When i try to transition from two clips with a diagonal, the values on motion tile are always incorrectly showing up. When i multiply the y value by 2 and change the x value to a negative, it always ends up not steep enough to fully transition like this: http://i.imgur.com/x0Cjjew.png
any ideas? i really need help!
Not sure what you are saying. Your footag is scaled, hence the values would need to be different. I'm afraid you have a misunderstanding here. To make things predictable, pre-compose the scaling before applying effects.
Mylenium
Hi Manica,
Did you fix this problem yet?
Kevin
