Uninstall FxFactory
Feb 03, 2017 Feb 03, 2017
Hello
I have some trouble to remove the plugin FxFactory
I use appcleaner to remove the plugin
but even there is no more file or folder of FxFactory
I still have in effect list FxFactory.
Someone know how to remove permanently ?
4.9K
LEGEND , Feb 03, 2017 Feb 03, 2017
a quick forum search found this: How to delete FXFactory presets form effect panel
also here from the Cow: CreativeCOW
I would also try contacting support here: FxFactory Support
is this a photoshop question?
and what version?
what os?
After effects plugin
Mac os 10.10.5
Adobe Employee ,
Moving this discussion to the After Effects forum.
ok thanks
May 19, 2018 May 19, 2018
iMac (27-inch, Late 2013)
MacOS High Sierra 10.13.4
3.4 GHz Intel Core i5
16 GB 1600 MHz DDR3
NVIDIA GeForce GTX 775M 2048 MB
To uninstall FxFactory Plugins from After Effects/Premiere:
Go To
/User/Library/Application Support/Adobe/Common/Plug-ins/7.0/MediaCore (Trash the FxFactory Folder with all the plugins)
Then Go To
/System HD/Library/Application Support/Adobe/Common/Plug-ins/7.0/MediaCore (Trash FxFactory Components)
After you have done this they will no longer appear in your plugin list.
On a side note instead of completely uninstalling FxFactory this is a great solution in case you want to use these plugins with another NLE. They should allow you to manage which NLE is using which plugins from their App. Just keep in mind when you relaunch FxFactory it will most likely reinstall all the plugins and components to these folders again. Rinse wash repeat.
I hope this helped.
Mar 03, 2021 Mar 03, 2021
Hi guys,
We have implemented individual switches (toggles) in our software to allow you to enable plugins for either/or AE and Premiere Pro. We are almost done testing the new version (FxFactory 7.2.4) so the change should become public soon.
When this version ships, you will find the options under Preferences... → Adobe
In current versions of FxFactory, it is only possible to disable plugins in Premiere Pro, whereas they always load in AE.
For those trying to remove all our software from the system, the best approach is to launch the FxFactory app and use the Uninstall FxFactory... command under the Actions menu.
