Hi I am trying to use the create an animated gif, the first time I used this it worked a treat. I am now trying to create another gif and the button referred to in the tutorial Create animated GIFs | doesn't show up? see attached image. I am converting video.
Thanks Chris
Your screen shot is showing a Frame animation, and not a video in the timeline. You are not seeing the button you referred to, because you have already converted the video into a frame animation, and you can now export it as an animated GIFF.
Do you know how to do the export?
Trevor thanks for your guidance - much appreciated Chris
Hi If you are importing your video (step 1 in the instructions) and you have "Make frames from layers" checked then when you open the timeline the frame animation will already be created so steps 2&3 are not needed
Just open the timeline and go straight to step 4 in the instructions
Dave
Dave thank you, clearly having a senior moment! Much appreciate your quick response. Chris
