TRAUM URLAUB im BESTEN HOTEL der Welt - YouTube
Ich würde gerne so eine Einblendung in mein Projekt einfügen habe aber keine Ahnung wie ich das machen soll.
Einfach mal auf den Link gehen und bei Sekunde 5 des Videos gucken. (unten Rechts)
[ Verschoben aus dem Forum für die Community-Hilfe-Anwendung zu einem angemesseneren Forum. Auch bearbeitet den Titel zu prägnanter - Moderator ]
I gave you a step by step. It is pretty easy. Here's what the composition would look like:
Starting at the bottom:
You can do that in After Effects with basic shape layer animation, text layers, and the use of Track Mattes.
If you are talking about this graphic animation:
It can be recreated with duplicate text layers for each color, a solid or shape layer for the white banner and a couple of animated track mattes or masks to do the reveal. All basc AE skills. There are no effects or plug-ins that will do this kind of thing with the click of a button.
I would create the first text layer and animate the text, duplicate the animated text layer, put a solid or a shape layer between the text layers, animate the solid or shape layer, then use the top copy of the text as a track matte for the solid layer.
If you are new to AE please start here: Basic AE (I hope there is a German version or translations available for you.)
can you make a template for me ?? would be very nice i need this for school until monday
Are you asking us to do your homework for you?
no, i just need this one thing. i edited the hole project on my own just this one thing is missing
There you go. One approach to the problem. There are many ways to do this but I think this is the fastest and easiest one that uses the fewest keyframes.
If you really want to get fancy you can tie the Source Text of the bottom text layer to the source text with an expression by simply dragging the expression pickwhip from the original source text property to the duplicate (yellow) source text layer. Now whoever you type in the top test layer appears in the second text layer. That's how you would create your own template.
i dont understand this instruction. can you send me the ae file pls
