I've got a script to take a psd file, convert to CMYK, flatten it and save it out with "CMYK_flat.psd" on the end of the new file.
All of that works fine, but I often work on RGB files and sometimes name them with _RGB.psd so I can see everything at a glance.
I need to use expressions somehow to search for the exact phrase of *RGB* anywhere in the name and remove it.
so I dont end up with names like this: myfile_RGB_CMYK.psd
here are the relevant lines of codes that I'm using to get the document name and save it out, if it helps:
var docName = app.activeDocument.name.match(/(.*)(\.[^\.]+)/)[1];
and
var saveFile = File( CurrentPath + "/" + docName + "_CMYK_flat.psd");
I've tried a few things but don't really have a clue how to do this, so any help would be appreciated.
one way with minimal changes in your code could be:
var docName = app.activeDocument.name.match(/(.*)(\.[^\.]+)/)[1].replace(/_RGB/i,"");
Have fun
Have fun
Awesome, this works perfectly.
Thanks pixxxel schubser!
actually, theres something else, how would I go about adding more strings to the argument to be excluded?
not really as crucial but would be good to cover all my bases so I don't get double ups.
for example"_flat" and "_CMYK"..... it would need to be the exact phrases again obviously
just not sure how to add them in there, I tried adding them each in seperate lines but that doesn't work
(I should have known each one would replace the other lol)
I hope I understand you right.
It's possible to adding more strings to the argument to be excluded.
If you have files eg like:
12345_Rgb.tif and
and the result should always be:
12345_CMYK.tif and
you only have to add one mor replace method with the next string.
var docName = app.activeDocument.name.match(/(.*)(\.[^\.]+)/)[1].replace(/_rgb$/i,"").replace(/_flat$/i,"");
This is easy to write, but a little bit cumbersome.
The part in between slashes is a regular expression.
Better is to use the summarizing arguments /_rgb$/ and /_flat$/ in a new Regex --> /_(rgb|flat)$/
Now your new line should look like that
var docName = app.activeDocument.name.match(/(.*)(\.[^\.]+)/)[1].replace(/_(rgb|flat)$/i,"");
Have fun
thanks man, it's really good to have that little bit of explination explaining all this stuff. I tried looking up a page about reg ex but most of it wasn't really relevant and I nearly fell asleep at my keyboard before I found anything useful
this line works for me perfectly:
var docName = app.activeDocument.name.match(/(.*)(\.[^\.]+)/)[1].replace(/_flat/i,"").replace(/_RGB/i,"").replace(/_CMYK/i,"");
And it'll do fine for now, however, I couldn't get this one to work:
var docName = app.activeDocument.name.match(/(.*)(\.[^\.]+)/)[1].replace(/_(rgb|cmyk|flat)$/i,"");
you're right it does look more elegant, would be nice if I could get it to work!
I tested it as many different ways I could think of, it seems to only catch the first one inside the brackets or something like that, in this example it would only replace the (_RGB)
Hmmh?
Your second variant also should work. Can you post the full file names which are not catched with this Regex, please?
I tested it just now with this exact line.
I started with thing_RGB_flat.psd
and it came back with thing_RGB_CMYK_flat.psd
if I give it thing_RGB_CMYK_flat.psd
it comes back with thing_RGB_CMYK_CMYK_flat.psd
So in both examples it seems to have caught the flat but nothing else.....
Hahaha,
I never thought, you want to use all variations in row in one name.
Try this
var docName = app.activeDocument.name.match(/(.*)(\.[^\.]+)/)[1].replace(/(_(rgb|cmyk|flat))+$/i,"");
One note: Regex ist a very wide wide area.
Have fun
thanks man, this line works perfectly.
Really good to see both ways of doing it.....
You're right Regex is pretty huge and confusing....
This suits my purposes well so I'm not even gonna attempt to figure out everything that's going on in there
