Error compiling movie: Unknown error
Jan 26, 2017 Jan 26, 2017
Hi all,
Just recently pulled out a copy of Premiere Elements 13 I had lying around and tried to use it to edit a video. Everything works smoothly...until I try to render. The moment it tries to do anything, it gives up with the message: "Error compiling movie: Unknown error".
I've read through various other threads on this issue, but none of them quite match mine - this is a very short project (1 minute 30 seconds), I do have plenty of disk space, there's not much intermixing of weird file formats (MTS for camcorder video, AVI from After Effects for a single animation), and I did make the necessary sacrifices of Coke and pizza to the computer overlords. I've tried rendering tiny work areas, disabling auto-save...the works. No such luck. Does anyone have any suggestions on how to fix this?
Specifications:
As mentioned, Premiere Elements 13
Windows 7 Ultimate SP1
Core i7-4790 3.6 GHz
NVIDIA GeForce GTX 745
24 GB RAM
3 TB HDD, about 300 GB available for this (I dual boot and Windows is the secondary)
Thanks in advance!
747
Community Expert , Jan 26, 2017 Jan 26, 2017
Have you got Quicktime 7's components installed, per the program requirements?
Have you tried downloading the free trial of version 15, just to see if it duplicates or resolves the problem?
about ppro but may help
Error Compiling Movie... some past discussions and ideas
May be caused by . in name https://forums.adobe.com/thread/2166620
-1st, create a new project and import the project that has errors and see if that fixes the problem
-http://helpx.adobe.com/premiere-pro/kb/error-compiling-movie-rendering-or.html
-and a long discussion https://forums.adobe.com/thread/1240823
Thank you, but unfortunately none of those worked...there wasn't a . in the name to begin with, I can't seem to import an Elements project into another one at all, and none of the other solutions have worked so far...
I had to install QuickTime to fix another issue (a crash on startup). Haven't tried 15 yet...I'll download the trial and take a shot with it later tonight, then report back!
Jan 28, 2017 Jan 28, 2017
Well, it took me a little longer than I'd hoped to try it out...I had another, unrelated hardware issue come up and focused on fixing that first.
Now that that's done, I've installed the trial and attempted to export the project with it. The result? Success, surprisingly...it renders without any issues at all in 15. Very strange...
I suppose I should just upgrade at this point?
Sounds like the easiest solution.
