x7fff98dacff3 com.apple.security (7.0 - 57337.60.3) <4BF5CF26-6E34-35EC-8D41-58ED65F9BFB8> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff98dad000 - 0x7fff98dadfff libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
0x7fff98dae000 - 0x7fff98dcafff com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff98e19000 - 0x7fff98e36ff7 com.apple.pluginkit.framework (1.0 - 1) <0BA96479-0451-3DA9-A2AC-FE1D86D383AB> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fff98e37000 - 0x7fff98f54fff libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
0x7fff98fa5000 - 0x7fff98fceff7 libxpc.dylib (765.50.8.1.1) <2819674A-621A-3ACB-9657-DF42353D6CFD> /usr/lib/system/libxpc.dylib
0x7fff9910b000 - 0x7fff99113fff libGFXShared.dylib (12.1) <22F78420-D92E-3B5F-BA86-918A34289FCD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff994d8000 - 0x7fff996f9ff7 com.apple.CoreImage (11.4.0 - 366.4.20) <7721BA55-A10E-3425-8392-C5D7C510EAAB> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff996fd000 - 0x7fff997d6fff com.apple.CoreMedia (1.0 - 1731.15.207) <70CAD4A7-3F8B-3767-A420-98BE1062C230> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff998d4000 - 0x7fff999e2ff3 com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff999e3000 - 0x7fff999effff com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff99ab6000 - 0x7fff99b11ff7 libTIFF.dylib (1461) <A112AACB-AF27-33AC-9341-014F6312625B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff99b12000 - 0x7fff99c9eff7 libGLProgrammability.dylib (12.1) <6D4C193C-5F7B-3E82-81D9-D14D25BBD962> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff99c9f000 - 0x7fff99c9ffff com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff99ca0000 - 0x7fff99ca1fff libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
0x7fff99f58000 - 0x7fff99f63fff com.apple.DirectoryService.Framework (10.11 - 194) <6F827D0E-0F02-3B09-B2A8-252865EECA7F> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff99f64000 - 0x7fff9a01dff7 libvMisc.dylib (563.5) <BF612F7D-FA3B-3F9F-8BE7-8D1BCB21ECC5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff9a01e000 - 0x7fff9a01fff7 libodfde.dylib (23) <F84CB160-D638-3190-B6F5-A262E9AF09F6> /usr/lib/libodfde.dylib
0x7fff9a04d000 - 0x7fff9a09ffff com.apple.AppleVAFramework (5.0.32 - 5.0.32) <4F5F5CD6-631F-3C97-AA62-7DF19BD5EC15> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff9a0a0000 - 0x7fff9a10ffff com.apple.datadetectorscore (7.0 - 460) <E8616F01-90AC-3863-B18C-426E6DD1ACDE> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff9a119000 - 0x7fff9a137ff7 libsystem_kernel.dylib (3248.60.11.5.3) <F8228B30-AF62-3D47-A3A9-4A360787B238> /usr/lib/system/libsystem_kernel.dylib
0x7fff9a1cf000 - 0x7fff9a27afff com.apple.PDFKit (3.1 - 3.1) <27AF3C85-1C0B-389C-856C-2E527620C195> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff9a27b000 - 0x7fff9a310fff com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff9a368000 - 0x7fff9a38cfff com.apple.quartzfilters (1.10.0 - 1.10.0) <F5C482E2-5AFB-3959-8C01-C149D48E7583> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff9a3ba000 - 0x7fff9a3dcfff com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff9a3dd000 - 0x7fff9a522fff com.apple.QTKit (7.7.3 - 2943.13) <3E3DB3DD-8D7E-3478-B020-F975CCAAE522> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff9a902000 - 0x7fff9a91bfe7 libcompression.dylib (28) <F83F421D-115D-3457-A9AA-1BEB5070A30B> /usr/lib/libcompression.dylib
0x7fff9a91c000 - 0x7fff9a927fff libcsfde.dylib (517.50.1) <52F0DB6A-13B8-355E-ADFD-72834D3CA183> /usr/lib/libcsfde.dylib
0x7fff9a928000 - 0x7fff9a92efff com.apple.IOAccelerator (205.11 - 205.11) <3E86AB1B-C1CF-307D-900F-385C8D8C534A> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fff9a949000 - 0x7fff9a972ffb libRIP.A.dylib (970) <BA17C96B-83CC-3835-8AFD-CB5A69D3D26F> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff9a9be000 - 0x7fff9a9c3ff7 libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
