I have been using cs6 2015 ever since it came out and my photos / twitter headers have always been 2mb and under and recently they have jumped to 19mb and up please help ..i turned down the quality and that did nothing stil 19 mb ... idk what to do... this has never happend before ..
Try File >> Export >> Legacy
when over 32 people see your post and wont help you...
Try using File >> Save for Web
You should be able to adjust size/quality and see a preview before saving.
yeah there is no save for web on 2015 ...
It's still there, but now tucked away under the Export heading in the File menu.
Which you can also use. The new Export module ("Export As") is intended to replace Save For Web, which uses outdated code.
Either way, the problem is very likely excessive metadata. There are numerous posts about this. Export/SFW will strip that out.
thats not the thing though this has never happened i can save as a jpeg and get the file size to only be 1mb but some reason now all my saves are 15 + mb
ok that worked but how can i save the file in a custom folder cause atm .... it says can not save here
