I have a web app that has a long list of questions, and when answered or not answered, the questions appear on the web app detail page. I would like to know if anyone has a solution for the following:
In a member submitted web app item environment, using the True/False Boolean field type, the customer is given the ability to hide the questions that are not answered, and only show answered ones. I would apply selectors to various elements, and if the field type is check, then it hides those selectors on the detail page.
For example:
1. Question is listed here.
Client answers the question in text field type.
2. Question is listed here.
(No answer)
3. Question is listed here.
[check box] Hide unanswered questions
Select the True/False Boolean field type triggers JS on the detail page to hide all unanswered or targeted selectors and results is such:
I can hide the selector results, but not familiar enough with the True/False Boolean field type.
Thanks in advance!
Teejay
True false field just returns the value "true" or "false".
In liquid you would just run if xxx == true etc and same in javascript.
Not sure what your asking outside of this Teejay, does not seem to be a real question. You can do what your hoping.
Let's see if I can explain the task different (take the boolean out of the equation for now):
In the EDIT mode
We have a web app item field
User enters data
Then has a choice to hide the aforementioned field on the detail page
I was thinking using the yes/no boolean field where the customer checks the box, and when submitted, I can hide what ever I choose to hide on the Detail page.
Does this help?
Can you enlighten me a little on this? Any references?
"In liquid you would just run if xxx == true etc and same in javascript."
I am not sure Teejay, what your after.
First post - Yes
To your second question, I am not sure what your after. IF it is jquery..
{% if SHOWTHISFIELDTARGET == true -%}
THE FIELD INPUT
{% endif -%}
And similar with javascript. This is just basic conditional wrapping.
