1
RGB Color Picker?
Feb 02, 2017 Feb 02, 2017
Is there a way to activate the RGB color picker that was previously in Flash? Similar to the one that's in Photoshop? The current one is just unusable to me.
5.3K
LEGEND , Feb 02, 2017 Feb 02, 2017
To get a color picker similar to the old Flash ones just select the "B:" radio button next to it (the first B, for Brightness, not the second B, for Blue).
what's different about it from previously and ps that's causing a problem for you?
i don't remember it working different previously and the differences i see in ps are less desirable (to me - ie, more color options cmyk etc but no live color selection as you hover).
I tried Clay's suggestion, and it does work, but note that if you are using Photoshop's color picker with it set to H, you would use H in the Animate one to make it match. Same for SB & RGB. There's nothing equivalent to L, a and b.
[Colin Holgate is the op talking about the color panel?]
I think we both took it to mean the color picker. That is, you click on the fill swatch square, then click on the color wheel in the upper right, to see the color picker.
Both the Color Picker and the Color window use nearly identical HSB/RGB widgets, so the answer is the same either way.
[thank you both]
Feb 03, 2017 Feb 03, 2017
That's what i was looking for! Thank you You're a life saver.
Jun 05, 2023 Jun 05, 2023
So simple, and yet mind-blowingly great! Just saved me hours of frustration. Thank you!
Apr 26, 2017 Apr 26, 2017
Genius!  Thanks so much!
