problem with graphicLine geometric
Participant ,
Feb 02, 2017 Feb 02, 2017
hi there,
i'm stuck with this problem.. i've created a line on page using JS.
var myLine;
myLine=app.activeDocument.graphicLines.add();
myLine.geometricBounds = ['200mm', '0mm', '200mm','300mm'];
myLine.strokeWeight ="8pt";
when i select the line on page, it gives X: 0mm, Y:198.589mm,  L:300mm
what i don't understand is why Y is not 200mm? How to make it 200mm.
Thank you.
Scripting
592
Guru , Feb 02, 2017 Feb 02, 2017
app.activeDocument.layoutWindows[0].transformReferencePoint =  LEFT_CENTER_ANCHOR;
HTH
Trevor
Guru ,
Can you spot the difference?
Which of the 9 squares is highlighted by you?
Participant ,
the top one..
anyway to use JS to set the default as bottom?
Guide ,
Guru ,
Hi tpk1982
Sorry you are way off, this has nothing to do with math rounding.
There's a setting for which reference point of the control bounds are being used.
I'm trying to remember how to refer to it.
Click the right box in and look at the x value.
Trevor
Guide ,
Feb 03, 2017 Feb 03, 2017
Thanks Trevor, maybe i oversight the requirement
Guru ,
HTH
Trevor
Participant ,
got it.. Thank you Trevor
app.activeDocument.layoutWindows[0].transformReferencePoint =  AnchorPoint.BOTTOM_LEFT_ANCHOR;
Guide ,
use Math.round
