I need help. I need to create a certificate of completion for a county training session. Are there any templates out there I can use??
You should look for templates for e.g. MS Word or InDesign, and then use these to create your certificates - yo are much more likely to find non-PDF formats. Once done, convert to PDF, and you can then create a field in the PDF document in which you enter the name of the participant. You can even set up an automated process to create all your certificates based on e.g. an Excel document. Here are instructions to do that: Batch-Import Excel Data into PDF Forms - KHKonsulting LLC
Hi WillMan54,
Are you working with any specific application or looking for a template in the Acrobat application.
Could you please help us with more information, that would be helpful.
Akanchha
