Thanks for the tips.
I don't see where/how to change the default highlight color in Acrobat 9.
I'd like to be able to set it for either a particular file, or for all future use (default setting).
Right click (or ctrl-click) on the highlighter tool to change the default colour.
When I go to print a PDF that has highlighted test, the highlight color does not print. Yes it is a color printer. What gives?
What type of printer are you using (Brand, Model, is it a wireless connection or a wired connection)?
Also, it could be the settings you are using. Do you have it set to print document AND mark-up?
Pax,
Voner
(I usually put my contact information here, but it will just be removed by an administrator)
A little late for the original post, but for anyone else looking to highlight text in Acrobat Pro 9 and be able to change the highlighter color...
Accessing the highlighter tool:
Changing the highlighter color:
While using the Highlight Text tool, turn on the Properties Bar (make it visible)
This will give you quick access to your highlighter properties, and it will remember your selected color between uses.
The Properties Bar is context aware and will change based on the tool you're actively using, so you have access to change your highlight color through it when the Highlight Text tool is selected/in use.
THANKS SOOO MUCH!!! MY JAW JUST DROPPED AT HOW EASY!!!
I'm wondering if I can put 4 or 5 highlight colors right on a quick toolbar so I can pick the color I want with one click on a handy toobar.
Nope, you can't...
hi,
refering to the possibility of more easily accessing the coloring option:
since there is a demand for being able to do this simple thing, i find no reason for this not being implemented already..
in the end, it's about usability of the interface and options; the option of coloring exists already, it just needs to allow users to more easily access it.
i'm totally waiting for that simple feature...
luck
Ok, I am curious about this one.
I use PDF to read my texts for school, as well as journal articles downloaded from the university library. I can highlight text on journal articles, but not on my PDF text. Is there a reason for this?
jmcarroll79: Are you sure you have PDF text (or actual text)? Often you have a picture of text and the picture can not be highlighted. You can use the drawing tools to underline just like a pencil in such cases, but not to highlight a graphic.
I'm in a similar boat. I read a lot of patent documents, most of them PDFs but not text proper; they're scanned images of text. I like the way Adobe Reader (free) renders background light blue when I click, makes for easy reading. What I can't figure out how to do is make it global i.e. whole document not just page-by-page.
As a screenwriter and producer, I find this immensly helpful! To change the DEFAULT color, there is a checkbox at the bottom of the properties pop-up that I originally didn't see - very helpful. Saves time manually highlighting parts for the same actor with different roles.
Adobe needs to make the background modifiable for the user. I should be able to pick whatever background color I want. That ugly gray is terrible!
This is an application that we use often, they should make it more user-friendly and improve the appearance.
It should not take this long to fix! Obviously the Customers want this.
I don't know how, but my highlighter highlights like a pencil and I cant change it back, can anyone please tell me how to fix that before I pull my hair out
Mine did this too. Only for some documents. I finally opened the comment toolbar and on the far right is a bucket (color picker) and some lines (line thickness). I used the line thickness slider to create a fatter line. I suppose I will have to change this for the other documents but at least I found something that worked for me.
"my highlighter highlights like a pencil and I cant change it back"
