Hi All,
Is there any event available to bind on "app.encoder" object when AME Render is Stopped from AME UI? "onEncoderJobError" doesn't work.
Premiere Pro version: 11.0.1
Extension Type: Panel
Thanks & Regards,
Meet Tank
I've updated PProPanel on GitHub, to respond to the helpful new OnEncoderJobCanceled message.
Could you try the current version (11.0.2)? I'm pretty sure cancels make it through, now.
Hi Bruce,
I have tried with 11.0.2 version, but still "onEncoderJobError" is not fired. Is there any other event gets invoked?
Meet
Please send me a failing ExtendScript snippet, at my day job address; b b b at adobe dot com
Hello Bruce,
I have sent you an email with a code snippet.
Meet
Hello Bruce Bullis,
I can't find "OnEncoderJobCanceld" event inside Samples/Premiere.jsx at master · Adobe-CEP/Samples · GitHub
Could you please provide some details about this change? How to use this new event? Which Premiere Pro version to use, etc.
Meet
Sorry; try now.
Which version to use = 11.1 and higher.
How to use = If you register a function, it will be called if the user cancels the render job.
Thanks Bruce Bullis​. It is working now. Surprisingly, it works on older versions too!! (e.g. Pre Pro 9.0.0)
Meet
