Workspace doesn't show the entire content
Jan 28, 2017 Jan 28, 2017
Hi guys,
I have a problem which I dont know how to solve. If I open any photo or picture or even if I open a new project with blank space, it won't show it. I can see in layers that there is something. It looks like I can use any tool, but I cannot see the content. I have tried many times reset preferences and reinstall photoshop, but nothing changed. Would you please help me?
405
Community Expert , Jan 28, 2017 Jan 28, 2017
A couple of things to try:
Can you go to preferences Performance and set Cache levels to at least 4.
If already set that way try unchecking "Use Graphics Processor"
You will need to restart after each
Dave
Adobe
What happens to the image when you select ctrl/cmd 0 (the image should fit the screen)?
Nothing. It shows the function, but image doesn't fit to the screen. There are now centered side sliders but there is still a blank space.
Try resetting your Photoshop preferences using this technique:
Close and relaunch Photoshop, and IMMEDIATELY hold down Ctrl + Alt + Shift (Windows) or Cmd + Ctrl + Opt + Shift (Mac), and respond in the affirmative to the dialog asking if you really want to replace the preferences. you must be extremely fast on the keyboard (if you don’t see the confirmation prompt, you were too slow)
You may have to do it a couple of times before you get the hang of it!
I have tried this method many times. Even now. But unfortunately - nothing have changed, again.
Uninstall the Photoshop application using the dropdown in the Creative Cloud app, then run Adobe Cleaner Use the Creative Cloud Cleaner Tool to solve installation problems and then reinstall Photoshop.
I've tried this option twice without any results. Same for now. And that Cleaner did not offer me uninstall photoshop cc 2017 so it looks like it was uninstalled properly via Creative Cloud uninstaller.
Dave
Oh, finally! Cache levels: 4 have been set by default, but I have changed Cache tile size to 1024 K and unchecked using graphics processor. After relaunch my photos are finally showing!
Thank you all!
Thank you all!
Excellent, and thanks for the feedback.  Looks like I was wrong about cache levels.
Ok there is another step you try now, so that you don't lose access to features that use the GPU
Re-enable the graphics processor but then click on advanced settings and try each of the three options Basic, Normal and Advanced in turn (restarting each time). If any work - keep the highest one that works.
Dave
Dave, I tried every three modes but unfortunately, neither of them didn't work. So I had to turn of graphics procesor.
The truth is that my computer is old. It is almost 7 years I've been using it. It has Nvidia 540M GPU and it is probably not the best for Photoshop CC, but anyway, we've found the solution.
I am thinking about buying a new computer later. I will need it for my school and later I hope for my work.
Once again, thank you!
I don't think it is cache levels Dave.  That usually shows as heavy noise when cache levels is set to 1.  Any level higher than 1 fixes that.
It could be GPU related, but I didn't respond to this thread earlier, because I have never seen anything like it in all the years I have been posting here.  It's all files, _and_ new documents.
The document window is showing RGB 38,38,38 and I am wondering if that is in any way significant?  I don't know if those values remained accurate from a screen grab though, but the interface shows about right, so it won't be far off.  It's a really interesting problem.
Dave has read it as CS6, (from his instructions of resetting Preferences) but I can't see that anywhere in the thread, and the interface looks the same to me with CS6 and CC.  I'd want to be very sure that the reset took OK before proceeding.
Ahhh,  just seen that the OP has now mentioned CC2017.
