Im using a mobilestudio pro 13 from Wacom, it is 2560 x 1440 resolution
if i change the compatibility settings it works but the canvas ends up on the far right of the screen and i cant move it.
not sure if you can even tell in the screen cap but its hard to miss when your using the tablet
make sure your display settings are 100%.
Ah ok this works! Is there any way to do this for just the program? Everything else gets smaller too
not that i know of.
i think there will be an update to animate that will handle the issue more like photoshop which seems to deal with this problem more effectively.
There is an update today that fixes the sharpness of the UI in Windows. Go to the CC menu and in the cog select Check for App Updates. If the update isn't already showing for you.
