I am working on a project similar to Trap Nation, I am using a mix (15:30) of various songs with background equalizer and particular effect from trapcode (red giant) this video is 15:30 long and so far it has taken 4 days to render and STILL isnt done!!!!!
I am using multiframe processing, most of my ram's brain compacity, idk.
I am rendering in h264 1080p60fps
Specs of my PC:
asus 79zk
i5 4690k
16 GB DDR3 RAM
GTX 970
1 TB harddrive
250GB SSD
I don't know what I can do better or what Im doing wrong... PLEASE SEND HELP.
Not sure what you are asking. 15 minutes is an awfully long clip for a compositing program and using audio processing, which is mostly single-threaded and heavy particle effects, that due to linear progression also only run with few threads clearly doesn't help. Conversely, rendering to a clip format, which in itself enforces linear rendering frame by frame will not do anything to improve matters. So as far as all that goes, it's perfectly normal. It's inherent in how AE works and how these effects function. If at all you can pre-render an image sequence and then in a second pass encode the clip, but this will not do magic things, either. It may just allow to actually use multiple cores and render some things out of sequence plus possibly avoid too much disk activity by not producing as many temp and cache files, but overall your computer still has a mouthful to chew on and that simply takes time.
Mylenium
I sent a project to render yesterday that was taking 7 minutes per frame on average. For that kind of project it is the render time is about what I expected. I sent another project to render this morning and it rendered at about 15 frames per minute, also about what I expected. Without seeing your project and knowing all of the details it's hard to say if your render times are excessive. Welcome to AE. In fact welcome to just about any compositing or 3D app. Render times are often very long. It just depends on what you are trying to do.
55,860 frames i believe = 5.5 days
crazy that it would take that long without any form of resolution.
SolidMusic wrote:
crazy that it would take that long...
Like Rick sez -- it all depends on what you're doing.
Hey there SolidMusic,
As the guys said, a 15:30 export with all the effects you mentioned would take a long time to render indeed. Did it end up coming out OK? We'd love to hear back from you and get your observations and to see how you're doing. Do you still need assistance with this. Let us know.
Kevin
