Hi
I use MAC version for lightroom 6.0. (not CC) I thought the latest lightroom version is 6.8. How do I update to 6.8?
My MAC OS is 10.10.5 Yosemite.
You should be able to click Help > Updates inside Lightroom but that's not always reliable.
If it doesn't work, download from the link provided above and double click the downloaded dmg file to install manually.
Thank you very much for providing the link! I'll look for the update! Thank you very much for your help again,
Hello!
I have been in contact with Adobe-support regarding my need to update my Lightroom 6.0 to at least 6.5 and Camera Raw to I think 9.5 (?), and Adobe says that the time-limit for support of this product has ended. I can not import raw-files from my Canon 1Dx MkII after reinstalling Lightroom after a disc-crash!
Can you helt or connect to anyone that can guide me.
I tried the link above but could not find any updates there.
Kind regards
Ulf
hi, can you provide the update again ? i really need lr 6.4 ( or higher ) BIG THANKS
Hi John!
Thank you very much for your help! I tried Help>Updates inside LIghtroom but it didn't show lightroom updates. You're right that it's not always reliable.
I looked the link above and downloaded dmg file. It worked perfectly to update!!! Thank you very much for your help!!
Hi. I have the same issue. I purchased lightroom 6 and I want to update it to 6.8 and tried (help- updates but did not work). I know you said "download it from link above" I can't seem to find the link.? Please assist. Thank you
Click the link posted in this discussion by Just Shoot Me
If you click on the little circle/balloon in the lower right-hand corner of the screen in the link I am providing, you can start a online chat with Adobe. If they will not provide you with a link to Lightroom 6.14 (which was the final update for Lightroom 6) then your other alternative would be to use the free DNG converter to create digital negative copies of your raw files that will open with the version that you have installed now. But give this a try and see if Adobe will help you.
