Lightroom
Jan 27, 2017 Jan 27, 2017
In Lightroom is er kleurverschil tussen een foto voor en n in de module ontwikkelen.. Waar zou dat aan kunnen liggen?
485
Community Expert , Jan 27, 2017 Jan 27, 2017
A screenshot of the problem would be helpful.
But it is possible that you have a defective monitor profile - try setting it to sRGB, or Adobe RGB if you have a wide gamut monitor.
If this fixes the problem, you should ideally calibrate the monitor with a hardware calibrator.
See https://www.lightroomqueen.com/articles-page/how-do-i-change-my-monitor-profile-to-check-whether-its-corrupted/
See https://www.lightroomqueen.com/articles-page/how-do-i-change-my-monitor-profile-to-check-whether-its...
Hello Per,
I have chosen for srgb in my colormanagement. Now the colors are the  same.  Great!
But my screen is an Eizo screen and I wonder why the profile after calibrating my screen and when I use that profile the colors are not the same in LR.
Greetings, Ria
Jan 28, 2017 Jan 28, 2017
So the profile you were using before changing to sRGB was created by calibrating?
Then I guess that the profile had somehow become corrupted, and that you should calibrate again.
It is always better to have a profile created with a hardware calibrator - it will be more accurate than sRGB or Adobe RGB.
What model Eizo do you have, and what calibrator?
And are you using the Eizo Color Navigator software when calibrating?
Jan 29, 2017 Jan 29, 2017
Yes, the profile had somehow become corrupted. But I have calibrate it again and when I want to go from LR to PS there comes the message corrupt. Not when I use the sRGB profile. I wonder what is the problem.
My Eizo is:CG223W and I always use the Eizo Color Navigator software with the Spyder 3 Pro.
This is my profile
Kalibreren van Eizo-scherm
Start met het Eizopictogram (vlindertje)
Create a new target                        next
Monitornative              next
Brightness                       100 (stond oorspronkelijk op 80)                  next
White point                   D65              next
Zwartpunt                       minimaal                        next
Gamma      2.20             next
R                                            2.20
B                                            2.20
Finish
Naam geven                   Achter de naam die er staat een datum zetten. Create now
Spyderpro op monitor plaatsen
Proceed
Save
What have you chosen under Profile policy > Version in Color Navigator?
Lightroom has a problem with version 4 profiles, so if you chose version 4, try recalibrating with version 2.
See also Re: Lightroom and colormanagement with two monitor profiles
Iam using version 5.3.0.3
I cannot find the profile policy.
The latest version of Color Navigator is 6.4.15.3, so you should update.
There seems to be a problem with Color Navigator 5 and Spyder calibrators.
See post #12 in the thread I linked to above.
To get to the profile policy, start out by creating a new target.
Highliht an existing target, and click Create a new target.
Go through the process until this screen appears, and click Customize profile, which will bring up the screen I posted previously.
Then choose Version 2.2.
So I can better update to the latest version instead of  2.2
How can I update this version in the colour navigator?
Thanks for all your information and help.
Colour Navigator is upgradet.
There is no corrupt profile in LR --> PS.
The colors in LR develop after import (bedore and after) are the same.
Great!!! Thank jou very much.
