For example, when I select the brush tool the mouse simply stays as the default apple mouse.
Hi Lucian Rex Alexander-Roy​! You posted your question in the non-Technical Lounge forum. I'll move it to the Animate forum so that you can get answer.
are you using a drawing pad?
I am! Is that causing the problem?
almost certainly.
but you can test. detach your drawing pad and test using a mouse.
if it is your drawing pad, update your drivers to the latest to see if that helps.
