Unable to create window
Contributor ,
Jan 17, 2017 Jan 17, 2017
     I have created window for a process and it was working fine.  Recently  getting error in one machine (Mac 10.9.5). I don't know the reason for the error.  Script is not running.  Dialog is not created.  But its working in other machine.
If i click the "OK" button, then i get the below error.
Code:
     var myDlg = new Window('dialog', 'Dialog Title');
     roundTypePanel = myDlg.add('panel', undefined, "Round ");
     roundTypePanel.orientation = 'row';
     var rad1 = roundTypePanel.add('radiobutton', [156,75,325,105], "Round 1");
     var rad2 = roundTypePanel.add('radiobutton', [156,75,325,105], "Round 2");
     rad1.value = true;
     roundType = 1;
     myDlg.show();
Can anyone help me??
- Sudha K
Scripting
621
Engaged ,
Hi Sudha,
Your code is working fine.
     var myOkButton = myDlg.add ("button", undefined, "OK");
     var myCancelButton = myDlg.add ("button", undefined, "Cancel");
     rad1.value ==true;
     roundType = 1;
     myDlg.show();
Prabu G
Prabu
Design smarter, faster, and bolder with InDesign scripting.
People's Champ ,
I confirm it works at my place. Maybe you should trash your preferences.
Contributor ,
Thank you... I will check and let you know...
Why should we remove the preferences?? For me also its working in another system. I don't know the reason for this...
Whats the issue in this??
People's Champ ,
Jan 18, 2017 Jan 18, 2017
Well your code works for most of the users who tried it. You have only one desk where it doesn't and it's on your machine.
So I am guessing maybe something is wrong with your own configuration. So trashing preferences is generally a good way to start indesign from scratch and get back to the standard configuration.
Have a try. At least it will discard this reason. Do you know the first rule in computer support ? …restart to see if problem is gone.
Contributor ,
Jan 26, 2017 Jan 26, 2017
     Sorry for the late reply...
     I cleared the InDesign preference and then run the script, its working.  If I restart the computer after cleared the InDesign preference, its throwing the same error.  I don't know the reason for this issue and how to run the script.
People's Champ ,
Jan 27, 2017 Jan 27, 2017
Don't you have any startup scripts which could corrupt the app ? Worst case scenario a new install from scratch.
Contributor ,
Jan 28, 2017 Jan 28, 2017
Thank you for your reply... I will check and come back...
How to check startup scripts?? Any scripts placed inside the folder "startup scripts"??
People's Champ ,
Jan 30, 2017 Jan 30, 2017
yes that's the idea. Obvioulsy something is messing your app. It could be a startup script or a plugin that once called makes things dirty unless you clean preferences till next call.
Contributor ,
Feb 01, 2017 Feb 01, 2017
There is no scripts inside the "startup scripts" folder.
People's Champ ,
Any third parties plug-in ?
Contributor ,
Any third party plug-in for an InDesign application?
There is no third party plug-in and startup scripts.
People's Champ ,
Feb 02, 2017 Feb 02, 2017
Well, no more hints to give.
Hm. Would shielding the code be of use?
Like using another targetengine—not main—and put it into an anonymous function?
#targetengine sudha
var runThis = function()
    rad1.value = true;
    roundType = 1;
    myDlg.show();
runThis();
FWIW: Sudha's code is running well with my tests on InDesign CC 2017 on Mac OSX 10.10.5.
With or without using a different targetengine:
Uwe
