I got the trial for After Effects CC today (latest update) and it was working fine, I could import videos or any media and see all the details, the video thumbnail, etc. Whenever I move any video into the timeline however (all of the videos I tested worked completely fine in the Premiere CC Trial (The Premiere Trial had some problems as well)) and it just comes up with the Transform Borders on the Program window and then crashes. I uninstalled and reinstalled the program and it made no different. Please help, thanks.
Hi ACowNamedDave,
Sorry for your issues.
What are your system specs and which OS are you on?
What are the properties of your media files?
Kulpreet Singh
Sorry about the late response, been busy for the past couple days. The computer I'm using is this: Toshiba Satellite L750D-ST4N01 Specs - CNET
With a 2tb HDD and 8GB of DDR3 RAM. I'm using Windows 7 Professional and the properties of the ones I tested were:
1.
Video:
Type: .wmv
Length: 14 min 36 seconds
Frame Width/Height: 1280 X 720
Data Rate: 12000kbps
Total Bitrate: 121228kbps
Frame Rate: 25fps
h.264
Audio:
128kbps
2 Channels
48 kHz sample rate
2.
(This is the original of "1.", I thought it was something wrong with the file so I exported it at a lower resolution in Movie Maker to see if it would fix it, it didn't change anything however)
Video:
Type: .mp4
Frame Width/Height: 1920 X 1080
Data Rate: 14854kbps
Total Bitrate: 14954kbps
Frame Rate: 25fps
h.264
Audio:
99kbps
1 Channel
44 kHz Sample Rate
(I recorded the audio for the video on an external mic since my camera's is not very good at all)
I then also downloaded a video and tried to use it, wouldn't work and tried pictures of different sizes and file types as well, all of which didn't work.
Hi A Cow Named Dave,
Sorry that you had trouble during your trial period. I hope that you figured out your issue with this media. My guess is that this was not standard footage. If you subscribed, let us know if you need further assistance.
Kevin
I hope you just found this stuff out! Here's why:
At one time, Adobe apps had a 30-day tryout period. You had time to get the feel of how they really worked That's ESPECIALLY important with such a quirky, convoluted and complicated pice of software as AE.
Not any more!
The trial period has been reduced to seven days. 168 hours. Just a little over ten-thousand minutes. If you started the tryout a few days ago, good luck finding a solution to your woes AND learning a little about AE.
The clock's ticking. If it runs out, you're hosed.
Hope you solved your issue. If your problem is solved, let us know. If not, please tell us how we can help you further. We just need a little more info from you.
Kevin
