When I try to edit a document in Adobe Acrobat DC, the tags get all wonky. Does this happen to you?
Can you please be a bit more specific: What type of edit operations are you performing, and what do you mean by "all wonky"? Can you provide a sample document before and after?
When I change the color of the text, the tags move around; so that portion has to be retagged. Also, if I add in text or delete text, it does the same thing.
This is not something that I've ever experienced. How was the document tagged? Again, can you provide a sample document that shows this problem?
I will try to send you something for the end of the day. Thanks.
