HELP! I cannot see the bottom of any dialogue boxes to click ok/cancel etc
I assume Adobe Lightroom> if so, its a well known issue that Adobe is fully aware of
work around - set your desktop to a different rez, make the edits you need then reset your desktop back to widescreen
What Adobe product are you using? I'll move your question to the correct forum. This is a non technical forum.
Have you adjusted the screen resolution in some way?
Right click on the taskbar (the bar across the bottom of the screen), select settings and then turn on "Automatically hide the taskbar in desktop mode"
when you move the mouse down to click ok the taskbar will just pop back up and block you... at least it does in windows 8.1, 8 and 10
Moved to the Lightroom forum.
I'd be interested to know what screen resolution you're using when you see this issue.