0x7fff9aaf8000 - 0x7fff9ab9cfff com.apple.Bluetooth (4.4.6 - 4.4.6f1) <FFD72A25-3213-3857-9B4F-DD674F0078F0> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff9aba5000 - 0x7fff9abc1ff3 libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
0x7fff9abc2000 - 0x7fff9abd5ff3 com.apple.SafariServices.framework (11603 - 11603.2.5) <FBF52A64-E7B7-3C11-B04E-13A0A4F4009E> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff9abd6000 - 0x7fff9ac10fff com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff9ad37000 - 0x7fff9ad3afff libspindump.dylib (197.1) <B86EE257-4429-32E9-B98D-B12BFF2A373B> /usr/lib/libspindump.dylib
0x7fff9ad3b000 - 0x7fff9b08ffff com.apple.Foundation (6.9 - 1259.22) <C83D734C-6885-3549-80FE-70DEB04318D5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff9b0a1000 - 0x7fff9b0a5fff libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
0x7fff9b36e000 - 0x7fff9b3c1ff7 libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
0x7fff9b3c2000 - 0x7fff9b582ffb libBLAS.dylib (1162.2) <B4C21826-5EB3-3C6D-B75D-CA4886E2B6A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff9b644000 - 0x7fff9b64dfff com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x7fff9b64e000 - 0x7fff9b662fff com.apple.CoreDuetDaemonProtocol (1.0 - 1) <1D60D60C-914A-3BAB-8607-79F68F4C712E> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff9b66e000 - 0x7fff9b7b8ff7 com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff9b7b9000 - 0x7fff9b7c4fff com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff9b7c5000 - 0x7fff9b7ecfff com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff9b7f0000 - 0x7fff9ba77fff com.apple.CFNetwork (760.6.5 - 760.6.5) <FF0DD816-884C-3F9F-BA78-D0A1D3ED0723> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff9ba78000 - 0x7fff9baeffeb libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib
0x7fff9baf0000 - 0x7fff9baf9ff7 com.apple.DisplayServicesFW (3.0 - 378) <45BE1B99-8E10-32F0-A180-A6B6CB5883AE> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff9bafa000 - 0x7fff9bb0afff libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
0x7fff9bb0b000 - 0x7fff9bb59fff libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
0x7fff9bb5a000 - 0x7fff9bb8eff7 com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff9bb8f000 - 0x7fff9bc48ff7 com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff9bc58000 - 0x7fff9bd6afef libvDSP.dylib (563.5) <5702650E-DF08-3D58-B16F-9EF0A28702B3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff9bd7e000 - 0x7fff9bdb5ff7 com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff9bdb6000 - 0x7fff9be3fff7 com.apple.PerformanceAnalysis (1.0 - 1) <E783E193-8FAD-3A1E-9139-2F56E564CDE7> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff9bee7000 - 0x7fff9bee9fff libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
0x7fff9beea000 - 0x7fff9bef2fef libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
0x7fff9c60a000 - 0x7fff9c699fff com.apple.CorePDF (4.0 - 4) <849BBFF6-0700-3ED1-98DF-A6E93B9B707F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff9c6aa000 - 0x7fff9c6aafff com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff9cb4e000 - 0x7fff9cb65fff libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
0x7fff9ccca000 - 0x7fff9cd1aff7 com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff9cd1b000 - 0x7fff9d259ff7 com.apple.MediaToolbox (1.0 - 1731.15.207) <63AD3FB7-BAD3-3040-8A99-843033F24CF6> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff9d2d5000 - 0x7fff9d567ffb com.apple.RawCamera.bundle (6.21 - 879) <4F0A10FB-7C96-31E8-9A70-E30F615B2565> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff9d773000 - 0x7fff9d782fe7 com.apple.AppleFSCompression (81.20.2 - 1.0) <2FE122A9-5265-320A-9600-FFC5CE4DE197> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff9d783000 - 0x7fff9daee657 libobjc.A.dylib (680) <D55D5807-1FBE-32A5-9105-44D7AFE68C27> /usr/lib/libobjc.A.dylib
