I'm wondering why the High-Quality Print preset for exporting to PDF converts text that is using black ink only, into a four-color (CMYK) process black?
In what scenario would this ever be desired?
Yes Output Preview is the one to inspect, you are right.
Because the original problem keeps digressing into other topics through this post, and having since corrected my problem by using the PDF/X1-a preset solved the issue I'm going to close this question.
Thank you for all your help.
I think you may have Rich Black selected for text, this is not desirable except maybe for registration marks.
Are you making any changes to the [High Quality] preset?
Where are you measuring the PDF values? AcrobatPro's Output Preview? If so what version
Rob, here's a quick rundown of the Export settings, apologies I can't remember them all:
Preset = High-Quality PDF
Output = Convert to Destination (preserve numbers), SWOP v2
Nothing else I believe would affect the shift of all text output as 4-color post export. Someone else mentioned Transparency Blend Space and the document is set to CMYK for that.
I inspected the PDF to verify the 4-color black text (as it was brought up by the printer) in Acrobat CC (latest) using the Ink Manager in the Print Production Tools.
***I have since exported using the PDF/X-1A standard and the issue has disappeared. I wonder if this was the problem?***
The latest is Acrobat DC 2015 Release. The reason I ask is the earlier Acrobat XI could give incorrect output values of DeviceCMYK objects in Output Preview.
You mean Separations in Output Preview? Ink Manager doesn't show output values.
no. like i said, the Ink Manager in the Print Production Tools (see screenshot)
Ink Manager does not give you any output values—it shows expected ink densities which are not separation halftone values.
You have to open Output Preview where the Separations panel gives you the output CMYK values under your cursor for the chosen destination profile (Simulation Profile):
You can also use Preview>Object Inspector to get an object's assigned color profile and native color values.
I can't think of a scenario where you would want your blacks to change upon export to a print PDF. Is your transparency blend space set to CMYK? There are times when you should not use 100% black type; Small black type that is on top of an image or object should be set to overprint, whenever there is a possibility for misregistration. Some rips will automatically make this change as part of the trap settings, even if the file is not set up this way. Large black type set to overprint might show a hard line where it covers the edge of an object, the fix is to set the large black type to not overprint (aka knock out), or change it to a rich or 4C black. I have noticed some designers prefer to set their black type to 90% black, I suppose it's just a design decision, has anybody else ever noticed this? or know what the advantage might be?
The black ink limit (or the maximum percentage of black allowed in the separation) is determined by the CMYK profile used to make the conversion into CMYK. I doubt it's the designer's preference, rather an indicator that the default US Web Coated SWOP profile was used to make the conversion. The SWOP black limit is 90%, but Coated Fogra 27 is 100%, while US Newsprint SNAP is 69%. The limit might vary slightly depending on the conversion intent setting.
I think the theory is limiting black and compensating with CMY will hold more shadow detail in lower end printing conditions.
Thanks rob, that's interesting, but many of the files I receive are packaged InDesign files and occasionally the live black type is set to 90% black in InDesign.
That is an odd choice. Not gray not quite black with the disadvantage of introducing a halftone screen.
There is the notion that grayscale images should have a minimum percentage of 2-4% and a maximum of 90-95% depending on the press capabilities. So maybe your designers have taken that conventional wisdom literally and think it should be applied to type?
The white point minimum is essential otherwise you can get a jarring drop off from 5% to white if the press can't hold a 3% dot, but I've never bought in to limiting black. In the end all it does is further limit the grayscale's already poor dynamic range. I don't think you get the equivalent jump if the press can't hold a 97% dot because the ink density is still changing as the black approaches 100%.
I have a vague recollection about small black type spreading slightly on some press conditions and being slightly less legible than screened black type, which would appear to be solid from a distance. I was hoping for confirmation, or is it just my imagination, or possibly an old printing myth.
The appearance of text would change depending on black ink density, but if I were worried about legibility at small point sizes I would think about the font selection first.
