Hi Guys
I am a IT guy support for a company.
One of the staff installed Adobe Photoshop CC 2015 on a computer
After a while , she keep getting any error message something about not enough memory to run
The computer spec are
Dell Latitude E7250
Processor is Intel Core i5 5300U 2.30Ghz
Memory is 4.Gb
harddisk is 256 GB SSD
Is this machine okay to run Adobe Photoshop CC 2015?
I looked around and found out for CC 2015
'Windows
Intel® Core 2 or AMD Athlon® 64 processor; 2 GHz or faster processor
Microsoft Windows 7 with Service Pack 1, Windows 8.1, or Windows 10
2 GB of RAM (8 GB recommended)
2.6 GB of available hard-disk space for 32-bit installation; 3.1 GB of available hard-disk space for 64-bit installation; additional free space required during installation (cannot install on a volume that uses a case-sensitive file system)
1024 x 768 display (1280x800 recommended) with 16-bit color and 512 MB of dedicated VRAM; 2 GB is recommended*
OpenGL 2.0–capable system"
Would appreciate any help from you guys !
The Latitude E7250 has an integrated Intel HD Graphics 5500, which has been tested for Photoshop.
The out of memory error may be referring to RAM
Take a look at Preferences > Performance
More details on adjusting the memory usage, and monitoring the efficiency indicator can be found here:
Thanks, will try this on the computer and let you know if it works
Also because people are very confused about memory, check the actual message. It could be that the disk is filling. Photoshop creates scratch files if many gigabytes. The machine isnt going to be suitable for very high definition work so check the pixel size.
Thanks all for the reply,
The guide works on the user`s computer