0x7fff9eb5e000 - 0x7fff9eb60ff7 com.apple.securityhi (9.0 - 55006) <AC151C58-A7AD-3ECF-B15D-5E09FF94FC23> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff9ec78000 - 0x7fff9ec89fff libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
0x7fff9edf1000 - 0x7fff9ee1bff7 GLRendererFloat (12.1) <0412B850-BB25-33B1-AF0D-8E6297D4620E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff9ee1c000 - 0x7fff9ee38ff7 libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
0x7fff9ee39000 - 0x7fff9ee40ff7 com.apple.phonenumbers (1.1.1 - 105) <A616AFB5-2336-385A-B058-16A423D2B21B> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fff9effc000 - 0x7fff9f2f1fff com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff9f392000 - 0x7fff9f395fff com.apple.IOSurface (108.2.4 - 108.2.4) <E7A63C0D-2FDA-3BC6-947D-07E3C4A13110> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff9f396000 - 0x7fff9f3a2fff com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff9f3a3000 - 0x7fff9f688ffb com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff9f708000 - 0x7fff9f721fff com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff9f722000 - 0x7fff9f726fff libGIF.dylib (1461) <81C36C41-AEF2-33CC-BBCC-C43F48F63906> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff9fa66000 - 0x7fff9fab2ffb com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff9fab3000 - 0x7fff9fab6ffb libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
0x7fff9fabc000 - 0x7fff9fabefff libCGXType.A.dylib (970) <A931200A-B248-39EF-8A8B-311D881BE372> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff9facf000 - 0x7fff9fb21fff com.apple.ImageCaptureCore (7.0 - 7.0) <9F3123D8-29D2-332F-AD6B-AB9BF1A58022> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff9fb22000 - 0x7fff9fb3dfff com.apple.aps.framework (4.0 - 4.0) <CAD47B6E-A581-3B35-885B-67B206F41D5E> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff9fb5d000 - 0x7fffa001bfcf com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fffa001c000 - 0x7fffa0021ff7 com.apple.NetFSServer (2.0 - 1) <A233387F-2626-334C-8CA6-E947B56E1654> /System/Library/PrivateFrameworks/NetFSServer.framework/Versions/A/NetFSServer
0x7fffa0022000 - 0x7fffa0077fff com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fffa008d000 - 0x7fffa0095fff com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fffa0096000 - 0x7fffa00a1fff libkxld.dylib (3248.60.11.5.3) <B6A73C46-FEF3-390A-A816-89F1D35B3D53> /usr/lib/system/libkxld.dylib
0x7fffa00a2000 - 0x7fffa00b5fff com.apple.contacts.ContactsPersistence (1.0 - 2137.1) <71232F20-11BD-370D-9F43-F262BFE46C93> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersistence
0x7fffa00b6000 - 0x7fffa00b6fff com.apple.quartzframework (1.5 - 21) <5DC3D0D9-9E3F-3AA5-92F1-F229907A49B9> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fffa00b7000 - 0x7fffa00bcff7 com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
0x7fffa00bd000 - 0x7fffa0119fff com.apple.Suggestions (5.0 - 180) <450BCB58-786F-37DC-9AC7-2E3D13198032> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
0x7fffa0125000 - 0x7fffa0128ff7 com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <6932B5EC-0EA9-333D-BF7E-665047392FEC> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fffa01a2000 - 0x7fffa01bbfff com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fffa01bc000 - 0x7fffa05eafff com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fffa0e2c000 - 0x7fffa0e92ff7 libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib
