I am having trouble when I type in certain areas of the Character and Paragraph windows. For example, if I want to adjust the "space after" and I manually type .125, for example, it will jump to my text in the text window. If I use the arrows to adjust it is not a problem. But sometimes I need more precise numbers and have to type it in. Strange thing is if I use the window in the top toolbar, that works fine. It is the floating window for Character and Paragraph that is causing issues. Can anyone help me fix this issue? Anyone else having this problem? I am on a Mac, using the latest OS. I also regularly update my Adobe Creative Suite apps.
Known bug on Mac.
1. Turn on "Application Frame" under menu "Window".
and / or
2. Navigate to Preferences -> Advanced Type -> Show Adornment on Text Selection/Text Frame for more Type controls >> uncheck these.
Known bug on Mac.
and / or
Thank you for the prompt response! So far, this seems to have done the trick. Thanks!
