[CC][JS]URL Grep at the end of story
Jan 31, 2017 Jan 31, 2017
Hi guys,
I have a working grep for finding url in an InDesign document and I'd say it finds everything:
app.findGrepPreferences.findWhat="(http|https|Http|Https|rtsp|Rtsp|ftp|www).+?(?=(\\)|\\.|\\,|\\?|\\!|\"|'|;|\\r)*(\\s))";
the only problem is can't find the ones at the end of the story.
Any thoughts?
-CharlesD
Scripting
1.8K
Advisor , Jan 31, 2017 Jan 31, 2017
(http|https|Http|Https|rtsp|Rtsp|ftp|www).+?(?=(\\)|\\.|\\,|\\?|\\!|\"|'|;|\\r)*($|\\s)) seems to work.
Guide ,
I hope you are using app.changeGrep();   to change.. if not use this to change for entire document
Engaged ,
var myDoc = app.activeDocument;
var Stories = app.activeDocument.stories.everyItem().getElements()
for(i=0; i<Stories.length; i++)
app.findGrepPreferences = app.changeGrepPreferences=null;
app.findGrepPreferences.findWhat= ""; // find code
app.findGrepPreferences.changeTo= "";  // change code
app.changeGrep();
Prabu
Prabu
Design smarter, faster, and bolder with InDesign scripting.
Advisor ,
stab in the dark, as i can't test:
(http|https|Http|Https|rtsp|Rtsp|ftp|www).+?(?=(\\)|\\.|\\,|\\?|\\!|\"|'|;|\\r)*(\\s|\\Z))
@Vamitul
that's exactly how I tried it but '\\z' is a bit of a mystery. Any other options?
Advisor ,
It should be capital - Z (not z)
I tried both, no luck
People's Champ ,
(http|https|Http|Https|rtsp|Rtsp|ftp|www)://([\w_-]+(?:(?:\.[\w_-]+)+))([\w.,@?^=%&:/#-]*[\w@?^=%&/#-])?
Advisor ,
Perfect! I've seen a lot of grep combinations from this forum even from 5 years ago and i always check for new ideas but this one is by far the most reliable. please try it out and let me know its faults so we can improve it for everyone's benefit.
Have you just tried it in a para with 2 www.….com?
Advisor ,
Actually, I think the absolute best one I've found for urls is: Daring Fireball: An Improved Liberal, Accurate Regex Pattern for Matching URLs
(short version:
(?i)\b((?:[a-z][\w-]+:(?:/{1,3}|[a-z0-9%])|www\d{0,3}[.]|[a-z0-9.\-]+[.][a-z]{2,4}/)(?:[^\s()<>]+|\(([^\s()<>]+|(\([^\s()<>]+\)))*\))+(?:\(([^\s()<>]+|(\([^\s()<>]+\)))*\)|[^\s`!()\[\]{};:'".,<>?«»“”‘’]))
I've just copied/pasted it: It doesn't work!
Vamitul​, the one you posted from Daring Fireball failed on this url:
http://uli​.org/wp-content/uploads/ULIDocuments/Norfolk_PanelReport_Fweb.pdf
It only gets up to this:
If you guys have other patterns that you think is perfect please post it here.
It's time to establish the most reliable pattern once and for all. Should we create a new discussion?
Engaged ,
Please try this:
(https?://?|www?)[-./\~\w&]+
Prabu G
Prabu
Thanks for the quick replies. I don't actually use changeGrep because I don't change anything I just have to find those urls and make them as live links. Here are some parts of my code:
    if (myDoc.findGrep().length > 0){
        URLlinker(myDoc.findGrep());
function URLlinker(){
  ... do something with with the found urls
It finds all the urls except the end of the stories.
I also tried using \\s|\\z but it doesn't find anything. So I had to duplicate the function and just replace '\\s' with '\\z' but it gives me some odd results.
Participant ,
Oct 25, 2018 Oct 25, 2018
I tried these both code but not working, can anyone help to find the problem?
app.findGrepPreferences.findWhat="(https?://?|www?)[-./\~\w&]+";
app.changeGrepPreferences.appliedCharacterStyle="Hyperlink"
app.changeGrep();
app.findGrepPreferences.findWhat= "(https?://?|www?)[-./~w&]+"; // find code
app.changeGrep();
Thanks in advance.
by
hasvi
Ok guys I started a new thread:
[CC][JS]Searching for the most reliable URL grep pattern
Please post there your ideas. Thanks!
