Hi,, this issue has been irking me for a while:
When I zoom-in and use the brush tool, everything works fine.. until I make a mistake, and have to use the 'UNDO' command. After that, the brush lags like crazy, and to get rid of the lag I have to stop everything, zoom-out, and then zoom back in (and then rinse/repeat). Obviously this doesn't really allow for a work flow.. Any advice on fixing this would be much appreciated,, thanks!!
Hi
I'm not seeing that here. It would be useful to know some system information and what you are doing with the brush at the time e.g. were you using the brush to paint on a layer/ a mask / a channel etc, so that someone on a similar system can try and replicate it.
My system for comparison : CC2017.0.1 ; Windows 10 Pro; 64GB RAM AMD HD7970 3GB graphics
Preferences Performance - Use Graphics Processor checked and drawing mode set to "Advanced" - Cache level 4 ; Cache size 1024k
Wacom Intuos Pro - D
...Copy link to clipboard
Hi
Wacom Intuos Pro - Driver 6.3.17-3
Dave
Hi, thanks for the response.. i found that if I press "command z" to undo instead of "option command z," there are no lag issues.. So this solves my issue for the time being..
