I need help with this issue as I cannot not use any filters etc. in Photoshop. I have a new computer windows, download the cc photoshop and cant use. please help
It sounds like some features aren't installed or are corrupted. You may need to re-install Photoshop
When is this message appearing?
Anytime you try to open a "workspace" except "Essentials". Anytime you try to close a file. Anytime you try to use "Select and Mask"
in trying to use a blur gallery tilt-shift
but is happening with all other function in the gallery
shelton fox wrote:
Benjamin Root: It would be more helpful if a person who has nothing to say were to say nothing.
Maybe you should follow your own advice Shelton, besides Benjamin's suggestion is perfectly reasonable and probably would fix the issue-so please refrain from posting just to see your name on screen.
Hi, I have someone getting the exact same error message. It happens when the image is closed down within Photoshop, and also when trying to open the same file when Photoshop is already open.
I am having the same problem. I uninstalled and reinstalled Photoshop. Still have the same problem with anything in the Blur Gallery. If there was a separate download or something, that would be great. I haven't found anything at all about a download or any other fix. Please help.
Reinstalled no help
