Report for behind the text frame from rectangle or image
Contributor ,
Jan 27, 2017 Jan 27, 2017
Hi All,
How to find and report the hidden text frames, example the below text frame behind the rectangle frame.
Note: we must ignore the grouped, anchored and wrap objects.
The below sample is not working
//An InDesign file with two objects on the same page,
//one text frame and one rectangle that holds an image.
var d=app.documents[0];
var myImageContainerDup = d.allGraphics[0].parent.duplicate();
var myTextFrameDup = d.textFrames[0].duplicate();
//Make a selection:
app.select([myImageContainerDup,myTextFrameDup]);
//ID for New MultiStateObject: 83621
//Adding a MultiStateObject (MSO) with the two selected objects:
try{app.scriptMenuActions.itemByID(83605).invoke()}catch(e){alert(e);$.writeln("Something went wrong!");exit()};
//The object in the front goes to state 1
//The object in the back goes to state 2
var myMSO = d.multiStateObjects[-1];
//State 1
$.writeln("Front:"+"\t"+myMSO.states[0].groups[0].pageItems[0].getElements()[0].constructor.name); //=> "TextFrame" if text frame is in front
//State 2
$.writeln("Back:"+"\t"+myMSO.states[1].groups[0].pageItems[0].getElements()[0].constructor.name); //=> "TextFrame" if text frame is in the back
Thanks in advance,
Selva
Scripting
648
Jan 28, 2017 Jan 28, 2017
Hi Selva,
what exactly is not working?
Building the MSO ?
If you are working with selected objects and a menu action you should have the MSO panel open:
app.panels.itemByName("$ID/$$$/Panel/MSOPanel").visible = true;
Or is the problem to get the right order of page items in a certain state?
For the first state of the first MSO in an document this will return an array of page items in stacking order:
app.documents[0].multiStateObjects[0].states[0].pageItems[0].allPageItems
Uwe
Or do you want to get the pageItems in the active state of an MSO?
Then check the value of activeStateIndex of the MSO.
var myMSO = app.documents[0].multiStateObjects[0];
var activeStateIndex = myMSO.activeStateIndex;
myMSO.states[activeStateIndex].pageItems[0].allPageItems;
Uwe
Contributor ,
Jan 30, 2017 Jan 30, 2017
Hi Uwe,
Thanks for the guidance.
Sorry i'm going completely wrong way based on my previous code. Because, I check only the hidden text frame in every pages (behind from rectangle or graphic).
Kindly guide to me.
Selva
Sorry. I simply don't get what you are after…
Are you talking about MSOs or not?
Uwe
selvam214 wrote:
… Because, I check only the hidden text frame in every pages (behind from rectangle or graphic).
If you are still talking about a text frame in an MSO that is not in the active state of that MSO, it is not "hidden" technically if you refer to the property "visible" of text frames. There is no property "hidden" for text frames. There is an object "hiddenText", but that belongs to a different realm: Conditional Text.
So you see: I simply have no clue what you are talking about.
Uwe
Contributor ,
Feb 01, 2017 Feb 01, 2017
let me explain you clearly about my problem.
I want to find out the object frames under which a text frame is available. In the second image which i have already sent, you may find a object frame in green color under which a text frame is available. this needs to be shown as error.
please guide me and let me know if still it is unclear.
Selva
May 29, 2017 May 29, 2017
Is this right answer. I have the same query like  to find hidden textframe behind (Rectangle or Images). So Please can you share right scripting.
Sangeetha.K
