Indesign is giving me hard times with creating ToC, and I tried a lot of different things - nothing helps. I`m a begginer in Indesign, so I hope I`ll find solution here.
I`ve set ToC for document and it works, I can click any position and it sends me to right page, but I can`t set navigation one ( trhat shows up on left in for ex. Adobe Digital Editions). I`ve tried to set style same as one I used inside document, it only shows one position, and it`s a random one page from middle of book. I tried other settings, adding different style, but as a result I only managed to show up... page numbers in nav. menu ( still can`t figure out how).
When I started to work on the book, I had already saved some new styles and settings, and I worked on them, I wonder if they might be the problem ( this would mean I have to "restyle" whole document but I want to find different solution first)
Thank you!
Is this a Reflowable text ePub or a FXL layout ePub?
Which version of InDesign do you have?
Moving to InDesign EPUB forum
FXL layout
InDeisgn CC 2017
Have a look at these online video tutorials from Lynda.com, you'll find them invaluable (you can get a 10-day free trial):
https://www.lynda.com/InDesign-tutorials/InDesign-CC-2015-EPUB-Fundamentals/374187-2.html
I`ve found out what happened. I had all texts rasterized during export, and I think when Indesign exports files, it first turn it into graphic then tries to "read" those texts.
But thank you for help it lead me to an answer