0x7fffa0ea6000 - 0x7fffa0fa2fff libFontParser.dylib (158.7) <393EFEA3-42B7-38DA-99DA-D01DEAA734CF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fffa104d000 - 0x7fffa1071ff7 libJPEG.dylib (1461) <614518EC-7C72-3051-80AB-1DBA39C63BAC> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fffa1072000 - 0x7fffa1158fef unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x7fffa1159000 - 0x7fffa11c0fff com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fffa11ce000 - 0x7fffa12bdff7 libxml2.2.dylib (29.13) <1C510151-06AE-322B-A725-79C91EF79E1C> /usr/lib/libxml2.2.dylib
0x7fffa12be000 - 0x7fffa12e0ff7 com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fffa12e1000 - 0x7fffa12e1fff com.apple.Accelerate (1.10 - Accelerate 1.10) <5831771A-C1C3-3625-9FE9-2CCB6B2E7EE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fffa12e2000 - 0x7fffa12f2fff libSparseBLAS.dylib (1162.2) <6F591A0F-80D0-384D-8304-B035C4ED1BBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fffa130c000 - 0x7fffa1318ff7 com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fffa1319000 - 0x7fffa14bfff7 com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <370E95BC-956C-3962-86CC-0A14CF6A0389> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fffa14dc000 - 0x7fffa14e5ff7 com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fffa14e6000 - 0x7fffa177cfff libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 7
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 9604
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=589.0M resident=0K(0%) swapped_out_or_unallocated=589.0M(100%)
Writable regions: Total=757.3M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=757.3M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
ATS (font support) 32.9M 9
ATS (font support) (reserved) 8K 3 reserved VM address space (unallocated)
Accelerate.framework 256K 3
Activity Tracing 2048K 2
CG backing stores 8716K 8
CG image 232K 47
CG shared images 400K 12
CoreAnimation 732K 88
CoreUI image data 1816K 24
CoreUI image file 384K 7
Dispatch continuations 32.0M 2
Foundation 24K 3
Image IO 1728K 29
Kernel Alloc Once 8K 3
MALLOC 535.7M 218
MALLOC guard page 32K 7
MALLOC_LARGE (reserved) 7692K 2 reserved VM address space (unallocated)
Memory Tag 242 12K 2
Memory Tag 249 156K 4
Memory Tag 251 56K 4
OpenCL 8K 2
Process Corpse Info 2048K 2
STACK GUARD 56.3M 67
Stack 40.6M 73
VM_ALLOCATE 67.1M 21
__DATA 69.6M 861
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__LINKEDIT 129.4M 345
__TEXT 459.6M 627
__UNICODE 552K 2
mapped file 102.4M 80
shared memory 16.4M 11
TOTAL 1.5G 2539
TOTAL, minus reserved VM space 1.5G 2539
Model: MacPro4,1, BootROM MP41.0081.B07, 8 processors, Quad-Core Intel Xeon, 2.26 GHz, 6 GB, SMC 1.39f5
Graphics: NVIDIA GeForce GT 120, NVIDIA GeForce GT 120, PCIe, 512 MB
Memory Module: DIMM 1, 1 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313132553742465238432D47372020
Memory Module: DIMM 2, 1 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313132553742465238432D47372020
Memory Module: DIMM 3, 1 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313132553742465238432D47372020
Memory Module: DIMM 5, 1 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313132553742465238432D47372020
Memory Module: DIMM 6, 1 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313132553742465238432D47372020
Memory Module: DIMM 7, 1 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54313132553742465238432D47372020
Bluetooth: Version 4.4.6f1 17910, 3 services, 19 devices, 1 incoming serial ports
Network Service: Ethernet 2, Ethernet, en1
PCI Card: NVIDIA GeForce GT 120, Display Controller, Slot-1
Serial ATA Device: HL-DT-ST DVD-RW GH41N
Serial ATA Device: WDC WD6400AAKS-41H2B0, 640.14 GB
USB Device: USB 2.0 Bus
USB Device: USB Flash Drive
USB Device: My Passport 07A8
USB Device: FreeAgent GoFlex
USB Device: Keyboard Hub
USB Device: USB Receiver
USB Device: Apple Keyboard
USB Device: USB Bus
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Bus
USB Device: USB Bus
FireWire Device: built-in_hub, Up to 800 Mb/sec
Thunderbolt Bus:
