I have an InDesign document containing hyperlinks that was created before the 2017 CC update. (created in 2016) Whenever I try to launch/open the hyperlink control menu InDesign crashes. The hyperlink menu launches when I start with a blank document. However, when I switch back to my previously created InDesign file that contains hyperlinks, InDesign crashes again. Is anyone else having this issue? I am constantly updating older documents that have tons of interactive hyperlinks. It's not practical to try and reset all of these hyperlinks.
- Trina
[Moved from non-technical Forum Lounge to specific Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
I myself haven't had this issue, but it sounds like this patch might work. Fixes problems with Quick Apply that also seem to be affecting the Hyperlinks panel: http://indesignsecrets.com/fix-quick-apply-crash-cc-2017.php
Thanks for the input. I'm sure this patch will probably solve my issue. Unfortunately, I can't get the Copy Plugin script from Adobe to progress to the install/ok command. I have an inquiry into Adobe about this issue.
Ah, good luck! And let us know how it turns out!
The plugin worked! Thanks. Adobe's instructions for installing the plugin was missing one small installation step. I figured it out and the hyperlink panel is working now. I went ahead and put in a correction request for their installation instructions. Hopefully, they will revise it soon. Thanks again.
Hi Trina,
can you tell us what this one small installation step missing was?
Uwe
Sure,
It is a very small oversight but important to someone who isn't familiar with installing software patches.
If you go to the Adobe support page that covers this patch/update InDesign CC 2017 crashes on macOS you will see 6 steps to installing the CopyPlugin patch. After STEP 4 you must select the Adobe InDesign application icon before the installation script will progress to STEP 5 where you can "Click OK." (If you don't select the Adobe InDesign application icon the "OK" button is greyed out and you can't proceed.)
Great!
thank you it works
