Photoshop converts RGB/CMYK/LAB/Gray images to Multicolor profiles. So far so good. When I save such a converted image e.g. using PSD format, the save window prompts if I want to embed the multicolor ICC into the image. I do this. When I close and re-open this image the embedded multicolor ICC is lost. Why is that? Any idea how to resolve that?
I am sure that the profile is actually being embedded into the image as I've tested it with a very small file (e.g. 10x10 pixels). Saving this file by embedding or not embedding the multicolor ICC profile shows a file size difference of exactly the size of the multicolor ICC profile. Furthermore, other (good) ICC conform applications do recognize the embedded multicolor ICC profile.
Would be great to have this sorted out.
Joe
Hi Joe,
May I know in which format are you saving your image?
Please refer to this article Embedding ICC profiles in image file formats
Sahil
Joe-
If you are saving in .psd format, the profiles you saved your files with should still be there when the file is opened. How are you determining that the profile is lost?
-Tom Attix
Hi, I‘ve noticed that I‘ve never followed up this old topic. My post referred to saving multicolor ICC profiles. No issues with RGB, CMYK or Grayscale profiles when saving and opening them. But using Multicolor ICC conversions, the Multicolor ICC profile is saved (embedded) but not re-loaded from the image in Photoshop.
